  3. Compilation Error for Arduino Pro or Pro Mini
29 Posts 5 Posters 7.6k Views 4 Watching
  • Daniel RuizD
    Daniel RuizD
    Daniel Ruiz
    Good evening,
    Below you will find the details of the error message.
    I think I do not have to integrate the external library correctly.
    My problem occurs just with external libraries.
    cordially,
    Daniel
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Daniel\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Daniel\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Daniel\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10803 -build-path C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631 -warnings=none -build-cache C:\Users\Daniel\AppData\Local\Temp\arduino_cache_357691 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Users\Daniel\Documents\Arduino\sketch_jul30a\sketch_jul30a.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Daniel\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Daniel\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Daniel\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10803 -build-path C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631 -warnings=none -build-cache C:\Users\Daniel\AppData\Local\Temp\arduino_cache_357691 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Users\Daniel\Documents\Arduino\sketch_jul30a\sketch_jul30a.ino
    Using board 'pro' from platform in folder: C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19
    Using core 'arduino' from platform in folder: C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19
    Detecting libraries used...
    "C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\eightanaloginputs" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\sketch\sketch_jul30a.ino.cpp" -o "nul"
    "C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\eightanaloginputs" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI\src" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\sketch\sketch_jul30a.ino.cpp" -o "nul"
    "C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\eightanaloginputs" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\sketch\sketch_jul30a.ino.cpp" -o "nul"
    "C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\eightanaloginputs" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\sketch\sketch_jul30a.ino.cpp" -o "nul"
    "C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10803 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\cores\arduino" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\variants\eightanaloginputs" "-IC:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\sketch\sketch_jul30a.ino.cpp" -o "C:\Users\Daniel\AppData\Local\Temp\arduino_build_524631\preproc\ctags_target_for_gcc_minus_e.cpp"
    In file included from C:\Users\Daniel\Documents\Arduino\sketch_jul30a\sketch_jul30a.ino:37:0:
    C:\Users\Daniel\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:22:21: fatal error: OneWire.h: No such file or directory
    #include <OneWire.h>
    compilation terminated.
    Utilisation de la bibliothèque SPI version 1.0 dans le dossier: C:\Users\Daniel\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.19\libraries\SPI
    Utilisation de la bibliothèque MySensors version 2.0.0 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\MySensors
    Utilisation de la bibliothèque DallasTemperature prise dans le dossier : C:\Users\Daniel\Documents\Arduino\libraries\DallasTemperature (legacy)
    exit status 1
    Erreur de compilation pour la carte Arduino Pro or Pro Mini
    • Daniel RuizD Daniel Ruiz
      Good evening,
      cordially,
      Daniel
      exit status 1
      @Daniel-Ruiz which sketch are you trying to compile?
      • Daniel RuizD
        Daniel RuizD
        Daniel Ruiz
        As I started, I wanted to start simple with two temperature probes.
        Dallas Temperature Sensor
        • B
          B
          Ben Andrewes
          Have you installed the onewire library?
            @Daniel-Ruiz Do you mean this one? https://www.mysensors.org/build/temp#example
            If that's the case you seem to have missed the step mentioned just above the code:
            This example uses a modified version of the external DTH library
            Follow the link to install it and you should be good to go.
            • Daniel RuizD
              Daniel RuizD
              Daniel Ruiz
              Hello and thank you for your help.
              I installed onewire library
              I used the link: http://www.mysensors.org/build/temp#example
              I no longer have the compile error message for the ARDUINO PRO MINI card
              I now have as a message:
              Exit status 1
              'Class DallasTemperature' has no member named 'millisToWaitForConversion'
              I was about to give up, still a little patience
              Good night
              Daniel
              • B
                B
                Ben Andrewes
                Hi Daniel
                See @mfalkvidd 's post above - have you installed the custom DallasTemparature.h library as well? I had the same problem before and the reason was that I hadn't used this library...
                • Daniel RuizD
                  Daniel RuizD
                  Daniel Ruiz
                  Hello everyone,
                  The DALLAS TEMPARATURE .H library is well installed. I still have an error message:
                  rejoe2R 1 Reply Last reply
                    Hello everyone,
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @Daniel-Ruiz
                    You may insert two things to get around this in your sketch:
                    Insert a line
                    int resolution = 12;
                    in the first part of the sketch and
                    conversionTime = 750 / (1 << (12 - resolution));
                    in before() or setup() section.
                    These are the relevant lines that went private for some time in the dallasTemperature-lib.
                    • Daniel RuizD
                      Daniel RuizD
                      Daniel Ruiz
                      Thank you for your help.
                      I do not understand very well with the translation in French. Could you explain to me in more detail or I have to add the two lines.
