  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
  • d00616D d00616
    @Anticimex At the moment I have other priorities than implementing another security solution or protocol for NRF5. Another protocol can be implemented as a second radio driver including breaking the NRF24 compatibility with larger packet sizes and protocol optimization.
    mtiutiuM
    mtiutiuM
    mtiutiu
    @d00616
    This is a such great addition for this project. For long time I wanted something like this: a RF SOC with pretty good and usable software support and low power also(and a Cortex arch - pff..that's too much :simple_smile: ). I just wanted to congratulate you for your work and bringing this in to MySensors project - it's very neat and useful.
    I tested it and it works just great so far. I would give you 100 likes on openhardware.io if it would be possible :simple_smile: . Thanks once again for your effort.
    d00616D 1 Reply Last reply
    • mtiutiuM mtiutiu
      @d00616
      d00616D
      d00616D
      d00616
      @mtiutiu Thank you very much. I like to read your words. Have fun with this port.
      I have started 2014 to work on Sensors based on the nRF51 chips. At this time the MCU was well documented, but Software was only available under an NDA. Without luck, I tried to build a free Arduino version based on RFduino. There are problems with my linker scripts.
      My next attempt was to use RIOT OS as the base for my Sensor project. Later I have found the great MySensors project. I have started to extend the RIOT Arduino layer to let MySensors running. On my research, I found the Arduino port of Sandeep Mistry (thank you!), so it was easier for me add the missing functionality to MySensors and arduino-nrf5 instead to RIOT OS. From this point, I required eight months to a functional MySensors port.
      • ileneken3I
        ileneken3I
        ileneken3
        Congratulations on winning the contest. That convinces me to give it a try.
        Even though this has been available for months, I'm not seeing much discussion on:
        • Improvements on range.
        • The best module to purchase for the simplest nodes - like temperature.
        • Battery performance.
        Anyone have feedback on those yet?
        Thanks ahead of time
          #22
          @ileneken3
          I'm having some fun with @d00616 work :) And it's working fine so far (thx again).
          I have not tested battery performance for the moment.. NRF52 is capable of very low power but i think the low power is not enabled yet in the porting, it's explained in the project prez if i remember
          Regarding range, sure NRF52 is an improved chip compared to NRF24 for instance, but the most important part is the antenna. That's the case for all mcu though. Take a long range capable mcu and a bad antenna choice, or a bad antenna design (bad gnd plane, bad clearance for antenna etc) and you'll never get the long range (example: miniaturized chip antenna, or some pcb antennas too).
          For the simplest devices to buy, no idea as i'm making custom boards.
          • ileneken3I ileneken3
            d00616D
            d00616D
            d00616
            @ileneken3 Thank you.
            Like @scalz has written, the range depending mostly on the antenna. With the same antenna the nRF52 series are more efficient.
            If you need a simple module to start with, a RedBear BLE Nano 2 or Nano is a good module. It's a small module with integrated voltage regulator and 2.54mm pins. This module is available in the second generation with compatible pin layout.
            If you need an cheap module, there are some starting at 3-6€ with an nRF51. I don't know how long these modules are sold. If possible, use nRF52 based modules. The nRF52 is faster (https://github.com/mysensors/MySensors/pull/845), more flexible and less current consuming then nRF51. The interrupt vector of the nRF52 can be moved into RAM. This reduces the interrupt latency and allows to implement OTA updates in an simple way.
            Most peripherals (e.g. expect ADC) can be assigned to any IO pin. So you can change the role in arduinos board definition.
            You can find detailed information about the current consumption in the datasheets. The MySensors sleep function consumes 3µA until you want to wait for an Interrupt (1mA). To fix this cores/nRF5/WInterrupts.c needs an partitial rewrite. I have no time at the moment to fix this issue. The discussion about how to fix is sleeping: https://github.com/sandeepmistry/arduino-nRF5/issues/153
            Another point to save some energy is to manage the DCDC converter (not available on all boards) in the radio or sleep code. -> https://devzone.nordicsemi.com/question/685/ldo-vs-dcdc-nrf51822/
            More energy savings, requires breaking the compatibility to NRF24 radios and implementing an additional communication protocol. This allows to implement battery powered nodes which can receive packages.
