  3. Compilation Error for Arduino Pro or Pro Mini
29 Posts 5 Posters 7.6k Views 4 Watching
  • Daniel RuizD
    Daniel RuizD
    Daniel Ruiz
    Hello everyone,
    The DALLAS TEMPARATURE .H library is well installed. I still have an error message:
    rejoe2R 1 Reply Last reply
    • Daniel RuizD Daniel Ruiz
      Hello everyone,
      rejoe2R
      rejoe2R
      rejoe2
      @Daniel-Ruiz
      You may insert two things to get around this in your sketch:
      Insert a line
      int resolution = 12;
      in the first part of the sketch and
      conversionTime = 750 / (1 << (12 - resolution));
      in before() or setup() section.
      These are the relevant lines that went private for some time in the dallasTemperature-lib.
      • Daniel RuizD
        Daniel RuizD
        Daniel Ruiz
        Thank you for your help.
        I do not understand very well with the translation in French. Could you explain to me in more detail or I have to add the two lines.
        DANIEL
        rejoe2R dbemowskD 2 Replies Last reply
          DANIEL
          rejoe2R
          rejoe2R
          rejoe2
          @Daniel-Ruiz
          Based on the original sketch:
          int numSensors=0;
          bool receivedConfig = false;
          bool metric = true;
          MyMessage msg(0,V_TEMP);
          int resolution = 12;  //<---added
          void before()
            sensors.begin();
            conversionTime = 750 / (1 << (12 - resolution)); //<---added
            DANIEL
            dbemowskD
            dbemowskD
            @Daniel-Ruiz Can we see your whole sketch?
            • Daniel RuizD
              Daniel RuizD
              Daniel Ruiz
              [code]
              • The MySensors Arduino library handles the wireless radio link and protocol
              • between your home built sensors/actuators and HA controller of choice.
              • The sensors forms a self healing radio network with optional repeaters. Each
              • repeater and gateway builds a routing tables in EEPROM which keeps track of the
              • network topology allowing messages to be routed to nodes.
              • Created by Henrik Ekblad henrik.ekblad@mysensors.org
              • Copyright (C) 2013-2015 Sensnology AB
              • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
              • Documentation: http://www.mysensors.org
              • Support Forum: http://forum.mysensors.org
              • This program is free software; you can redistribute it and/or
              • modify it under the terms of the GNU General Public License
              • version 2 as published by the Free Software Foundation.
              • DESCRIPTION
              • Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
              • http://www.mysensors.org/build/temp
              #include <OneWire.h>
              int numSensors=0;
              bool metric = true;
              void before()
              sensors.begin();
              present(i, S_TEMP);
              sleep(conversionTime);
              #if COMPARE_TEMP == 1
              sleep(SLEEP_TIME);
              [/code]
                [code]
                • DESCRIPTION
                int numSensors=0;
                bool metric = true;
                void before()
                sensors.begin();
                present(i, S_TEMP);
                sleep(SLEEP_TIME);
                [/code]
                rejoe2R
                rejoe2R
                rejoe2
                @Daniel-Ruiz OK. Just to be sure:
                This sketch now is compiling and working as expected?
                • Daniel RuizD
                  Daniel RuizD
                  Daniel Ruiz
                  C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Daniel\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10802 -build-path C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187 -warnings=none -build-cache C:\Users\Daniel\AppData\Local\Temp\arduino_cache_4544 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino
                  C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Daniel\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10802 -build-path C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187 -warnings=none -build-cache C:\Users\Daniel\AppData\Local\Temp\arduino_cache_4544 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino
                  Using board 'pro' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                  Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                  Detecting libraries used...
                  "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                  "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                  "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                  "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                  "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "nul"
                  "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
                  "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp\DallasTemperature.cpp" -o "nul"
                  "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\Documents\Arduino\libraries\OneWire-master\OneWire.cpp" -o "nul"
                  Generating function prototypes...
                  "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\preproc\ctags_target_for_gcc_minus_e.cpp"
                  "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\preproc\ctags_target_for_gcc_minus_e.cpp"
                  Compilation du croquis...
