  3. Mysensors si7021 sketch
11 Posts 5 Posters 3.8k Views 4 Watching
  • T Tommas
    Dear All!
    Has anybody a sketch for this temperature and humidity sensor? I would like to use it with mini pro combined easypcb board.
    Thank you in advance!
    sundberg84S
    sundberg84S
    @Tommas - some resources i found.
    https://forum.mysensors.org/topic/2432/si7021-multisensor-first-try
    https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries/SI7021
    https://forum.mysensors.org/topic/6434/solved-problems-with-an-si7021-temp-humidity-sensor/3
    T 2 Replies Last reply
    • sundberg84S sundberg84
      Tommas
      Dear @sundberg84
      Thanks for the suggestions!
      Another, which pin should i connect to the si7021? I cant find this info...
      • T Tommas
        Dear @sundberg84
        @Tommas the si7021 uses i2c so you can use the wiring described at https://www.mysensors.org/build/light-bh1750 which also is an i2c device.
          Tommas
          wrote on last edited by Tommas
          Dear @mfalkvidd !
          Thank you, and to everyone for the help!
          I got it work!
          If the sketch will be completed i will upload that!
            Tommas
            @sundberg84
            What is the problem with my sketch? It is in developement phase, but the reading stops at this line, but sometimes it works for 3-4 loop...
            " DEBUG_PRINTLN("Send TEMP and HUM started"); "
             * Version 1.0: Henrik EKblad
             * sensor using a DHT11/DHT-22.
            #define MY_NODE_ID 4
            // Enable debug prints
            //#define MY_RS485
            by m26872, 20151109
            #include <SI7021.h>
            #include <RunningAverage.h>
            #define DEBUG
            #ifdef DEBUG
            #define NODE_ID 4             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
            #define CHILD_ID_TEMP 0
            #define CHILD_ID_HUM 1
            //#define SLEEP_TIME 15000 // 15s for DEBUG
            #define SLEEP_TIME 10000   // 5 min
            //#define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
            #define FORCE_TRANSMIT_CYCLE 1  // 5min*12=1/hour, 5min*36=1/3hour
            //#define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
            //#define VMIN 1900
            //#define VMAX 3300
            #define AVERAGES 2
            //int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
            int measureCount = 0;
            float lastTemperature = -100;
            int lastHumidity = -100;
            SI7021 humiditySensor;
            //MySensor gw;
            void presentation(){
            sendSketchInfo("Node 4, Temp,Hum sensor", "1.1");
              present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
              present(CHILD_ID_HUM, S_HUM);
              DEBUG_SERIAL(115200);
              //DEBUG_PRINT("Voltage: ");
              //DEBUG_PRINT(readVcc());
              //DEBUG_PRINTLN(" mV");
              delay(500);
              DEBUG_PRINTLN(" *C");
              //begin(NULL,NODE_ID);
              //DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
              raHum.clear();
              DEBUG_PRINTLN("Loop started");
              measureCount ++;
              bool forceTransmit = true;
              //if (measureCount > FORCE_TRANSMIT_CYCLE) {
              //forceTransmit = true;
              sleep(SLEEP_TIME);
              DEBUG_PRINTLN("Loop ended");
             * Parameters
              bool tx = force;
              float temperature = data.celsiusHundredths / 100.0;
              //if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
              //lastTemperature = temperature;
              //measureCount = 0;
              DEBUG_PRINTLN("T sent!");
              raHum.addValue(humidity);
              //if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
              //lastHumidity = humidity;
              //measureCount = 0;
              DEBUG_PRINTLN("H sent!");
            • T Tommas
              @sundberg84
              //#define MY_RS485
              by m26872, 20151109
              #include <SI7021.h>
              #define DEBUG
              #ifdef DEBUG
              //#define VMIN 1900
              //#define VMAX 3300
              #define AVERAGES 2
              //MySensor gw;
                delay(500);
                raHum.clear();
                measureCount ++;
                sleep(SLEEP_TIME);
               * Parameters
                bool tx = force;
                //measureCount = 0;
                //measureCount = 0;
              sundberg84S
              sundberg84S
              @Tommas - sorry, im not the code expert...
              If it stops without any indication why it can be a power issue as well.
                Tommas
                @sundberg84
                There arent any indication. Sometimes it works.... i tried another si7021 and same. Voltage is Ok. A connected the sda - A4 scl - A5 on easypcb board
                Any idea?
                • T Tommas
                  @sundberg84
                  Any idea?
                  @Tommas do you have pullups (around 10k) at sda & scl lines?
                  • YveauxY Yveaux
                    Tommas
                    Dear @Yveaux
                    I think that yes. The si7021 module has an smd 103 part on it. Maybe it is at the sda and scl but im not sure.
                    https://www.ebay.com/i/401364416322
                    • Nca78N
                      you are missing the sensor.begin() to initialize the sensor. Return value will tell you if initialization succeeded or not.
                      if (!sensor.begin()) {
                      #ifdef MY_DEBUG
                          Serial.println("FAILED TO INIT SENSOR !!!!");
