  3. nRF5 action!
nRF5 action!
  • d00616D d00616
    Is there any example code which illustrates the use of interrupts on the nRF52832?
    https://github.com/sandeepmistry/arduino-nRF5/issues/52
    https://github.com/mysensors/MySensors/blob/development/drivers/NRF5/Radio_ESB.cpp#L500
      #871
      @d00616
      Are there special reserved names to always use for the IRQ handlers? e.g. RADIO_IRQHandler(void), and so on?
        @d00616
        If I'm using
        sleep(1000000000);
        to sleep the CPU while keeping the PPI active, is there a way for the PPI to subsequently wake the CPU so that the CPU can resume where it left off? I'm not seeing any TASKS which look suitable for doing that. Or do I need an altogether different configuration for sleeping the CPU?
        Back on August 5, @RMTUCKER had suggested using:
        If I were to go that route, I could probably have the PPI toggle PIN 10 to do a wake-up, but I found that, for whatever reason, that method of sleeping had a much higher current draw.
        [Edit: scratch that. I just tried "sleep(digitalPinToInterrupt(10), FALLING,0);", and it appears to turn-off PPI. Oddly enough, it appears to leave the RTC running, which is actually just fine by me. However, I need the PPI running too. ]
        d00616D
        d00616D
        d00616
        The PPI cannot wake up the CPU. You can try to trigger events to a timer which resumes the CPU.
        Are there special reserved names to always use for the IRQ handlers? e.g. GPIOTE_IRQHandler(void), and so on?
        The names are defined there:
        https://github.com/sandeepmistry/arduino-nRF5/blob/dc53980c8bac27898fca90d8ecb268e11111edc1/cores/nRF5/SDK/components/device/nrf52.h#L65
        • d00616D d00616
          #873
          Does the current development software support the use of at most one ISR in total at any one time?
          • d00616D d00616
            #874
            @d00616
            I changed your example to use sleep(...) instead of delay(...) in the main loop, but what then becomes obvious is that the interrupts don't wake up the MCU. Well, in a sense they do, because the ISR is executed, but the MCU doesn't remain awake like it would on an Arduino. So, how does one escape the sleep mode after it has begun without waiting for it to simply time out?
            // This code is public domain
            #include <nrf.h>
            //#define RTC NRF_RTC0
            //#define RTC_IRQ RTC0_IRQn
            int interrupt = 0;
              Serial.begin(250000);
              Serial.println("Start");
              // Configure RTC
              NRF_RTC0->TASKS_STOP = 1;
              NRF_RTC0->PRESCALER = 31; //1024Hz frequency
              NRF_RTC0->CC[0] = NRF_RTC0->COUNTER + (3 * 1024);
              NRF_RTC0->EVTENSET = RTC_EVTENSET_COMPARE0_Msk;
              NRF_RTC0->INTENSET = RTC_INTENSET_COMPARE0_Msk;
              NRF_RTC0->TASKS_START = 1;
              NRF_RTC0->EVENTS_COMPARE[0] = 0;
              // Enable interrupt
              NVIC_EnableIRQ(RTC0_IRQn);
              Serial.println();
              Serial.println();
              Serial.print(millis());
              Serial.print(" ");
              Serial.print(NRF_RTC0->COUNTER);
              Serial.print(" ");
              Serial.println(interrupt);
              sleep(10000);
             * Reset events and read back on nRF52
             * http://infocenter.nordicsemi.com/pdf/nRF52_Series_Migration_v1.0.pdf
            #if __CORTEX_M == 0x04
                    event = 0;        \
                    (void)event
            // This must be in one line
            extern "C" { void RTC0_IRQHandler(void) { NRF5_RESET_EVENT(NRF_RTC0->EVENTS_COMPARE[0]); interrupt++; NRF_RTC0->TASKS_CLEAR = 1; }}
            I guess maybe the answer is to clear the SLEEPONEXIT bit in the System Control Register (SCR) before exiting the ISR? The SCR is described on page 4-19 of: http://infocenter.arm.com/help/topic/com.arm.doc.dui0553a/DUI0553A_cortex_m4_dgug.pdf
            At the moment, though, I'm not even sure how to access that register, as so far I've only seen the API for the nRF52832 generally, not the code interface for the ARM Cortex M4 per se that's inside it.
