  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
    #26
    @d00616 thx for the info :+1:
    I'll try to measure power consumption asap
      #27
      FWIW, you may want to delete this passage in your overview, as it's not really accurate:
      Don't buy an nRF5 development kit to program other nRF5 modules. The programmer is hard wired to the nRF5 chip on most DK boards.
      In fact, Nordic has this video that I just now came across on how to do it:
      https://www.youtube.com/watch?v=n6sNDnRA6BY
      IMHO, I think the DK is a good way for noobs to get started, because the setup is well supported for the onboard nRF52 and "just works." The fact that it can later be used to program external nRF5 devices is a nice (and very poorly advertised) bonus. The DK has a real Segger J-Link on the DK board.
      That being said, the DK is not the cheapest option, so noobs may need to weigh "easy" vs "cheap" in their purchase decision.
      rmtuckerR 1 Reply Last reply
        rmtuckerR
        rmtuckerR
        rmtucker
        I am having problems compiling the Mockmysensors example on the waveshare board.
        If you comment out all sensors and uncomment
        #define ID_S_MULTIMETER 28
        I get the following error:
        exit status 1
        call of overloaded 'set(int&)' is ambiguous
        • rmtuckerR rmtucker
          exit status 1
          @rmtucker said in 💬 MySensors NRF5 Platform:
          exit status 1
          Did you remember to do this?
          //#define MY_RADIO_NRF24
          #define MY_RADIO_NRF5_ESB
            exit status 1
            rmtuckerR
            rmtuckerR
            rmtucker
            Yes did that.
            Strange though if you run the sketch with just the first 2 sensors uncommented it compiles fine.
            It must me something to do with multimeter?
              #31
              At least on my system, if I don't uncomment anything (other than the passage I just indicated), it at least compiles. Haven't actually tried to see if it works yet....
                Well, I just tried what you queried about, and it compiles fine on my system:
                * MockMySensors
                //#define MY_RADIO_RFM95
                #define MY_NODE_ID 254
                // Wait times
                #define LONG_WAIT 500
                #define SHORT_WAIT 50
                #define SKETCH_VERSION "v0.5"
                // Define Sensors ids
                	S_SCENE_CONTROLLER
                // one at a time.
                //#define ID_S_TEMP              7
                //#define ID_S_BARO              9
                //// Lib 1.5 sensors
                #define ID_S_SPRINKLER         29
                // Global Vars
                bool metric = true;
                long randNumber;
                #ifdef ID_S_ARMED
                bool isArmed;
                #ifdef ID_S_LIGHT
                bool isLightOn=0;
                #ifdef ID_S_DIMMER
                int dimmerVal=100;
                #ifdef ID_S_COVER
                #ifdef ID_S_TEMP
                #ifdef ID_S_HUM
                #ifdef ID_S_BARO
                MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
                #ifdef ID_S_WIND
                #ifdef ID_S_RAIN
                #ifdef ID_S_UV
                #ifdef ID_S_WEIGHT
                #ifdef ID_S_POWER
                #ifdef ID_S_HEATER
                float heater_setpoint=21.5;
                //  float heater_temp=23.5;
                //  bool heater_status=false;
                #ifdef ID_S_DISTANCE
                #ifdef ID_S_LIGHT_LEVEL
                #ifdef ID_S_LOCK
                bool isLocked = 0;
                #ifdef ID_S_IR
                long irVal = 0;
                #ifdef ID_S_WATER
                #ifdef ID_S_AIR_QUALITY
                #ifdef ID_S_DUST
                #ifdef ID_S_SCENE_CONTROLLER
                char *scenes[] = {
                	(char *)"Good Morning",
                	(char *)"Clean Up!",
                	(char *)"All Lights Off",
                	(char *)"Music On/Off"
                int sceneVal=0;
                int sceneValPrevious=0;
                #ifdef ID_S_RGB_LIGHT
                String rgbState="000000";
                //RGB light V_RGB, V_WATT
                #ifdef ID_S_RGBW_LIGHT
                String rgbwState="00000000";
                #ifdef ID_S_COLOR_SENSOR
                //Color sensor	V_RGB
                #ifdef ID_S_HVAC
                //Thermostat/HVAC device
                // NOT IMPLEMENTED YET
                #ifdef ID_S_MULTIMETER
                // V_VOLTAGE	38	Voltage level
                // V_CURRENT	39	Current level
                #ifdef ID_S_SPRINKLER
                #ifdef ID_S_WATER_LEAK
                #ifdef ID_S_SOUND
                #ifdef ID_S_VIBRATION
                #ifdef ID_S_MOISTURE
                #ifdef ID_S_CUSTOM
                	// Random SEED
                	randomSeed(analogRead(0));
                	wait(LONG_WAIT);
                	Serial.println("GW Started");
                	Serial.print(SKETCH_NAME);
                	wait(LONG_WAIT);
