  3. ๐Ÿ’ฌ MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
  • ileneken3I ileneken3
    Congratulations on winning the contest. That convinces me to give it a try.
    Even though this has been available for months, I'm not seeing much discussion on:
    • Improvements on range.
    • The best module to purchase for the simplest nodes - like temperature.
    • Battery performance.
    Anyone have feedback on those yet?
    Thanks ahead of time
    d00616D
    d00616D
    d00616
    @ileneken3 Thank you.
    Like @scalz has written, the range depending mostly on the antenna. With the same antenna the nRF52 series are more efficient.
    If you need a simple module to start with, a RedBear BLE Nano 2 or Nano is a good module. It's a small module with integrated voltage regulator and 2.54mm pins. This module is available in the second generation with compatible pin layout.
    If you need an cheap module, there are some starting at 3-6โ‚ฌ with an nRF51. I don't know how long these modules are sold. If possible, use nRF52 based modules. The nRF52 is faster (https://github.com/mysensors/MySensors/pull/845), more flexible and less current consuming then nRF51. The interrupt vector of the nRF52 can be moved into RAM. This reduces the interrupt latency and allows to implement OTA updates in an simple way.
    Most peripherals (e.g. expect ADC) can be assigned to any IO pin. So you can change the role in arduinos board definition.
    You can find detailed information about the current consumption in the datasheets. The MySensors sleep function consumes 3ยตA until you want to wait for an Interrupt (1mA). To fix this cores/nRF5/WInterrupts.c needs an partitial rewrite. I have no time at the moment to fix this issue. The discussion about how to fix is sleeping: https://github.com/sandeepmistry/arduino-nRF5/issues/153
    Another point to save some energy is to manage the DCDC converter (not available on all boards) in the radio or sleep code. -> https://devzone.nordicsemi.com/question/685/ldo-vs-dcdc-nrf51822/
    More energy savings, requires breaking the compatibility to NRF24 radios and implementing an additional communication protocol. This allows to implement battery powered nodes which can receive packages.
    When issue 153 is fixed, I think the nRF5 platform is a good choice to start new developments of sensors without the CPU and memory limitations of ATMEGA or maybe in the future the limitations of NRF24 radio. When its not fixed this is a good platform for main powered components and sensors which are only waking up by time.
    • scalzS scalz
      @ileneken3
      I'm having some fun with @d00616 work :) And it's working fine so far (thx again).
      I have not tested battery performance for the moment.. NRF52 is capable of very low power but i think the low power is not enabled yet in the porting, it's explained in the project prez if i remember
      Regarding range, sure NRF52 is an improved chip compared to NRF24 for instance, but the most important part is the antenna. That's the case for all mcu though. Take a long range capable mcu and a bad antenna choice, or a bad antenna design (bad gnd plane, bad clearance for antenna etc) and you'll never get the long range (example: miniaturized chip antenna, or some pcb antennas too).
      For the simplest devices to buy, no idea as i'm making custom boards.
      d00616D
      d00616D
      d00616
      wrote on last edited by d00616
      #24
      @scalz said in ๐Ÿ’ฌ MySensors NRF5 Platform:
      Low power in implemented at the MySensors side. There is an issue at the Arduino side -> ๐Ÿ’ฌ MySensors NRF5 Platform
      Edit: The radio is saving power in some states. There is a little room for improvments like fast rampup for nRF52. With an NRF24 incompatible protocol there is room for improvements.
      d00616D 1 Reply Last reply
      • d00616D d00616
        d00616D
        d00616D
        d00616
        @d00616 I found the current issue is a problem only with older nRF51 hardware. I can't measure the current on with newer nRF51 or nRF52 chips. But a fix is documented in http://infocenter.nordicsemi.com/pdf/nRF51822-pan_v3.0.pdf (s. PAN #39)
          #26
          @d00616 thx for the info :+1:
          I'll try to measure power consumption asap
            #27
            FWIW, you may want to delete this passage in your overview, as it's not really accurate:
            Don't buy an nRF5 development kit to program other nRF5 modules. The programmer is hard wired to the nRF5 chip on most DK boards.
            In fact, Nordic has this video that I just now came across on how to do it:
            https://www.youtube.com/watch?v=n6sNDnRA6BY
            IMHO, I think the DK is a good way for noobs to get started, because the setup is well supported for the onboard nRF52 and "just works." The fact that it can later be used to program external nRF5 devices is a nice (and very poorly advertised) bonus. The DK has a real Segger J-Link on the DK board.
            That being said, the DK is not the cheapest option, so noobs may need to weigh "easy" vs "cheap" in their purchase decision.
            rmtuckerR 1 Reply Last reply
              rmtuckerR
              rmtuckerR
              rmtucker
              I am having problems compiling the Mockmysensors example on the waveshare board.
              If you comment out all sensors and uncomment
              #define ID_S_MULTIMETER 28
              I get the following error:
              exit status 1
              call of overloaded 'set(int&)' is ambiguous
              • rmtuckerR rmtucker
                exit status 1
                @rmtucker said in ๐Ÿ’ฌ MySensors NRF5 Platform:
                exit status 1
                Did you remember to do this?