            rmtuckerR NeverDieN 2 Replies Last reply
              @d00616
              #include <nrf.h>
              int interrupt = 0;
                // Configure RTC
                // Enable interrupt
                Serial.println();
                Serial.println();
                Serial.print(" ");
                Serial.print(" ");
                sleep(10000);
                      event = 0;        \
                      (void)event
              rmtuckerR
              rmtuckerR
              rmtucker
              I am a little lost with this,I am using sleep and wake from ext int on the nrf51 and it has been working every second for the last 2 weeks.
              What kind of int are you trying to implement?
              • rmtuckerR rmtucker
                #876
                This is for the case where the PPI is doing things (like, for example, getting the radio to periodically listen for incoming packets) all while the CPU is sleeping. If, for instance, a packet is received in that mode, the CPU needs to be awoken to process it.
                So, this is different than the easier case (which I already have working) of sleeping the CPU, then it wakes up every, say, 100ms, and then the CPU controls the radio to listen for packets and then takes action if one is received. Instead, this is a case where the PPI is controlling the radio while the CPU sleeps.
                The PPI has a lot of power saving potential, so we're figuring out how best to exploit that potential.
                Also, the more general topic of how to use interrupts and ISR's on the nRF52832 (such as how many different ones can be active at once, as supported by the current development code) needs to be addressed, independent of the regular sleep(..) function.
                rmtuckerR 1 Reply Last reply
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                    [[topic:post-is-deleted]]
                    #878
                    All we need right now is a controller that covers the majority of home use.
                    Tried domoticz for 2 years and it covers energy use and cost really well but then is limited to saving data every 5mins and no mixed/multisensor graphs to any extent so useless for my current needs.
                    Tried myHouse for 6 months and it,s graphing was great but the display of binary sensors were not in real time and it does not do energy use at all.
                    I can not find a controller that seems to cover average needs for automation/energy/and realtime feedback.
                    I know it's a little off topic but it is a big problem when you can build the range of mysensors using the nrf5 but then not be able to get the feedback and energy/cost stuff on the screen.
                    Maybe i am just disgruntled that the controllers do not seem to keep up with the electronics very well.
                    Yes, agreed, but please let's not go into that here, because it would seriously throw us off topic. You might try: https://forum.mysensors.org/topic/7178/are-folks-here-happy-with-domoticz/63 which has some useful suggestions, especially regarding Node Red and MQTT.
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      Sorry mate i have deleted it i am just a little miffed with the controller searching:angry:
                        @d00616
                        #include <nrf.h>
                        int interrupt = 0;
                          // Configure RTC
                          // Enable interrupt
                          Serial.println();
                          Serial.println();
                          Serial.print(" ");
                          Serial.print(" ");
                          sleep(10000);
                                event = 0;        \
                                (void)event
                        #880
                        OK, the file core_cm4.h is where the structure that contains the SCR is defined:
                        typedef struct
                          __IM  uint32_t CPUID;                  /*!< Offset: 0x000 (R/ )  CPUID Base Register */
                          __IOM uint32_t ICSR;                   /*!< Offset: 0x004 (R/W)  Interrupt Control and State Register */
                          __IOM uint32_t VTOR;                   /*!< Offset: 0x008 (R/W)  Vector Table Offset Register */
                          __IOM uint32_t AIRCR;                  /*!< Offset: 0x00C (R/W)  Application Interrupt and Reset Control Register */
                          __IOM uint32_t SCR;                    /*!< Offset: 0x010 (R/W)  System Control Register */
                          __IOM uint32_t CCR;                    /*!< Offset: 0x014 (R/W)  Configuration Control Register */
                          __IOM uint8_t  SHP[12U];               /*!< Offset: 0x018 (R/W)  System Handlers Priority Registers (4-7, 8-11, 12-15) */