                	Serial.print("Get Config: ");
                	wait(LONG_WAIT);
                	// Init Armed
                #ifdef ID_S_ARMED
                	isArmed = true;
                #ifdef ID_S_DOOR
                	Serial.println("  S_DOOR");
                	wait(SHORT_WAIT);
                #ifdef ID_S_MOTION
                	Serial.println("  S_MOTION");
                	wait(SHORT_WAIT);
                #ifdef ID_S_SMOKE
                	Serial.println("  S_SMOKE");
                	wait(SHORT_WAIT);
                #ifdef ID_S_LIGHT
                	Serial.println("  S_LIGHT");
                	wait(SHORT_WAIT);
                #ifdef ID_S_DIMMER
                	Serial.println("  S_DIMMER");
                	wait(SHORT_WAIT);
                #ifdef ID_S_COVER
                	Serial.println("  S_COVER");
                	wait(SHORT_WAIT);
                #ifdef ID_S_TEMP
                	Serial.println("  S_TEMP");
                	wait(SHORT_WAIT);
                #ifdef ID_S_HUM
                	Serial.println("  S_HUM");
                	wait(SHORT_WAIT);
                #ifdef ID_S_BARO
                	Serial.println("  S_BARO");
                	present(ID_S_BARO,S_BARO," Air pressure");
                	wait(SHORT_WAIT);
                #ifdef ID_S_WIND
                	Serial.println("  S_WIND");
                	wait(SHORT_WAIT);
                #ifdef ID_S_RAIN
                	Serial.println("  S_RAIN");
                	wait(SHORT_WAIT);
                #ifdef ID_S_UV
                	Serial.println("  S_UV");
                	wait(SHORT_WAIT);
                #ifdef ID_S_WEIGHT
                	Serial.println("  S_WEIGHT");
                	wait(SHORT_WAIT);
                #ifdef ID_S_POWER
                	Serial.println("  S_POWER");
                	wait(SHORT_WAIT);
                #ifdef ID_S_HEATER
                	Serial.println("  S_HEATER");
                	wait(SHORT_WAIT);
                	wait(SHORT_WAIT);
                	wait(SHORT_WAIT);
                #ifdef ID_S_LOCK
                	Serial.println("  S_LOCK");
                	wait(SHORT_WAIT);
                #ifdef ID_S_IR
                	Serial.println("  S_IR");
                	wait(SHORT_WAIT);
                #ifdef ID_S_WATER
                	Serial.println("  S_WATER");
                	wait(SHORT_WAIT);
                	wait(SHORT_WAIT);
                #ifdef ID_S_DUST
                	Serial.println("  S_DUST");
                	wait(SHORT_WAIT);
                	wait(SHORT_WAIT);
                	wait(SHORT_WAIT);
                	wait(SHORT_WAIT);
                	wait(SHORT_WAIT);
                #ifdef ID_S_HVAC
                	Serial.println("  HVAC");
                	wait(SHORT_WAIT);
                	wait(SHORT_WAIT);
                #ifdef ID_S_SOUND
                	wait(SHORT_WAIT);
                #ifdef ID_S_CUSTOM
                	Serial.println("  S_CUSTOM");
                	wait(SHORT_WAIT);
                	Serial.println("");
                	Serial.println("");
                	Serial.println("");
                	randNumber=random(0,101);
                	Serial.println(randNumber);
                	// Send fake battery level
                	sendBatteryLevel(randNumber);
                	wait(LONG_WAIT);
                	// Request time
                	requestTime();
                	wait(LONG_WAIT);
                	//Read Sensors
                #ifdef ID_S_DOOR
                	door();
                #ifdef ID_S_MOTION
                	motion();
                #ifdef ID_S_SMOKE
                	smoke();
                #ifdef ID_S_LIGHT
                	light();
                #ifdef ID_S_DIMMER
                	dimmer();
                #ifdef ID_S_COVER
                	cover();
                #ifdef ID_S_TEMP
                	temp();
                #ifdef ID_S_HUM
                	hum();
                #ifdef ID_S_BARO
                	baro();
                #ifdef ID_S_WIND
                	wind();
                #ifdef ID_S_RAIN
                	rain();
                #ifdef ID_S_UV
                	uv();
                #ifdef ID_S_WEIGHT
                	weight();
                #ifdef ID_S_POWER
                	power();
                #ifdef ID_S_HEATER
                	heater();
                	distance();
                	light_level();
                #ifdef ID_S_LOCK
                	lock();
                #ifdef ID_S_IR
                	ir();
                #ifdef ID_S_WATER
                	water();
                	air();
                #ifdef ID_S_DUST
                	dust();
                	scene();
                	rgbLight();
                	rgbwLight();
                	color();
                #ifdef ID_S_HVAC
                	hvac();
                	multimeter();
                #ifdef ID_S_SOUND
                	moisture();
                #ifdef ID_S_CUSTOM
                	custom();
                	wait(SHORT_WAIT);
                //void door(){}
                #ifdef ID_S_DOOR
                void door()
                	Serial.print("Door is: " );
                	if (randNumber <= 50) {