                //#define MY_RADIO_NRF24
                #define MY_RADIO_NRF5_ESB
                  exit status 1
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  Yes did that.
                  Strange though if you run the sketch with just the first 2 sensors uncommented it compiles fine.
                  It must me something to do with multimeter?
                    #31
                    At least on my system, if I don't uncomment anything (other than the passage I just indicated), it at least compiles. Haven't actually tried to see if it works yet....
                      Well, I just tried what you queried about, and it compiles fine on my system:
                      * MockMySensors
                      //#define MY_RADIO_RFM95
                      #define MY_NODE_ID 254
                      // Wait times
                      #define LONG_WAIT 500
                      #define SHORT_WAIT 50
                      #define SKETCH_VERSION "v0.5"
                      // Define Sensors ids
                      	S_SCENE_CONTROLLER
                      // one at a time.
                      //#define ID_S_TEMP              7
                      //#define ID_S_BARO              9
                      //// Lib 1.5 sensors
                      #define ID_S_SPRINKLER         29
                      // Global Vars
                      bool metric = true;
                      long randNumber;
                      #ifdef ID_S_ARMED
                      bool isArmed;
                      #ifdef ID_S_LIGHT
                      bool isLightOn=0;
                      #ifdef ID_S_DIMMER
                      int dimmerVal=100;
                      #ifdef ID_S_COVER
                      #ifdef ID_S_TEMP
                      #ifdef ID_S_HUM
                      #ifdef ID_S_BARO
                      MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
                      #ifdef ID_S_WIND
                      #ifdef ID_S_RAIN
                      #ifdef ID_S_UV
                      #ifdef ID_S_WEIGHT
                      #ifdef ID_S_POWER
                      #ifdef ID_S_HEATER
                      float heater_setpoint=21.5;
                      //  float heater_temp=23.5;
                      //  bool heater_status=false;
                      #ifdef ID_S_DISTANCE
                      #ifdef ID_S_LIGHT_LEVEL
                      #ifdef ID_S_LOCK
                      bool isLocked = 0;
                      #ifdef ID_S_IR
                      long irVal = 0;
                      #ifdef ID_S_WATER
                      #ifdef ID_S_AIR_QUALITY
                      #ifdef ID_S_DUST
                      #ifdef ID_S_SCENE_CONTROLLER
                      char *scenes[] = {
                      	(char *)"Good Morning",
                      	(char *)"Clean Up!",
                      	(char *)"All Lights Off",
                      	(char *)"Music On/Off"
                      int sceneVal=0;
                      int sceneValPrevious=0;
                      #ifdef ID_S_RGB_LIGHT
                      String rgbState="000000";
                      //RGB light V_RGB, V_WATT
                      #ifdef ID_S_RGBW_LIGHT
                      String rgbwState="00000000";
                      #ifdef ID_S_COLOR_SENSOR
                      //Color sensor	V_RGB
                      #ifdef ID_S_HVAC
                      //Thermostat/HVAC device
                      // NOT IMPLEMENTED YET
                      #ifdef ID_S_MULTIMETER
                      // V_VOLTAGE	38	Voltage level
                      // V_CURRENT	39	Current level
                      #ifdef ID_S_SPRINKLER
                      #ifdef ID_S_WATER_LEAK
                      #ifdef ID_S_SOUND
                      #ifdef ID_S_VIBRATION
                      #ifdef ID_S_MOISTURE
                      #ifdef ID_S_CUSTOM
                      	// Random SEED
                      	randomSeed(analogRead(0));
                      	wait(LONG_WAIT);
                      	Serial.println("GW Started");
                      	Serial.print(SKETCH_NAME);
                      	wait(LONG_WAIT);
                      	Serial.print("Get Config: ");
                      	wait(LONG_WAIT);
                      	// Init Armed
                      #ifdef ID_S_ARMED
                      	isArmed = true;
                      #ifdef ID_S_DOOR
                      	Serial.println("  S_DOOR");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_MOTION
                      	Serial.println("  S_MOTION");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_SMOKE
                      	Serial.println("  S_SMOKE");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_LIGHT
                      	Serial.println("  S_LIGHT");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_DIMMER
                      	Serial.println("  S_DIMMER");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_COVER
                      	Serial.println("  S_COVER");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_TEMP
                      	Serial.println("  S_TEMP");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_HUM
                      	Serial.println("  S_HUM");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_BARO
                      	Serial.println("  S_BARO");
                      	present(ID_S_BARO,S_BARO," Air pressure");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_WIND
                      	Serial.println("  S_WIND");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_RAIN
                      	Serial.println("  S_RAIN");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_UV
                      	Serial.println("  S_UV");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_WEIGHT
