  2. Announcements
  3. ๐Ÿ’ฌ Relay
๐Ÿ’ฌ Relay
139 Posts 47 Posters 82.5k Views 45 Watching
  • HenryWhiteH HenryWhite
    @Rene046 you could try my sketch: https://forum.mysensors.org/topic/6638/multiple-relays-motion-sketch-fully-customizable-optional-timer-manual-override
    R
    R
    Rene046
    @HenryWhite
    thx
      sineverba
      wrote on last edited by sineverba
      #45
      Hi to all!
      I would edit the secure relay sketch so in loop the node sends to the gateway, let's say every hours, his state (on or off).
      1. I avoid delay otherwise Arduino cannot receive the comands from gateway, so I will use the millis sketch, modified from the official Arduino website.
      My doubt is... How can I get the current state of the relay?
      Relevant part of sketch is in loop and before setup()
      /* TIME variables */
      unsigned long previousMillis = 0;        // will store last time state is sent
      // constants won't change:
      const long interval = 10000;           // interval at which to send state (milliseconds === seconds x 1000). For test we try every 10 seconds
      And the main loop
        // check to see if it's time to send state; that is, if the difference
        // between the current time and last time you sent state is bigger than
        // the interval at which you want to send the state.
        if (currentMillis - previousMillis >= interval) {
          // save the last time you blinked the LED
          // send the state here!
          // test
          Serial.println("This is the moment where I need to send state");
          //send(?????????); // Send current state. Probabily will update also the log?
      The base sketch is >>> https://github.com/mysensors/MySensors/blob/master/examples/SecureActuator/SecureActuator.ino
      And the millis example is >>> https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
      Thank you to all!
      S 1 Reply Last reply
      • S sineverba
        Hi to all!
        And the main loop
            // test
        Thank you to all!
        sineverba
        #46
        @sineverba
        Edit:
        I did edit the pre-setup configuration
        int val = 0;  // the value of digital pin
        And I did edit the loop:
            // test
            val = digitalRead(LOCK_1);
            Serial.print("Il valore del relay รจ ");
            Serial.println(val);
            send(msg.set(val),true); // Send new state and request ack back.
        I got the update in Domoticz in Hardware > Configuration > Children of nodes
        And I did test also every 3 seconds, all ok.
        But I don't have the refresh in "main page":
        I did test removing current to Arduino when Relay was ON. With Arduino off, I did change the state in domoticz to OFF.
        Because Arduino save previous state in EEPROM, after full start the relay did go ON, in Domoticz got "1" in children (all right, because digitalRead was 1) but main panel shows OFF.
        I did expect a graphical change...
        Thank you (and hope that all is clear) :)
          sineverba
          Hi to all!
          To achieve my goal (node that sends relay state after power failure to sync with domoticz), I'm editing the button script.
          I have added this line
          state = digitalRead(RELAY_PIN);
          send(msg.set(state?false:true), true); // Send new state and request ack back
          in setup, so I thought it send only one time at startup the current state after power failure.
          But..... the relay shutdown/shuton (or viceversa) twice, in fast sequence....
          Thank you very much!
          S Boots33B 2 Replies Last reply
          • S sineverba
            Hi to all!
            sineverba
            @sineverba
            Bingo!
            If I did understand well, the actuator sketch DOESN'T directly acts the relay, but sends to the gateway and expect from the gw itself the "new state" (in effect, you short GND & PIN 4, arduino sends new state to the gateway and gateway resend the new state).
            So, 'cause I would to update the state on controller, I did this simple edit on setup:
             state = loadState(CHILD_ID);
             Serial.print("Lo stato ultimo era ");
             Serial.println(state);
             if ( state == 1) {
               state = 0;
               state = 1;
            Basically, If relay was OFF on a power failure, and someone on Domoticz try to start the relay, the state in Domoticz will be "on".
            When power returns, the arduino read the state (in my example OFF == 0), convert in 1 and send to the gateway the 1. The gateway // Domoticz will be answer with 0.
            So, relay doesn't nothing and Domoticz state is update.
            But.... why I need to invert the logic? :D
            • S sineverba
              Hi to all!
              Boots33B
              Boots33B
              Boots33
              @sineverba said in ๐Ÿ’ฌ Relay:
              Have a look at the sketch I used for my Synchronising Light switch you may be able to use some of that code perhaps.
              • Boots33B Boots33
                sineverba
                @Boots33
                Never seen the request function.
                You are hero-member for a reason...
                Thank you very much! :) :)
                Boots33B 1 Reply Last reply
                • S sineverba
                  @Boots33
                  Boots33B
                  Boots33B
                  Boots33
                  You can find request and other useful info on the API page.