                		Serial.println("Open");
                		Serial.println("Closed");
                #ifdef ID_S_ARMED
                	Serial.print("System is: " );
                #ifdef ID_S_MOTION
                void motion()
                	Serial.print("Motion is: " );
                		Serial.println("Active");
                		send(msg_S_MOTION_T.set(1));
                		Serial.println("Quiet");
                		send(msg_S_MOTION_T.set(0));
                #ifdef ID_S_ARMED
                #ifdef ID_S_SMOKE
                void smoke()
                	Serial.print("Smoke is: " );
                		send(msg_S_SMOKE_T.set(1));
                		send(msg_S_SMOKE_T.set(0));
                #ifdef ID_S_ARMED
                #ifdef ID_S_LIGHT
                void light()
                	Serial.print("Light is: " );
                #ifdef ID_S_DIMMER
                void dimmer()
                	Serial.println(dimmerVal);
                #ifdef ID_S_COVER
                void cover()
                	Serial.print("Cover is : " );
                	if (coverState == 1) {
                		Serial.println("Opening");
                		send(msg_S_COVER_U.set(1));
                		Serial.println("Closing");
                		send(msg_S_COVER_D.set(0));
                		Serial.println("Idle");
                		send(msg_S_COVER_S.set(-1));
                #ifdef ID_S_TEMP
                void temp()
                #ifdef ID_S_HUM
                void hum()
                #ifdef ID_S_BARO
                void baro()
                	long pressure = map(randNumber,1,100,870,1086);// hPa?
                	int forecast = map(randNumber,1,100,0,5);
                	Serial.print("Atmosferic Pressure is: " );
                	Serial.println(pressure);
                	send(msg_S_BARO_P.set(pressure));
                	Serial.print("Weather forecast: " );
                	send(msg_S_BARO_F.set(weather[forecast]));
                #ifdef ID_S_WIND
                void wind()
                #ifdef ID_S_RAIN
                void rain()
                #ifdef ID_S_UV
                void uv()
                #ifdef ID_S_WEIGHT
                void weight()
                	Serial.print("Weight is: " );
                #ifdef ID_S_POWER
                void power()
                	Serial.print("Watt is: " );
                	Serial.print("KWH is: " );
                #ifdef ID_S_HEATER
                void heater()
                	//  String heatState="Off";
                void distance()
                void light_level()
                #ifdef ID_S_LOCK
                void lock()
                	Serial.print("Lock is: " );
                #ifdef ID_S_IR
                void ir()
                	Serial.println(irVal);
                	send(msg_S_IR_S.set(irVal));
                	send(msg_S_IR_R.set(irVal));
                #ifdef ID_S_WATER
                void water()
                void air()
                #ifdef ID_S_DUST
                void dust()
                void scene()
                	Serial.print("Scene is: " );
                		sceneValPrevious=sceneVal;
                void rgbLight()
                	Serial.println(rgbState);
                void rgbwLight()
                	Serial.println(rgbwState);
                void color()
                	String colorState;
                	Serial.println(colorState);
                #ifdef ID_S_HVAC
                void hvac()
                	Serial.println(hvac_Speed);
                void multimeter()
                	Serial.println(impedance);
                	Serial.println(volt);
                	Serial.println(amps);
                #ifdef ID_S_SOUND
                void moisture()
                #ifdef ID_S_CUSTOM
                void custom()
                	switch (message.type) {
                #ifdef ID_S_ARMED
                	case V_ARMED:
                		isArmed = message.getBool();
                #ifdef ID_S_DOOR
                		door();//temp ack for door
                #ifdef ID_S_MOTION
                		motion();//temp ack
                #ifdef ID_S_SMOKE
                		smoke();//temp ack
                	case V_STATUS: // V_LIGHT:
                #ifdef ID_S_LIGHT
                			light(); // temp ack
                		//    #ifdef ID_S_HEATER
                		//    #endif
                #ifdef ID_S_DIMMER
                	case V_DIMMER:
                		dimmerVal= message.getInt();
                		dimmer();// temp ack
                #ifdef ID_S_COVER
                	case V_UP:
                		coverState=1;
                		Serial.println("V_UP");
                		cover(); // temp ack
                	case V_DOWN:
                		coverState=-1;
                		Serial.println("V_DOWN");
                		cover(); //temp ack
                	case V_STOP:
                		coverState=0;
                		Serial.println("V_STOP");
                		cover(); //temp ack
                	case V_HVAC_SETPOINT_HEAT:
                #ifdef ID_S_HEATER
                			heater();//temp ack
                #ifdef ID_S_HVAC
                			hvac();//temp ack
                	case V_HVAC_FLOW_STATE:
                #ifdef ID_S_HEATER
                			heater();//temp ack
                #ifdef ID_S_HVAC
                			hvac();//temp ack
                #ifdef ID_S_LOCK
                	case V_LOCK_STATUS:
                		lock(); //temp ack
                #ifdef ID_S_IR
                	case V_IR_SEND:
                		irVal = message.getLong();
                		ir(); // temp ack
                	case V_IR_RECEIVE:
                		ir(); // temp ack
                	case V_SCENE_ON:
                		sceneVal = message.getInt();
                		Serial.println(" On");
                		scene();// temp ack
                	case V_SCENE_OFF:
                		Serial.println(" Off");
                		scene();// temp ack
                	case V_RGB:
                		rgbState=message.getString();
                		rgbLight(); // temp ack
                	case V_RGBW:
                		rgbwLight();
                #ifdef ID_S_HVAC
                	//  hvac_SetPointHeat
                	//  hvac_SetPointCool
                	//  hvac_FlowState
                	//  hvac_FlowMode
                	//  hvac_Speed
                	case V_HVAC_SETPOINT_COOL:
                		hvac();//temp ack
                	case V_HVAC_FLOW_MODE:
                		hvac();//temp ack
                	case V_HVAC_SPEED:
                		hvac();//temp ack
                	default:
                		Serial.println(message.type);
                  * MockMySensors
                  // Wait times
                  	S_SCENE_CONTROLLER
                  // one at a time.
                  // Global Vars
                  bool metric = true;
                  long randNumber;
                  #ifdef ID_S_ARMED
                  bool isArmed;
                  #ifdef ID_S_LIGHT
                  bool isLightOn=0;
                  #ifdef ID_S_DIMMER
                  int dimmerVal=100;
                  #ifdef ID_S_COVER
                  #ifdef ID_S_TEMP
                  #ifdef ID_S_HUM
                  #ifdef ID_S_BARO
                  #ifdef ID_S_WIND
                  #ifdef ID_S_RAIN
                  #ifdef ID_S_UV
                  #ifdef ID_S_WEIGHT
                  #ifdef ID_S_POWER
                  #ifdef ID_S_HEATER
                  #ifdef ID_S_LOCK
                  bool isLocked = 0;
                  #ifdef ID_S_IR
                  long irVal = 0;
                  #ifdef ID_S_WATER
                  #ifdef ID_S_DUST
                  char *scenes[] = {
                  int sceneVal=0;
                  #ifdef ID_S_HVAC
                  #ifdef ID_S_SOUND
                  #ifdef ID_S_CUSTOM
                  	// Random SEED
                  	wait(LONG_WAIT);
                  	wait(LONG_WAIT);
                  	wait(LONG_WAIT);
                  	// Init Armed
                  #ifdef ID_S_ARMED
                  	isArmed = true;
                  #ifdef ID_S_DOOR
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_MOTION
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_SMOKE
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_LIGHT
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_DIMMER
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_COVER
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_TEMP
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_HUM
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_BARO
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_WIND
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_RAIN
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_UV
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_WEIGHT
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_POWER
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_HEATER
                  	wait(SHORT_WAIT);
                  	wait(SHORT_WAIT);
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_LOCK
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_IR
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_WATER
                  	wait(SHORT_WAIT);
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_DUST
                  	wait(SHORT_WAIT);
                  	wait(SHORT_WAIT);
                  	wait(SHORT_WAIT);
                  	wait(SHORT_WAIT);
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_HVAC
                  	wait(SHORT_WAIT);
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_SOUND
                  	wait(SHORT_WAIT);
                  #ifdef ID_S_CUSTOM
                  	wait(SHORT_WAIT);
                  	Serial.println("");
                  	Serial.println("");
                  	Serial.println("");
                  	wait(LONG_WAIT);
                  	// Request time
                  	requestTime();
                  	wait(LONG_WAIT);
                  	//Read Sensors
                  #ifdef ID_S_DOOR
                  	door();
                  #ifdef ID_S_MOTION
                  	motion();
                  #ifdef ID_S_SMOKE
                  	smoke();
                  #ifdef ID_S_LIGHT
                  	light();
                  #ifdef ID_S_DIMMER
                  	dimmer();
                  #ifdef ID_S_COVER