                      	Serial.println("  S_WEIGHT");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_POWER
                      	Serial.println("  S_POWER");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_HEATER
                      	Serial.println("  S_HEATER");
                      	wait(SHORT_WAIT);
                      	wait(SHORT_WAIT);
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_LOCK
                      	Serial.println("  S_LOCK");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_IR
                      	Serial.println("  S_IR");
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_WATER
                      	Serial.println("  S_WATER");
                      	wait(SHORT_WAIT);
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_DUST
                      	Serial.println("  S_DUST");
                      	wait(SHORT_WAIT);
                      	wait(SHORT_WAIT);
                      	wait(SHORT_WAIT);
                      	wait(SHORT_WAIT);
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_HVAC
                      	Serial.println("  HVAC");
                      	wait(SHORT_WAIT);
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_SOUND
                      	wait(SHORT_WAIT);
                      #ifdef ID_S_CUSTOM
                      	Serial.println("  S_CUSTOM");
                      	wait(SHORT_WAIT);
                      	Serial.println("");
                      	Serial.println("");
                      	Serial.println("");
                      	randNumber=random(0,101);
                      	Serial.println(randNumber);
                      	// Send fake battery level
                      	sendBatteryLevel(randNumber);
                      	wait(LONG_WAIT);
                      	// Request time
                      	requestTime();
                      	wait(LONG_WAIT);
                      	//Read Sensors
                      #ifdef ID_S_DOOR
                      	door();
                      #ifdef ID_S_MOTION
                      	motion();
                      #ifdef ID_S_SMOKE
                      	smoke();
                      #ifdef ID_S_LIGHT
                      	light();
                      #ifdef ID_S_DIMMER
                      	dimmer();
                      #ifdef ID_S_COVER
                      	cover();
                      #ifdef ID_S_TEMP
                      	temp();
                      #ifdef ID_S_HUM
                      	hum();
                      #ifdef ID_S_BARO
                      	baro();
                      #ifdef ID_S_WIND
                      	wind();
                      #ifdef ID_S_RAIN
                      	rain();
                      #ifdef ID_S_UV
                      	uv();
                      #ifdef ID_S_WEIGHT
                      	weight();
                      #ifdef ID_S_POWER
                      	power();
                      #ifdef ID_S_HEATER
                      	heater();
                      	distance();
                      	light_level();
                      #ifdef ID_S_LOCK
                      	lock();
                      #ifdef ID_S_IR
                      	ir();
                      #ifdef ID_S_WATER
                      	water();
                      	air();
                      #ifdef ID_S_DUST
                      	dust();
                      	scene();
                      	rgbLight();
                      	rgbwLight();
                      	color();
                      #ifdef ID_S_HVAC
                      	hvac();
                      	multimeter();
                      #ifdef ID_S_SOUND
                      	moisture();
                      #ifdef ID_S_CUSTOM
                      	custom();
                      	wait(SHORT_WAIT);
                      //void door(){}
                      #ifdef ID_S_DOOR
                      void door()
                      	Serial.print("Door is: " );
                      	if (randNumber <= 50) {
                      		Serial.println("Open");
                      		Serial.println("Closed");
                      #ifdef ID_S_ARMED
                      	Serial.print("System is: " );
                      #ifdef ID_S_MOTION
                      void motion()
                      	Serial.print("Motion is: " );
                      		Serial.println("Active");
                      		send(msg_S_MOTION_T.set(1));
                      		Serial.println("Quiet");
                      		send(msg_S_MOTION_T.set(0));
                      #ifdef ID_S_ARMED
                      #ifdef ID_S_SMOKE
                      void smoke()
                      	Serial.print("Smoke is: " );
                      		send(msg_S_SMOKE_T.set(1));
                      		send(msg_S_SMOKE_T.set(0));
                      #ifdef ID_S_ARMED
                      #ifdef ID_S_LIGHT
                      void light()
                      	Serial.print("Light is: " );
                      #ifdef ID_S_DIMMER
                      void dimmer()
                      	Serial.println(dimmerVal);
                      #ifdef ID_S_COVER
                      void cover()
                      	Serial.print("Cover is : " );
                      	if (coverState == 1) {
                      		Serial.println("Opening");
                      		send(msg_S_COVER_U.set(1));
                      		Serial.println("Closing");
                      		send(msg_S_COVER_D.set(0));
                      		Serial.println("Idle");
                      		send(msg_S_COVER_S.set(-1));
                      #ifdef ID_S_TEMP
                      void temp()
                      #ifdef ID_S_HUM
                      void hum()
                      #ifdef ID_S_BARO
                      void baro()
                      	long pressure = map(randNumber,1,100,870,1086);// hPa?
