  3. Startup time of arduino pro mini with mysensors 2.2 - took 10 sec (guess its the radio), can I execute some code immediately (<1sec)?
22 Posts 4 Posters 5.2k Views 5 Watching
  • rozpruwaczR rozpruwacz
    @alterfritz said in Startup time of arduino pro mini with mysensors 2.2 - took 10 sec (guess its the radio), can I execute some code immediately (<1sec)?:
    d with the w
    If I correctly understood your setup you have wall switch on the high AC voltage side ? why not make it on the low voltage side ? the arduino can be powered all the time and your problem is gone.
    alterfritz
    @rozpruwacz its a normal wall switch, using 220v. The LED using a ac-dc converter with 5v output. I use pro mini with 3.3v on raw input. seesm to work, however when I switch on it took around 10 sec, even I place analogWrite( LED_PIN, 255); 1st line in setup().
    • M manutremo
      In order to try help you find out... please share your sketch, serial output... which radio are you using... what makes you think it's the radio?
      alterfritz
      @manutremo
      here it is - mostly the example... I'm using NRF24L01. Why the radio - I can check messages on gateway / mqtt (on raspPi). Took them around 10 sec to show up...
      • The MySensors Arduino library handles the wireless radio link and protocol
      • between your home built sensors/actuators and HA controller of choice.
      • The sensors forms a self healing radio network with optional repeaters. Each
      • repeater and gateway builds a routing tables in EEPROM which keeps track of the
      • network topology allowing messages to be routed to nodes.
      • Created by Henrik Ekblad henrik.ekblad@mysensors.org
      • Copyright (C) 2013-2015 Sensnology AB
      • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
      • Documentation: http://www.mysensors.org
      • Support Forum: http://forum.mysensors.org
      • This program is free software; you can redistribute it and/or
      • modify it under the terms of the GNU General Public License
      • version 2 as published by the Free Software Foundation.
      • REVISION HISTORY
      • Version 1.0 - February 15, 2014 - Bruce Lacey
      • Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
      • DESCRIPTION
      • This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
      • henrik.ekblad@gmail.com Vera Arduino Sensor project.
      • Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
      • The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
      • The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
      • to the LED negative terminal and the MOSFET Source pin is connected to ground.
      • This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
      • http://www.mysensors.org/build/dimmer
      //#define MY_NODE_ID
      //#define MY_RADIO_NRF5_ESB
      //#define MY_RADIO_RFM95
      #define EPROM_LIGHT_STATE 1
      #define EPROM_DIMMER_LEVEL 2
      #define LIGHT_OFF 0
      #define LIGHT_ON 1
      #define SN "WallLight6"
      #define SV "1.0"
      #define CHILD_ID_LIGHT 1
      #define LED_PIN 3 // Arduino pin attached to MOSFET Gate pin
      #define FADE_DELAY 10 // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
      static int16_t currentLevel = 0; // Current dim level...
      MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
      MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT);
      int16_t LastLightState=LIGHT_OFF;
      int16_t LastDimValue=100;
      • Dimmable LED initialization method
        // Pull the gateway's current dim level - restore light level upon sendor node power-up
        //request( CHILD_ID_LIGHT, V_DIMMER );
        //Serial.println( "Node ready to receive messages..." );
        int LightState=loadState(EPROM_LIGHT_STATE);
        if (LightState<=1) {
        LastLightState=LightState;
        int DimValue=loadState(EPROM_DIMMER_LEVEL);
        if ((DimValue>0)&&(DimValue<=100)) {
        //There should be no Dim value of 0, this would mean LIGHT_OFF
        LastDimValue=DimValue;
      //Here you actualy switch on/off the light with the last known dim level
      SetCurrentState2Hardware();
      // Register the LED Dimmable Light with the gateway
      sendSketchInfo(SN, SV);
      present( CHILD_ID_LIGHT, S_DIMMER );
      • Dimmable LED main processing loop
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
      	Serial.print( "Changing level to " );
      	Serial.print( ", from " );
      	Serial.println( currentLevel );
      	fadeToLevel( requestedLevel );
      saveState(EPROM_DIMMER_LEVEL, requestedLevel);
      	send(lightMsg.set(currentLevel > 0));
      	// hek comment: Is this really nessesary?
      	send( dimmerMsg.set(currentLevel) );
      • This method provides a graceful fade up/down effect
        void fadeToLevel( int toLevel )
        int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
        while ( currentLevel != toLevel ) {
        currentLevel += delta;
        analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
        delay( FADE_DELAY );
      void SetCurrentState2Hardware()
      if (LastLightState==LIGHT_OFF) {
      Serial.println( "Light state: OFF" );
      Serial.print( "Light state: ON, Level: " );
      Serial.println( LastDimValue );
      //Send current state to the controller
      SendCurrentState2Controller();
      void SendCurrentState2Controller()
      if ((LastLightState==LIGHT_OFF)||(LastDimValue==0)) {
      send(dimmerMsg.set((int16_t)0));
      send(dimmerMsg.set(LastDimValue));
      • rozpruwaczR
        rozpruwaczR
        rozpruwacz
        and why You choosed that design ? you are not able to switch on the lights remotely.