                  	cover();
                  #ifdef ID_S_TEMP
                  	temp();
                  #ifdef ID_S_HUM
                  	hum();
                  #ifdef ID_S_BARO
                  	baro();
                  #ifdef ID_S_WIND
                  	wind();
                  #ifdef ID_S_RAIN
                  	rain();
                  #ifdef ID_S_UV
                  	uv();
                  #ifdef ID_S_WEIGHT
                  	weight();
                  #ifdef ID_S_POWER
                  	power();
                  #ifdef ID_S_HEATER
                  	heater();
                  	distance();
                  	light_level();
                  #ifdef ID_S_LOCK
                  	lock();
                  #ifdef ID_S_IR
                  	ir();
                  #ifdef ID_S_WATER
                  	water();
                  	air();
                  #ifdef ID_S_DUST
                  	dust();
                  	scene();
                  	rgbLight();
                  	rgbwLight();
                  	color();
                  #ifdef ID_S_HVAC
                  	hvac();
                  	multimeter();
                  #ifdef ID_S_SOUND
                  	moisture();
                  #ifdef ID_S_CUSTOM
                  	custom();
                  	wait(SHORT_WAIT);
                  //void door(){}
                  #ifdef ID_S_DOOR
                  void door()
                  #ifdef ID_S_ARMED
                  #ifdef ID_S_MOTION
                  void motion()
                  #ifdef ID_S_ARMED
                  #ifdef ID_S_SMOKE
                  void smoke()
                  #ifdef ID_S_ARMED
                  #ifdef ID_S_LIGHT
                  void light()
                  #ifdef ID_S_DIMMER
                  void dimmer()
                  #ifdef ID_S_COVER
                  void cover()
                  #ifdef ID_S_TEMP
                  void temp()
                  #ifdef ID_S_HUM
                  void hum()
                  #ifdef ID_S_BARO
                  void baro()
                  #ifdef ID_S_WIND
                  void wind()
                  #ifdef ID_S_RAIN
                  void rain()
                  #ifdef ID_S_UV
                  void uv()
                  #ifdef ID_S_WEIGHT
                  void weight()
                  #ifdef ID_S_POWER
                  void power()
                  #ifdef ID_S_HEATER
                  void heater()
                  void distance()
                  void light_level()
                  #ifdef ID_S_LOCK
                  void lock()
                  #ifdef ID_S_IR
                  void ir()
                  #ifdef ID_S_WATER
                  void water()
                  void air()
                  #ifdef ID_S_DUST
                  void dust()
                  void scene()
                  void rgbLight()
                  void rgbwLight()
                  void color()
                  	String colorState;
                  #ifdef ID_S_HVAC
                  void hvac()
                  void multimeter()
                  #ifdef ID_S_SOUND
                  void moisture()
                  #ifdef ID_S_CUSTOM
                  void custom()
                  #ifdef ID_S_ARMED
                  	case V_ARMED:
                  #ifdef ID_S_DOOR
                  #ifdef ID_S_MOTION
                  		motion();//temp ack
                  #ifdef ID_S_SMOKE
                  		smoke();//temp ack
                  #ifdef ID_S_LIGHT
                  		//    #endif
                  #ifdef ID_S_DIMMER
                  	case V_DIMMER:
                  #ifdef ID_S_COVER
                  	case V_UP:
                  		coverState=1;
                  	case V_DOWN:
                  		coverState=-1;
                  		cover(); //temp ack
                  	case V_STOP:
                  		coverState=0;
                  		cover(); //temp ack
                  #ifdef ID_S_HEATER
                  			heater();//temp ack
                  #ifdef ID_S_HVAC
                  			hvac();//temp ack
                  #ifdef ID_S_HEATER
                  			heater();//temp ack
                  #ifdef ID_S_HVAC
                  			hvac();//temp ack
                  #ifdef ID_S_LOCK
                  	case V_LOCK_STATUS:
                  		lock(); //temp ack
                  #ifdef ID_S_IR
                  	case V_IR_SEND:
                  		ir(); // temp ack
                  	case V_IR_RECEIVE:
                  		ir(); // temp ack
                  	case V_SCENE_ON:
                  		scene();// temp ack
                  	case V_SCENE_OFF:
                  		scene();// temp ack
                  	case V_RGB:
                  	case V_RGBW:
                  		rgbwLight();
                  #ifdef ID_S_HVAC
                  	//  hvac_FlowState
                  	//  hvac_FlowMode
                  	//  hvac_Speed
                  		hvac();//temp ack
                  		hvac();//temp ack
                  	case V_HVAC_SPEED:
                  		hvac();//temp ack
                  	default:
                  Oops. Uncommented the wrong thing. I'll try again.