                      	int forecast = map(randNumber,1,100,0,5);
                      	Serial.print("Atmosferic Pressure is: " );
                      	Serial.println(pressure);
                      	send(msg_S_BARO_P.set(pressure));
                      	Serial.print("Weather forecast: " );
                      	send(msg_S_BARO_F.set(weather[forecast]));
                      #ifdef ID_S_WIND
                      void wind()
                      #ifdef ID_S_RAIN
                      void rain()
                      #ifdef ID_S_UV
                      void uv()
                      #ifdef ID_S_WEIGHT
                      void weight()
                      	Serial.print("Weight is: " );
                      #ifdef ID_S_POWER
                      void power()
                      	Serial.print("Watt is: " );
                      	Serial.print("KWH is: " );
                      #ifdef ID_S_HEATER
                      void heater()
                      	//  String heatState="Off";
                      void distance()
                      void light_level()
                      #ifdef ID_S_LOCK
                      void lock()
                      	Serial.print("Lock is: " );
                      #ifdef ID_S_IR
                      void ir()
                      	Serial.println(irVal);
                      	send(msg_S_IR_S.set(irVal));
                      	send(msg_S_IR_R.set(irVal));
                      #ifdef ID_S_WATER
                      void water()
                      void air()
                      #ifdef ID_S_DUST
                      void dust()
                      void scene()
                      	Serial.print("Scene is: " );
                      		sceneValPrevious=sceneVal;
                      void rgbLight()
                      	Serial.println(rgbState);
                      void rgbwLight()
                      	Serial.println(rgbwState);
                      void color()
                      	String colorState;
                      	Serial.println(colorState);
                      #ifdef ID_S_HVAC
                      void hvac()
                      	Serial.println(hvac_Speed);
                      void multimeter()
                      	Serial.println(impedance);
                      	Serial.println(volt);
                      	Serial.println(amps);
                      #ifdef ID_S_SOUND
                      void moisture()
                      #ifdef ID_S_CUSTOM
                      void custom()
                      	switch (message.type) {
                      #ifdef ID_S_ARMED
                      	case V_ARMED:
                      		isArmed = message.getBool();
                      #ifdef ID_S_DOOR
                      		door();//temp ack for door
                      #ifdef ID_S_MOTION
                      		motion();//temp ack
                      #ifdef ID_S_SMOKE
                      		smoke();//temp ack
                      	case V_STATUS: // V_LIGHT:
                      #ifdef ID_S_LIGHT
                      			light(); // temp ack
                      		//    #ifdef ID_S_HEATER
                      		//    #endif
                      #ifdef ID_S_DIMMER
                      	case V_DIMMER:
                      		dimmerVal= message.getInt();
                      		dimmer();// temp ack
                      #ifdef ID_S_COVER
                      	case V_UP:
                      		coverState=1;
                      		Serial.println("V_UP");
                      		cover(); // temp ack
                      	case V_DOWN:
                      		coverState=-1;
                      		Serial.println("V_DOWN");
                      		cover(); //temp ack
                      	case V_STOP:
                      		coverState=0;
                      		Serial.println("V_STOP");
                      		cover(); //temp ack
                      	case V_HVAC_SETPOINT_HEAT:
                      #ifdef ID_S_HEATER
                      			heater();//temp ack
                      #ifdef ID_S_HVAC
                      			hvac();//temp ack
                      	case V_HVAC_FLOW_STATE:
                      #ifdef ID_S_HEATER
                      			heater();//temp ack
                      #ifdef ID_S_HVAC
                      			hvac();//temp ack
                      #ifdef ID_S_LOCK
                      	case V_LOCK_STATUS:
                      		lock(); //temp ack
                      #ifdef ID_S_IR
                      	case V_IR_SEND:
                      		irVal = message.getLong();
                      		ir(); // temp ack
                      	case V_IR_RECEIVE:
                      		ir(); // temp ack
                      	case V_SCENE_ON:
                      		sceneVal = message.getInt();
                      		Serial.println(" On");
                      		scene();// temp ack
                      	case V_SCENE_OFF:
                      		Serial.println(" Off");
                      		scene();// temp ack
                      	case V_RGB:
                      		rgbState=message.getString();
                      		rgbLight(); // temp ack
                      	case V_RGBW:
                      		rgbwLight();
                      #ifdef ID_S_HVAC
                      	//  hvac_SetPointHeat
                      	//  hvac_SetPointCool
                      	//  hvac_FlowState
                      	//  hvac_FlowMode
                      	//  hvac_Speed
                      	case V_HVAC_SETPOINT_COOL:
                      		hvac();//temp ack
                      	case V_HVAC_FLOW_MODE:
                      		hvac();//temp ack
                      	case V_HVAC_SPEED:
                      		hvac();//temp ack
                      	default:
                      		Serial.println(message.type);
                        * MockMySensors
                        // Wait times
                        	S_SCENE_CONTROLLER
                        // one at a time.
