  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 106.0k Views 40 Watching
    @RAD-X both will work in the stable branch. See https://github.com/mysensors/MySensors/blob/28c4f3f19e7026f56fd9bbc61d566f770fd7a9d2/MyConfig.h#L935
    R
    R
    RAD-X
    @mfalkvidd
    Hmm.... Is not that a reference to the development branch? :-)
    I think that right content for stable branch is: https://github.com/mysensors/MySensors/blob/master/MyConfig.h
    If you don´t believe it, try to download a stable branch, unpack and search for string "MY_RFM69_CS_PIN".
    • R RAD-X
      @mfalkvidd
      #93
      @RAD-X yes, you are correct. Thanks for noticing.
      I thought that if I selected the master branch on github and used the search function, the search results would only show hits from the selected branch. But it seems like this is not the case.
      Linking to a specific line in a file doesn't work very well, because that line might move by later commits. That's why I select a specific commit to link to. But as you point out, my link points to a commit in the development branch.
      The correct link is https://github.com/mysensors/MySensors/blob/8bb3cfb2e14214ae19e8531c989d1e81c9660614/MyConfig.h#L663 and there is indeed no support for MY_RFM69_CS_PIN.
      I'll update the documentation again. The documentation is meant to reflect the current stable branch.
      EDIT: Found this in the Github documentation:
      Only the default branch is considered.
      So there is no way to search in the stable branch.
        manutremo
        I have one question regarding the length of the 868MHz antenna. According to the theory, a the wavelength of a 868Mhz signal is 300/868 = 34.6 mm, so a quarter wave antenna should be 8.6mm long. The table above indicates 8.2mm. May someone confirm the correct figure, and also indicate how critical is that difference in terms of range?
        mfalkviddM G 2 Replies Last reply
        • M manutremo
          @manutremo the speed of electromagnetic waves is slower in metal than in vacuum, that's why the length is shorter.
          My experience is that the length doesn't need to be exact, but antenna theory is way too complicated for me to understand the details.
            manutremo
            Many thanks @mfalkvidd . That explains it.
            While waiting for an answer I also found some sites which mention that the speed of electromagnetic waves is even slower if the conductor has an isolation layer around, which would further justify the difference.
            Many thanks! :+1:
            • M manutremo
              Many thanks! :+1:
              @manutremo I think that part is due to skin effect.
                manutremo
                @mfalkvidd Many thanks again... I learn new things every day.
                • M manutremo
                  G
                  G
                  gvorster
                  wrote on last edited by gvorster
                  #99
                  @manutremo said in 💬 Connecting the Radio:
                  I tried 3 types of antennas with RFM69HCW 868mhz.
                  1. Just a 8.6 cm wire
                  2. helical antenna
                  1. sma antenna
                  Indoor in my appartement (one floor) it doesn't matter which one I use. All is working fine.
                  I tried 2 nodes in my metal mailbox 10 meters below which has 2 tiny holes.
                  One with helical antenna, one with sma antenna.
                  Gateway (using sma antenna) receives no data.
                  Testing two repeater nodes (1 helical, 1 sma antenna) near a window I receive data via both repeaters. Sometimes the repeater with sma antenna is not relaying messages for the node with the sma antenna.
                  In my situation, the helical antenna works better for me. I just buy them on ebay.
                    Maybe the sma antenna is for the wrong frequency and it's giving poor results.
                    • K
                      K
                      krisha
                      There is a mini module of the NRF 24L01+. Unfortunately some pinouts on the web were not correct. Not sure if many people use that, but here is a pinout that worked for me: http://s2.electrodragon.com/wp-content/uploads/2014/12/NRF24-Mini-02.jpg
                      • manulM
                        manulM
                        manul
                        Hi Team,
                        First of all, thank you for your amazing work! It does help a lot to sea a dream become true :)
                        I was wondering, it seems that I can't receive messages from NRF24 radio while arduino node is sleeping... I've read several testimonies in this way as well on forums. I did connect the IRQ of the transceiver to the PIN 2 of my arduino, and took this as event for exiting sleep mode, but it seems not to work.