                    OK, confirmed. The full error message is:
                    C:\Users\CoolerMaster\Documents\Arduino\mysensors sketches\mockmysensors\MockMySensors_v002\MockMySensors_v002.ino: In function 'void multimeter()':
                    MockMySensors_v002:1183: error: call of overloaded 'set(int&)' is ambiguous
                    In file included from C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/MySensors.h:364:0,
                                     from C:\Users\CoolerMaster\Documents\Arduino\mysensors sketches\mockmysensors\MockMySensors_v002\MockMySensors_v002.ino:20:
                    C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:269:12: note: candidate: MyMessage& MyMessage::set(bool)
                     MyMessage& MyMessage::set(bool value)
                    C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:277:12: note: candidate: MyMessage& MyMessage::set(uint8_t)
                     MyMessage& MyMessage::set(uint8_t value)
                    C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:294:12: note: candidate: MyMessage& MyMessage::set(uint32_t)
                     MyMessage& MyMessage::set(uint32_t value)
                    C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:302:12: note: candidate: MyMessage& MyMessage::set(int32_t)
                     MyMessage& MyMessage::set(int32_t value)
                    C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:310:12: note: candidate: MyMessage& MyMessage::set(uint16_t)
                     MyMessage& MyMessage::set(uint16_t value)
                    C:\Users\CoolerMaster\Documents\Arduino\libraries\MySensors-development/core/MyMessage.cpp:318:12: note: candidate: MyMessage& MyMessage::set(int16_t)
                     MyMessage& MyMessage::set(int16_t value)
                    MockMySensors_v002:1187: error: call of overloaded 'set(int&)' is ambiguous
                    MockMySensors_v002:1191: error: call of overloaded 'set(int&)' is ambiguous
                    exit status 1
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      Ha Yes Sprinkler works fine.
                        exit status 1
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        So after running through all the sensors in the mockmysensors sketch there are quite a few that have the same problem.
                        I have done the same tests on my standard setup ATmega328 and all compile ok.
                        I also tried some of my own small sketches on both platforms and had problems on the nrf5 platform with the same error.
                        So is this a mySensors problem or is it something deeper?.
                        Why should it not work on both as far as the syntax is concerned.
                        Who if anybody do i report the problem too?
                        I took the plunge and ordered a jlink/v2 programmer and a waveshare BLE400 motherboard and core module (I know it is nrf51822 but it is a start) but i hope the above problem can be sorted out.
                          #37
                          Yes, the ones I noticed that seem to have the problem are: motion, smoke, dimmer, cover, scene controller, and, of course, multimeter. The rest compiled.
                          I don't know the answers to your other good questions, but AFAIK @d00616 appears to be the point man. Perhaps @d00616 can comment?
                          Also, if you're not already aware of it, @rmtucker I invite you to join in on the constantly evolving discussion at: https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/498
                          rmtuckerR 3 Replies Last reply
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            After trawling through posts on the forum the following changes compile ok.
                            Altered int to uint16_t
                            void multimeter()
                            	uint16_t impedance=map(randNumber,1,100,0,15000);
                            	uint16_t volt=map(randNumber,1,100,0,380);
                            	uint16_t amps=map(randNumber,1,100,0,16);
                            #endif```
                            d00616D 1 Reply Last reply
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              After adding a Few uint16_t the whole sketch now compiles with all the sensors turned on and only uses 19% of available memory space :smiley: ,could never have done that on the ATmega platform.
                              Just wish we could work out why it had to be changed
                              * MockMySensors
                              // Wait times
                              	S_SCENE_CONTROLLER
                              // one at a time.
