  3. How do I get multiple different mock barometers?
53 Posts 6 Posters 11.5k Views 5 Watching
  • rmtuckerR rmtucker
    Here is a little sketch that compiles on the NRF5.
    #define MY_RADIO_NRF5_ESB
       @def MY_NRF5_ESB_PA_LEVEL
       @brief Default nRF5 PA level. Override in sketch if needed.
       - NRF5_PA_MIN = -40dBm
       - NRF5_PA_LOW = -16dBm
       - NRF5_PA_HIGH = 0dBm
       - NRF5_PA_MAX = 4dBm
    #define MY_NRF5_ESB_PA_LEVEL (NRF5_PA_MAX)
    #define MY_NRF5_ESB_CHANNEL (76)
    #define MY_NRF5_ESB_MODE (NRF5_250KBPS)
    #define MY_NODE_ID 10
    #define VOLTAGE     0
    float vcc = (hwCPUVoltage() / 1000.0);
    MyMessage VoltageMsg(VOLTAGE, V_VOLTAGE);
      sendSketchInfo("General sensor", "1.0");
      present(VOLTAGE, S_MULTIMETER);
    //  Serial.begin(115200);
    //  while (!Serial) ; // wait for Arduino Serial Monitor
      send(VoltageMsg.set(vcc, 3));
    //  Serial.print(F("Voltage = "));
    //  Serial.print(vcc, 3);
    //  Serial.println(F("v"));
      sleep(60000);
    #43
    @rmtucker said in How do I get multiple different mock barometers?:
    Just now noticing that your definitions:
    can also be set in myconfig.h.
    Strangely, myconfig.h defaults to max Tx power on the nrf52, but not max Tx power on the nrf24. Not sure why, especially since, if anything, the nRF24 needs it more.
    So, I just now changed myconfig.h to put everything at max Tx power and 2mbps ota datarate. A lot of the nrf24 fake chips don't even run at 250kbps.
    rmtuckerR 1 Reply Last reply
      Do mean the fake chips need to run at higher datarate?
        rmtuckerR
        rmtuckerR
        rmtucker
        Ye i just like all the settings at the beginning of my sketches etc,it reminds me if i have changed channel number etc.
          @gohan said in How do I get multiple different mock barometers?:
          All the fakes I've encountered can handle 1mbps and 2mbps.
            Not sure why, but by upgrading to 2mbps datarate from the previous default of just 250kbps, I'm able to reduce LONG_WAIT to 0 without incurring packet losses. Go figure.
              For the SHORT_WAIT, 10ms seems adequate on an nRF52832. Not sure where it hangs if the SHORT_WAIT is reduced too much lower than that though.
              gohanG 1 Reply Last reply
                @NeverDie my question was if thay handle higher speeds better than the lowest since you said "A lot of the nrf24 fake chips don't even run at 250kbps"
                  I'm not understanding your question.
                    What does it mean when the Domoticz log looks like this?
                    2017-08-11 08:11:20.670 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:24.053 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:24.068 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:27.454 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:27.470 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:30.870 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:30.887 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:34.245 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:34.260 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:37.650 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:37.666 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:41.036 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:41.051 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:44.375 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:44.391 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:47.800 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:47.816 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:51.185 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:51.200 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:54.583 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:54.599 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:11:58.005 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:11:58.021 MySensors: Node: 1, Sketch Version: v0.5
                    2017-08-11 08:12:01.384 MySensors: Node: 1, Sketch Name: MockMySensors
                    2017-08-11 08:12:01.401 MySensors: Node: 1, Sketch Version: v0.5
                    Plainly, it's caught in a loop of some kind and never receives the sensor values.
                      For some reason, downgrading from 2mbps back down to 250kbps solved the above problem.
                        Fortunately, 1mbps seems to work, even if 2mbps doesn't.
