  3. Sensor Node V2.0
Sensor Node V2.0
23 Posts 9 Posters 15.0k Views 6 Watching
  • axillentA
    axillentA
    axillent
    We are going to have a set of Mysensors PCB for different purposes. The first one will be powered from a single AAA alkaline battery and will also have MCP9700 on board
    Regardless DevDuino it will have radio on board and will have some more benefits
    It is a good time now before the production to change something. There is no problem to install a precise and low power I2C temperature sensor on board.
    But are you ready to pay $1-1.5 more for the board to get ± 0.5 ° C precision instead of ± 2 ° C?
    sense and drive
    jendrushJ clippermiamiC 2 Replies Last reply
    • axillentA axillent
      jendrushJ
      jendrushJ
      jendrush
      @axillent I am ready to pay more for better precision. I'm assuming that ± 2 ° C is max accuracy error. So i am wondering what is typical accuracy.
      • hariH
        hariH
        hari
        I'd prefer the hi-res sensor
        • axillentA
          axillentA
          axillent
          OK, thanks for the feedback
          are you talking about default etc. embedded sensor?
          you will also have custom connectors to connect any kind of sensor
          what else in your view should be the default option for MySensors.Battery?
          sense and drive
          jendrushJ 1 Reply Last reply
            jendrushJ
            jendrushJ
            jendrush
            @axillent I think that default sensor should be with good precision. In my case i would buy aprox 15 devices like this, and use this over a long period of time(at least few years) so ~20 usd difference in price isn't big. Maybe is worth to think about installing temp and humidity sensor(maybe antother model of device). How do you think - how long it could work on single battery when i need to read temp with 1 or 10 minutes period?
            • axillentA
              axillentA
              axillent
              software side is of the sensor is as important for the long run as a hardware side
              In my assumption if all will be done correctly the average current sourced from the battery will be about 200mkA
              this is in assumption of using one sensor for measurement each 1 minute and sending radio for each measurement
              for 1A * H battery (should be common for alkaline AAA) it is about 5000 hours or 208 days.
              discounting this we should have stable 6 months run time
              but only real practice will give us real figures. We plan to have a test run as soon as prototypes will be ready.
              also this board is have an optional solar power as a second power
              with solar power attached battery life can be increased by 30-50%
              sense and drive
                jendrushJ
                jendrushJ
                jendrush
                @axillent I've noticed solar power pins:) This would be great for outdoor sensors. I think that when suitable solar panel will be used our sensor could work almost without changing battery. Ofcourse until battery really need to be replaced because of phisical damage.
                • F
                  F
                  filiphag
                  @axillent
                  What chip are you using as step-up from the singel cell battery source.
                  Looks like The pcb antenna of The nrf module is located in The midle of the pcb. Have you tried out The RF range in that placement?
                  • D
                    Dennis van Velzen
                    Nice PCB design...
                    Suggested boards:
                    • 4 PWM logic FETs (dimming RGB W LED strips, 12V lights) Some FETs are easily capable of doing 8 amps and have almost no excess heat.
                    • 230V AC triac dimmer module (200w that fits in a EU wall box) EU net frequency.
                    • 0-10V input module (that fits behind a 0-10V dimmer in a wall box. Round max 60mm, thick approx. 15mm) power from 230VAC line.
                    • 0-10V output module.
                    • 1..4 channel opto input 3-250v module.
                    • 1..2 channel solid state relay module.
                    Can add nice usable parts, example schema's later... main goal good/better cheap(er) open source products!
                    • T
                      Tommy Sharp
                      Being able to buy something like this that is "all in one" will be great for us newbies! A more accurate temperature sensor would be ideal and worth the extra dollar!
                      axillentA 1 Reply Last reply
                      • T Tommy Sharp
                        axillentA
                        axillentA
                        axillent
                        @Tommy-Sharp "all in one" is one of our goal while working on the project boards
                        Thanks all for ideas. We plan to have several project specific boards.
                        First one will be the battery operated board designed for wireless sensors.
                        Bellow is updated picture, should look better now.
                        Sensor will be the digital one with precision 0.5C or better and very low power consumption
                        Should we seriously support 5V from battery? For many applications 3.3V are sufficient and it will consume much less power from the battery.
                        Relays, dimmers, SSRs will be managed by another board.
                        sense and drive
                          clippermiamiC
                          clippermiamiC
                          clippermiami
                          @axillent How is this project coming along? Looking forward to a standardized PCB version.
                          • clippermiamiC clippermiami
                            axillentA
                            axillentA
                            axillent
                            @clippermiami we are currently in discussion with possible partners, we discussing production of the PCB and assembled PCB
                            in parallel I'm doing a prototyping of the battery operated board
                            Battery operated board will came first, later we plan to release a set of stackable boards ready be used for switching, dimming and integration behind a wall switch
                            sense and drive
                            clippermiamiC BulldogLowellB 2 Replies Last reply
                              clippermiamiC
                              clippermiamiC
                              clippermiami
                              @axillent LOOKING forward to it, a nice PCB makes a good clean project.
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                North American wall switch?:ballot_box_with_check:
                                  axillentA
                                  axillentA
                                  axillent
                                  @BulldogLowell from electrical side it is a clear plan to be universal between 110/220V 60/50Hz etc. to support both US and EU standard
                                  from the form factor point of view I have a view to EU standard but not US.. Hopefully we can be universal too but I will need your input on this.
                                  Even I'm not sure what is "North American" stands for :) is it common for US only or for Canada too?
                                  While for battery board the design is almost 95% clear the wall board is still under discussion.
                                  Most likely it will be stackable form factor with universal MCU -board and many different power&switch&dimm sub-boards
                                  All feel free to provide your inputs, to share ideas or wishes.
                                  sense and drive
                                  clippermiamiC 1 Reply Last reply
                                    clippermiamiC
                                    clippermiamiC
                                    clippermiami
                                    @axillent North American standard is common to both US and Canada.
                                      axillentA
                                      axillentA
                                      axillent
                                      @clippermiami what can be the maximum acceptable form factor?
                                      sense and drive
                                        clippermiamiC
                                        clippermiamiC
                                        clippermiami
                                        @axillent From my recent experience the Jasco/GE switches are about the biggest thing you can got in a North American wall box and even that can be a challenge. Depending on the number of circuits that come into the box and the number of connections (wire nuts, or whatever you use for the connections) can create quite a bit of congestion in the box. It can sometimes be a challenge to fit even the Jasco switch :-)
                                          Malx
                                          Basic sensors that you are using for logging and alarm are ok. However, when starting with power/switch/dimm, then security starting to be a big issue. (Also when using the sensors to control something)
                                          I hope this boards will be sold with a big warning on that point.
                                          (I'm not negative to mysensors and using those myself, why would I else be here :). I'm just not a fan of people seeing this as a complete HA solution)