                        // Global Vars
                        bool metric = true;
                        long randNumber;
                        #ifdef ID_S_ARMED
                        bool isArmed;
                        #ifdef ID_S_LIGHT
                        bool isLightOn=0;
                        #ifdef ID_S_DIMMER
                        int dimmerVal=100;
                        #ifdef ID_S_COVER
                        #ifdef ID_S_TEMP
                        #ifdef ID_S_HUM
                        #ifdef ID_S_BARO
                        #ifdef ID_S_WIND
                        #ifdef ID_S_RAIN
                        #ifdef ID_S_UV
                        #ifdef ID_S_WEIGHT
                        #ifdef ID_S_POWER
                        #ifdef ID_S_HEATER
                        #ifdef ID_S_LOCK
                        bool isLocked = 0;
                        #ifdef ID_S_IR
                        long irVal = 0;
                        #ifdef ID_S_WATER
                        #ifdef ID_S_DUST
                        char *scenes[] = {
                        int sceneVal=0;
                        #ifdef ID_S_HVAC
                        #ifdef ID_S_SOUND
                        #ifdef ID_S_CUSTOM
                        	// Random SEED
                        	wait(LONG_WAIT);
                        	wait(LONG_WAIT);
                        	wait(LONG_WAIT);
                        	// Init Armed
                        #ifdef ID_S_ARMED
                        	isArmed = true;
                        #ifdef ID_S_DOOR
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_MOTION
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_SMOKE
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_LIGHT
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_DIMMER
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_COVER
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_TEMP
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_HUM
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_BARO
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_WIND
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_RAIN
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_UV
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_WEIGHT
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_POWER
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_HEATER
                        	wait(SHORT_WAIT);
                        	wait(SHORT_WAIT);
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_LOCK
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_IR
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_WATER
                        	wait(SHORT_WAIT);
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_DUST
                        	wait(SHORT_WAIT);
                        	wait(SHORT_WAIT);
                        	wait(SHORT_WAIT);
                        	wait(SHORT_WAIT);
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_HVAC
                        	wait(SHORT_WAIT);
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_SOUND
                        	wait(SHORT_WAIT);
                        #ifdef ID_S_CUSTOM
                        	wait(SHORT_WAIT);
                        	Serial.println("");
                        	Serial.println("");
                        	Serial.println("");
                        	wait(LONG_WAIT);
                        	// Request time
                        	requestTime();
                        	wait(LONG_WAIT);
                        	//Read Sensors
                        #ifdef ID_S_DOOR
                        	door();
                        #ifdef ID_S_MOTION
                        	motion();
                        #ifdef ID_S_SMOKE
                        	smoke();
                        #ifdef ID_S_LIGHT
                        	light();
                        #ifdef ID_S_DIMMER
                        	dimmer();
                        #ifdef ID_S_COVER
                        	cover();
                        #ifdef ID_S_TEMP
                        	temp();
                        #ifdef ID_S_HUM
                        	hum();
                        #ifdef ID_S_BARO
                        	baro();
                        #ifdef ID_S_WIND
                        	wind();
                        #ifdef ID_S_RAIN
                        	rain();
                        #ifdef ID_S_UV
                        	uv();
                        #ifdef ID_S_WEIGHT
                        	weight();
                        #ifdef ID_S_POWER
                        	power();
                        #ifdef ID_S_HEATER
                        	heater();
                        	distance();
                        	light_level();
                        #ifdef ID_S_LOCK
                        	lock();
                        #ifdef ID_S_IR
                        	ir();
                        #ifdef ID_S_WATER
                        	water();
                        	air();
                        #ifdef ID_S_DUST
                        	dust();
                        	scene();
                        	rgbLight();
                        	rgbwLight();
                        	color();
                        #ifdef ID_S_HVAC
                        	hvac();
                        	multimeter();
                        #ifdef ID_S_SOUND
                        	moisture();
                        #ifdef ID_S_CUSTOM
                        	custom();
                        	wait(SHORT_WAIT);
                        //void door(){}
                        #ifdef ID_S_DOOR
                        void door()
                        #ifdef ID_S_ARMED
                        #ifdef ID_S_MOTION
                        void motion()
                        #ifdef ID_S_ARMED
                        #ifdef ID_S_SMOKE
                        void smoke()
                        #ifdef ID_S_ARMED
                        #ifdef ID_S_LIGHT
                        void light()
                        #ifdef ID_S_DIMMER
                        void dimmer()
                        #ifdef ID_S_COVER
                        void cover()
                        #ifdef ID_S_TEMP
                        void temp()
                        #ifdef ID_S_HUM
                        void hum()
                        #ifdef ID_S_BARO
                        void baro()
                        #ifdef ID_S_WIND
                        void wind()
                        #ifdef ID_S_RAIN
                        void rain()
                        #ifdef ID_S_UV
                        void uv()
                        #ifdef ID_S_WEIGHT
                        void weight()
                        #ifdef ID_S_POWER
                        void power()
                        #ifdef ID_S_HEATER
                        void heater()
                        void distance()
                        void light_level()
                        #ifdef ID_S_LOCK
