  3. MQTT Broker gateway
MQTT Broker gateway
132 Posts 34 Posters 147.5k Views 7 Watching
  • A
    adrianmihai83
    Yes, I am talking about node ID, but what I can tell you is that until two days ago I didn't assigned node ID manual and I didn't have 3 NRF's to test with gateway + 2 nodes. Only when I got other RF's and made a couple of sensors saw that the gateway is assigning node ID 0 to all of the sensors, and all sensors worked, for example:
    1. temp humidity node had Node ID 0 and Child 0 and 1, and from openHAB I could use them at MYMQTT/0/0/V_HUM and MYMQTT/0/1/V_TEMP
    2. motion sensor at MYMQTT/0/2/V_MOTION
    3. and do on, other 2 sensors, all I had to take care is that all of them had distinct Child ID
    Only when I got other NRF's and could make sensors and use them in paralel saw that the gateway is offering NODE ID 0 to all of my sensors, I don't know why, checked MYMQTT.h and it was set to auto assign Node ID, even in the statemant gateway.begin() assumes that the gateway should auto assign Node ID, and gw.begin(incomingMessage, AUTO, true) states it clear that relay sensor should get Node ID from the gateway.
    All I did is manual assigned nodes for every one and workking like a charm. I simply like it this way, it let's more control, it's simply more "my way".
    Now I want to combine some of the sensors and use a Mega2560 for this, hoping for a nice outcome.
    • JohnJ
      JohnJ
      John
      wrote on last edited by John
      #53
      DammeD 1 Reply Last reply
      • JohnJ John
        [[topic:post-is-deleted]]
        DammeD
        DammeD
        Damme
        Code Contributor
        @John Could you send me log from MQTTgateway also? (or tcpdump)
        JohnJ 1 Reply Last reply
        • DammeD Damme
          JohnJ
          JohnJ
          John
          • T
            toomij
            I have a next problem:
            OpenHAB (192.168.1.3) <-> Arduino GW mqtt (192.168.1.234:1883)<-> Arduino TEMP (DHT)
            org.eclipse.paho.client.mqttv3.MqttException: ═х єфрхЄё  яюфъы■ўшЄ№ё  ъ ёхЁтхЁє
            at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNet
            workModule.java:75)
            at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(Cli
            entComms.java:538)
            at java.lang.Thread.run(Unknown Source)
            Caused by: java.net.ConnectException: Connection timed out: connect
            at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
            at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
            at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
            at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
            at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
            at java.net.PlainSocketImpl.connect(Unknown Source)
            at java.net.SocksSocketImpl.connect(Unknown Source)
            at java.net.Socket.connect(Unknown Source)
            workModule.java:66)
            entComms.java:538)
            with ping everything is ok.
            test
            • JohnJ
              JohnJ
              John
              #57
              • T
                toomij
                I connected the serial to MQTT GW:
                If I have connected Wiznet, I've got "0;0;3;0;9;check wires",
                if i disconnected Wiznet then got "Started!"
                • JohnJ
                  JohnJ
                  John
                  @Damme
                  You can forget about my posts, after some quite intensive debugging i found out there was an ugly inconsistent race condition going on in my app. Issue is gone now.
                  • K
                    K
                    kihotx
                    Could anyone help me with running MQTTGateway with enc28j60 ethernet module? Should a gateway respond to ping? Openhab says 'no route to host'. Should i change anything else than Ethernet.h to UIPEthernet.h in source code ?
                    • DammeD
                      DammeD
                      Damme
                      Code Contributor
                      I just wanted to say hello again to everyone. I had to disappear for a while. Just had too much for my brain to handle. So all my automation project were on halt but will be continued again.
                      I know there are lot of bugs in this GW and I will hopefullt start developing soon again. Just write your experience you had so far and I'll try to keep up :)
                      //Damme
                      CARSTENC 1 Reply Last reply
                      • JohnJ
                        JohnJ
                        John
                        @Damme Good luck!
                        • DammeD Damme
                          //Damme
                          CARSTENC
                          CARSTENC
                          CARSTEN
                          @Damme I tried today the mysensor 1.4.1 library, uploaded with Arduino 1.5.8 to UNO with Ethernet Shield (W5100) and an NRF24L01+pa+lna. Compilation and upload worked fine.
                          I can ping the IP address defined in the MQTTGateway.ino sketch.