                  "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Daniel\Documents\Arduino\libraries\MySensors" "-IC:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp" "-IC:\Users\Daniel\Documents\Arduino\libraries\OneWire-master" "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp" -o "C:\Users\Daniel\AppData\Local\Temp\arduino_build_29187\sketch\sketch_aug01a.ino.cpp.o"
                  C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino: In function 'void before()':
                  sketch_aug01a:59: error: 'conversionTime' was not declared in this scope
                  C:\Users\Daniel\Documents\Arduino\sketch_aug01a\sketch_aug01a.ino: In function 'void loop()':
                  sketch_aug01a:87: error: 'class DallasTemperature' has no member named 'millisToWaitForConversion'
                  Utilisation de la bibliothèque SPI version 1.0 dans le dossier: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                  Utilisation de la bibliothèque MySensors version 2.1.1 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\MySensors
                  Utilisation de la bibliothèque MAX31850_DallasTemp version 1.0.0 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\MAX31850_DallasTemp
                  Utilisation de la bibliothèque OneWire-master version 2.3.3 dans le dossier: C:\Users\Daniel\Documents\Arduino\libraries\OneWire-master
                  exit status 1
                    exit status 1
                    rejoe2R
                    rejoe2R
                    rejoe2
                    wrote on last edited by rejoe2
                    @Daniel-Ruiz Thx.
                    You may start the line with
                    const int conversionTime = 750 / (1 << (12 - resolution));
                    Sorry for letting that out...
                    • Daniel RuizD
                      Daniel RuizD
                      Daniel Ruiz
                      @rejoe2 said in Compilation Error for Arduino Pro or Pro Mini:
                      Sorry to bore you again.
                      I have to add the two lines as you indicated.
                      I now have a new errone message.
                      Daniel
                        Daniel
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @Daniel-Ruiz Already noticed that.
                        Fix above should work (newest version, had first vo check for the correct type of data type).
                        • Daniel RuizD
                          Daniel RuizD
                          Daniel Ruiz
                          I have just done your last modification I have a new error message0_1501769497783_2017-08-03_16h11_10.png
                          • rejoe2R
                            rejoe2R
                            rejoe2
                            just comment this line out (start with //int16_t). This calculation is replaced by the one in the before() section.
                            • Daniel RuizD
                              Daniel RuizD
                              Daniel Ruiz
                              I also put // before the line sleep (conversatuionTime);
                              Which gave an error message.
                              And now lr sketch no longer has any error.
                              I thank you for help, and I will try to advance now in the discovery of MY SENSORS.
                              Daniel
                                Daniel
                                rejoe2R
                                rejoe2R
                                rejoe2
                                #24
                                @Daniel-Ruiz
                                Sorry, but to make the picture complete:
                                the sleep() is necessary!
                                Please do as follows:
                                insert
                                const int conversionTime;
                                in the line below int resolution...
                                revert back in before to conversionTime = 750 / (1 << (12 - resolution)); //<---added
                                reactivate the sleep(conversionTime) in loop() (or use wait(conversionTime) instead.
                                • Daniel RuizD
                                  Daniel RuizD
                                  Daniel Ruiz
                                  J'ai modifié comme ci dessous:
                                    rejoe2R
                                    rejoe2R
                                    rejoe2
                                    @Daniel-Ruiz je parle aussi un peu de francais, mais comme ce n'est pas gentile aux autres, je continue en anglais:
                                    This is not a a good idea to "solve" the problem like this.
                                    What is necessary is a global variable. This has to be introduced in the header of the c file (before the before() part). But as in the header no calculation is allowed, we have to do this calculation somwhere else (proposal was in the before() section. It is sufficient, to do this once, but it would also be possible to do that in loop(). If you do not want to calculate at all, you may just delete everything with "conversionTime" and do a sleep() with 750ms like that: sleep(750); this is absolutely necessary to get proper results from the DS18x20!
                                    Further remark: If you want to go further steps with MySensors, you should try to understand the meanings of global variables, data-types, initialisation-functions like before(), presentation() and setup() and the loop().
                                    • Daniel RuizD
                                      Daniel RuizD
                                      Daniel Ruiz
                                      I modified as follows:
                                      There is no more errors
                                      I thought that setting up MYSENSORS was something simple, as indicated in the presentation of the website. I thought the skits were working without changing them. I note that this is not the case, and that it is necessary to have notions of programming.
                                        rejoe2R
                                        rejoe2R
                                        rejoe2
                                        @Daniel-Ruiz According to my experience, it normally is not necessary to change sketches.
                                        Especially not as long as they are "official" MySensors Sketches. But as soon as additional libs are concerned (here: dallasTemperature), the developers may not be able to survey all external changes that may happen. (The conversionTime calculation had been "public" in the past; this had been changed for whatever reason by the dallas-lib-guys). So this sketch originally had worked. It also may have worked, if you installed an older version of the relevant lib (with the lib manager in the IDE).
                                        Nevertheless: You most likely already got a first idea how these things work. Me too, I had to fullfill a fast learning curve... BUT: It is fun!
                                        • Daniel RuizD
                                          Daniel RuizD
                                          Daniel Ruiz
                                          I fully agree with you.
                                          I have already assimilated some notions thanks to your experience. I'm going to hang on and move on. I love learning and discovering new technologies.
                                          I wish you a good evening.
                                          Daniel