                              #define ID_S_DOOR              1
                              #define ID_S_TEMP              7
                              #define ID_S_HUM               8
                              #define ID_S_UV                12
                              #define ID_S_IR                19
                              // Global Vars
                              bool metric = true;
                              long randNumber;
                              #ifdef ID_S_ARMED
                              bool isArmed;
                              #ifdef ID_S_LIGHT
                              bool isLightOn=0;
                              #ifdef ID_S_DIMMER
                              uint16_t dimmerVal=100;
                              #ifdef ID_S_COVER
                              #ifdef ID_S_TEMP
                              #ifdef ID_S_HUM
                              #ifdef ID_S_BARO
                              #ifdef ID_S_WIND
                              #ifdef ID_S_RAIN
                              #ifdef ID_S_UV
                              #ifdef ID_S_WEIGHT
                              #ifdef ID_S_POWER
                              #ifdef ID_S_HEATER
                              #ifdef ID_S_LOCK
                              bool isLocked = 0;
                              #ifdef ID_S_IR
                              long irVal = 0;
                              #ifdef ID_S_WATER
                              #ifdef ID_S_DUST
                              char *scenes[] = {
                              int sceneVal=0;
                              #ifdef ID_S_HVAC
                              #ifdef ID_S_SOUND
                              #ifdef ID_S_CUSTOM
                              	// Random SEED
                              	wait(LONG_WAIT);
                              	wait(LONG_WAIT);
                              	wait(LONG_WAIT);
                              	// Init Armed
                              #ifdef ID_S_ARMED
                              	isArmed = true;
                              #ifdef ID_S_DOOR
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_MOTION
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_SMOKE
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_LIGHT
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_DIMMER
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_COVER
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_TEMP
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_HUM
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_BARO
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_WIND
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_RAIN
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_UV
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_WEIGHT
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_POWER
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_HEATER
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_LOCK
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_IR
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_WATER
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_DUST
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_HVAC
                              	wait(SHORT_WAIT);
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_SOUND
                              	wait(SHORT_WAIT);
                              #ifdef ID_S_CUSTOM
                              	wait(SHORT_WAIT);
                              	Serial.println("");
                              	Serial.println("");
                              	Serial.println("");
                              	wait(LONG_WAIT);
                              	// Request time
                              	requestTime();
                              	wait(LONG_WAIT);
                              	//Read Sensors
                              #ifdef ID_S_DOOR
                              	door();
                              #ifdef ID_S_MOTION
                              	motion();
                              #ifdef ID_S_SMOKE
                              	smoke();
                              #ifdef ID_S_LIGHT
                              	light();
                              #ifdef ID_S_DIMMER
                              	dimmer();
                              #ifdef ID_S_COVER
                              	cover();
                              #ifdef ID_S_TEMP
                              	temp();
                              #ifdef ID_S_HUM
                              	hum();
                              #ifdef ID_S_BARO
                              	baro();
                              #ifdef ID_S_WIND
                              	wind();
                              #ifdef ID_S_RAIN
                              	rain();
                              #ifdef ID_S_UV
                              	uv();
                              #ifdef ID_S_WEIGHT
                              	weight();
                              #ifdef ID_S_POWER
                              	power();
                              #ifdef ID_S_HEATER
                              	heater();
                              	distance();
                              	light_level();
                              #ifdef ID_S_LOCK
                              	lock();
                              #ifdef ID_S_IR
                              	ir();
                              #ifdef ID_S_WATER
                              	water();
                              	air();
                              #ifdef ID_S_DUST
                              	dust();
                              	scene();
                              	rgbLight();
                              	rgbwLight();
                              	color();
                              #ifdef ID_S_HVAC
                              	hvac();
                              	multimeter();
                              #ifdef ID_S_SOUND
                              	moisture();
                              #ifdef ID_S_CUSTOM
                              	custom();
                              	wait(SHORT_WAIT);
                              //void door(){}
                              #ifdef ID_S_DOOR
                              void door()
                              #ifdef ID_S_ARMED
                              #ifdef ID_S_MOTION
                              void motion()
                              		send(msg_S_MOTION_T.set((uint16_t) 1));
                              		send(msg_S_MOTION_T.set((uint16_t) 0));
                              #ifdef ID_S_ARMED
                              #ifdef ID_S_SMOKE
                              void smoke()
                              		send(msg_S_SMOKE_T.set((uint16_t) 1));
                              		send(msg_S_SMOKE_T.set((uint16_t) 0));
                              #ifdef ID_S_ARMED
                              #ifdef ID_S_LIGHT
                              void light()
                              #ifdef ID_S_DIMMER
                              void dimmer()
                              #ifdef ID_S_COVER
                              void cover()
                              		send(msg_S_COVER_U.set((uint16_t) 1));
                              		send(msg_S_COVER_D.set((uint16_t) 0));
                              		send(msg_S_COVER_S.set((uint16_t) -1));
                              	send(msg_S_COVER_V.set((uint16_t) coverState));
                              #ifdef ID_S_TEMP
                              void temp()