            When issue 153 is fixed, I think the nRF5 platform is a good choice to start new developments of sensors without the CPU and memory limitations of ATMEGA or maybe in the future the limitations of NRF24 radio. When its not fixed this is a good platform for main powered components and sensors which are only waking up by time.
            • scalzS scalz
              @ileneken3
              d00616D
              d00616D
              d00616
              wrote on last edited by d00616
              #24
              @scalz said in 💬 MySensors NRF5 Platform:
              Low power in implemented at the MySensors side. There is an issue at the Arduino side -> 💬 MySensors NRF5 Platform
              Edit: The radio is saving power in some states. There is a little room for improvments like fast rampup for nRF52. With an NRF24 incompatible protocol there is room for improvements.
              • d00616D d00616
                d00616D
                d00616D
                d00616
                @d00616 I found the current issue is a problem only with older nRF51 hardware. I can't measure the current on with newer nRF51 or nRF52 chips. But a fix is documented in http://infocenter.nordicsemi.com/pdf/nRF51822-pan_v3.0.pdf (s. PAN #39)
                  #26
                  @d00616 thx for the info :+1:
                  I'll try to measure power consumption asap
                    #27
                    FWIW, you may want to delete this passage in your overview, as it's not really accurate:
                    Don't buy an nRF5 development kit to program other nRF5 modules. The programmer is hard wired to the nRF5 chip on most DK boards.
                    In fact, Nordic has this video that I just now came across on how to do it:
                    https://www.youtube.com/watch?v=n6sNDnRA6BY
                    IMHO, I think the DK is a good way for noobs to get started, because the setup is well supported for the onboard nRF52 and "just works." The fact that it can later be used to program external nRF5 devices is a nice (and very poorly advertised) bonus. The DK has a real Segger J-Link on the DK board.
                    That being said, the DK is not the cheapest option, so noobs may need to weigh "easy" vs "cheap" in their purchase decision.
                    rmtuckerR 1 Reply Last reply
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      I am having problems compiling the Mockmysensors example on the waveshare board.
                      If you comment out all sensors and uncomment
                      #define ID_S_MULTIMETER 28
                      I get the following error:
                      exit status 1
                      call of overloaded 'set(int&)' is ambiguous
                      • rmtuckerR rmtucker
                        exit status 1
                        @rmtucker said in 💬 MySensors NRF5 Platform:
                        exit status 1
                        Did you remember to do this?
                        //#define MY_RADIO_NRF24
                        #define MY_RADIO_NRF5_ESB
                          exit status 1
                          rmtuckerR
                          rmtuckerR
                          rmtucker
                          Yes did that.
                          Strange though if you run the sketch with just the first 2 sensors uncommented it compiles fine.
                          It must me something to do with multimeter?
                            #31
                            At least on my system, if I don't uncomment anything (other than the passage I just indicated), it at least compiles. Haven't actually tried to see if it works yet....
                              Well, I just tried what you queried about, and it compiles fine on my system:
                              * MockMySensors
                              //#define MY_RADIO_RFM95
                              #define MY_NODE_ID 254
                              // Wait times
                              #define LONG_WAIT 500
                              #define SHORT_WAIT 50
                              #define SKETCH_VERSION "v0.5"
                              // Define Sensors ids
                              	S_SCENE_CONTROLLER
                              // one at a time.
