  3. Domoticz
  4. Problem with Domoticz
12 Posts 3 Posters 4.4k Views 3 Watching
  • A
    arduino_89_89
    I understand, but the only sensors that connect are: The temperature sensor and the gas sensor, which send periodic signals. My system is structured on 3 floors. The first floor has the Gateway, and off the first floor has a Node Repeater. Then the second floor has another Node Repeater and has 2 Relay Nodes. And finally the Third Floor with another repeater and 2 sensors, Gas and Temp / Hum.
      Without the serial logs of when you are experiencing the problem, it is kind of impossible to help.
      • A
        arduino_89_89
        But should I use watchdog? To reset nodes automatically every day?
          That is a workaround, it is not a solution. You need to debug the issue and find the root cause. Also posting the logs can be helpful for us to help
          • A
            arduino_89_89
            How do I send it to you? It's too long.
              Just paste it here using a different "insert code block" tag for each log, also try to cleanup the logs so they are not hundreds of lines each.
              • A
                arduino_89_89
                It's too long.
                • A
                  arduino_89_89
                  0_1502269526374_Log.txt
                  • A
                    arduino_89_89
                    0_1502270247458_Log.txt
                    • A arduino_89_89
                      Hi everyone, I wanted to know how ever whenever the PC reboots, I also change the com port. And why when I break the gateway, are the sensors no longer connected? It's okay to restart them all to let them read.
                      P
                      P
                      pjr
                      @arduino_89_89 said in Problem with Domoticz:
                      What environment? Could this help? https://www.domoticz.com/wiki/Assign_fixed_device_name_to_USB_port
                      12.5k