        A 1 Reply Last reply
          alterfritz
          @rozpruwacz This is the way it was constructed. I plan to leave them on all time, maybe remove / replace them in the future - however if somebody uses the switches the lights should go on instantly, basically by set analogWrite( LED_PIN,255); like a normal switch.
          Any way to do so?
          rejoe2R 1 Reply Last reply
          • A alterfritz
            Any way to do so?
            rejoe2R
            rejoe2R
            rejoe2
            @alterfritz
            Try to add the "on" command not in setup() (this requires presetation() to be already passed) and use a before()-routine instead.
            • rozpruwaczR
              rozpruwaczR
              rozpruwacz
              So I would rather make it in hardware. pull-up resistor on the switching transistor will make it on at the powerup. and I would store the last dimm value into eeprom to not wait for the gateway response because you will not make it response in less that 1s - the protocol just not allow for that.
                rejoe2R
                rejoe2R
                rejoe2
                @rozpruwacz Exactly. This is why the "on" should be issued in before() (or something like hwInit()).
                "before()" is executed before any MySensors-specific communication....
                  manutremo
                  In addition to the other advices you're already receiving, and following your suspicion that the delay might be related to the radio, you could try adding the following defines to your sketch:
                  #define MY_PARENT_NODE_ID 0
                  #define MY_TRANSPORT_MAX_TX_FAILURES 3
                  The first two avoid the node from having to search for it.
                  The last one might help you determine if the problem is the radio not starting correctly if the time is reduced after you add it.
                  Let us know how it goes.
                  • rozpruwaczR
                    rozpruwaczR
                    rozpruwacz
                    yes, so in the before() function read the eeprom value and set it in analogWrite. hardware pull-up is optional because the delay between switching power on and before function call will be short enough, bit if You use the pull-up the delay will be even shorter.
                    • rejoe2R rejoe2
                      @alterfritz
                      alterfritz
                      @rejoe2 like this... btw - this forum is fanastic... responses more or less in real time... :-)
                      • A alterfritz
                        alterfritz
                        @alterfritz
                        sorry ... mean before ...like this
                        void before()
                        This seems to have done the trick... LED switch on immediately! Thanks!
                        Btw... I also try the mysbootloader. This wirless update is great, however - does this bootloader slows down bootup time?
                        • rozpruwaczR
                          rozpruwaczR
                          rozpruwacz
                          yes, because the code that will run in the node must be first uploaded to it. the bootup time will be dependent on the code size.
                          • rejoe2R
                            rejoe2R
                            rejoe2
                            wrote on last edited by rejoe2
                            @alterfritz Yes, update-bootloader tries to connect to GW for updates first seconds (around 20). So it is not dependend on code size...
                            Additional note: Waiting for RF connection to be established can also be prevented by using
                            #define MY_TRANSPORT_WAIT_READY_MS ...
                            • rejoe2R rejoe2
                              alterfritz
                              @rejoe2
                              So
                              #define MY_TRANSPORT_WAIT_READY_MS 1000
                              Will wait for 1 sec?
                              • A alterfritz
                                @rejoe2
                                So
                                rejoe2R
                                rejoe2R
                                rejoe2
                                @alterfritz Exactly. After trying to connect to the controller for 1 sec., the node will execute normal code like any other "just-arduino".
                                Pls note: as there is no connection to the controller, the node may miss relevant info typically provided by the controller. Things like myControllerConfig, last values for counters etc... If you use this, you should make sure, these are set correctly later on.
                                • A
                                  alterfritz
                                  So - thanks for all your help. Great forum. Let me summarize what I understand so far:
                                  1.) by using the before() procedbure I can execute immediately. Quickly tested. Seems perfect for me... however... :-)
                                  2.) I really like this mysbootloader. But by using this it always takes up around 20 sec to boot up. There is NO way to switch on my LED directly when I power it up...
                                  Correct?
                                  • A alterfritz
                                    Correct?
                                    rejoe2R
                                    rejoe2R
                                    rejoe2
                                    @alterfritz Speaking about software: Not exactly, there is one thing you could still do: Compile the bootloader yourself with light switched on... :grinning:
                                    • rejoe2R rejoe2
                                      alterfritz
                                      @rejoe2 Right... :-) I may look into this. For now I will try to get a stable version and load it without bootloader directly via usbasp...