                              //#define ID_S_TEMP              7
                              //#define ID_S_BARO              9
                              //// Lib 1.5 sensors
                              #define ID_S_SPRINKLER         29
                              // Global Vars
                              bool metric = true;
                              long randNumber;
                              #ifdef ID_S_ARMED
                              bool isArmed;
                              #ifdef ID_S_LIGHT
                              bool isLightOn=0;
                              #ifdef ID_S_DIMMER
                              int dimmerVal=100;
                              #ifdef ID_S_COVER
                              #ifdef ID_S_TEMP
                              #ifdef ID_S_HUM
                              #ifdef ID_S_BARO
                              MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
                              #ifdef ID_S_WIND
                              #ifdef ID_S_RAIN
                              #ifdef ID_S_UV
                              #ifdef ID_S_WEIGHT
                              #ifdef ID_S_POWER
                              #ifdef ID_S_HEATER
                              float heater_setpoint=21.5;
                              //  float heater_temp=23.5;
                              //  bool heater_status=false;
                              #ifdef ID_S_DISTANCE
                              #ifdef ID_S_LIGHT_LEVEL
                              #ifdef ID_S_LOCK
                              bool isLocked = 0;
                              #ifdef ID_S_IR
                              long irVal = 0;
                              #ifdef ID_S_WATER
                              #ifdef ID_S_AIR_QUALITY
                              #ifdef ID_S_DUST
                              #ifdef ID_S_SCENE_CONTROLLER
                              char *scenes[] = {
                              	(char *)"Good Morning",
                              	(char *)"Clean Up!",
                              	(char *)"All Lights Off",
                              	(char *)"Music On/Off"
                              int sceneVal=0;
                              int sceneValPrevious=0;
                              #ifdef ID_S_RGB_LIGHT
                              String rgbState="000000";
                              //RGB light V_RGB, V_WATT
                              #ifdef ID_S_RGBW_LIGHT
                              String rgbwState="00000000";
                              #ifdef ID_S_COLOR_SENSOR
                              //Color sensor	V_RGB
                              #ifdef ID_S_HVAC
                              //Thermostat/HVAC device
                              // NOT IMPLEMENTED YET
                              #ifdef ID_S_MULTIMETER
                              // V_VOLTAGE	38	Voltage level
                              // V_CURRENT	39	Current level
                              #ifdef ID_S_SPRINKLER
                              #ifdef ID_S_WATER_LEAK
                              #ifdef ID_S_SOUND
                              #ifdef ID_S_VIBRATION
                              #ifdef ID_S_MOISTURE
                              #ifdef ID_S_CUSTOM
                              	// Random SEED
                              	randomSeed(analogRead(0));
                              	wait(LONG_WAIT);
                              	Serial.println("GW Started");
                              	Serial.print(SKETCH_NAME);
                              	wait(LONG_WAIT);
                              	Serial.print("Get Config: ");
                              	wait(LONG_WAIT);
                              	// Init Armed
                              #ifdef ID_S_ARMED
                              	isArmed = true;
                              #ifdef ID_S_DOOR
                              	Serial.println("  S_DOOR");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_MOTION
                              	Serial.println("  S_MOTION");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_SMOKE
                              	Serial.println("  S_SMOKE");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_LIGHT
                              	Serial.println("  S_LIGHT");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_DIMMER
                              	Serial.println("  S_DIMMER");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_COVER
                              	Serial.println("  S_COVER");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_TEMP
                              	Serial.println("  S_TEMP");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_HUM
                              	Serial.println("  S_HUM");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_BARO
                              	Serial.println("  S_BARO");
                              	present(ID_S_BARO,S_BARO," Air pressure");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_WIND
                              	Serial.println("  S_WIND");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_RAIN
                              	Serial.println("  S_RAIN");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_UV
                              	Serial.println("  S_UV");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_WEIGHT
                              	Serial.println("  S_WEIGHT");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_POWER
                              	Serial.println("  S_POWER");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_HEATER
                              	Serial.println("  S_HEATER");
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_LOCK
                              	Serial.println("  S_LOCK");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_IR
                              	Serial.println("  S_IR");
