  3. Controlling Blinds.com RF Dooya Motors with Arduino and Vera
90 Posts 29 Posters 112.5k Views 24 Watching
  • petewillP petewill
    @Rantlers Yeah, see if you can find what frequency that remote is communicating on. There must be some specs some where on the remote.
    RantlersR
    RantlersR
    Rantlers
    @petewill Checking back in, have good news & bad news...
    Bad News: No go on the 315mHz receivers. But that's because...
    Good News: I did some research on the remote since you said you didn't recognize it and was able to find the users manual online:
    http://www.automatedshadeinc.com/files/controls-hunterdouglas/powerplatinum_remote_guide_5110540054_0912.pdf
    According to this the RF signal is 2.4ghz (last page of the pdf). However, that being said, am I now SOL in replicating the RF sniffing step with your setup? The only 2.4ghz transceiver I was able to find is this one:
    http://www.amazon.com/Addicore-nRF24L01-Transceiver-Antistatic-Compatible/dp/B00E594ZX0/ref=sr_1_sc_1?s=pc&ie=UTF8&qid=1464286496&sr=1-1-spell&keywords=2.4ghz+transciever+arduino
    petewillP 1 Reply Last reply
    • RantlersR Rantlers
      petewillP
      petewillP
      petewill
      @Rantlers Dang! That's too bad. Are the blinds blinds.com brand or Hunter Douglas? I just want to make sure they didn't use a similar remote style but change the frequency.
      The NRF24 is what most of use for these projects so it might not be bad to order some to test. I'm not an expert on radio though so it may not be as easy to "sniff" the signal. I know @Yveaux has built a sniffer but that may only work for the MySensors network. Sorry I can't be more help!
        It will only work for nRF24L01+ chips. It isn't limited to MySensors.
        • J
          J
          jfeger
          Are you sure you have the economy shades? Ive noticed they have disappeared from Blinds.com, or at least I don't see them anymore.
          J 1 Reply Last reply
          • J jfeger
            J
            J
            jfeger
            I just confirmed with Blinds.com online chat that the economy blinds aren't available anymore, or at least for now. They stated there was a defect in the motors, so they had to pull the product and work on a redesign. No timeline on a release.
            • peashooterP
              peashooterP
              peashooter
              wrote on last edited by peashooter
              #63
              Thanks!!! this was such a great help in getting my dooya blinds from aliexpress working over network.
              I couldn't get the test code above to work and my sequence was 40 bits, so i modified the code quite a bit and made it much more efficient. Here is the code if anyone needs to test their code on arduino.
              //Define Variables
              #define SEND_DATA 4 //Data pin for RF Transmitter
              #define ZERO_HIGH 363 //Delay for the high part of a 0 in microseconds
              #define ZERO_LOW 726 //Delay for the low part of a 0 in microseconds
              #define ONE_HIGH 726 //Delay for the high part of a 1 in microseconds
              #define ONE_LOW 363 //Delay for the low part of a 1 in microseconds
              Serial.begin(9600);
              String code = "1100111101000001000111011011000100010001";  // Change your blinds code here
              Serial.println(code);
              Serial.println();
              for (int i=0; i <= 10; i++) {
                int delayTime;
                for(int k=0;k<40;k++) {                  //Change k max value here (40) is mine
                  char code1 = code.charAt(k);
                  int highTime;
                  int lowTime;
                  delayTime = ((int) code1) -48;        // 48 is zero in ASCII, so 48-48 = 0 as a number.
                      if (delayTime == 1){
                      highTime = ONE_HIGH;
                      lowTime = ONE_LOW;
                    else {
                      highTime = ZERO_HIGH;
                      lowTime = ZERO_LOW;
                      digitalWrite(SEND_DATA, HIGH);
                      delayMicroseconds(highTime);
                      digitalWrite(SEND_DATA, LOW);
                      delayMicroseconds(lowTime);
                Serial.println();
                Serial.print("Round:");
                Serial.print(i);
                Serial.println();
                delay(50);
              • かいとか
                かいとか
                かいと
                Please help me,
                My remote is dooya. And sniff code:
                10000011 01000010 01001001 11100001 00110011 pause
                10000011 01000010 01001001 11100001 01010101 up
                10000011 01000010 01001001 11100001 00111100 down
                I had use USB Saleae Analyzer sniff code.
                But not work, :(
                YveauxY petewillP 2 Replies Last reply
                • かいとか かいと
                  Please help me,
                  But not work, :(
                  @かいと please do not cross post. If people can help you they will respond. Be patient!
