  2. Announcements
  3. 💬 Relay
💬 Relay
139 Posts 47 Posters 82.5k Views 45 Watching
  • S sineverba
    Hi to all!
    To achieve my goal (node that sends relay state after power failure to sync with domoticz), I'm editing the button script.
    I have added this line
    state = digitalRead(RELAY_PIN);
    send(msg.set(state?false:true), true); // Send new state and request ack back
    in setup, so I thought it send only one time at startup the current state after power failure.
    But..... the relay shutdown/shuton (or viceversa) twice, in fast sequence....
    Thank you very much!
    sineverba
    @sineverba
    Bingo!
    If I did understand well, the actuator sketch DOESN'T directly acts the relay, but sends to the gateway and expect from the gw itself the "new state" (in effect, you short GND & PIN 4, arduino sends new state to the gateway and gateway resend the new state).
    So, 'cause I would to update the state on controller, I did this simple edit on setup:
     state = loadState(CHILD_ID);
     Serial.print("Lo stato ultimo era ");
     Serial.println(state);
     if ( state == 1) {
       state = 0;
       state = 1;
    Basically, If relay was OFF on a power failure, and someone on Domoticz try to start the relay, the state in Domoticz will be "on".
    When power returns, the arduino read the state (in my example OFF == 0), convert in 1 and send to the gateway the 1. The gateway // Domoticz will be answer with 0.
    So, relay doesn't nothing and Domoticz state is update.
    But.... why I need to invert the logic? :D
    • S sineverba
      Hi to all!
      Boots33B
      Boots33B
      Boots33
      @sineverba said in 💬 Relay:
      Have a look at the sketch I used for my Synchronising Light switch you may be able to use some of that code perhaps.
      S 1 Reply Last reply
      • Boots33B Boots33
        sineverba
        @Boots33
        Never seen the request function.
        You are hero-member for a reason...
        Thank you very much! :) :)
        Boots33B 1 Reply Last reply
        • S sineverba
          @Boots33
          Boots33B
          Boots33B
          Boots33
          You can find request and other useful info on the API page.
          Hope you are enjoying your MySensors journey :)
          • fhenrycoF
            fhenrycoF
            fhenryco
            since the relay has leds and is therefore power consuming, i was wondering if someone has written a sketch for a low power usage of the relay (as for the sensors) allowing the arduino (and the relay) to sleep all the time and wake up every 5 minutes for instance just to check if the controller has changed the desired state of the switch.
            Of course then the relay could be as late as 5minute, but this is not an issue for my application ...
            thanks for any suggestion
            • fhenrycoF fhenryco
              @fhenryco can't the relay node use power from whatever it is controlling?
              For sleeping nodes, the smartsleep feature can be useful. Search for that keyword in the forum and look at https://www.mysensors.org/download/sensor_api_20#sleeping
              fhenrycoF 1 Reply Last reply
              • fhenrycoF
                fhenrycoF
                fhenryco
                thanks , indeed it's because the relay is controlling a 12V battery power to solenoid valve , that low power consumption is needed. BTW the 12V is obtained from a 4S lipo (16.5V max voltage) and a 12 regulator and i dont know if its better to feed the arduino from a 5V regulator fed by the same Lipo , or use an additional set of AA batteries ... i remember that it's better to have an as low as possible drop in voltage to save power...
                  Boots33B
                  Boots33B
                  Boots33
                  @fhenryco If you are trying to keep your power use down then you could also consider using either a Latching Relay or even a MOSFET.
                  gohanG 1 Reply Last reply
                    fhenrycoF
                    fhenrycoF
                    fhenryco
                    @mfalkvidd smartsleep was not supported by domoticz at the begining of the year ... but there was a domoticz upgrade in july ... do you know if it's now supported ?
                    • Boots33B Boots33
                      @Boots33 said in 💬 Relay:
                      Agreed, if you want to save power you need to use a latching relay. Also another regulator would be fine to power the arduino.
                        fhenrycoF
                        fhenrycoF
                        fhenryco
                        @gohan can you explain the benefit (for a low power app) of a relay switching on electrical pulse rather something else ?
                        i mean, even the regular relay has both an open by default circuit output and close by default circuit ouput so it could remain on the desired state even when not powered up ...
                          I am referring that when relay is on it is drawing power to stay on, while a latching relay it only draws power during the switch on and only during the switch off.
                            fhenrycoF
                            fhenrycoF
                            fhenryco
                            @gohan not sure this is going to be an easy way: need find arduino code for latch relay, dont know if domoticz is supporting this device ?, ...
                              Domoticz will just see the same relay node, it is the code that need to be a little different as the relay is switched with a pulse and you need a pin to verify the relay status (if you get the ones that have a monitoring contact)
                              • amemo06A
                                amemo06A
                                amemo06
                                Hi Everyone,
                                maybe the below will help people facing random incorrect behaviors.
                                In sample from december 2016 /mysensors/MySensors/examples/RelayActuator/RelayActuator.ino, there is something which could be seen as a bug.
                                In my case, I have used that sample to control a lot of relais. I noticed some rare but really annoying errors. From time to time a relay got switched incorrectly.
                                Annoying and strange as coding was pretty straightforward. All relais are coded to act in pulse mode.
                                          digitalWrite(message.sensor-1+RELAY_1, RELAY_OFF);
                                          wait(1000);
                                          digitalWrite(message.sensor-1+RELAY_1, RELAY_ON);
                                And this is the reason of the bug.