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_WATER
                              	Serial.println("  S_WATER");
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_DUST
                              	Serial.println("  S_DUST");
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_HVAC
                              	Serial.println("  HVAC");
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_SOUND
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_CUSTOM
                              	Serial.println("  S_CUSTOM");
                              	wait(SHORT_WAIT);
                              	Serial.println("");
                              	Serial.println("");
                              	Serial.println("");
                              	randNumber=random(0,101);
                              	Serial.println(randNumber);
                              	// Send fake battery level
                              	sendBatteryLevel(randNumber);
                              	wait(LONG_WAIT);
                              	// Request time
                              	requestTime();
                              	wait(LONG_WAIT);
                              	//Read Sensors
                              #ifdef ID_S_DOOR
                              	door();
                              #ifdef ID_S_MOTION
                              	motion();
                              #ifdef ID_S_SMOKE
                              	smoke();
                              #ifdef ID_S_LIGHT
                              	light();
                              #ifdef ID_S_DIMMER
                              	dimmer();
                              #ifdef ID_S_COVER
                              	cover();
                              #ifdef ID_S_TEMP
                              	temp();
                              #ifdef ID_S_HUM
                              	hum();
                              #ifdef ID_S_BARO
                              	baro();
                              #ifdef ID_S_WIND
                              	wind();
                              #ifdef ID_S_RAIN
                              	rain();
                              #ifdef ID_S_UV
                              	uv();
                              #ifdef ID_S_WEIGHT
                              	weight();
                              #ifdef ID_S_POWER
                              	power();
                              #ifdef ID_S_HEATER
                              	heater();
                              	distance();
                              	light_level();
                              #ifdef ID_S_LOCK
                              	lock();
                              #ifdef ID_S_IR
                              	ir();
                              #ifdef ID_S_WATER
                              	water();
                              	air();
                              #ifdef ID_S_DUST
                              	dust();
                              	scene();
                              	rgbLight();
                              	rgbwLight();
                              	color();
                              #ifdef ID_S_HVAC
                              	hvac();
                              	multimeter();
                              #ifdef ID_S_SOUND
                              	moisture();
                              #ifdef ID_S_CUSTOM
                              	custom();
                              	wait(SHORT_WAIT);
                              //void door(){}
                              #ifdef ID_S_DOOR
                              void door()
                              	Serial.print("Door is: " );
                              	if (randNumber <= 50) {
                              		Serial.println("Open");
                              		Serial.println("Closed");
                              #ifdef ID_S_ARMED
                              	Serial.print("System is: " );
                              #ifdef ID_S_MOTION
                              void motion()
                              	Serial.print("Motion is: " );
                              		Serial.println("Active");
                              		send(msg_S_MOTION_T.set(1));
                              		Serial.println("Quiet");
                              		send(msg_S_MOTION_T.set(0));
                              #ifdef ID_S_ARMED
                              #ifdef ID_S_SMOKE
                              void smoke()
                              	Serial.print("Smoke is: " );
                              		send(msg_S_SMOKE_T.set(1));
                              		send(msg_S_SMOKE_T.set(0));
                              #ifdef ID_S_ARMED
                              #ifdef ID_S_LIGHT
                              void light()
                              	Serial.print("Light is: " );
                              #ifdef ID_S_DIMMER
                              void dimmer()
                              	Serial.println(dimmerVal);
                              #ifdef ID_S_COVER
                              void cover()
                              	Serial.print("Cover is : " );
                              	if (coverState == 1) {
                              		Serial.println("Opening");
                              		send(msg_S_COVER_U.set(1));
                              		Serial.println("Closing");
                              		send(msg_S_COVER_D.set(0));
                              		Serial.println("Idle");
                              		send(msg_S_COVER_S.set(-1));
                              #ifdef ID_S_TEMP
                              void temp()
                              #ifdef ID_S_HUM
                              void hum()
                              #ifdef ID_S_BARO
                              void baro()
                              	long pressure = map(randNumber,1,100,870,1086);// hPa?