                  • かいとか かいと
                    Please help me,
                    But not work, :(
                    petewillP
                    petewillP
                    petewill
                    @かいと The pattern for the control may have changed...? Because you have a recording of the remote I would try to record what you are sending with your transmitter and compare the waveform of the two devices. They should be identical. That is how I ended up figuring out the exact timing needed for my motors.
                    • かいとか
                      かいとか
                      かいと
                      My remote alt text
                      • P
                        P
                        PeteKnight
                        Hi guys,
                        I realise that this is quite an old thread, but i found it a useful source of info when looking for a solution for my 433MHz problem, so I thought I'd share some of my findings...
                        We have a holiday home in Spain and it has some external 'awnings' that extend over the windows to provide shade from the sun. In Spain these are called Toldos. They operate using tubular motors controlled using 433MHz remote controls – one remote for each awning, three in total. I'd tried all the regular methods to sniff the 433MHz protocol, but none of the standard Arduino libraries would even acknowledge that the remote was sending out any sort of signal. Other remotes, such as garage door openers, PIR detectors etc work fine with my sniffer, so the hardware/software I was using is good.
                        I eventually resorted to using my sound card and Audacity software to capture the transmissions from the remote controls and this work surprisingly well (I'd tried every digital approach you can imagine up to this point, including a logic analyser, and was reluctant to try the analogue approach but wish I’d trued it earlier).
                        What I discovered is that when I press either the UP or the Down buttons on the remote, it transmits a timing pulse followed by 40 bits of data. At first I thought that this sequence was repeated 8 times, but I eventually realised that one 40-bit code was used for the first 4 repetitions of the data, followed by a different code for the next 4 repetitions. I later realised that whenever one of these buttons is pressed, the initial 40 bit code is transmitted continuously then the other code is transmitted 4 times when the button is released. When the button is pressed quickly I just get the 'Pressed' code 4 times followed by the 'Released' code 4 times.
                        The Stop button works slightly differently - only one code is used and this is transmitted at least 4 times and will continue to be transmitted as long as the button is pressed. (in other words, the Stop button has a 'Pressed' code, but not a 'Released' code).
                        It's actually the 'Pressed' code for each button that controls the awnings. The 'Released' code doesn't seem to serve any function with my awnings.
                        These 'Released' codes really confused me to begin with, as I when I checked two different bursts of data from the same button using Audacity, I was getting different results. This was obviously because on one occasion I’d picked one of the ‘Pressed’ codes to analyse, but on the second occasion I’d inadvertently analysed a ‘Released’ code. At first I’d thought the analogue capture process was unreliable, but then I thought that maybe some sort of rolling code system was being used. I eventually realised what was going on, but not until I'd spent quite a bit of time cursing the remote control and the PC.
                        I was able to replicate the transmitted code fairly accuracy using a version of @peashooter's code (thanks!) and this worked well
                        I’m repeating the ‘Pressed’ code 4 times and it seems to work very reliably.
                        As well as being able to control the awnings using an Arduino/ESP8266 transmitter, I also wanted to be able to use the existing handheld remotes, so to be able to understand the current position of each awning I needed a way of receiving the commands from the remotes and using them to keep track of each individual awning. This bought me back to the original problem of not being able to find a way to listen to the 433MHz messages from the remotes using any of the current Arduino libraries.
                        In started delving into the idea of modifying the RC-Switch library, now that I knew the timing characteristics of the signals. At that point I stumbled across this small library:
                        https://github.com/bjwelker/Raspi-Rollo
                        It has an Arduino sketch that is written to identify the codes that are being transmitted by remote controllers for blinds, so that these codes can then be used to control the blinds using a Raspberry Pi.
                        When I ran the Arduino sketch it immediately produced results from my Awning remotes – If only I’d found this earlier!
                        The results it gives are in a “Quad Bit” format, but when I modified the code to print out the raw received codes they were identical to the results I’d obtained from Audacity.
                        I’m not interested in using a Pi to transmit the codes to the blinds, and this wasn’t needed anyway, as using @peashooter's code I already had a transmission solution. I’m now in the process of fine-tuning the code that tracks each blind’s position based on the commands that are sent from either the hand-held remotes or my transmitter. The position is simply based on time between the start and stop transmissions and the known time that it takes to fully extend each awning.
