  3. MQTT Broker gateway
MQTT Broker gateway
132 Posts 34 Posters 147.8k Views 7 Watching
  • JohnJ
    JohnJ
    John
    wrote on last edited by John
    #53
    DammeD 1 Reply Last reply
    • JohnJ John
      [[topic:post-is-deleted]]
      DammeD
      DammeD
      Damme
      Code Contributor
      @John Could you send me log from MQTTgateway also? (or tcpdump)
      JohnJ 1 Reply Last reply
      • DammeD Damme
        JohnJ
        JohnJ
        John
        • T
          toomij
          I have a next problem:
          OpenHAB (192.168.1.3) <-> Arduino GW mqtt (192.168.1.234:1883)<-> Arduino TEMP (DHT)
          org.eclipse.paho.client.mqttv3.MqttException: ═х єфрхЄё  яюфъы■ўшЄ№ё  ъ ёхЁтхЁє
          at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNet
          workModule.java:75)
          at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(Cli
          entComms.java:538)
          at java.lang.Thread.run(Unknown Source)
          Caused by: java.net.ConnectException: Connection timed out: connect
          at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
          at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
          at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
          at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
          at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
          at java.net.PlainSocketImpl.connect(Unknown Source)
          at java.net.SocksSocketImpl.connect(Unknown Source)
          at java.net.Socket.connect(Unknown Source)
          workModule.java:66)
          entComms.java:538)
          with ping everything is ok.
          test
          • JohnJ
            JohnJ
            John
            #57
            • T
              toomij
              I connected the serial to MQTT GW:
              If I have connected Wiznet, I've got "0;0;3;0;9;check wires",
              if i disconnected Wiznet then got "Started!"
              • JohnJ
                JohnJ
                John
                @Damme
                You can forget about my posts, after some quite intensive debugging i found out there was an ugly inconsistent race condition going on in my app. Issue is gone now.
                • K
                  K
                  kihotx
                  Could anyone help me with running MQTTGateway with enc28j60 ethernet module? Should a gateway respond to ping? Openhab says 'no route to host'. Should i change anything else than Ethernet.h to UIPEthernet.h in source code ?
                  • DammeD
                    DammeD
                    Damme
                    Code Contributor
                    I just wanted to say hello again to everyone. I had to disappear for a while. Just had too much for my brain to handle. So all my automation project were on halt but will be continued again.
                    I know there are lot of bugs in this GW and I will hopefullt start developing soon again. Just write your experience you had so far and I'll try to keep up :)
                    //Damme
                    CARSTENC 1 Reply Last reply
                    • JohnJ
                      JohnJ
                      John
                      @Damme Good luck!
                      • DammeD Damme
                        //Damme
                        CARSTENC
                        CARSTENC
                        CARSTEN
                        @Damme I tried today the mysensor 1.4.1 library, uploaded with Arduino 1.5.8 to UNO with Ethernet Shield (W5100) and an NRF24L01+pa+lna. Compilation and upload worked fine.
                        I can ping the IP address defined in the MQTTGateway.ino sketch.
                        I maintained on my RPI the openhab.cfg file with the url and port number from the gateway.
                        When starting the openhab it shows:
                        ... - MQTT Service initialization completed.
                        ... - Starting MQTT broker connection 'mysensor'.
                        Then a couple of message later:
                        ...Mqtt Exception
                        Caused by: java.net.SocketTimeoutException: connect timed out
                        Any suggestion what I could look at.
                        I also tried to work with the development library of Mysensors but did not get very far with that. My ultimate goal is to something like a moteino with the RFM69HW radio module in connection with either openhab or pidome.
                        I have a quite a bit of hardware lying around here so I am happy to do any testing if somebody gives me some guidance.
                        • CARSTENC CARSTEN
                          ...Mqtt Exception
                          C
                          C
                          C.r.a.z.y.
                          • V
                            V
                            viking
                            Thanks for the mqtt broker. Just a tip to people who might fall in to the same pit as I:
                            The mqtt broker gateway doesn't distribute node ids unless you're connected to it using a mqtt client. I.e. if you did what I did, installed the gateway and wanted to test that the sensors found the gateway and was distributing the code then it doesn't work until you've connected to it. I had to go through the source code to figure it out.
                            If you don't have openhab or simply want to test, this is what I did on my raspberry (but should work similarly on others)
                            // install mosquitto client
                            sudo apt-get install mosquitto-clients
                            // Start the client, replace the 10.0.0.200 with your ip. The port will default to 1883
                            mosquitto_sub -h 10.0.0.200 -d -t hello/world -v
                            You should be able to see messages:
                            Received PUBLISH (d0, q0, r0, m0, 'MyMQTT/20/0/V_LIGHT_LEVEL', ... (2 bytes))
                              A Former User
                              wrote on last edited by [[global:former-user]]
                              #66
                              Hi All
                              Just a simple question:
                              Are there any limitation in how many MQTT connections/sessions the MQTT Gateway can handle?
                              If so, can this be changed?
                              A 1 Reply Last reply
                              • G
                                G
                                Gambituk
                                Hello. I am new to Mysensors, openhab and mosquitto.. I have a working knowledge of arduino and nrf24l01, and currently am running a wireless(nrf) twitter controlled heating scheduler, and am sending multiple temp (ds18b20) sensors to Xively feed.
                                I am really hooked on the idea of mqtt and openhab, and i thought that mysensors seemed like a good solution for implementing that idea.
                                My progress so far is to install the DallasTemperatureSensor by MySensors node to one nano, and the ethernet gateway sketc as a first step, and now i have installed the mqttgateway again from the build page, and i have a working install of mosquitto and openhab on a rasp pi b+.
                                I am just having difficulty getting it all stuck together. I have created the sitemap items and transform files as above and can access the openhab sitemap for the above configuration. i just don't know if i need to configure other items? how can i test each step? and can i use mosquitto with the setup that i have outlined. There seems to be conflicting info about what can and cannot be done with mosquitto and mysensors.
                                1 do i need to modify the sketch of the temp node? i have some output from the serial that suggests that it is communicating with the gateway.
                                2 do i need to modify the gateway with info of the mosquitto server?
                                3 what can i do to test each step of the transit from temp sensor to openhab?
                                Thanks for any and all responses.
                                • X
                                  X
                                  xefil
                                  Hello!
                                  I've downloaded the 1.4.1 version of the library and tested it via OpenHab.
                                  I'm still not getting the sketch_name correctly via MQTT and Openhab. Is it still an open bug?
                                  Simon
                                  • I
                                    I
                                    igorvin2
                                    Hi Simon,
                                    I had the same problem
                                    I tried several time clean Eeprom and flash sketch again but with no results
                                    Only after cleaning of Eeprom with the following scratch my sensor is starting work correctly
                                    I recommend to try it:
                                    Clearing EEPROM
                                    Igor
                                    • ? A Former User
                                      Hi All
                                      alexeinz
                                      @mwhansen Hi, I am also struggling with this, seems it can only handle one connection now which makes it extremely hard to debug or check node ids
                                      mqtt gw 1.4 /openhab / zwave
                                        marceloaqno
                                        Code Contributor
                                        @Gambituk To connect to a external MQTT server (mosquitto) use this MQTT gateway version:
                                        http://forum.mysensors.org/topic/524/mqtt-client-gateway/
                                        • G
                                          G
                                          Gambituk
                                          Thanks @celonunes I eventually found that version of gateway via somebody else. i have another post with some issues i found with that version. http://forum.mysensors.org/topic/921/strange-value-being-sent-from-controller-using-mixed-temp-relay-node it's not really resolved, but i have some kind of workaround.