                                Explanation.
                                During that second of wait, a lot of things may occurs. Due to the 'message' declaration, it is possible that the 'message' is getting changed.
                                Typically a ping may come and as result the 'message' is not anymore the same.
                                For that reason I would suggest the code to be changed a little bit.
                                void receive(const MyMessage &message_orig)
                                  MyMessage message;
                                  message = message_orig;
                                This way, the function works with a local copy and you are sure nothing can change during the processing.
                                Anyway, thanks for the sample it was nevertheless very helpful
                                BulldogLowellB gohanG 2 Replies Last reply
                                • amemo06A amemo06
                                  Hi Everyone,
                                            wait(1000);
                                  Explanation.
                                    MyMessage message;
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @amemo06
                                  Because of the const keyword this is a const reference or said another way, a reference to a constant. The const keyword guarantees that the function may not change the object.
                                  So, I wonder what your real issue is....
                                  amemo06A 1 Reply Last reply
                                    @amemo06
                                    amemo06A
                                    amemo06A
                                    amemo06
                                    @BulldogLowell No This is not the coding of the function which changes it. It is most likely the event which triggers it which may changes it.
                                    I can show the coding with trace and trace result.
                                    //void receive(const MyMessage &message_orig)
                                    //  MyMessage message;
                                    //  message = message_orig;
                                      Serial.println("receive_in:");
                                    Serial.print("1st read:Sensor=");Serial.print(message.sensor);Serial.print(", getBool=");Serial.println(message.getBool());
                                      if (message.type==V_STATUS) {
                                        // Change relay state
                                        if (message.getBool() == RELAY_ON){
                                    Serial.print("2nd read:Sensor=");Serial.print(message.sensor);Serial.print(", getBool=");Serial.println(message.getBool());
                                          wait(1000);
                                    Serial.print("3rd read:Sensor=");Serial.print(message.sensor);Serial.print(", getBool=");Serial.println(message.getBool());
                                    Serial.println("receive_out:");
                                    Below is a normal trace
                                    0;255;3;0;9;Eth: 0;0;3;0;18;PING
                                    0;255;3;0;9;Eth: 0;1;1;0;2;1
                                    receive_in:
                                    1st read:Sensor=1, getBool=1
                                    2nd read:Sensor=1, getBool=1
                                    3rd read:Sensor=1, getBool=1
                                    receive_out
                                    So you see the ping which occured before the message I'm interested in
                                    Now, because of the wait in the middle of the code, it may occurs the ping arrive in that period. Then the issue occurs.
                                    See the trace with error.
                                    receive_in:
                                    3rd read:Sensor=0, getBool=0
                                    receive_out
                                    In the 3rd read, sensor value has changed and getBool returns also a different value.
                                    Removing the wait or ensuring the function modules performs faster could reduce the risk. Still it will never be reliable.
                                    Better is to have either a local copy of the message like I wrote in the original post. Or make immediately copies of the information from the message I'm interested in.
                                    • amemo06A amemo06
                                      Hi Everyone,
                                                wait(1000);
                                      Explanation.
                                        MyMessage message;
                                      @amemo06 said in 💬 Relay:
                                      wait(1000);
                                      where did you find that? I wasn't able to find it
                                        wait(1000);
                                        amemo06A
                                        amemo06A
                                        amemo06
                                        @gohan This is not in the original coding. I needed something like a wait in order to make a relay pulse.
                                        The wait increases the risk or the frequency of the trouble. Removing it does not solves the issue.
                                        Processing of the function will always take time. And the message can still changes before reaching the end like it is show in the second trace.
                                        • amemo06A amemo06
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @amemo06
                                          You should treat the message like an ISR... get in and out so that you don't have another message colliding while you are in the function.
                                          Get rid of that wait(). I couldn't find the source for that function but you could try to just use delay() to block while you hold the relay.
                                          otherwise just set a flag to handle the relay event in loop() or use a Timer/callback like the MsTimer2 Library
                                          example:
                                          #include <MsTimer2.h>
                                          const byte onButton = 5;
                                            Serial.begin(9600);
                                            pinMode(13, OUTPUT);
                                            pinMode(onButton, INPUT_PULLUP);
                                            if(onButtonPressed())
                                             flashLedThirteen(5000);
                                          bool onButtonPressed(void)
                                            static unsigned long lastMillis = 0;
                                            static byte lastPress = HIGH;
                                            byte currentPress = digitalRead(onButton);
                                            if(currentPress != lastPress)
                                              if(millis() - lastMillis < 200) return false;
                                              lastPress = currentPress;
                                              if(currentPress == LOW)
                                                Serial.println(" button press detected!");
                                                lastMillis = millis();
                                                return true;
                                            return false;
                                          void flashLedThirteen(int ledTime)
                                            digitalWrite(13, HIGH);
                                            Serial.println("LED ON");
                                            // sets a new timer callback function
                                            MsTimer2::set(ledTime, [] {  // the square brackets define the start of the anonymous callback function which is executed after 5000 milliseconds in this example
                                              digitalWrite(13, LOW);
                                              Serial.println("Timer expired...");
                                              Serial.println("LED OFF");
                                              MsTimer2::stop();
                                            }); // the curly brace defines the end of the anonymous callback function
                                            MsTimer2::start();