                        The primary reason for wanting to control the awnings is that when it gets windy, I want to be able to automatically retract them. I’m using data from a weather station to monitor the wind speed and if it meets the criteria (very strong winds for a short period, or not quite so strong winds for a slightly longer period, then the awnings will be retracted (assuming that they’re extended of course). I’m also automatically retracting them when it gets dark, as it’s easy to forget to do this and a bit cumbersome to walk around and do all three awnings using the separate hand-held remote controls.
                        Here’s some pictures of one of the remotes:
                        The brand name on the remote is Gaviota and the circuit board says “Designed by D Team” “DC104/105” “V2.1” and “No.DA288”.
                        Here are what the awnings look like:
                        I have no idea what the brand name is on the tubular motors, as they’re hidden inside the mechanism.
                        Hopefully this saves someone at least some of the pain that I’ve been through to get to this point.
                        Pete.
                          I recently figured out how to control my Blinds.com motorized cellular shades (http://www.blinds.com/control/product/productID,97658) with my Vera 3. The blinds have Dooya DV24CE motors (which use a 433 MHz RF for remote control) built into them but I couldn't find any already built RF transmitter that integrated directly with the Vera. I had recently started building Arduino sensors with Henrik's amazing MySensors Arduino Sensor Plugin (http://www.mysensors.org) so I decided to try to build my own. Thanks to many helpful resources on the internet I was able to control my blinds for less than $20 in Arduino parts.
                          Here is a link to a YouTube video with an overview of the process: http://youtu.be/EorIqw-9eJw
                          Here is a pdf with more info on the process if you are interested in doing it yourself:
                          Controlling Blinds.com RF Dooya Motors with Arduino and Vera.pdf
                          Arduino Code MySensors Version 2.x:
                          https://gist.github.com/petewill/ac31b186291743e046f83497de0ffa87
                          And the Arduino Code (OLD CODE):
                          BlindsVera.ino
                          2020-12-06: Edited to add updated code
                          MortenVinding
                          @petewill
                          Great guide.
                          I stumbled upon this when I realised that my Debel awning was using a Dooya motor and remote.
                          I did not use your cool system with the soundcard to sniff the RF codes, but instead used my RTL-SDR usb receiver, since I already had it laying around 😀
                          After finding the codes I programmed an Arduino with it and connected it to my OpenHAB installation. Now the awning can be controlled with the OpenHAB app, and my wife just loves it 😀
                          Just wanted to point it out for others looking for RF codes for Debel awnings.
                          • M MortenVinding
                            @petewill
                            Great guide.
                            petewillP
                            petewillP
                            petewill
                            @mortenvinding cool! I looked at a couple of code "sniffers" when I did this but none of them worked. Good to hear progress has been made on that. Should save quite a bit of time.
                            • ssuckowS
                              ssuckowS
                              ssuckow
                              I recognize this is an old post, but I've not found any newer discussion and I have hit a roadblock. I've followed all of the very helpful posts to build a sniffer and decode it as tools like RCSwitch wouldn't work. I even used @PeteKnight 's tip to notice there was a different code sent initially when a button was pressed. I've tried sending both versions, emulating the initial (timing?) signal at the start. I tweaked the high and low delays and I think I've got a rf signal that is extremely close to the one from the remote. Here are the two different sources in audacity for comparison.
                              ![0_1598212142451_RemoteInAudacity.JPG](Uploading 100%)
                              //Define Variables
                              #define GND 3
                              #define VCC 4
                              #define DATA 5 //Data pin for RF Transmitter
                              #define ZERO_HIGH 307 //Delay for the high part of a 0 in microseconds
                              #define ZERO_LOW 750 //Delay for the low part of a 0 in microseconds
                              #define ONE_HIGH 648 //Delay for the high part of a 1 in microseconds
                              #define ONE_LOW 409 //Delay for the low part of a 1 in microseconds
                              int startUp = 1;
                              unsigned char standardBits1 = 0b00001111; //integer value of the 28 bit standard sequence referenced above. "0b" prefix is for *******
                              unsigned char standardBits2 = 0b01111100;
                              unsigned char standardBits3 = 0b01100100;
                              unsigned char standardBits4 = 0b00000001;
                              unsigned char standardBits5 = 0b00011110;
                                pinMode(GND,OUTPUT);
                                pinMode(VCC,OUTPUT);
                                pinMode(DATA,INPUT);
                                digitalWrite(GND,LOW);
                                digitalWrite(VCC,HIGH);
                                 Serial.begin(9600);
                               unsigned char i;
                                    delay(3000);
                                  if(startUp ==1){
                                  for(i=0;i<10;i++) {
                                    delay(1000);
                                    digitalWrite(DATA, HIGH);
                                    delayMicroseconds(5000);
                                    digitalWrite(DATA, LOW);
                                    delayMicroseconds(1500);
                                    eightBits(standardBits1);
                                    eightBits(standardBits2);
                                    eightBits(standardBits3);
                                    eightBits(standardBits4);
                                    eightBits(standardBits5);
                                    startUp = 0;
                                    void eightBits(unsigned char bits){
                                        unsigned char k;
                                        int delayTime;
                                        for(k=0;k<8;k++) {
                                          int highTime;
                                          int lowTime;
                                          delayTime = ((bits>>(7-k)) & 1 ? 1 : 0);
                                            lowTime = ONE_LOW;
                                          else {
                                            lowTime = ZERO_LOW;
                              Here are all the codes I was able to extract from audacity for one of the blinds.
