  3. Problem to program pro mini
11 Posts 4 Posters 4.2k Views 4 Watching
    Have you tried latest ide and boards definitions?
    • Nca78N
      it looks like a serial communication problem to me, are you sure you have no problem with the DTR connexion ?
      While the sketch compile, press the reset button on the pro mini, and just when it says it's starting to transfer, release it. If it works like that it means the DTR signal is wrong and not doing a reset on your board. But cable/jumper, adapter or arduino board problem, I don't know.
      Make sure also you have selected the right voltage on the USB to TTL adapter, if it's on 3.3V the atmega will not run.
        MagnusF
        I have updated ide to 1.8.3 but the result is the same. Find no way to update boards difinations.
        I missed one row in the error message which I think is important:
        "avrdude: stk500_recv(): programmer is not responding"
          maybe bad FTDI adapter?
          • sundberg84S
            sundberg84S
            Or a bad bootloader?
              MagnusF
              The problem is partially resolved, the first Pro mini is wrong in any way.
              Tried another Pro mini and it worked.
              Before I switched the minis, I searched the Arduino forum and found this topic on how to test a serial adapter and according to this test the FTDI adapter was ok.
              https://forum.arduino.cc/index.php?topic=73748.0
              After switching to Ide 1.8.3 and even when I switch back to 1.8.0 and I choose sketch, include library, manage library I get the following error message:
              Index error: could not find referenced tool name=gcc-arm-none-eabi version=5_2-2015q4 packager=sandeepmistry
              Index error: could not find referenced tool name=openocd version=0.10.0-dev.nrf5 packager=sandeepmistry
              Is there something to care about?
              • Nca78N
                You're trying to program using the wrong programmer maybe ?
                Select back Avr ISP mk2
                  MagnusF
                  I have programmed 3 more boards with the first settings and it worked well.
                  What I understood, only the choice of programmers is used when burning bootloaders, is this correct?
                  • sundberg84S sundberg84
                    MagnusF
                    @sundberg84
                    I read in another topic your reference to https://www.arduino.cc/en/Tutorial/ArduinoISP on how to burn a bootloader.
                    Is this an opportunity to get the wrong card to work?
                    Do you know if the capacitor mentioned in the reference is needed for a Pro Mini?
                    • M MagnusF
                      @sundberg84
                      sundberg84S
                      sundberg84S
                      @MagnusF - if the error is a bad bootloader, but that is rarely the case... I have seen that once. It will not hurt though to re-upload the bootloader if you suspect thats the problem.
