  3. Compilation Error for Arduino Pro or Pro Mini
29 Posts 5 Posters 7.6k Views 4 Watching
  • Daniel RuizD
    Daniel RuizD
    Daniel Ruiz
    @rejoe2 said in Compilation Error for Arduino Pro or Pro Mini:
    This sketch now is compiling and working as expected?
    Sorry to bore you again.
    I have to add the two lines as you indicated.
    I now have a new errone message.
    Daniel
    rejoe2R 1 Reply Last reply
    • Daniel RuizD Daniel Ruiz
      Daniel
      rejoe2R
      rejoe2R
      rejoe2
      @Daniel-Ruiz Already noticed that.
      Fix above should work (newest version, had first vo check for the correct type of data type).
      • Daniel RuizD
        Daniel RuizD
        Daniel Ruiz
        I have just done your last modification I have a new error message0_1501769497783_2017-08-03_16h11_10.png
        • rejoe2R
          rejoe2R
          rejoe2
          just comment this line out (start with //int16_t). This calculation is replaced by the one in the before() section.
          • Daniel RuizD
            Daniel RuizD
            Daniel Ruiz
            I also put // before the line sleep (conversatuionTime);
            Which gave an error message.
            And now lr sketch no longer has any error.
            I thank you for help, and I will try to advance now in the discovery of MY SENSORS.
            Daniel
              Daniel
              rejoe2R
              rejoe2R
              rejoe2
              wrote on last edited by rejoe2
              #24
              @Daniel-Ruiz
              Sorry, but to make the picture complete:
              the sleep() is necessary!
              Please do as follows:
              insert
              const int conversionTime;
              in the line below int resolution...
              revert back in before to conversionTime = 750 / (1 << (12 - resolution)); //<---added
              reactivate the sleep(conversionTime) in loop() (or use wait(conversionTime) instead.
              • Daniel RuizD
                Daniel RuizD
                Daniel Ruiz
                J'ai modifié comme ci dessous:
                  rejoe2R
                  rejoe2R
                  rejoe2
                  @Daniel-Ruiz je parle aussi un peu de francais, mais comme ce n'est pas gentile aux autres, je continue en anglais:
                  This is not a a good idea to "solve" the problem like this.
                  What is necessary is a global variable. This has to be introduced in the header of the c file (before the before() part). But as in the header no calculation is allowed, we have to do this calculation somwhere else (proposal was in the before() section. It is sufficient, to do this once, but it would also be possible to do that in loop(). If you do not want to calculate at all, you may just delete everything with "conversionTime" and do a sleep() with 750ms like that: sleep(750); this is absolutely necessary to get proper results from the DS18x20!
                  Further remark: If you want to go further steps with MySensors, you should try to understand the meanings of global variables, data-types, initialisation-functions like before(), presentation() and setup() and the loop().
                  • Daniel RuizD
                    Daniel RuizD
                    Daniel Ruiz
                    I modified as follows:
                    There is no more errors
                    I thought that setting up MYSENSORS was something simple, as indicated in the presentation of the website. I thought the skits were working without changing them. I note that this is not the case, and that it is necessary to have notions of programming.
                      rejoe2R
                      rejoe2R
                      rejoe2
                      @Daniel-Ruiz According to my experience, it normally is not necessary to change sketches.
                      Especially not as long as they are "official" MySensors Sketches. But as soon as additional libs are concerned (here: dallasTemperature), the developers may not be able to survey all external changes that may happen. (The conversionTime calculation had been "public" in the past; this had been changed for whatever reason by the dallas-lib-guys). So this sketch originally had worked. It also may have worked, if you installed an older version of the relevant lib (with the lib manager in the IDE).
                      Nevertheless: You most likely already got a first idea how these things work. Me too, I had to fullfill a fast learning curve... BUT: It is fun!
                      • Daniel RuizD
                        Daniel RuizD
                        Daniel Ruiz
                        I fully agree with you.
                        I have already assimilated some notions thanks to your experience. I'm going to hang on and move on. I love learning and discovering new technologies.
                        I wish you a good evening.
                        Daniel