                              	int forecast = map(randNumber,1,100,0,5);
                              	Serial.print("Atmosferic Pressure is: " );
                              	Serial.println(pressure);
                              	send(msg_S_BARO_P.set(pressure));
                              	Serial.print("Weather forecast: " );
                              	send(msg_S_BARO_F.set(weather[forecast]));
                              #ifdef ID_S_WIND
                              void wind()
                              #ifdef ID_S_RAIN
                              void rain()
                              #ifdef ID_S_UV
                              void uv()
                              #ifdef ID_S_WEIGHT
                              void weight()
                              	Serial.print("Weight is: " );
                              #ifdef ID_S_POWER
                              void power()
                              	Serial.print("Watt is: " );
                              	Serial.print("KWH is: " );
                              #ifdef ID_S_HEATER
                              void heater()
                              	//  String heatState="Off";
                              void distance()
                              void light_level()
                              #ifdef ID_S_LOCK
                              void lock()
                              	Serial.print("Lock is: " );
                              #ifdef ID_S_IR
                              void ir()
                              	Serial.println(irVal);
                              	send(msg_S_IR_S.set(irVal));
                              	send(msg_S_IR_R.set(irVal));
                              #ifdef ID_S_WATER
                              void water()
                              void air()
                              #ifdef ID_S_DUST
                              void dust()
                              void scene()
                              	Serial.print("Scene is: " );
                              		sceneValPrevious=sceneVal;
                              void rgbLight()
                              	Serial.println(rgbState);
                              void rgbwLight()
                              	Serial.println(rgbwState);
                              void color()
                              	String colorState;
                              	Serial.println(colorState);
                              #ifdef ID_S_HVAC
                              void hvac()
                              	Serial.println(hvac_Speed);
                              void multimeter()
                              	Serial.println(impedance);
                              	Serial.println(volt);
                              	Serial.println(amps);
                              #ifdef ID_S_SOUND
                              void moisture()
                              #ifdef ID_S_CUSTOM
                              void custom()
                              	switch (message.type) {
                              #ifdef ID_S_ARMED
                              	case V_ARMED:
                              		isArmed = message.getBool();
                              #ifdef ID_S_DOOR
                              		door();//temp ack for door
                              #ifdef ID_S_MOTION
                              		motion();//temp ack
                              #ifdef ID_S_SMOKE
                              		smoke();//temp ack
                              	case V_STATUS: // V_LIGHT:
                              #ifdef ID_S_LIGHT
                              			light(); // temp ack
                              		//    #ifdef ID_S_HEATER
                              		//    #endif
                              #ifdef ID_S_DIMMER
                              	case V_DIMMER:
                              		dimmerVal= message.getInt();
                              		dimmer();// temp ack
                              #ifdef ID_S_COVER
                              	case V_UP:
                              		coverState=1;
                              		Serial.println("V_UP");
                              		cover(); // temp ack
                              	case V_DOWN:
                              		coverState=-1;
                              		Serial.println("V_DOWN");
                              		cover(); //temp ack
                              	case V_STOP:
                              		coverState=0;
                              		Serial.println("V_STOP");
                              		cover(); //temp ack
                              	case V_HVAC_SETPOINT_HEAT:
                              #ifdef ID_S_HEATER
                              			heater();//temp ack
                              #ifdef ID_S_HVAC
                              			hvac();//temp ack
                              	case V_HVAC_FLOW_STATE:
                              #ifdef ID_S_HEATER
                              			heater();//temp ack
                              #ifdef ID_S_HVAC
                              			hvac();//temp ack
                              #ifdef ID_S_LOCK
                              	case V_LOCK_STATUS:
                              		lock(); //temp ack
                              #ifdef ID_S_IR
                              	case V_IR_SEND:
                              		irVal = message.getLong();
                              		ir(); // temp ack
                              	case V_IR_RECEIVE:
                              		ir(); // temp ack
                              	case V_SCENE_ON:
                              		sceneVal = message.getInt();
                              		Serial.println(" On");
                              		scene();// temp ack
                              	case V_SCENE_OFF:
                              		Serial.println(" Off");
                              		scene();// temp ack
                              	case V_RGB:
                              		rgbState=message.getString();
                              		rgbLight(); // temp ack
                              	case V_RGBW:
                              		rgbwLight();