                      DANIEL
                      rejoe2R dbemowskD 2 Replies Last reply
                        DANIEL
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @Daniel-Ruiz
                        Based on the original sketch:
                        int numSensors=0;
                        bool receivedConfig = false;
                        bool metric = true;
                        MyMessage msg(0,V_TEMP);
                        int resolution = 12;  //<---added
                        void before()
                          sensors.begin();
                          conversionTime = 750 / (1 << (12 - resolution)); //<---added
                          DANIEL
                          dbemowskD
                          dbemowskD
                          @Daniel-Ruiz Can we see your whole sketch?
                          • Daniel RuizD
                            Daniel RuizD
                            Daniel Ruiz
                            [code]
                            • The MySensors Arduino library handles the wireless radio link and protocol
                            • between your home built sensors/actuators and HA controller of choice.
                            • The sensors forms a self healing radio network with optional repeaters. Each
                            • repeater and gateway builds a routing tables in EEPROM which keeps track of the
                            • network topology allowing messages to be routed to nodes.
                            • Created by Henrik Ekblad henrik.ekblad@mysensors.org
                            • Copyright (C) 2013-2015 Sensnology AB
                            • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
                            • Documentation: http://www.mysensors.org
                            • Support Forum: http://forum.mysensors.org
                            • This program is free software; you can redistribute it and/or
                            • modify it under the terms of the GNU General Public License
                            • version 2 as published by the Free Software Foundation.
                            • DESCRIPTION
                            • Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                            • http://www.mysensors.org/build/temp
                            int numSensors=0;
                            bool metric = true;
                            void before()
                            sensors.begin();
                            present(i, S_TEMP);
                            sleep(conversionTime);
                            #if COMPARE_TEMP == 1
                            sleep(SLEEP_TIME);
                            [/code]
                              [code]
                              • DESCRIPTION
                              int numSensors=0;
                              bool metric = true;
                              void before()
                              sensors.begin();
                              present(i, S_TEMP);
                              sleep(SLEEP_TIME);
                              [/code]
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @Daniel-Ruiz OK. Just to be sure:
                              This sketch now is compiling and working as expected?
                              • Daniel RuizD
                                Daniel RuizD
                                Daniel Ruiz
                                C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Daniel\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10802 -build-path C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187 -warnings=none -build-cache C:\Users\Daniel\AppData\Local\Temp\arduino_cache_4544 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino
                                C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Daniel\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10802 -build-path C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187 -warnings=none -build-cache C:\Users\Daniel\AppData\Local\Temp\arduino_cache_4544 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino
                                Using board 'pro' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                                Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
                                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp\DallasTemperature.cpp" -o "nul"
                                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\Documents\Arduino\libraries\OneWire-master\OneWire.cpp" -o "nul"
                                Generating function prototypes...
                                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\preproc\ctags_target_for_gcc_minus_e.cpp"
                                "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\preproc\ctags_target_for_gcc_minus_e.cpp"
                                Compilation du croquis...
                                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp.o"
                                C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino: In function 'void before()':
                                sketch_aug01a:59: error: 'conversionTime' was not declared in this scope
                                C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino: In function 'void loop()':
                                sketch_aug01a:87: error: 'class DallasTemperature' has no member named 'millisToWaitForConversion'
                                Utilisation de la bibliothèque SPI version 1.0 dans le dossier: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                                Utilisation de la bibliothèque MySensors version 2.1.1 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\MySensors
                                Utilisation de la bibliothèque MAX31850_DallasTemp version 1.0.0 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp
                                Utilisation de la bibliothèque OneWire-master version 2.3.3 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\OneWire-master
                                exit status 1
                                  exit status 1
                                  rejoe2R
                                  rejoe2R
                                  rejoe2
                                  wrote on last edited by rejoe2
                                  @Daniel-Ruiz Thx.
                                  You may start the line with
                                  const int conversionTime = 750 / (1 << (12 - resolution));
                                  Sorry for letting that out...
                                  • Daniel RuizD
                                    Daniel RuizD
                                    Daniel Ruiz
                                    @rejoe2 said in Compilation Error for Arduino Pro or Pro Mini:
                                    Sorry to bore you again.
                                    I have to add the two lines as you indicated.
                                    I now have a new errone message.
                                    Daniel
                                      Daniel
                                      rejoe2R
                                      rejoe2R
                                      rejoe2
                                      @Daniel-Ruiz Already noticed that.
                                      Fix above should work (newest version, had first vo check for the correct type of data type).
                                      • Daniel RuizD
                                        Daniel RuizD
                                        Daniel Ruiz
                                        I have just done your last modification I have a new error message0_1501769497783_2017-08-03_16h11_10.png
                                        • rejoe2R
                                          rejoe2R
                                          rejoe2
                                          just comment this line out (start with //int16_t). This calculation is replaced by the one in the before() section.