                          __IOM uint32_t SHCSR;                  /*!< Offset: 0x024 (R/W)  System Handler Control and State Register */
                          __IOM uint32_t CFSR;                   /*!< Offset: 0x028 (R/W)  Configurable Fault Status Register */
                          __IOM uint32_t HFSR;                   /*!< Offset: 0x02C (R/W)  HardFault Status Register */
                          __IOM uint32_t DFSR;                   /*!< Offset: 0x030 (R/W)  Debug Fault Status Register */
                          __IOM uint32_t MMFAR;                  /*!< Offset: 0x034 (R/W)  MemManage Fault Address Register */
                          __IOM uint32_t BFAR;                   /*!< Offset: 0x038 (R/W)  BusFault Address Register */
                          __IOM uint32_t AFSR;                   /*!< Offset: 0x03C (R/W)  Auxiliary Fault Status Register */
                          __IM  uint32_t PFR[2U];                /*!< Offset: 0x040 (R/ )  Processor Feature Register */
                          __IM  uint32_t DFR;                    /*!< Offset: 0x048 (R/ )  Debug Feature Register */
                          __IM  uint32_t ADR;                    /*!< Offset: 0x04C (R/ )  Auxiliary Feature Register */
                          __IM  uint32_t MMFR[4U];               /*!< Offset: 0x050 (R/ )  Memory Model Feature Register */
                          __IM  uint32_t ISAR[5U];               /*!< Offset: 0x060 (R/ )  Instruction Set Attributes Register */
                                uint32_t RESERVED0[5U];
                          __IOM uint32_t CPACR;                  /*!< Offset: 0x088 (R/W)  Coprocessor Access Control Register */
                        } SCB_Type;
                        Unfortunately, I just checked its status, and it's already cleared. So, something else is causing the MCU to go back to sleep at the end of the ISR.
                        The problem is that an ISR needs to be as short as possible. If something more elaborate needs to happen as a result of an interrupt, whether it be printing a bunch of debug information or something else, it should happen outside the ISR. Right now I don't see how to do that, because the MCU always immediately goes back to sleep after the ISR finishes. I suppose it must be something inside the sleep(..) routine that causes this?
                          I suspect it may be the while statement in this part of the library code that's doing it:
                          int8_t hwSleep(unsigned long ms)
                          	hwSleepPrepare(ms);
                          	while (nrf5_rtc_event_triggered == false) {
                          		hwSleep();
                          	hwSleepEnd(ms);
                          	return MY_WAKE_UP_BY_TIMER;
                            	hwSleepPrepare(ms);
                            		hwSleep();
                            	hwSleepEnd(ms);
                            #882
                            Yup, that was it. I excised the while-loop and re-wrote it as a differently named function, which I now call instead of sleep(..):
                            int8_t myHwSleep(unsigned long ms)
                              hwSleepPrepare(ms);
                              //while (nrf5_rtc_event_triggered == false) {
                                hwSleep();
                              hwSleepEnd(ms);
                            and it now works "correctly"--well, at least what I want it to do. :) I'll flag it for @d00616, who may have good reasons for keeping it as-is.
                              It looks like you are implementing a new radio protocol and you are coming forward.
                              Yes, I'm presently focused on trying to reduce the amount of energy consumed by probably the hardest case of all: a battery/solar/supercap receiver that needs to be both highly responsive (within 100ms) and listening 24/7 without running out of juice. Of course, one can always throw bigger batteries or bigger solar panels at the problem, but I'm first trying to be as ultra efficient as possible so that won't be necessary. The benefit will be smaller size, not to mention lower cost.
                              I am posting my findings as I go because there is precious little in the way of working examples, so I may yet still be of help to others in that way. From the view count, it does seem that people are reading this thread, even if not many are posting.
                              O
                              O
                              Omemanti
                              I follow your journey with great interest, one day Ill find the time to do something with it :)
                              • rmtuckerR
                                rmtuckerR
                                rmtucker
                                Just wondering if ota updates are possible with the nrf5 because it does not have the usual memory constraints?
