  3. nRF5 action!
nRF5 action!
    Comparing Figures 169 and 170 in the nRF52832 datasheet, it looks as though simply adding two inductors in series between DCC and DEC4 should be all that's needed to provide the needed hardware support for DC/DC. Looks as though the 10uH inductor also needs to be able to support a minimum of 50ma, according to the BOM (Table 145).
    So, is it as simple as that together with enabling register DCDCEN? Or, is there anything more to it?
      Yes. This is like that. I use 2 inductors (better) in serie. Why more complicated ;)
        Actually, even just sleeping the MCU with a simple command like:
        sleep(100);
        is apparently enough to require a re-init of the radio afterward. Not sure why that would be.
        d00616D
        d00616D
        d00616
        sleep(100);
        sleep() deinitializes the transport with transportDisable(). This results in power down the radio.
        At the moment I review the ESB code. I think the nRF5 is 12-13µs after an nRF24 in RX mode and 432µs before an nRF24 in TX. This can result in unstable connections when debug messages are disabled.
          #792
          Sort-of working. Here's a screen shot with the DC/DC modification. Compare to the earlier one above:
          Probably non-optimal placement of the inductors: between the DCC and DEC4 pins on my breakout board for the nRF52832.
          This is reason enough to do an new version of the breakout for the Ebyte module to improve the inductor positioning.
          Here's the enable code:
          If it's this easy, I'm just surprised that the module makers haven't included it. The difference in build cost is de minimus, but the difference in delivered value is huge.
          Also, it sounds like I'll have to write a variant of sleep that sleeps just the MPU while leaving the radio in receive mode. That's an easy win to improve the current consumption.
            #793
            Good news! I went back and re-rechecked using an un-modified Ebyte module, and, indeed, this time I'm sure that the DCDC inductors are already on it! What follows is the proof. Here is the current drawn when the above DCDCEN is enabled on an unmodified Ebyte module:
            Now, here is the current drawn with the exact same script on the exact same unmodified Ebyte module, but with the DCDCEN line of code commented out:
            QED.
            As you can see, the savings in current consumption are considerable with the DCDC enabled!
            [Edit: although looking at it again, the timescale seems way off. Argh. Something still isn't right.]
              Scratch the preceeding post. I redid it more carefully this time, and I believe it confirms that the Ebyte module does not have the two inductors required for DC/DC mode.
              Here is the current drawn by an unmodified Ebyte nRF52832 module which is programmed to be receiving for about 1.5ms every 100ms:
                #795
                Here is what happens with exactly the same hardware (no inductors yet added), but with DCDCEN enabled:
                It basically seems caught in a boot loop.
                  #796
                  Now, adding the two inductors between DCC and DEC4, and re-measuring, we get:
                  No less importantly, it does receive and decode packets!
                  Conclusion: Ebyte nRF52832 modules don't come with the DC/DC inductors already installed. However, they can be added, resulting in some current reduction.
                    #797
                    I've baked these findings into a new breakout board for the Ebyte nRF52832:
                    https://www.openhardware.io/view/471
                    The new breakout board will enable the module to work in DC/DC mode.
                      #798
                      I may have found a clue as to why the reset pin (pin0.21) on the nRF52832 isn't working.
                      On the nRF52832 DK, I read the following register values:
                      PSELRESET[0]=21
                      PSELRESET[1]=21
                      which is as expected. However, on the Ebyte nRF52832 module, I read those register values as:
                      PSELRESET[0]=4294967295
                      PSELRESET[1]=4294967295
                      which makes no sense. The values match, but they don't correspond to a pin number that can represent RESET.
                      These two registers are described in the nRF52832 datasheet.
                        PSELRESET[0]=21
                        PSELRESET[1]=21
                        @NeverDie not sure if you've already noticed, but 4294967295 is the maximum value for an unsigned 32-bit integer. So the value is 0xFFFFFFFF. That often means uninitialized. I don't know why it would be uninitialized though.
                          #800
                          @mfalkvidd
                          Maybe because they just never were?
                          Those particular registers are "The user information configuration registers (UICRs) are non-volatile memory (NVM) registers for configuring user specific settings." So, it would seem that initializing them just once would be enough, since they're non-volatile.
                          In any case, good catch! It explains both why they are that value and also why they match.
                            #801
                            4294967295
                            Also, since 4294967295 equals 0xFFFFFFFF, then bit 31 is a '1', which, according to the datasheet, means the pin is disconnected (see section 14.1.60 PSELRESET[0] of the datasheet for the detail].
