  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.7k Views 73 Watching
  • tekkaT tekka
    @romeo01 Thanks for reporting, this is a known issue with build 3314 and lib 2.2.0: The msg parser requires some changes - build 3316 is in preparation (also supporting new 2.2.0 features).
    V
    V
    vikasjee
    @tekka hi, can we access the previous build if that is working for MySensors2.1.1?
    tekkaT 1 Reply Last reply
    • siodS siod
      Hi, I am trying your software but I only get "connection refused" though in the status bar it says Connected... what can I do?
      tekkaT
      tekkaT
      tekka
      @siod Seems like something is wrong with your GW - either GW is not working or too many connections.
      • V vikasjee
        tekkaT
        tekkaT
        tekka
        @vikasjee What build are you looking for?
        V 1 Reply Last reply
        • tekkaT tekka
          V
          V
          vikasjee
          @tekka , I upgraded Arduino IDE from 1.6.0 to 1.8.2 recently. Burnt the gateway with the MySensors2.1.1 gateway sketch and the nodes bootloader with MysBootloader1.3.0beta3 from the master branch on github.
          As per my understanding the Node with MysBootloader should connect to the Gateway (checked with MysController 1.0beta b3314) where i can specify the Firmware for this new node. But i am not able to get the Node entry in the left hand side tree in MysController. Upon checking the MysController Debug, there are a stream of messages from the node but are being endlessly repeated:
          6/12/2017 19:24:59	RX	0;255;3;0;9;TSF:CKU:OK,FCTRL
          6/12/2017 19:24:59	RX	0;255;3;0;9;TSF:MSG:GWL OK
          6/12/2017 19:25:01	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=1,l=1,sg=0:235
          6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:BC
          6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
          6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:CKU:OK,FCTRL
          6/12/2017 19:25:06	RX	0;255;3;0;9;TSF:MSG:GWL OK
          6/12/2017 19:25:08	RX	0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=1,l=1,sg=0:235
          6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:BC
          6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
          6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:CKU:OK,FCTRL
          6/12/2017 19:25:09	RX	0;255;3;0;9;TSF:MSG:GWL OK
          I am unable to get to the root of the problem... and could not find any mention of a similar problem on this forum (searched far and wide :) )
          Any pointers to a solution or hint of what may be wrong will definitely help me save time...
          • V
            V
            vikasjee
            @tekka , there seems to be an issue with the build 3314 and MYSBootloader for MySensors 2.1.1,as noted above. Any good, working previous version should do...
            • V
              V
              vikasjee
              wrote on last edited by vikasjee
              #451
              @tekka please help with the MysController build 3312 if that one works with MYSBootloader for MySensors 2.1.1 master.
              • V vikasjee
                tekkaT
                tekkaT
                tekka
                @vikasjee Apologies for the late reply. This issue is not related to MYSController:
                The debug log hints to some issues with the radio (range, connection) and/or power supply (node does not receive the find_parent_response message), please double-check the wiring, power supply (appropriate caps on both, GW and node), change the distance between GW and node, or try with different radio modules.
                • tekkaT tekka
                  V
                  V
                  vikasjee
                  @tekka No Issues. Thanks for the response.
                  I have tried all of these with all my 35 radios (were all working before the upgrade) and equal number of nodes! :(
                  I will go through all this sequence once again though... Thanks for clearing the doubts on MYSController build. Indebted!
                    swiss
                    Newbie can't make it happen...
                    I've been struggling for the last couple of days, trying to make the mysensors world to fly. But unfortunately i have no success so i will try to post one of my many trials, would be very glad if you could let me know what i'm missing...
                    Hardware:
                    • Aurduino Mini Pro
                    • W5100 ETH interface
                    • long-distance NRF24L01 (Gateway)
                    • NRF24L01+ 2.4GHz Antenna Wireless Transceiver Module (Sensor)
                    Software:
                    • https://github.com/mysensors/MySensors/blob/master/examples/GatewayW5100/GatewayW5100.ino (Gateway)
                    • https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/BinarySwitchSensor/BinarySwitchSensor.ino (Sensor)
                    All i did was to load both sketch to the according mini.
                    Of course changing the IP of the gateway.
                    I can ping the gateway using Windows terminal, but i can't access the gateway using the MYSController. As soon i try to dicover any node the connection is terminated by the remot side (entry in the debug window of MYSCtrl)
                    If i did understand it correct i do not have to load the Bootloader as of now (as long i do not need OTA)
                    Any help would be highly appriciated,
                    matt
                    • S swiss
                      Hardware:
                      • Aurduino Mini Pro
                      Software:
                      matt
                      Welcome to the MySensors community @swiss :-)
                      What does the debug output from the gateway say?
                      How is the gateway powered?
                      If you haven't already, take a look at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to fix them.
                      S 1 Reply Last reply
                        swiss
                        @mfalkvidd
                        wow that was quick :-)
                        The gateway is powered thru a breadboard 3.3V psu.