                              #ifdef ID_S_HUM
                              void hum()
                              #ifdef ID_S_BARO
                              void baro()
                              #ifdef ID_S_WIND
                              void wind()
                              #ifdef ID_S_RAIN
                              void rain()
                              #ifdef ID_S_UV
                              void uv()
                              #ifdef ID_S_WEIGHT
                              void weight()
                              #ifdef ID_S_POWER
                              void power()
                              #ifdef ID_S_HEATER
                              void heater()
                              void distance()
                              void light_level()
                              #ifdef ID_S_LOCK
                              void lock()
                              #ifdef ID_S_IR
                              void ir()
                              #ifdef ID_S_WATER
                              void water()
                              void air()
                              #ifdef ID_S_DUST
                              void dust()
                              void scene()
                              		send(msg_S_SCENE_CONTROLLER_OF.set((uint16_t) sceneValPrevious));
                              		send(msg_S_SCENE_CONTROLLER_ON.set((uint16_t) sceneVal));
                              void rgbLight()
                              void rgbwLight()
                              void color()
                              	String colorState;
                              #ifdef ID_S_HVAC
                              void hvac()
                              void multimeter()
                              #ifdef ID_S_SOUND
                              void moisture()
                              #ifdef ID_S_CUSTOM
                              void custom()
                              #ifdef ID_S_ARMED
                              	case V_ARMED:
                              #ifdef ID_S_DOOR
                              #ifdef ID_S_MOTION
                              		motion();//temp ack
                              #ifdef ID_S_SMOKE
                              		smoke();//temp ack
                              #ifdef ID_S_LIGHT
                              		//    #endif
                              #ifdef ID_S_DIMMER
                              	case V_DIMMER:
                              #ifdef ID_S_COVER
                              	case V_UP:
                              		coverState=1;
                              	case V_DOWN:
                              		coverState=-1;
                              		cover(); //temp ack
                              	case V_STOP:
                              		coverState=0;
                              		cover(); //temp ack
                              #ifdef ID_S_HEATER
                              			heater();//temp ack
                              #ifdef ID_S_HVAC
                              			hvac();//temp ack
                              #ifdef ID_S_HEATER
                              			heater();//temp ack
                              #ifdef ID_S_HVAC
                              			hvac();//temp ack
                              #ifdef ID_S_LOCK
                              	case V_LOCK_STATUS:
                              		lock(); //temp ack
                              #ifdef ID_S_IR
                              	case V_IR_SEND:
                              		ir(); // temp ack
                              	case V_IR_RECEIVE:
                              		ir(); // temp ack
                              	case V_SCENE_ON:
                              		scene();// temp ack
                              	case V_SCENE_OFF:
                              		scene();// temp ack
                              	case V_RGB:
                              	case V_RGBW:
                              		rgbwLight();
                              #ifdef ID_S_HVAC
                              	//  hvac_FlowState
                              	//  hvac_FlowMode
                              	//  hvac_Speed
                              		hvac();//temp ack
                              		hvac();//temp ack
                              	case V_HVAC_SPEED:
                              		hvac();//temp ack
                              	default:
                                void multimeter()
                                #endif```
                                d00616D
                                d00616D
                                d00616
                                This issue seems to be an 32 bit platform issue. With SAMD I see equal error messages. This needs fixing at message level.
                                • d00616D d00616
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  @d00616
                                  So is this a mysensors issue and will you rase this issue please.
                                    @d00616
                                    d00616D
                                    d00616D
                                    d00616
                                    I have ask the other members of the core team if someone can take a look at this issue. I have time to do this not earlier than Sunday.
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      Just wondering about mysensors debug.
                                      If you have the jlink plugged in for programming but you also want to see the mysensors debug.
                                      Where is the ftdi adapter plugged in to for tx and rx ?
                                      And also i suspect that the vcc is not connected on the ftdi adapter because the jlink is supplying the board?
                                      Oh so many questions??
                                        #44
                                        That's determined by the "board" that you tell the compiler you are using. For example, on the nRF52 DK, the Rx pin is on P0.06. Presently, for simplicity, when I compile for the Ebyte module, I tell the Arduino IDE that it's an nRF52 DK, so then Rx is also on P0.06 and Tx is on P0.08.
                                        A more advanced way of doing it is to tell the Arduino IDE that the board is a "MyNrf5Board nRF52832", and then you can use d00616's method of pin mapping to make the Rx pin whichever of the mappable pins you want. That's a bit more involved though.
                                        Right. For old fashioned debugging using serial.println(), just Rx and GND is all I use.
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          wrote on last edited by rmtucker
                                          #45
                                          Disappointed so far with the NRF51822.:frowning:
                                          Basically it can not connect to any i2c sensors which mysensors relies on heavily.
                                          So not a lot can be done with it.
                                          It does integrate with mysensors well though,proved that with mockmysensors sketch.
                                          I dare not even try the spi interface.
                                          I would advise not trying this till the i2c problems are sorted out.
                                          At the moment it is running Blinky and thats it.
                                          AnticimexA 1 Reply Last reply