                              #ifdef ID_S_HVAC
                              	//  hvac_SetPointHeat
                              	//  hvac_SetPointCool
                              	//  hvac_FlowState
                              	//  hvac_FlowMode
                              	//  hvac_Speed
                              	case V_HVAC_SETPOINT_COOL:
                              		hvac();//temp ack
                              	case V_HVAC_FLOW_MODE:
                              		hvac();//temp ack
                              	case V_HVAC_SPEED:
                              		hvac();//temp ack
                              	default:
                              		Serial.println(message.type);
                                * MockMySensors
                                // Wait times
                                	S_SCENE_CONTROLLER
                                // one at a time.
                                // Global Vars
                                bool metric = true;
                                long randNumber;
                                #ifdef ID_S_ARMED
                                bool isArmed;
                                #ifdef ID_S_LIGHT
                                bool isLightOn=0;
                                #ifdef ID_S_DIMMER
                                int dimmerVal=100;
                                #ifdef ID_S_COVER
                                #ifdef ID_S_TEMP
                                #ifdef ID_S_HUM
                                #ifdef ID_S_BARO
                                #ifdef ID_S_WIND
                                #ifdef ID_S_RAIN
                                #ifdef ID_S_UV
                                #ifdef ID_S_WEIGHT
                                #ifdef ID_S_POWER
                                #ifdef ID_S_HEATER
                                #ifdef ID_S_LOCK
                                bool isLocked = 0;
                                #ifdef ID_S_IR
                                long irVal = 0;
                                #ifdef ID_S_WATER
                                #ifdef ID_S_DUST
                                char *scenes[] = {
                                int sceneVal=0;
                                #ifdef ID_S_HVAC
                                #ifdef ID_S_SOUND
                                #ifdef ID_S_CUSTOM
                                	// Random SEED
                                	wait(LONG_WAIT);
                                	wait(LONG_WAIT);
                                	wait(LONG_WAIT);
                                	// Init Armed
                                #ifdef ID_S_ARMED
                                	isArmed = true;
                                #ifdef ID_S_DOOR
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_MOTION
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_SMOKE
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_LIGHT
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_DIMMER
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_COVER
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_TEMP
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_HUM
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_BARO
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_WIND
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_RAIN
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_UV
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_WEIGHT
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_POWER
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_HEATER
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_LOCK
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_IR
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_WATER
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_DUST
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_HVAC
                                	wait(SHORT_WAIT);
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_SOUND
                                	wait(SHORT_WAIT);
                                #ifdef ID_S_CUSTOM
                                	wait(SHORT_WAIT);
                                	Serial.println("");
                                	Serial.println("");
                                	Serial.println("");
                                	wait(LONG_WAIT);
                                	// Request time
                                	requestTime();
                                	wait(LONG_WAIT);
                                	//Read Sensors
                                #ifdef ID_S_DOOR
                                	door();
                                #ifdef ID_S_MOTION
                                	motion();
                                #ifdef ID_S_SMOKE
                                	smoke();
                                #ifdef ID_S_LIGHT
                                	light();
                                #ifdef ID_S_DIMMER
                                	dimmer();
                                #ifdef ID_S_COVER
                                	cover();
                                #ifdef ID_S_TEMP
                                	temp();
                                #ifdef ID_S_HUM
                                	hum();
                                #ifdef ID_S_BARO
                                	baro();
                                #ifdef ID_S_WIND
                                	wind();
                                #ifdef ID_S_RAIN
                                	rain();
                                #ifdef ID_S_UV
                                	uv();
                                #ifdef ID_S_WEIGHT
                                	weight();
                                #ifdef ID_S_POWER
                                	power();
                                #ifdef ID_S_HEATER
                                	heater();
                                	distance();
                                	light_level();
                                #ifdef ID_S_LOCK
                                	lock();
                                #ifdef ID_S_IR
