  3. nRF5 action!
nRF5 action!
  • T Toyman
    @rmtucker
    before you design your own board:
    https://ru.aliexpress.com/item/Free-shipping-1pcs-NRF51822-development-board-ble4-0-Bluetooth-module-development-board-2-4G-low-power/32596438101.html?spm=a2g0v.search0204.3.73.ZtUmwF&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10209_10307_10301_10137_10060_439_10155_10154_10056_10055_10054_10059_100031_10099_10103_10102_10169_10052_10053_10142_10107_10050_10051_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_10311_10312_10313_10314_10315_10078_10079_10210_10073_10125,searchweb201603_19,ppcSwitch_7_ppcChannel&btsid=df5cc403-0dac-4fab-842a-646caeb0e554&algo_expid=230ba6b9-0318-4b2a-b991-a91aafb9b85f-9&algo_pvid=230ba6b9-0318-4b2a-b991-a91aafb9b85f
    rmtuckerR
    rmtuckerR
    rmtucker
    @Toyman
    Yes i am already running that board at the moment.
    But that board consumes around 140uA when sleeping.
    It must be the extra electronics like the regulator and uart.
    even when feeding the core board with 3.3v directly.
    When the core board is on its own it only measures 5uA when sleeping.
      This nRF52832 module looks to be pretty small, and it has both oscillators on it.
      It appears that it forces you to use an external antenna though.
      https://www.aliexpress.com/item/NRF52832-Bluetooth-4-2-Module-BLE-Low-Power-Bluetooth-External-Antenna/32825850305.html?spm=2114.search0104.3.2.Ehd1fQ&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10130_10068_5400011_10307_10137_10060_10155_10154_5370011_10056_10055_10054_10059_5380011_100031_10099_10103_10102_5410017_5430017_10052_10053_10142_10107_10050_10051_10084_10083_10119_10080_10082_10081_10178_10110_10111_10112_5390011_10113_10114_10312_10313_10314_10315_10078_10079_5420017_10073_10120,searchweb201603_2,ppcSwitch_4&btsid=2d85e0d1-50d7-434b-b096-286b0eb3b893&algo_expid=ef23bd47-74f5-4531-93b6-4883f068a6b4-0&algo_pvid=ef23bd47-74f5-4531-93b6-4883f068a6b4&transAbTest=ae803_3
      • T
        Toyman
        Help needed!! I am trying to program nrf51822 with Black Magic Probe , but BMP is not recognized by Arduino IDE.
        I can do everything in gdb, e.g. do mass erase, upload soft device etc, but BMP is simply not listed in programmers' list in Arduino IDE so I can't upload sketches.
        rmtuckerR 1 Reply Last reply
        • T Toyman
          rmtuckerR
          rmtuckerR
          rmtucker
          wrote on last edited by rmtucker
          #576
          Could anyone tell me why the waveshare board is pulling 140uA when sleeping with everything unpugged including the usb and all the header jumpers so only 3.3v and ground fed to the header pins so not using the regulator etc.
          I have attached a link to the schematic hoping some circuit wiz might be able to explain.
          link text
          If i unplug the core board and just power that with 3.3v and gnd it only uses 5uA when sleeping.
          mtiutiuM 1 Reply Last reply
          • rmtuckerR rmtucker
            link text
            mtiutiuM
            mtiutiuM
            mtiutiu
            @rmtucker
            Even if you're not using the regulator and the CP2102 usb-serial converter there are some leakage currents which are caused by the output stages of those IC's. For example the output stage of the voltage regulator can draw some even if it's not powered. The CP2102 can draw also through the TXD1/RXD1/SUSPEND1 LEDs and the associated GPIO pins P0.11, P0.09, etc.
            So to prove and test that the above it's true you need to:
            1. Desolder the RT9193-33 or at least its output pin(Vout pin 5)
            2. Desolder R6, R7, R10
            This is what I can conclude by looking at that schematic. Any other opinions?
            • mtiutiuM mtiutiu
              @rmtucker
              #578
              Any other opinions?
