  3. Startup time of arduino pro mini with mysensors 2.2 - took 10 sec (guess its the radio), can I execute some code immediately (<1sec)?
22 Posts 4 Posters 5.2k Views 5 Watching
  • rozpruwaczR rozpruwacz
    and why You choosed that design ? you are not able to switch on the lights remotely.
    alterfritz
    @rozpruwacz This is the way it was constructed. I plan to leave them on all time, maybe remove / replace them in the future - however if somebody uses the switches the lights should go on instantly, basically by set analogWrite( LED_PIN,255); like a normal switch.
    Any way to do so?
    rejoe2R 1 Reply Last reply
    • A alterfritz
      Any way to do so?
      rejoe2R
      rejoe2R
      rejoe2
      @alterfritz
      Try to add the "on" command not in setup() (this requires presetation() to be already passed) and use a before()-routine instead.
      A 1 Reply Last reply
      • rozpruwaczR
        rozpruwaczR
        rozpruwacz
        So I would rather make it in hardware. pull-up resistor on the switching transistor will make it on at the powerup. and I would store the last dimm value into eeprom to not wait for the gateway response because you will not make it response in less that 1s - the protocol just not allow for that.
          rejoe2R
          rejoe2R
          rejoe2
          @rozpruwacz Exactly. This is why the "on" should be issued in before() (or something like hwInit()).
          "before()" is executed before any MySensors-specific communication....
            manutremo
            In addition to the other advices you're already receiving, and following your suspicion that the delay might be related to the radio, you could try adding the following defines to your sketch:
            #define MY_PARENT_NODE_ID 0
            #define MY_TRANSPORT_MAX_TX_FAILURES 3
            The first two avoid the node from having to search for it.
            The last one might help you determine if the problem is the radio not starting correctly if the time is reduced after you add it.
            Let us know how it goes.
            • rozpruwaczR
              rozpruwaczR
              rozpruwacz
              yes, so in the before() function read the eeprom value and set it in analogWrite. hardware pull-up is optional because the delay between switching power on and before function call will be short enough, bit if You use the pull-up the delay will be even shorter.
              • rejoe2R rejoe2
                @alterfritz
                alterfritz
                @rejoe2 like this... btw - this forum is fanastic... responses more or less in real time... :-)
                • A alterfritz
                  alterfritz
                  @alterfritz
                  sorry ... mean before ...like this
                  void before()
                  This seems to have done the trick... LED switch on immediately! Thanks!
                  Btw... I also try the mysbootloader. This wirless update is great, however - does this bootloader slows down bootup time?
                  • rozpruwaczR
                    rozpruwaczR
                    rozpruwacz
                    yes, because the code that will run in the node must be first uploaded to it. the bootup time will be dependent on the code size.
                    • rejoe2R
                      rejoe2R
                      rejoe2
                      wrote on last edited by rejoe2
                      @alterfritz Yes, update-bootloader tries to connect to GW for updates first seconds (around 20). So it is not dependend on code size...
                      Additional note: Waiting for RF connection to be established can also be prevented by using
                      #define MY_TRANSPORT_WAIT_READY_MS ...
                      • rejoe2R rejoe2
                        alterfritz
                        @rejoe2
                        So
                        #define MY_TRANSPORT_WAIT_READY_MS 1000
                        Will wait for 1 sec?
                        • A alterfritz
                          @rejoe2
                          So
                          rejoe2R
                          rejoe2R
                          rejoe2
                          @alterfritz Exactly. After trying to connect to the controller for 1 sec., the node will execute normal code like any other "just-arduino".
                          Pls note: as there is no connection to the controller, the node may miss relevant info typically provided by the controller. Things like myControllerConfig, last values for counters etc... If you use this, you should make sure, these are set correctly later on.
                          • A
                            alterfritz
                            So - thanks for all your help. Great forum. Let me summarize what I understand so far:
                            1.) by using the before() procedbure I can execute immediately. Quickly tested. Seems perfect for me... however... :-)
                            2.) I really like this mysbootloader. But by using this it always takes up around 20 sec to boot up. There is NO way to switch on my LED directly when I power it up...
                            Correct?
                            • A alterfritz
                              Correct?
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @alterfritz Speaking about software: Not exactly, there is one thing you could still do: Compile the bootloader yourself with light switched on... :grinning:
                              • rejoe2R rejoe2
                                alterfritz
                                @rejoe2 Right... :-) I may look into this. For now I will try to get a stable version and load it without bootloader directly via usbasp...
