  3. ARDUINO UNO
ARDUINO UNO
19 Posts 5 Posters 6.8k Views 5 Watching
    You need to be a little more specific: are you running the USB gateway sketch on the pro mini and domoticz is configured to use the USB gateway?
    • Daniel RuizD
      Daniel RuizD
      Daniel Ruiz
      @gohan said in ARDUINO UNO:
      oui j'exécutel'esquisse de la passerelle USB sur pro mini et domoticz et bien configuré pour utiliser la passerelle USB.
      la passerelle usb est bien dans les log de domoticz.
      y a t'il une procédure pour inclure un device?
      Hier j'ai eu de la chance il est apparu directement dans la liste des dispositifs de domoticz et il fonctionnait correcetment
      DANIEL
        Sorry, I studied French too many years ago... I can't understand it :D
        • Daniel RuizD
          Daniel RuizD
          Daniel Ruiz
          Vous parlez Français?
            No, Italian English and some Spanish
            • Daniel RuizD
              Daniel RuizD
              Daniel Ruiz
              Yes I executed sketch of the USB gateway on pro mini and home automation and well configured to use the USB gateway.
              The usb gateway is well in the domoticz log.
              Is there a procedure to include a device?
              Yesterday I was lucky it appeared directly in the list of home automation devices and the functionality of the correction
              DANIEL
                I am still missing a piece: do you have one arduino as gateway and another arduino with the relay sketch or the relay is on the gateway?
                • Daniel RuizD
                  Daniel RuizD
                  Daniel Ruiz
                  I move slowly but surely.
                  My installation is as follows:
                  I do my tests on a second raspberry so as not to disrupt the home automation system that works perfectly.
                  • An Arduino pro gateway mini radio NRF24L01 + USB FT232RL
                    -An Arduino pro mini + radio module NRF24L01 + USB FT232RL + relay card
                    -An Arduino Uno + DHT22.
                  I now find my relay card in the list of Domoticz devices, the command is sent to the gateway but the relay of the relay card does not react. I think I have a problem with the radio and especially its 3volts power supply.
                  The LEDs that are on the radio card never light ????
                  I do not find in the list of devices to domoticz the probe temperature humidity.
                  In the serial monitor of the card arduino uno temperature probe there is the following message:
                  ! TSM: FFARFAIL
                  after that
                  TSM: ROIF
                  TSM: FFAR: NO REPLY
                  TSM: ROIF
                  This sounds like error messages but I do not know how to interpret them
                  Daniel
                    You need to look at the logs of both gateway and relay node to see what happen to the message.
                    About the UNO, it looks like it is having some radio issues: or missing cap on the radio module, or it is out of range of the gateway
                    • Daniel RuizD
                      Daniel RuizD
                      Daniel Ruiz
                      The gateway is 1 meter from the arduino The hardware is in test on my work table.
                      • Daniel RuizD
                        Daniel RuizD
                        Daniel Ruiz
                        How do I get the LEDs on the radio card?
                        ben999B gohanG 2 Replies Last reply
                        • Daniel RuizD Daniel Ruiz
                          ben999B
                          ben999B
                          ben999
                          @Daniel-Ruiz any leds on a NRF board ??
                            @Daniel-Ruiz TX rx leds needs to go on the arduino. Did you put any capacitor on the radio vcc? Do you have any other radio module to try?
                            • Nca78N
                              wrote on last edited by Nca78
                              Bonjour Daniel,
                              please use only English else it will limit your ability to get help, and ability for others to learn from your experience when reading this thread.
                              For your questions problems:
                              • there is no led on NRF24 radio, don't expect to see anything :)
                              • you need a capacitor on each radio module as close as possible to the Vcc and GND pins of the radio. Minimum 4.7uF but it's usually better to put a bit more like 10uF especially with cheap radios. If you don't put it the noise from the power supply/usb port will make the radio unstable
                              • It is possible that you have interferences between radio modules if they are too close, try to move modules and gateway away from each others and only keep on your desk the sensor that you are debugging
                              • there is no need for inclusion button on Domoticz, as you have seen it, the new modules/sensors will be added automatically to the list of devices. What you have is clearly a problem of stability of the radio link
                              • Daniel RuizD
                                Daniel RuizD
                                Daniel Ruiz
                                Hello everyone
                                Now it works very well, after changing the capacitor 4.7mF by a 10mF.
                                Thank you again for your help.
                                cordially
                                Danie