              Yes. If it really matters that much, RMTucker should buy or make a uCurrent Gold. Otherwise, he'll find hmself chasing phantoms. I have a Fluke 87V, and I don't trust it to do these types of measurements (I've tried, and the results are just wrong when compared to a uCurrent Gold). I would trust a crappy multimeter even less. Been there and tried that already.
              Just my two cents.
              NeverDieN Nca78N 2 Replies Last reply
                Any other opinions?
                Just my two cents.
                #579
                BTW, uCurrent Gold is open source. I have an original, but you can buy clones. For instance, LowPowerLab sells a clone. You might get it faster than ordering from Australia.... unless you live in Australia. Dave Jones did a video for me once, and so I thought he deserved the profit instead of somebody else. :)
                  Any other opinions?
                  Just my two cents.
                  Any other opinions?
                  Just my two cents.
                  It just depends on the burden voltage, no ? It's proportional to current in the circuit so in sleep mode when measuring around 10 uA it should be negligible.
                  Anyway I measure when powered with 3.3V so I'm sure what I measure is higher than what I will get in reality when circuit is powered with a 3V battery.
                  • mtiutiuM
                    mtiutiuM
                    mtiutiu
                    For measuring small currents I'm using Texas Instruments EnergyTrace piece of technology and it works pretty well. You just need one of their development boards with energytrace special microcontroller embedded which is very cheap. More infos here: http://43oh.com/2015/09/how-to-measure-an-energia-applications-power-usage-with-energytrace/
                    It can be used to measure other boards power usage also - you just need to take of some jumpers and plug in your external board.
                    It gives you real time energy measurements and with plotting too(and battery life estimation is displayed real time too). No need to worry about burden voltage and other external factors which affect the measurements.
                    • mtiutiuM mtiutiu
                      @mtiutiu
                      I think maybe the nRF52 DK also has some energy measurement capability, but I haven't looked into it.
                        @mtiutiu
                        Toyman
                        https://devzone.nordicsemi.com/tutorials/28/
                          #584
                          Looks like I was wrong earlier about the voltage reference being Vcc when doing an analog read on a pin. Instead, it seems to be a fixed reference. In any case, I'm getting better results with an expression like this, which is independent of Vcc:
                          millivolts = (analogRead(PIN)*3000/4095)
                          What are others here doing in this case?
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            As mentioned earlier by someone the nrf52 is preset to 0.6v internal ref and a 1/5 divider so 0 - 3v is the max input so your calculation is correct.
                            The nrf51 is different because the ref can be set to a few different settings but the default is vdd.
                            • rmtuckerR
                              rmtuckerR
                              rmtucker
                              Is RSSI reporting implemented in the NRF5 setup yet?
                              If so how is it done?
                                I don't think sendSignalStrength function is implemented yet, but you should be able to get this info with:
                                int16_t transportGetSendingRSSI(void)
                                int16_t transportGetReceivingRSSI(void)
                                rmtuckerR 2 Replies Last reply
                                • T
                                  Toyman
                                  How can I redefine UART pins in nrf51822? For example, if I want to have p13 as uart tx?
                                  scalzS 1 Reply Last reply
                                  • T Toyman
                                    @Toyman
                                    it has been explained above in the topic ;)
                                    you have to follow
                                    • https://github.com/mysensors/ArduinoBoards
                                    • https://github.com/mysensors/ArduinoHwNRF5
                                    • scalzS scalz
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      @scalz
                                      Rssi works really well.
                                      Thank you.
                                        @scalz
                                        Thank you.
                                        rmtuckerR
                                        rmtuckerR
                                        rmtucker
                                        So range test.
                                        Using esp8266 with standard nrf24 not amplified gateway at one end of the house.
                                        Nrf51822 node in garage which is not fastened to house so at a guess 15m through 3 brick walls is reporting -86db.
                                        I think that is quite respectable.;-)
                                        • scalzS scalz
                                          @Toyman
                                          you have to follow
                                          Toyman
                                          @scalz thx.