                                	ir();
                                #ifdef ID_S_WATER
                                	water();
                                	air();
                                #ifdef ID_S_DUST
                                	dust();
                                	scene();
                                	rgbLight();
                                	rgbwLight();
                                	color();
                                #ifdef ID_S_HVAC
                                	hvac();
                                	multimeter();
                                #ifdef ID_S_SOUND
                                	moisture();
                                #ifdef ID_S_CUSTOM
                                	custom();
                                	wait(SHORT_WAIT);
                                //void door(){}
                                #ifdef ID_S_DOOR
                                void door()
                                #ifdef ID_S_ARMED
                                #ifdef ID_S_MOTION
                                void motion()
                                #ifdef ID_S_ARMED
                                #ifdef ID_S_SMOKE
                                void smoke()
                                #ifdef ID_S_ARMED
                                #ifdef ID_S_LIGHT
                                void light()
                                #ifdef ID_S_DIMMER
                                void dimmer()
                                #ifdef ID_S_COVER
                                void cover()
                                #ifdef ID_S_TEMP
                                void temp()
                                #ifdef ID_S_HUM
                                void hum()
                                #ifdef ID_S_BARO
                                void baro()
                                #ifdef ID_S_WIND
                                void wind()
                                #ifdef ID_S_RAIN
                                void rain()
                                #ifdef ID_S_UV
                                void uv()
                                #ifdef ID_S_WEIGHT
                                void weight()
                                #ifdef ID_S_POWER
                                void power()
                                #ifdef ID_S_HEATER
                                void heater()
                                void distance()
                                void light_level()
                                #ifdef ID_S_LOCK
                                void lock()
                                #ifdef ID_S_IR
                                void ir()
                                #ifdef ID_S_WATER
                                void water()
                                void air()
                                #ifdef ID_S_DUST
                                void dust()
                                void scene()
                                void rgbLight()
                                void rgbwLight()
                                void color()
                                	String colorState;
                                #ifdef ID_S_HVAC
                                void hvac()
                                void multimeter()
                                #ifdef ID_S_SOUND
                                void moisture()
                                #ifdef ID_S_CUSTOM
                                void custom()
                                #ifdef ID_S_ARMED
                                	case V_ARMED:
                                #ifdef ID_S_DOOR
                                #ifdef ID_S_MOTION
                                		motion();//temp ack
                                #ifdef ID_S_SMOKE
                                		smoke();//temp ack
                                #ifdef ID_S_LIGHT
                                		//    #endif
                                #ifdef ID_S_DIMMER
                                	case V_DIMMER:
                                #ifdef ID_S_COVER
                                	case V_UP:
                                		coverState=1;
                                	case V_DOWN:
                                		coverState=-1;
                                		cover(); //temp ack
                                	case V_STOP:
                                		coverState=0;
                                		cover(); //temp ack
                                #ifdef ID_S_HEATER
                                			heater();//temp ack
                                #ifdef ID_S_HVAC
                                			hvac();//temp ack
                                #ifdef ID_S_HEATER
                                			heater();//temp ack
                                #ifdef ID_S_HVAC
                                			hvac();//temp ack
                                #ifdef ID_S_LOCK
                                	case V_LOCK_STATUS:
                                		lock(); //temp ack
                                #ifdef ID_S_IR
                                	case V_IR_SEND:
                                		ir(); // temp ack
                                	case V_IR_RECEIVE:
                                		ir(); // temp ack
                                	case V_SCENE_ON:
                                		scene();// temp ack
                                	case V_SCENE_OFF:
                                		scene();// temp ack
                                	case V_RGB:
                                	case V_RGBW:
                                		rgbwLight();
                                #ifdef ID_S_HVAC
                                	//  hvac_FlowState
                                	//  hvac_FlowMode
                                	//  hvac_Speed
                                		hvac();//temp ack
                                		hvac();//temp ack
                                	case V_HVAC_SPEED:
                                		hvac();//temp ack
                                	default:
                                Oops. Uncommented the wrong thing. I'll try again.