                              There's a chance we may have unwittingly done it ourselves! Remember back to when we were doing an explicit "Erase All"? From the datasheet:
                              11.5 Erase all
                              When erase is enabled, the whole Flash and UICR can be erased in one operation by using the ERASEALL
                              register.
                              Furthermore, from page 29 of the datasheet:
                              After erasing UICR all bits in UICR are set to '1'.
                              d00616D 1 Reply Last reply
                                11.5 Erase all
                                register.
                                d00616D
                                d00616D
                                d00616
                                This is part of the arduino-nrf5 code -> https://github.com/sandeepmistry/arduino-nRF5/blob/dc53980c8bac27898fca90d8ecb268e11111edc1/cores/nRF5/SDK/components/toolchain/system_nrf52.c#L156
                                I don't have any idea why this is not included in the binary. When the reset menu is selected then "-DCONFIG_GPIO_AS_PINRESET" is given to gcc.
                                When system_nrf52.c is completely ignored, then the erratas are not handled.
                                  #804
                                  Here is some verbose code which properly sets the registers to use pin P0.21 as the RESET pin:
                                  Serial.println("Testing...");
                                  delay(10000);  //give preparation time to open serial tty
                                  Serial.print(counter);
                                  Serial.print(", PSELRESET[0]=");
                                  Serial.println(NRF_UICR-> PSELRESET[0]);
                                  Serial.print(counter++);
                                  Serial.print(", PSELRESET[1]=");
                                  Serial.println(NRF_UICR-> PSELRESET[1]);
                                  Serial.println();
                                  Serial.println("Write-enabling CONFIG.");
                                  Serial.println();
                                  Serial.println("Now designating pin pO.21 as the RESET pin.");
                                  NRF_UICR-> PSELRESET[0]=21;  //designate pin pO.21 as the RESET pin
                                  NRF_UICR-> PSELRESET[1]=21;  //designate pin pO.21 as the RESET pin
                                  Serial.println();
                                  Serial.println("Confirming that RESET pin assigment took hold:");
                                  Serial.println();
                                  Serial.println("Return CONFIG to read-only mode.");
                                  Running it once seems to be good enough, unless there were to occur another "Erase All" or "Burn bootloader" event.
                                  Here is the output from running the code which shows that it succeeded:
                                  Testing...
                                  0, PSELRESET[0]=4294967295
                                  0, PSELRESET[1]=4294967295
                                  1, PSELRESET[0]=21
                                  1, PSELRESET[1]=21
                                    #805
                                    Until a more elegant solution can be found, I'm using this in the setup() routine as the workaround:
                                      if (((NRF_UICR-> PSELRESET[0])==0xFFFFFFFF) && ((NRF_UICR-> PSELRESET[1])==0xFFFFFFFF)) { //if the two RESET registers are erased
                                        NRF_UICR-> PSELRESET[0]=21;  //designate pin P0.21 as the RESET pin
                                        NRF_UICR-> PSELRESET[1]=21;  //designate pin P0.21 as the RESET pin
                                    The code has the positive virtue of not writing to the RESET rregisters unless both registers are erased. That helps ensure that the non-volatile memory does not get worn out prematurely.
                                      #806
                                      Good news! I've confirmed that doing this does indeed solve the problem I previously had with the EByte nRF52832 module not reacting to a reset on pin P0.21. After inserting the above code block into the nRF52832's setup() routine, I can now, using ESP-LINK, remotely reset an nRF52832 module:
                                        #807
                                        With that issue now settled, I'm moving on to a different topic: what happens if you put the radio into Tx mode, but with an empty buffer (i.e. nothing to send)? In this scenario an RFM69 transmits a continuous pre-amble, and I'm wondering whether the nRF52832 does the same?
                                        With an empty buffer, does it transmit anything at all? Anyone happen to know?
                                        The reason I ask is that I want to program the radio to send a continuous signal so as to quickly wake-up a receiver. With packets, there's the lag time of receiving and decoding the packet, rather than just reacting to a high RSSI. In this way, I can use much narrower listen windows and thereby save a lot of current consumption.
                                          According to the datasheet, the typical RSSI sample period is just 0.25us. However, what spoils that a bit is that the radio has to come up to speed beforehand.
                                          Anyhow, on the receive side, I now have at least that much working.
