  3. Step-up / Boost regulator PCBs
diyboosteaglepcbbattery
22 Posts 9 Posters 16.2k Views 5 Watching
  • slartiS slarti
    @bjornhallberg I'm trying to make some boards with the panelizer as well but I can't get the slots in the middle to show up in most gerber viewers. Did you have this problem? If so, how did you resolve it?
    Example:
    The slots ARE in the .gko file but won't show up.
    bjornhallbergB
    bjornhallbergB
    bjornhallberg
    @slarti Yes, that happened to me as well. My guess would be that you have your outline layer in just about every gerber. Some board houses (like DirtyPCBs) like it that way or have it in their CAM anyway. The panelizer however only works if you include the outline layer ONLY in your .GKO.
    If you send the files as shown above, your board house will probably figure things out, but then again they may not.
    slartiS 1 Reply Last reply
      slartiS
      slartiS
      slarti
      @bjornhallberg No, I only have the outline in the .gko file. It shows up fine in the picture generated by the panelizer but not in (almost) any viewer I've tried. Well, I sent the files in already so I guess we'll see what happens... :wink:
      "One is never alone with a rubber duck"
      • slartiS
        slartiS
        slarti
        Oh, yeah. Did you get a .gml file (milling)? If I included one of those every viewer went nuts and DirtyPCB wouldn't accept the file. When I left it out, everything was fine except for the problem described above.
        • slartiS slarti
          bjornhallbergB
          bjornhallbergB
          bjornhallberg
          @slarti I see now that at least GRBV doesn't render the output gerbers correctly. Weird. Oh well, mine worked fine and so will yours probably.
          I think I deleted the .GML. I also recall some sort of error if I didn't. "Board outline not found in GML/GBR/GKO file" or some such.
            slartiS
            slartiS
            slarti
            @bjornhallberg Good to know, thanks! Seems we had the same problems.
            • bjornhallbergB
              bjornhallbergB
              bjornhallberg
              wrote on last edited by bjornhallberg
              So, in conclusion I assembled the boost modules. I don't have an oscilloscope or any fancy variable load so I can't do much testing. But both the TPS61221 and LTC3525 seem to be working as intended, they power the NRF24 (not sensor in this particular picture below) without any hiccups at any rate.
              I tried some ceramic power resistors to put some load on the regulators and got something like ~60-80mA out of one fairly run down AA cell if I'm not mistaken. Basically according to spec.
              All I have to do now is design a compact sensor node where 1xAA actually makes sense. Kind of like LowPowerLabs' Moteino. Feels like it's time to take this to the next level. The only thing bugging me is the need to reflow instead of hand solder, and the massive task of sourcing components from AliExpress so I can avoid Mouse/Digikey. Perhaps I should give it a rest for now and see how the official MySensors modules turn out before I decide.
              • bjornhallbergB
                bjornhallbergB
                bjornhallberg
                Powering a 1.3 inch OLED display (i2c).
                Now if I could only put all of this together as a scene controller or whatever in a nice 3d printed box.
                • P
                  P
                  pedrodova
                  bjornhallberg, this is an excellent project. I’ve noticed that you ordered your components from AliExpress instead of mouse, farnell or digikey. I mostly order my components from farnell or digikey since mouse is a bit expensive. AliExpress is cheaper than all of these by a mile and I have been thinking of ordering from their stores but I can’t risk placing an order and not having my components delivered or not having the components that I ordered delivered. Please let me know how you found their service. Congratulations on a successful project by the way.
                  • P pedrodova
                    bjornhallbergB
                    bjornhallbergB
                    bjornhallberg
                    @pedrodova I think AliExpress has worked out nicely so far, though I can't be 100% sure I'm not getting counterfeit components from time to time (hard to tell with capacitors). Though it would seem unlikely with the rather uncommon components here, I mean if someone were putting out fake ICs they'd be all over Ebay/Ali and they're not obviously. There are only a few people selling LTC3525 and only one guy selling the inductor on Ali for instance, and prices are usually on par with Digikey etc if you look at volume sales and disregard shipping/customs. Considering the whole debacle with the NRF24 radio though I'll certainly be vigilant in the future in case things change.
                    I have ordered perhaps ~250 items from Ebay and ~25 from Ali and only ever had two things disappear in shipping (both from Ebay and one quite recently). Never had an issue with a seller not issuing a refund or re-sending a broken item. AliExpress packages are almost always sent as registered mail (as opposed to most Ebay packages) so I'll end up having to pick them up at my local post office as opposed to just being shoved in my mailbox. Shipping to Sweden takes about a month most of the time and some sellers are pretty slow to ship (though it is always stated on their item pages). If someone claims to take 15-20 days to even ship, you better believe it. Still haven't figured out why package delivery times differ so much either. Like I said, a month is what to expect but I've literally had packages (mostly from Ebay) arrive within a week.
                    Biggest issue with AliExpress is perhaps their search engine and the way some sellers list their items. Trying to find what you're looking for (or alternative products) can seem impossible sometimes.
                    Overall I'd say AliExpress is pretty safe and a nice way to save a few bucks on components - if you can find them, wont mind waiting and don't have a ton of components on your shopping list.
                    • V
                      V
                      viya
                      I hope you will succeed with your design but pay attention to the testing. With such things as high frequency switching DC-DC all is important - coper design, selection of capacitors and inductors.
                      -Link Removed by moderator-
                        Have you considered maybe posting your PCB's on openhardware.io?
                        • bjornhallbergB
                          bjornhallbergB
                          bjornhallberg
                          @NeverDie Perhaps but the design is a bit too simple and unoriginal. I'd have to clean up the files a bit and I haven't touched Eagle since I made this board several years ago.
                          12.5k
