  3. I have great problem with raspberry and domoticz and mysensors gateway !
42 Posts 6 Posters 12.8k Views 6 Watching
  • R Reza
    @tbowmo i search about this and i test this code before:
    Start Domoticz
    sudo service domoticz.sh start
    Stop Domoticz
    sudo service domoticz.sh stop
    Check if Domoticz is running
    sudo service domoticz.sh status
    but this is dont work for domoticz that compile from source.
    this is result:
    pi@raspberrypi:~ $ sudo service domoticz.sh stop
    Failed to stop domoticz.service: Unit domoticz.service not loaded.
    pi@raspberrypi:~ $ sudo service domoticz.sh status
    ● domoticz.service
       Loaded: not-found (Reason: No such file or directory)
       Active: inactive (dead)
    pi@raspberrypi:~ $
    for this i had to question from you :(
    #31
    @Reza you can run ps to see current services running. Maybe its named something else when compiled from source - or its not just running? Did you try to start it before stopping it?
    R 1 Reply Last reply
    • R Reza
      Start Domoticz
      Stop Domoticz
      this is result:
      ● domoticz.service
      pi@raspberrypi:~ $
      @Reza why are you running it from source and not from standard install?
      • S sundberg84
        R Offline
        R Offline
        Reza
        @sundberg84
        thank you friend. domoticz now is working for me.but when run ps i dont see domoticz:
        pi@raspberrypi:~ $ ps
          PID TTY          TIME CMD
         1000 pts/0    00:00:00 bash
         1026 pts/0    00:00:00 Xtightvnc
         1031 pts/0    00:00:00 xstartup
         1034 pts/0    00:00:00 lxsession
         1066 pts/0    00:00:00 dbus-launch
         1084 pts/0    00:00:00 openbox
         1086 pts/0    00:00:00 lxpolkit
         1088 pts/0    00:00:00 lxpanel
         1090 pts/0    00:00:01 pcmanfm
         1134 pts/0    00:00:00 start-pulseaudi
         1135 pts/0    00:00:00 xprop
         1585 pts/0    00:00:01 Xtightvnc
         1589 pts/0    00:00:00 xstartup
         1592 pts/0    00:00:00 lxsession
         1624 pts/0    00:00:00 dbus-launch
         1643 pts/0    00:00:00 openbox
         1645 pts/0    00:00:00 lxpolkit
         1647 pts/0    00:00:00 lxpanel
         1649 pts/0    00:00:02 pcmanfm
         1693 pts/0    00:00:00 start-pulseaudi
         1694 pts/0    00:00:00 xprop
         2546 pts/0    00:00:00 ps
        this is files after compile . and i put "/home/pi/rayan/domoticz" to "rc.local" for up after startup.
          R Offline
          R Offline
          Reza
          @gohan because i wanted change some things. for example font , theme , icons and etc...
          • T Offline
            T Offline
            tbowmo
            @Reza
            Once again, try this link http://bfy.tw/DnCc
            (Hint.. try looking for answers by using google!)
            R 2 Replies Last reply
            • T tbowmo
              @Reza
              R Offline
              R Offline
              Reza
              @tbowmo thank you . i will search about this issue
              • T tbowmo
                @Reza
                R Offline
                R Offline
                Reza
                @tbowmo thanks for all guide. i could do it. thank you
                My friend just one question . i want know if i choose for example 20mb for ram driver (tmpfs). after full this memory (if i dont clear this), so what happen ? raspberry will be crash ? or not happen and I dont have any new log and report ? or again write on ago log ? thank you for all help
                • T Offline
                  T Offline
                  tbowmo
                  I restart domoticz every night, and delete the log file. If you don't do this regularly, the disk will fill up, and domoticz will not be able to write any logs. I don't know what will happen with domoticz in that case
                  • T tbowmo
                    R Offline
                    R Offline
                    Reza
                    @tbowmo
                    every night !! :O you do with hand or auto with a program? if you have a program for this can you share this ?
                    i test with 1mb memory, i see after full , domoticz dont work and have some problem. so we must clear ...
                    can you help me for build a program for this ? for example when this is 90% memory (tmpfs) so clear this...