                              Down1: 00001111 01111100 01100100 00000001 00111100
                              Up1: 00001111 01111100 01100100 00000001 00011110
                              Stop1: 00001111 01111100 01100100 00000001 01010101
                              Start1: 00001111 01111100 01100100 00000001 00010001
                              Does anyone have an idea of what I might still be missing in getting this work?
                              petewillP D 2 Replies Last reply
                              • ssuckowS ssuckow
                                //Define Variables
                                #define GND 3
                                #define VCC 4
                                int startUp = 1;
                                   Serial.begin(9600);
                                 unsigned char i;
                                      delay(3000);
                                    if(startUp ==1){
                                    for(i=0;i<10;i++) {
                                      delay(1000);
                                      startUp = 0;
                                          unsigned char k;
                                          int delayTime;
                                          for(k=0;k<8;k++) {
                                            int highTime;
                                            int lowTime;
                                              lowTime = ONE_LOW;
                                            else {
                                              lowTime = ZERO_LOW;
                                petewillP
                                petewillP
                                petewill
                                @ssuckow I can't see the image but when I did this I started in small steps. Your first goal is to send a successful signal without all the MySensors code. I just created a standalone program with all my code in the setup so when it ran it would send a raise, stop or lower signal. Once you do that you can integrate it with MySensors much easier. It sounds like you have mostly done this based on your description above but I'm not sure. Also, are you sure the hardware is wired correctly? Is the 433Mhz device is getting enough power to send the signal to the blinds?
                                ssuckowS 1 Reply Last reply
                                • ssuckowS ssuckow
                                  //Define Variables
                                  #define GND 3
                                  #define VCC 4
                                  int startUp = 1;
                                     Serial.begin(9600);
                                   unsigned char i;
                                        delay(3000);
                                      if(startUp ==1){
                                      for(i=0;i<10;i++) {
                                        delay(1000);
                                        startUp = 0;
                                            unsigned char k;
                                            int delayTime;
                                            for(k=0;k<8;k++) {
                                              int highTime;
                                              int lowTime;
                                                lowTime = ONE_LOW;
                                              else {
                                                lowTime = ZERO_LOW;
                                  doteq
                                  @ssuckow said in Controlling Blinds.com RF Dooya Motors with Arduino and Vera:
                                  Why data pin is input? I think it should be output.
                                    ssuckowS
                                    ssuckowS
                                    ssuckow
                                    @petewill Sorry, it seems I had to use the .jpeg extension instead of .jpg. My code is just trying to move the blinds without any extra code. This image shows the remote signal on the top and the Arduino generated signal on the bottom.
                                    • D doteq
                                      ssuckowS
                                      ssuckowS
                                      ssuckow
                                      @doteq You are correct. That was a holdover from when I was trying to sniff. I tweaked that and this image shows the updated version as Arduino7. Apparently it worked with it defined as input (as receiver connected to audacity was picking it up), but their was a lot more noise. Now, the signal looks very much like the source remote. However, It still doesn't move the blinds. :disappointed:
                                      • electrikE
                                        electrikE
                                        electrik
                                        From the code it looks like you're switching on the receiver by enabling the gnd and vcc pins with an output of the microcontroller. Do you have additional transistors to do so, or just with the output pins directly? In the last case I would recommend to connect it to gnd and vcc directly, to make sure enough current is available.
                                        • ssuckowS
                                          ssuckowS
                                          ssuckow
                                          I just tried moving it to the VCC and ground pins and it didn't work either.