                        Is there anything in the roadmap regarding this? It could be really amazing to be able to sleep the battery-powered arduino, and wake it up as soon a message is received by the radio.
                        Or maybe there is something I did not correctly. Is there a feature for this?
                        • manulM manul
                          Hi Team,
                          #103
                          @manul it would indeed be amazing, but the radios consume so much power when listening that it is no use to sleep the mcu.
                          The smartsleep feature is the best alternative so far. documentation: https://www.mysensors.org/download/sensor_api_20#sleeping
                          • R
                            R
                            ricorico94
                            wrote on last edited by ricorico94
                            #104
                            I'm interested in using long range sensors based on LoRa and I saw on this forum that LORA radios should be supported with the RFM95. But I did not see any explanation or advice on hardware, pins, etc.
                            Could anyone confirm that the type of radio to attach on the gateway and the sensor is like:
                            link to aliexpress RFM95 radio
                            I see the chip mentioned is "RF96", but I did not see that name on the forum..(it was SX1276 I think), so I don't know.
                            Regarding frequency, I uderstood from other websites that in France, the frequency should be 868MHz, correct ? No risk to interfere with EnOcean/Zwave devices ?
                            I see also that these RFM95 radios have many more pins than the NRF24L01 : should I use the same pins than for NRF24 and leave the others unused ?
                            and then in the sketch, use the #define RFM95 statement ? Is it all that simple ?
                            And then I install the RFM95 as a second MySensors gateway on my network (for instance as an ethernet gateway) ?
                            br,
                            Ricorico94
                            • P
                              P
                              peerv
                              Hi ricorico94,
                              If you are interested in LoRa and how to connect the radio have a look at www.thethingsnetwork.org
                                MattiMan
                                Hello!
                                I would like to use NRF24+PA radio, but when I try to use it instead normal NRF24 radio in MQTT-gateway it just dont work. I cant make connection between sensors and gateway.
                                Normal radio works just fine, but the range is a bit short for me.
                                I tried the low power setting also, but no help.
                                What should I do to make it work?
                                I use Domoticz as my controller.
                                • M MattiMan
                                  Hello!
                                  Welcome to the MySensors community @mattiman !
                                  Could you post the debug logs of the node and the gateway? That's usually the quickest way to get a hint on what is wrong.
                                  If you haven't already, you can also look at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ which has recommendations on the most common problems and how to troubleshoot them.
                                  People have also been helped by this: http://blog.blackoise.de/2016/02/fixing-your-cheap-nrf24l01-palna-module/
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    Hi
                                    I use Arduino Pro Mini 5V and i want user radio RFM69HW. I must use logic level converter from 5V to 3.3V to connect radio or i can only reduce power from 5V to 3.3V to VCC ?
                                    On this page is nothing describe that i must use logic level converter,...but some users on this page write that i must use:
                                    https://www.openhardware.io/view/268/RFM69HW-interstitial-board-for-Arduino-Pro-Mini#tabs-comments
                                    Now i have connected only with reduce power to 3.3V but my Arduino not working still time. Only some minutes to test...
                                      It was already answered to you in another topic and if you read in the openhardware project it is clearly stated that it is meant for pro mini 3.3v. If you connected it to a 5v pro mini you most likely fried the RFM69 module.
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        wrote on last edited by pepson
                                        #110
                                        I connect to 5V Arduino but i use AMS1117 to step down power 5v to 3.3V and radio still working.
                                        • pepsonP pepson
                                          manutremo
                                          I have two of my nodes using rfm69hw and mini pro 5v 17mhz. I only step down the power line to 3.3v, the comms lines work just fine with 5v. I also remember reading somewhere that this is actually the case, even though the datasheet says the opposite.