                          I maintained on my RPI the openhab.cfg file with the url and port number from the gateway.
                          When starting the openhab it shows:
                          ... - MQTT Service initialization completed.
                          ... - Starting MQTT broker connection 'mysensor'.
                          Then a couple of message later:
                          ...Mqtt Exception
                          Caused by: java.net.SocketTimeoutException: connect timed out
                          Any suggestion what I could look at.
                          I also tried to work with the development library of Mysensors but did not get very far with that. My ultimate goal is to something like a moteino with the RFM69HW radio module in connection with either openhab or pidome.
                          I have a quite a bit of hardware lying around here so I am happy to do any testing if somebody gives me some guidance.
                          • CARSTENC CARSTEN
                            ...Mqtt Exception
                            C
                            C
                            C.r.a.z.y.
                            • V
                              V
                              viking
                              Thanks for the mqtt broker. Just a tip to people who might fall in to the same pit as I:
                              The mqtt broker gateway doesn't distribute node ids unless you're connected to it using a mqtt client. I.e. if you did what I did, installed the gateway and wanted to test that the sensors found the gateway and was distributing the code then it doesn't work until you've connected to it. I had to go through the source code to figure it out.
                              If you don't have openhab or simply want to test, this is what I did on my raspberry (but should work similarly on others)
                              // install mosquitto client
                              sudo apt-get install mosquitto-clients
                              // Start the client, replace the 10.0.0.200 with your ip. The port will default to 1883
                              mosquitto_sub -h 10.0.0.200 -d -t hello/world -v
                              You should be able to see messages:
                              Received PUBLISH (d0, q0, r0, m0, 'MyMQTT/20/0/V_LIGHT_LEVEL', ... (2 bytes))
                                A Former User
                                wrote on last edited by [[global:former-user]]
                                #66
                                Hi All
                                Just a simple question:
                                Are there any limitation in how many MQTT connections/sessions the MQTT Gateway can handle?
                                If so, can this be changed?
                                A 1 Reply Last reply
                                • G
                                  G
                                  Gambituk
                                  Hello. I am new to Mysensors, openhab and mosquitto.. I have a working knowledge of arduino and nrf24l01, and currently am running a wireless(nrf) twitter controlled heating scheduler, and am sending multiple temp (ds18b20) sensors to Xively feed.
                                  I am really hooked on the idea of mqtt and openhab, and i thought that mysensors seemed like a good solution for implementing that idea.
                                  My progress so far is to install the DallasTemperatureSensor by MySensors node to one nano, and the ethernet gateway sketc as a first step, and now i have installed the mqttgateway again from the build page, and i have a working install of mosquitto and openhab on a rasp pi b+.
                                  I am just having difficulty getting it all stuck together. I have created the sitemap items and transform files as above and can access the openhab sitemap for the above configuration. i just don't know if i need to configure other items? how can i test each step? and can i use mosquitto with the setup that i have outlined. There seems to be conflicting info about what can and cannot be done with mosquitto and mysensors.
                                  1 do i need to modify the sketch of the temp node? i have some output from the serial that suggests that it is communicating with the gateway.
                                  2 do i need to modify the gateway with info of the mosquitto server?
                                  3 what can i do to test each step of the transit from temp sensor to openhab?
                                  Thanks for any and all responses.
                                  • X
                                    X
                                    xefil
                                    Hello!
                                    I've downloaded the 1.4.1 version of the library and tested it via OpenHab.
                                    I'm still not getting the sketch_name correctly via MQTT and Openhab. Is it still an open bug?
                                    Simon
                                    • I
                                      I
                                      igorvin2
                                      Hi Simon,
                                      I had the same problem
                                      I tried several time clean Eeprom and flash sketch again but with no results
                                      Only after cleaning of Eeprom with the following scratch my sensor is starting work correctly
                                      I recommend to try it:
                                      Clearing EEPROM
                                      Igor
                                      • ? A Former User
                                        Hi All
                                        alexeinz
                                        @mwhansen Hi, I am also struggling with this, seems it can only handle one connection now which makes it extremely hard to debug or check node ids
                                        mqtt gw 1.4 /openhab / zwave
                                          marceloaqno
                                          Code Contributor
                                          @Gambituk To connect to a external MQTT server (mosquitto) use this MQTT gateway version:
                                          http://forum.mysensors.org/topic/524/mqtt-client-gateway/