                    • T tbowmo
                      R Offline
                      R Offline
                      Reza
                      wrote on last edited by Reza
                      #40
                      @tbowmo i found this script.but becuase i am beginner in script i can not know this.
                      can we use this for clean tmpfs after 2day each week ? can you edit this for our use exactly ? i build a tmpfs in /var/log . and i move domoticz.log to this folder... now what change i need in this script for clean /var/log every 2 days and how to use this automatic for always when power off/on , reboot and...
                      thank you for help
                      #!/bin/bash
                      # Diskclean-Linux.sh - Remove unused files from /tmp directories
                      # @author: Crunchify.com
                      # ------------- Here are Default Configuration --------------------
                      # CRUNCHIFY_TMP_DIRS - List of directories to search
                      # DEFAULT_FILE_AGE - # days ago (rounded up) that file was last accessed
                      # DEFAULT_LINK_AGE - # days ago (rounded up) that symlink was last accessed
                      # DEFAULT_SOCK_AGE - # days ago (rounded up) that socket was last accessed
                      CRUNCHIFY_TMP_DIRS="/tmp /var/tmp /usr/src/tmp /mnt/tmp"
                      DEFAULT_FILE_AGE=+2
                      DEFAULT_LINK_AGE=+2
                      DEFAULT_SOCK_AGE=+2
                      # Make EMPTYFILES true to delete zero-length files
                      EMPTYFILES=false
                      #EMPTYFILES=true
                      cd
                      /tmp/log "cleantmp.sh[$$] - Begin cleaning tmp directories"
                      echo ""
                      echo "delete any tmp files that are more than 2 days old"
                      /usr/bin/find $CRUNCHIFY_TMP_DIRS                               \
                           -depth                                                     \
                           -type f -a -ctime $DEFAULT_FILE_AGE                        \
                           -print -delete
                      echo ""
                      echo "delete any old tmp symlinks"
                           -depth                                                     \
                           -type l -a -ctime $DEFAULT_LINK_AGE                        \
                           -print -delete
                      echo ""
                      if /usr/bin/$EMPTYFILES ;
                      then
                      echo "delete any empty files"
                           -depth                                                     \
                           -type f -a -empty                                          \
                           -print -delete
                      fi
                      echo "Delete any old Unix sockets"
                           -depth                                                     \
                           -type s -a -ctime $DEFAULT_SOCK_AGE -a -size 0             \
                           -print -delete
                      echo""
                      echo "delete any empty directories (other than lost+found)"
                           -depth -mindepth 1                                         \
                           -type d -a -empty -a ! -name 'lost+found'                  \
                           -print -delete
                      echo ""
                      /usr/bin/logger "cleantmp.sh[$$] - Done cleaning tmp directories"
                      # send out an email about diskcleanup action
                      mail -s "Disk cleanup has been performed successfully." you@email.com
                      echo ""
                      echo "Diskcleanup Script Successfully Executed"
                      exit 0
                      • T Offline
                        T Offline
                        tbowmo
                        @Reza
                        One quick fix would be to delete the /var/log/domoticz.log file whenever domoticz is restarting. Then you just need to implement a periodically restart of domoticz.
                        • R Offline
                          R Offline
                          Reza
                          #42
                          ok thank you. but i have a new problem...
                          i think just move domoticz.log to ram driver. but report of sensors in mysensors... where these is save?:/
                          i think report of mysensors can not write... now in domoticz log i can not see report.. also i chack var/log memory after 1 day.when i send command for turn on light (alot command) memory of var/log increase.but 1 day i dont send any command and i wait for increase memory with report sensors but dont increase.what is problem? when i change your setting to defult work and i see report of sensors.
                          and this is memory of log after one day. sensors was sending report to controller for 1 deys but before memory was 1304 and now is 1304...