                                  #885
                                  Epilog: It turns out that the reason I was getting erroneous readings of RSSISAMPLE by the CPU is that the radio must be turned-on when that register is being read. I had hoped it was being stored somewhere else in memory, but it's not. So, probably the best that can be done from an energy standpoint is to have the PPI pipeline the waking of the radio and the CPU from sleep, such that neither is waiting for the other to wake up in order to get work done. Ideally, the moment the RSSI measurement is taken by the PPI, the CPU would have just then fully woken up and be able to evaluate RSSISAMPLE, while the radio is still turned on.
                                  A different approach would be to have the PPI cyclically wake the radio into Rx mode for a period of time and then shut it down. If it received a packet, it would trigger a wake-up on the CPU. This is more or less how the RFM69's "listen mode" works. I may give this a try also so as to measure whether total current consumed is greater or less than the current consumed by the revised RSSI approach (above). I think it might. Although the radio has to remain on longer than it would if it were doing purely an RSSI measurement, it has the advantage that the CPU can remain asleep until an actual packet is received. Given that the radio spends a lot of time just ramping up after being disabled, I'm guessing the incremental Rx time needed for packet detection won't seem so much in comparison. The hard part to this approach will be timing just how long the Radio is in RX mode. Although there are technically three RTC instantiations that can be used, they all share the same prescaler.
                                  So, in order to create a short delay timer, I set one GPIO pin high, which charges a second GPIO pin through a very small capacitor and diode in parallel. Then, when the first GPIO pin goes low, the voltage on the second GPIO pin decays. By setting a PPI event on the second pin to trigger from a Hi2Lo transition, I'm able to create an analog delay, which varies in duration depending on the value of the capacitor. Presently, using a 2.2nF capacitor creates about a 2ms delay between the first pin going LOW and the second pin detecting a Hi2Lo event. It is that event which could be used to trigger turning off the radio after it has listened for packets, whereas it is the first pin going LOW that would have triggered turning on the radio and putting it into RX mode. This is all controlled by the PPI, so no energy needs to be used by the CPU. :)
                                  If anyone can think of a better or more of a digital way to create a predictable time delay, please do post. However, I'm using this method for now just for proof of concept purposes.
                                    #886
                                    Here's a scope capture of it:
                                    The yellow line shows the rapid charging and then subsequent decay of voltage on the second pin. The blip on the blue line shows that after slightly more than 2ms, the Hi2Lo event was triggered, because the voltage on the second pin had dropped enough for the Hi2Lo transition to occur. As you can see, it happens at around 1v. I was able to capture it on the scope because I used that event to very briefly set a third pin (the one whose voltage is being tracked by the blue line) HIGH.
                                    Again, all of this is being managed by the PPI while the CPU is asleep. :)
                                    • d00616D
                                      d00616D
                                      d00616
                                      If your goal is to minimize the RX-on time, then you can trigger the RX start and stop by a timer for your minimal window where the frame must be start. Then use the bitcounter top stop the timer in case a packet is received. A shortcut to the end is disabling the RX mode. You can wakeup the CPU with the END event.
                                      P.S.: you can reduce the RX/TX time by enabling fast ramp up in MODECNF0 if you haven't to care about nRF51 compatibility.
                                      • d00616D d00616
                                        #888
                                        Thanks! It finally dawned on me that having the PPI use the RTC's CC registers would be a far better way to schedule turning on and off the radio's RX than using the stopgap analog delay that I had devised (above). Your interrupt handler example helped me see what had been staring me in the face the entire time, but without my recognizing it as the answer to the problem. Funny how that can sometimes happen, where the whole gestalt can just suddenly change. So, thanks again for sharing your example code. This will be a much less awkward solution! :)
                                          Where exactly do I look to find all the pin mappings that are assumed for the "Generic nRF52" board? For example, what are the pin numbers that are assumed for RXI, TXO, MISO, MOSI, etc.?