                        Here is teh log dump of the gateway:
                        0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        Thank you so much!
                        • S swiss
                          @mfalkvidd
                          Thank you so much!
                          #457
                          @swiss could you post the entire log?
                          EDIT: How much current can the breadboard psu provide? Which capacitor(s) are you using?
                          • mfalkviddM
                            and yes, you are correct that bootloader is only needed for FOTA.
                              swiss
                              @mfalkvidd
                              0;255;3;0;9;TSM:INIT
                              0;255;3;0;9;TSF:WUR:MS=0
                              0;255;3;0;9;TSM:INIT:TSP OK
                              0;255;3;0;9;TSM:INIT:GW MODE
                              IP: 192.168.8.155
                              0;255;3;0;9;MCO:BGN:STP
                              0;255;3;0;9;TSF:PNG:SEND,TO=0
                              • S swiss
                                @mfalkvidd
                                IP: 192.168.8.155
                                @swiss nothing at all happens after TSF:MSG:BC ?
                                  swiss
                                  its repeating
                                    swiss
                                    @mfalkvidd
                                    the psu provides 350 mA
                                    • S swiss
                                      its repeating
                                      ok. So from the log parser we see that the gateway sends a response to the id request, but the node keeps requesting a new id anyway.
                                      Could you post the log from the node?
                                      • S swiss
                                        @mfalkvidd
                                        @swiss which capacitor(s) do you use? The nrf radio is extremely sensitive to power fluctuations.
                                          swiss
                                          @mfalkvidd
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          12 TSM:INIT:TSP OK
                                          14 TSM:FPAR
                                          16 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2025 !TSM:FPAR:NO REPLY
                                          2027 TSM:FPAR
                                          2029 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          4038 !TSM:FPAR:NO REPLY
                                          4040 TSM:FPAR
                                          4042 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          6051 !TSM:FPAR:NO REPLY
                                          6053 TSM:FPAR
                                          6055 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          8065 !TSM:FPAR:FAIL
                                          8067 TSM:FAIL:CNT=1
                                          8069 TSM:FAIL:PDT
                                          18073 TSM:FAIL:RE-INIT
                                          18075 TSM:INIT
                                          18081 TSM:INIT:TSP OK
                                          18085 TSM:FPAR
                                          18087 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          20097 !TSM:FPAR:NO REPLY
                                          20099 TSM:FPAR
                                          20101 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          22110 !TSM:FPAR:NO REPLY
                                          22112 TSM:FPAR
                                          22114 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          24123 !TSM:FPAR:NO REPLY
                                          24125 TSM:FPAR
                                          24127 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          26136 !TSM:FPAR:FAIL
                                          26138 TSM:FAIL:CNT=2
                                          26140 TSM:FAIL:PDT
                                          36143 TSM:FAIL:RE-INIT
                                          36145 TSM:INIT
                                          36151 TSM:INIT:TSP OK
                                          36155 TSM:FPAR
                                          36157 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          38166 !TSM:FPAR:NO REPLY
                                          38168 TSM:FPAR
                                          38170 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          40179 !TSM:FPAR:NO REPLY
                                          40181 TSM:FPAR
                                          40183 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          42194 !TSM:FPAR:NO REPLY
                                          42196 TSM:FPAR
                                          42199 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          44208 !TSM:FPAR:FAIL
                                          44210 TSM:FAIL:CNT=3
                                          44212 TSM:FAIL:PDT
                                          54216 TSM:FAIL:RE-INIT
                                          54218 TSM:INIT
                                          54224 TSM:INIT:TSP OK
                                          54228 TSM:FPAR
                                          54231 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          56240 !TSM:FPAR:NO REPLY
                                          56242 TSM:FPAR
                                          56244 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          58253 !TSM:FPAR:NO REPLY
                                          58255 TSM:FPAR
                                          58257 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          60266 !TSM:FPAR:NO REPLY
                                          60268 TSM:FPAR
                                          60270 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          62279 !TSM:FPAR:FAIL
                                          62281 TSM:FAIL:CNT=4
                                          62283 TSM:FAIL:PDT
                                          72286 TSM:FAIL:RE-INIT
                                          72288 TSM:INIT
                                          72294 TSM:INIT:TSP OK
                                          72298 TSM:FPAR
                                          72300 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          74309 !TSM:FPAR:NO REPLY
                                          74311 TSM:FPAR
                                          74313 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          76322 !TSM:FPAR:NO REPLY
                                          76324 TSM:FPAR
                                          76326 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          78336 !TSM:FPAR:NO REPLY
                                          78338 TSM:FPAR
                                          78340 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          80349 !TSM:FPAR:FAIL
                                          80351 TSM:FAIL:CNT=5
                                          80353 TSM:FAIL:PDT
                                          at the moment i have no capacitors in place since i thought the communication was ok...