                        void lock()
                        #ifdef ID_S_IR
                        void ir()
                        #ifdef ID_S_WATER
                        void water()
                        void air()
                        #ifdef ID_S_DUST
                        void dust()
                        void scene()
                        void rgbLight()
                        void rgbwLight()
                        void color()
                        	String colorState;
                        #ifdef ID_S_HVAC
                        void hvac()
                        void multimeter()
                        #ifdef ID_S_SOUND
                        void moisture()
                        #ifdef ID_S_CUSTOM
                        void custom()
                        #ifdef ID_S_ARMED
                        	case V_ARMED:
                        #ifdef ID_S_DOOR
                        #ifdef ID_S_MOTION
                        		motion();//temp ack
                        #ifdef ID_S_SMOKE
                        		smoke();//temp ack
                        #ifdef ID_S_LIGHT
                        		//    #endif
                        #ifdef ID_S_DIMMER
                        	case V_DIMMER:
                        #ifdef ID_S_COVER
                        	case V_UP:
                        		coverState=1;
                        	case V_DOWN:
                        		coverState=-1;
                        		cover(); //temp ack
                        	case V_STOP:
                        		coverState=0;
                        		cover(); //temp ack
                        #ifdef ID_S_HEATER
                        			heater();//temp ack
                        #ifdef ID_S_HVAC
                        			hvac();//temp ack
                        #ifdef ID_S_HEATER
                        			heater();//temp ack
                        #ifdef ID_S_HVAC
                        			hvac();//temp ack
                        #ifdef ID_S_LOCK
                        	case V_LOCK_STATUS:
                        		lock(); //temp ack
                        #ifdef ID_S_IR
                        	case V_IR_SEND:
                        		ir(); // temp ack
                        	case V_IR_RECEIVE:
                        		ir(); // temp ack
                        	case V_SCENE_ON:
                        		scene();// temp ack
                        	case V_SCENE_OFF:
                        		scene();// temp ack
                        	case V_RGB:
                        	case V_RGBW:
                        		rgbwLight();
                        #ifdef ID_S_HVAC
                        	//  hvac_FlowState
                        	//  hvac_FlowMode
                        	//  hvac_Speed
                        		hvac();//temp ack
                        		hvac();//temp ack
                        	case V_HVAC_SPEED:
                        		hvac();//temp ack
                        	default:
                        Oops. Uncommented the wrong thing. I'll try again.
                          OK, confirmed. The full error message is:
                          C:\Users\CoolerMaster\Documents\Arduino\mysensors sketches\mockmysensors\MockMySensors_v002\MockMySensors_v002.ino: In function 'void multimeter()':
                          MockMySensors_v002:1183: error: call of overloaded 'set(int&)' is ambiguous
                          In file included from C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/MySensors.h:364:0,
                                           from C:\Users\CoolerMaster\Documents\Arduino\mysensors sketches\mockmysensors\MockMySensors_v002\MockMySensors_v002.ino:20:
                          C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:269:12: note: candidate: MyMessage& MyMessage::set(bool)
                           MyMessage& MyMessage::set(bool value)
                          C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:277:12: note: candidate: MyMessage& MyMessage::set(uint8_t)
                           MyMessage& MyMessage::set(uint8_t value)
                          C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:294:12: note: candidate: MyMessage& MyMessage::set(uint32_t)
                           MyMessage& MyMessage::set(uint32_t value)
                          C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:302:12: note: candidate: MyMessage& MyMessage::set(int32_t)
                           MyMessage& MyMessage::set(int32_t value)
                          C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:310:12: note: candidate: MyMessage& MyMessage::set(uint16_t)
                           MyMessage& MyMessage::set(uint16_t value)
                          C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:318:12: note: candidate: MyMessage& MyMessage::set(int16_t)
                           MyMessage& MyMessage::set(int16_t value)
                          MockMySensors_v002:1187: error: call of overloaded 'set(int&)' is ambiguous
                          MockMySensors_v002:1191: error: call of overloaded 'set(int&)' is ambiguous
                          exit status 1
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            Ha Yes Sprinkler works fine.
                              exit status 1
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              So after running through all the sensors in the mockmysensors sketch there are quite a few that have the same problem.
                              I have done the same tests on my standard setup ATmega328 and all compile ok.
                              I also tried some of my own small sketches on both platforms and had problems on the nrf5 platform with the same error.
                              So is this a mySensors problem or is it something deeper?.
                              Why should it not work on both as far as the syntax is concerned.
                              Who if anybody do i report the problem too?
                              I took the plunge and ordered a jlink/v2 programmer and a waveshare BLE400 motherboard and core module (I know it is nrf51822 but it is a start) but i hope the above problem can be sorted out.
                                #37
                                Yes, the ones I noticed that seem to have the problem are: motion, smoke, dimmer, cover, scene controller, and, of course, multimeter. The rest compiled.
                                I don't know the answers to your other good questions, but AFAIK @d00616 appears to be the point man. Perhaps @d00616 can comment?
                                Also, if you're not already aware of it, @rmtucker I invite you to join in on the constantly evolving discussion at: https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/498
                                rmtuckerR 3 Replies Last reply
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  After trawling through posts on the forum the following changes compile ok.