                                  OK, confirmed. The full error message is:
                                  C:\Users\CoolerMaster\Documents\Arduino\mysensors sketches\mockmysensors\MockMySensors_v002\MockMySensors_v002.ino: In function 'void multimeter()':
                                  MockMySensors_v002:1183: error: call of overloaded 'set(int&)' is ambiguous
                                  In file included from C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/MySensors.h:364:0,
                                                   from C:\Users\CoolerMaster\Documents\Arduino\mysensors sketches\mockmysensors\MockMySensors_v002\MockMySensors_v002.ino:20:
                                  C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:269:12: note: candidate: MyMessage& MyMessage::set(bool)
                                   MyMessage& MyMessage::set(bool value)
                                  C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:277:12: note: candidate: MyMessage& MyMessage::set(uint8_t)
                                   MyMessage& MyMessage::set(uint8_t value)
                                  C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:294:12: note: candidate: MyMessage& MyMessage::set(uint32_t)
                                   MyMessage& MyMessage::set(uint32_t value)
                                  C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:302:12: note: candidate: MyMessage& MyMessage::set(int32_t)
                                   MyMessage& MyMessage::set(int32_t value)
                                  C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:310:12: note: candidate: MyMessage& MyMessage::set(uint16_t)
                                   MyMessage& MyMessage::set(uint16_t value)
                                  C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:318:12: note: candidate: MyMessage& MyMessage::set(int16_t)
                                   MyMessage& MyMessage::set(int16_t value)
                                  MockMySensors_v002:1187: error: call of overloaded 'set(int&)' is ambiguous
                                  MockMySensors_v002:1191: error: call of overloaded 'set(int&)' is ambiguous
                                  exit status 1
                                    rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    Ha Yes Sprinkler works fine.
                                      exit status 1
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      So after running through all the sensors in the mockmysensors sketch there are quite a few that have the same problem.
                                      I have done the same tests on my standard setup ATmega328 and all compile ok.
                                      I also tried some of my own small sketches on both platforms and had problems on the nrf5 platform with the same error.
                                      So is this a mySensors problem or is it something deeper?.
                                      Why should it not work on both as far as the syntax is concerned.
                                      Who if anybody do i report the problem too?
                                      I took the plunge and ordered a jlink/v2 programmer and a waveshare BLE400 motherboard and core module (I know it is nrf51822 but it is a start) but i hope the above problem can be sorted out.
                                        #37
                                        Yes, the ones I noticed that seem to have the problem are: motion, smoke, dimmer, cover, scene controller, and, of course, multimeter. The rest compiled.
                                        I don't know the answers to your other good questions, but AFAIK @d00616 appears to be the point man. Perhaps @d00616 can comment?
                                        Also, if you're not already aware of it, @rmtucker I invite you to join in on the constantly evolving discussion at: https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/498
                                        rmtuckerR 3 Replies Last reply
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          After trawling through posts on the forum the following changes compile ok.
                                          Altered int to uint16_t
                                          void multimeter()
                                          	uint16_t impedance=map(randNumber,1,100,0,15000);
                                          	uint16_t volt=map(randNumber,1,100,0,380);
                                          	uint16_t amps=map(randNumber,1,100,0,16);
                                          #endif```
