  3. I have great problem with raspberry and domoticz and mysensors gateway !
42 Posts 6 Posters 12.9k Views 6 Watching
  • R Reza
    @tbowmo i search about this and i test this code before:
    Start Domoticz
    sudo service domoticz.sh start
    Stop Domoticz
    sudo service domoticz.sh stop
    Check if Domoticz is running
    sudo service domoticz.sh status
    but this is dont work for domoticz that compile from source.
    this is result:
    pi@raspberrypi:~ $ sudo service domoticz.sh stop
    Failed to stop domoticz.service: Unit domoticz.service not loaded.
    pi@raspberrypi:~ $ sudo service domoticz.sh status
    ● domoticz.service
       Loaded: not-found (Reason: No such file or directory)
       Active: inactive (dead)
    pi@raspberrypi:~ $
    for this i had to question from you :(
    @Reza why are you running it from source and not from standard install?
    R 1 Reply Last reply
    • sundberg84S sundberg84
      @Reza you can run ps to see current services running. Maybe its named something else when compiled from source - or its not just running? Did you try to start it before stopping it?
      R
      R
      Reza
      @sundberg84
      thank you friend. domoticz now is working for me.but when run ps i dont see domoticz:
      pi@raspberrypi:~ $ ps
        PID TTY          TIME CMD
       1000 pts/0    00:00:00 bash
       1026 pts/0    00:00:00 Xtightvnc
       1031 pts/0    00:00:00 xstartup
       1034 pts/0    00:00:00 lxsession
       1066 pts/0    00:00:00 dbus-launch
       1084 pts/0    00:00:00 openbox
       1086 pts/0    00:00:00 lxpolkit
       1088 pts/0    00:00:00 lxpanel
       1090 pts/0    00:00:01 pcmanfm
       1134 pts/0    00:00:00 start-pulseaudi
       1135 pts/0    00:00:00 xprop
       1585 pts/0    00:00:01 Xtightvnc
       1589 pts/0    00:00:00 xstartup
       1592 pts/0    00:00:00 lxsession
       1624 pts/0    00:00:00 dbus-launch
       1643 pts/0    00:00:00 openbox
       1645 pts/0    00:00:00 lxpolkit
       1647 pts/0    00:00:00 lxpanel
       1649 pts/0    00:00:02 pcmanfm
       1693 pts/0    00:00:00 start-pulseaudi
       1694 pts/0    00:00:00 xprop
       2546 pts/0    00:00:00 ps
      this is files after compile . and i put "/home/pi/rayan/domoticz" to "rc.local" for up after startup.
        R
        R
        Reza
        @gohan because i wanted change some things. for example font , theme , icons and etc...
        • tbowmoT
          tbowmoT
          tbowmo
          @Reza
          Once again, try this link http://bfy.tw/DnCc
          (Hint.. try looking for answers by using google!)
          R 2 Replies Last reply
          • tbowmoT tbowmo
            @Reza
            R
            R
            Reza
            @tbowmo thank you . i will search about this issue
            • tbowmoT tbowmo
              @Reza
              R
              R
              Reza
              @tbowmo thanks for all guide. i could do it. thank you
              My friend just one question . i want know if i choose for example 20mb for ram driver (tmpfs). after full this memory (if i dont clear this), so what happen ? raspberry will be crash ? or not happen and I dont have any new log and report ? or again write on ago log ? thank you for all help
              • tbowmoT
                tbowmoT
                tbowmo
                I restart domoticz every night, and delete the log file. If you don't do this regularly, the disk will fill up, and domoticz will not be able to write any logs. I don't know what will happen with domoticz in that case
                • tbowmoT tbowmo
                  R
                  R
                  Reza
                  @tbowmo
                  every night !! :O you do with hand or auto with a program? if you have a program for this can you share this ?
                  i test with 1mb memory, i see after full , domoticz dont work and have some problem. so we must clear ...
                  can you help me for build a program for this ? for example when this is 90% memory (tmpfs) so clear this...
                  • tbowmoT tbowmo
                    R
                    R
                    Reza
                    wrote on last edited by Reza
                    #40
                    @tbowmo i found this script.but becuase i am beginner in script i can not know this.
                    can we use this for clean tmpfs after 2day each week ? can you edit this for our use exactly ? i build a tmpfs in /var/log . and i move domoticz.log to this folder... now what change i need in this script for clean /var/log every 2 days and how to use this automatic for always when power off/on , reboot and...
                    thank you for help
                    #!/bin/bash
                    # Diskclean-Linux.sh - Remove unused files from /tmp directories
                    # @author: Crunchify.com
                    # ------------- Here are Default Configuration --------------------
                    # CRUNCHIFY_TMP_DIRS - List of directories to search
                    # DEFAULT_FILE_AGE - # days ago (rounded up) that file was last accessed
                    # DEFAULT_LINK_AGE - # days ago (rounded up) that symlink was last accessed
                    # DEFAULT_SOCK_AGE - # days ago (rounded up) that socket was last accessed
                    CRUNCHIFY_TMP_DIRS="/tmp /var/tmp /usr/src/tmp /mnt/tmp"
                    DEFAULT_FILE_AGE=+2
                    DEFAULT_LINK_AGE=+2
                    DEFAULT_SOCK_AGE=+2
                    # Make EMPTYFILES true to delete zero-length files
                    EMPTYFILES=false
                    #EMPTYFILES=true
                    cd
                    /tmp/log "cleantmp.sh[$$] - Begin cleaning tmp directories"
                    echo ""
                    echo "delete any tmp files that are more than 2 days old"
                    /usr/bin/find $CRUNCHIFY_TMP_DIRS                               \
                         -depth                                                     \
                         -type f -a -ctime $DEFAULT_FILE_AGE                        \
                         -print -delete
                    echo ""
                    echo "delete any old tmp symlinks"
                         -depth                                                     \
                         -type l -a -ctime $DEFAULT_LINK_AGE                        \
                         -print -delete
                    echo ""
                    if /usr/bin/$EMPTYFILES ;
                    then
                    echo "delete any empty files"
                         -depth                                                     \
                         -type f -a -empty                                          \
                         -print -delete
                    fi
                    echo "Delete any old Unix sockets"
                         -depth                                                     \
                         -type s -a -ctime $DEFAULT_SOCK_AGE -a -size 0             \
                         -print -delete
                    echo""
                    echo "delete any empty directories (other than lost+found)"
                         -depth -mindepth 1                                         \
                         -type d -a -empty -a ! -name 'lost+found'                  \
                         -print -delete
                    echo ""
                    /usr/bin/logger "cleantmp.sh[$$] - Done cleaning tmp directories"
                    # send out an email about diskcleanup action
                    mail -s "Disk cleanup has been performed successfully." you@email.com
                    echo ""
                    echo "Diskcleanup Script Successfully Executed"
                    exit 0
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @Reza
                      One quick fix would be to delete the /var/log/domoticz.log file whenever domoticz is restarting. Then you just need to implement a periodically restart of domoticz.
                      • R
                        R
                        Reza
                        #42
                        ok thank you. but i have a new problem...
                        i think just move domoticz.log to ram driver. but report of sensors in mysensors... where these is save?:/
                        i think report of mysensors can not write... now in domoticz log i can not see report.. also i chack var/log memory after 1 day.when i send command for turn on light (alot command) memory of var/log increase.but 1 day i dont send any command and i wait for increase memory with report sensors but dont increase.what is problem? when i change your setting to defult work and i see report of sensors.
                        and this is memory of log after one day. sensors was sending report to controller for 1 deys but before memory was 1304 and now is 1304...