                                  Altered int to uint16_t
                                  void multimeter()
                                  	uint16_t impedance=map(randNumber,1,100,0,15000);
                                  	uint16_t volt=map(randNumber,1,100,0,380);
                                  	uint16_t amps=map(randNumber,1,100,0,16);
                                  #endif```
                                    rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    After adding a Few uint16_t the whole sketch now compiles with all the sensors turned on and only uses 19% of available memory space :smiley: ,could never have done that on the ATmega platform.
                                    Just wish we could work out why it had to be changed
                                    * MockMySensors
                                    // Wait times
                                    	S_SCENE_CONTROLLER
                                    // one at a time.
                                    #define ID_S_DOOR              1
                                    #define ID_S_TEMP              7
                                    #define ID_S_HUM               8
                                    #define ID_S_UV                12
                                    #define ID_S_IR                19
                                    // Global Vars
                                    bool metric = true;
                                    long randNumber;
                                    #ifdef ID_S_ARMED
                                    bool isArmed;
                                    #ifdef ID_S_LIGHT
                                    bool isLightOn=0;
                                    #ifdef ID_S_DIMMER
                                    uint16_t dimmerVal=100;
                                    #ifdef ID_S_COVER
                                    #ifdef ID_S_TEMP
                                    #ifdef ID_S_HUM
                                    #ifdef ID_S_BARO
                                    #ifdef ID_S_WIND
                                    #ifdef ID_S_RAIN
                                    #ifdef ID_S_UV
                                    #ifdef ID_S_WEIGHT
                                    #ifdef ID_S_POWER
                                    #ifdef ID_S_HEATER
                                    #ifdef ID_S_LOCK
                                    bool isLocked = 0;
                                    #ifdef ID_S_IR
                                    long irVal = 0;
                                    #ifdef ID_S_WATER
                                    #ifdef ID_S_DUST
                                    char *scenes[] = {
                                    int sceneVal=0;
                                    #ifdef ID_S_HVAC
                                    #ifdef ID_S_SOUND
                                    #ifdef ID_S_CUSTOM
                                    	// Random SEED
                                    	wait(LONG_WAIT);
                                    	wait(LONG_WAIT);
                                    	wait(LONG_WAIT);
                                    	// Init Armed
                                    #ifdef ID_S_ARMED
                                    	isArmed = true;
                                    #ifdef ID_S_DOOR
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_MOTION
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_SMOKE
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_LIGHT
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_DIMMER
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_COVER
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_TEMP
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_HUM
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_BARO
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_WIND
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_RAIN
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_UV
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_WEIGHT
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_POWER
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_HEATER
                                    	wait(SHORT_WAIT);
                                    	wait(SHORT_WAIT);
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_LOCK
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_IR
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_WATER
                                    	wait(SHORT_WAIT);
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_DUST
                                    	wait(SHORT_WAIT);
                                    	wait(SHORT_WAIT);
                                    	wait(SHORT_WAIT);
                                    	wait(SHORT_WAIT);
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_HVAC
                                    	wait(SHORT_WAIT);
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_SOUND
                                    	wait(SHORT_WAIT);
                                    #ifdef ID_S_CUSTOM
                                    	wait(SHORT_WAIT);
                                    	Serial.println("");
                                    	Serial.println("");
                                    	Serial.println("");
                                    	wait(LONG_WAIT);
                                    	// Request time
                                    	requestTime();
                                    	wait(LONG_WAIT);
                                    	//Read Sensors
                                    #ifdef ID_S_DOOR
                                    	door();
                                    #ifdef ID_S_MOTION
                                    	motion();
                                    #ifdef ID_S_SMOKE
                                    	smoke();
                                    #ifdef ID_S_LIGHT
                                    	light();
                                    #ifdef ID_S_DIMMER
                                    	dimmer();
                                    #ifdef ID_S_COVER
                                    	cover();
                                    #ifdef ID_S_TEMP
                                    	temp();
                                    #ifdef ID_S_HUM
                                    	hum();
                                    #ifdef ID_S_BARO
                                    	baro();
                                    #ifdef ID_S_WIND
                                    	wind();
                                    #ifdef ID_S_RAIN
                                    	rain();
                                    #ifdef ID_S_UV
                                    	uv();
                                    #ifdef ID_S_WEIGHT
                                    	weight();
                                    #ifdef ID_S_POWER
                                    	power();
                                    #ifdef ID_S_HEATER
                                    	heater();
                                    	distance();
                                    	light_level();
                                    #ifdef ID_S_LOCK
                                    	lock();
                                    #ifdef ID_S_IR
                                    	ir();
                                    #ifdef ID_S_WATER
                                    	water();
                                    	air();
                                    #ifdef ID_S_DUST
                                    	dust();
                                    	scene();
                                    	rgbLight();
                                    	rgbwLight();
                                    	color();
                                    #ifdef ID_S_HVAC
                                    	hvac();
                                    	multimeter();