                  Hope you are enjoying your MySensors journey :)
                  • fhenrycoF
                    fhenrycoF
                    fhenryco
                    since the relay has leds and is therefore power consuming, i was wondering if someone has written a sketch for a low power usage of the relay (as for the sensors) allowing the arduino (and the relay) to sleep all the time and wake up every 5 minutes for instance just to check if the controller has changed the desired state of the switch.
                    Of course then the relay could be as late as 5minute, but this is not an issue for my application ...
                    thanks for any suggestion
                    • fhenrycoF fhenryco
                      @fhenryco can't the relay node use power from whatever it is controlling?
                      For sleeping nodes, the smartsleep feature can be useful. Search for that keyword in the forum and look at https://www.mysensors.org/download/sensor_api_20#sleeping
                      fhenrycoF 1 Reply Last reply
                      • fhenrycoF
                        fhenrycoF
                        fhenryco
                        thanks , indeed it's because the relay is controlling a 12V battery power to solenoid valve , that low power consumption is needed. BTW the 12V is obtained from a 4S lipo (16.5V max voltage) and a 12 regulator and i dont know if its better to feed the arduino from a 5V regulator fed by the same Lipo , or use an additional set of AA batteries ... i remember that it's better to have an as low as possible drop in voltage to save power...
                          Boots33B
                          Boots33B
                          Boots33
                          @fhenryco If you are trying to keep your power use down then you could also consider using either a Latching Relay or even a MOSFET.
                          gohanG 1 Reply Last reply
                            fhenrycoF
                            fhenrycoF
                            fhenryco
                            @mfalkvidd smartsleep was not supported by domoticz at the begining of the year ... but there was a domoticz upgrade in july ... do you know if it's now supported ?
                            • Boots33B Boots33
                              @Boots33 said in ๐Ÿ’ฌ Relay:
                              Agreed, if you want to save power you need to use a latching relay. Also another regulator would be fine to power the arduino.
                                fhenrycoF
                                fhenrycoF
                                fhenryco
                                @gohan can you explain the benefit (for a low power app) of a relay switching on electrical pulse rather something else ?
                                i mean, even the regular relay has both an open by default circuit output and close by default circuit ouput so it could remain on the desired state even when not powered up ...
                                  I am referring that when relay is on it is drawing power to stay on, while a latching relay it only draws power during the switch on and only during the switch off.
                                    fhenrycoF
                                    fhenrycoF
                                    fhenryco
                                    @gohan not sure this is going to be an easy way: need find arduino code for latch relay, dont know if domoticz is supporting this device ?, ...
                                      Domoticz will just see the same relay node, it is the code that need to be a little different as the relay is switched with a pulse and you need a pin to verify the relay status (if you get the ones that have a monitoring contact)
                                      • amemo06A
                                        amemo06A
                                        amemo06
                                        Hi Everyone,
                                        maybe the below will help people facing random incorrect behaviors.
                                        In sample from december 2016 /mysensors/MySensors/examples/RelayActuator/RelayActuator.ino, there is something which could be seen as a bug.
                                        In my case, I have used that sample to control a lot of relais. I noticed some rare but really annoying errors. From time to time a relay got switched incorrectly.
                                        Annoying and strange as coding was pretty straightforward. All relais are coded to act in pulse mode.
                                                  digitalWrite(message.sensor-1+RELAY_1, RELAY_OFF);
                                                  wait(1000);
                                                  digitalWrite(message.sensor-1+RELAY_1, RELAY_ON);
                                        And this is the reason of the bug.
                                        Explanation.
                                        During that second of wait, a lot of things may occurs. Due to the 'message' declaration, it is possible that the 'message' is getting changed.
                                        Typically a ping may come and as result the 'message' is not anymore the same.
                                        For that reason I would suggest the code to be changed a little bit.
                                        void receive(const MyMessage &message_orig)
                                          MyMessage message;
                                          message = message_orig;
                                        This way, the function works with a local copy and you are sure nothing can change during the processing.
                                        Anyway, thanks for the sample it was nevertheless very helpful
                                        BulldogLowellB gohanG 2 Replies Last reply
                                        • amemo06A amemo06
                                          Hi Everyone,
                                                    wait(1000);
                                          Explanation.
                                            MyMessage message;
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @amemo06
                                          Because of the const keyword this is a const reference or said another way, a reference to a constant. The const keyword guarantees that the function may not change the object.
                                          So, I wonder what your real issue is....
                                          amemo06A 1 Reply Last reply
                                          With your input, this post could be even better ๐Ÿ’—