                                    #ifdef ID_S_SOUND
                                    	moisture();
                                    #ifdef ID_S_CUSTOM
                                    	custom();
                                    	wait(SHORT_WAIT);
                                    //void door(){}
                                    #ifdef ID_S_DOOR
                                    void door()
                                    #ifdef ID_S_ARMED
                                    #ifdef ID_S_MOTION
                                    void motion()
                                    		send(msg_S_MOTION_T.set((uint16_t) 1));
                                    		send(msg_S_MOTION_T.set((uint16_t) 0));
                                    #ifdef ID_S_ARMED
                                    #ifdef ID_S_SMOKE
                                    void smoke()
                                    		send(msg_S_SMOKE_T.set((uint16_t) 1));
                                    		send(msg_S_SMOKE_T.set((uint16_t) 0));
                                    #ifdef ID_S_ARMED
                                    #ifdef ID_S_LIGHT
                                    void light()
                                    #ifdef ID_S_DIMMER
                                    void dimmer()
                                    #ifdef ID_S_COVER
                                    void cover()
                                    		send(msg_S_COVER_U.set((uint16_t) 1));
                                    		send(msg_S_COVER_D.set((uint16_t) 0));
                                    		send(msg_S_COVER_S.set((uint16_t) -1));
                                    	send(msg_S_COVER_V.set((uint16_t) coverState));
                                    #ifdef ID_S_TEMP
                                    void temp()
                                    #ifdef ID_S_HUM
                                    void hum()
                                    #ifdef ID_S_BARO
                                    void baro()
                                    #ifdef ID_S_WIND
                                    void wind()
                                    #ifdef ID_S_RAIN
                                    void rain()
                                    #ifdef ID_S_UV
                                    void uv()
                                    #ifdef ID_S_WEIGHT
                                    void weight()
                                    #ifdef ID_S_POWER
                                    void power()
                                    #ifdef ID_S_HEATER
                                    void heater()
                                    void distance()
                                    void light_level()
                                    #ifdef ID_S_LOCK
                                    void lock()
                                    #ifdef ID_S_IR
                                    void ir()
                                    #ifdef ID_S_WATER
                                    void water()
                                    void air()
                                    #ifdef ID_S_DUST
                                    void dust()
                                    void scene()
                                    		send(msg_S_SCENE_CONTROLLER_OF.set((uint16_t) sceneValPrevious));
                                    		send(msg_S_SCENE_CONTROLLER_ON.set((uint16_t) sceneVal));
                                    void rgbLight()
                                    void rgbwLight()
                                    void color()
                                    	String colorState;
                                    #ifdef ID_S_HVAC
                                    void hvac()
                                    void multimeter()
                                    #ifdef ID_S_SOUND
                                    void moisture()
                                    #ifdef ID_S_CUSTOM
                                    void custom()
                                    #ifdef ID_S_ARMED
                                    	case V_ARMED:
                                    #ifdef ID_S_DOOR
                                    #ifdef ID_S_MOTION
                                    		motion();//temp ack
                                    #ifdef ID_S_SMOKE
                                    		smoke();//temp ack
                                    #ifdef ID_S_LIGHT
                                    		//    #endif
                                    #ifdef ID_S_DIMMER
                                    	case V_DIMMER:
                                    #ifdef ID_S_COVER
                                    	case V_UP:
                                    		coverState=1;
                                    	case V_DOWN:
                                    		coverState=-1;
                                    		cover(); //temp ack
                                    	case V_STOP:
                                    		coverState=0;
                                    		cover(); //temp ack
                                    #ifdef ID_S_HEATER
                                    			heater();//temp ack
                                    #ifdef ID_S_HVAC
                                    			hvac();//temp ack
                                    #ifdef ID_S_HEATER
                                    			heater();//temp ack
                                    #ifdef ID_S_HVAC
                                    			hvac();//temp ack
                                    #ifdef ID_S_LOCK
                                    	case V_LOCK_STATUS:
                                    		lock(); //temp ack
                                    #ifdef ID_S_IR
                                    	case V_IR_SEND:
                                    		ir(); // temp ack
                                    	case V_IR_RECEIVE:
                                    		ir(); // temp ack
                                    	case V_SCENE_ON:
                                    		scene();// temp ack
                                    	case V_SCENE_OFF:
                                    		scene();// temp ack
                                    	case V_RGB:
                                    	case V_RGBW:
                                    		rgbwLight();
                                    #ifdef ID_S_HVAC
                                    	//  hvac_FlowState
                                    	//  hvac_FlowMode
                                    	//  hvac_Speed
                                    		hvac();//temp ack
                                    		hvac();//temp ack
                                    	case V_HVAC_SPEED:
                                    		hvac();//temp ack
                                    	default:
                                      void multimeter()
                                      #endif```
                                      d00616D
                                      d00616D
                                      d00616
                                      This issue seems to be an 32 bit platform issue. With SAMD I see equal error messages. This needs fixing at message level.
                                      • d00616D d00616
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        @d00616
                                        So is this a mysensors issue and will you rase this issue please.
                                          @d00616
                                          d00616D
                                          d00616D
                                          d00616
                                          I have ask the other members of the core team if someone can take a look at this issue. I have time to do this not earlier than Sunday.
                                          With your input, this post could be even better ๐Ÿ’—
