  3. nRF5 action!
nRF5 action!
    #928
    However, there's one fly in the ointment remaining. It turns out that some other timer is sometimes waking up the CPU:
    time=15798, Radio STATE=0, COUNTER=0x49, packetCounter=22
    time=15900, Radio STATE=0, COUNTER=0x49, packetCounter=23
    time=16001, Radio STATE=0, COUNTER=0x49, packetCounter=24
    time=16103, Radio STATE=0, COUNTER=0x49, packetCounter=25
    time=16204, Radio STATE=0, COUNTER=0x49, packetCounter=26
    time=16306, Radio STATE=0, COUNTER=0x49, packetCounter=27
    time=512000, Radio STATE=0, COUNTER=0x2035, packetCounter=27
    time=1024000, Radio STATE=0, COUNTER=0x269, packetCounter=27
    time=1536000, Radio STATE=0, COUNTER=0x1803, packetCounter=27
    time=2048000, Radio STATE=3, COUNTER=0x36, packetCounter=27
    time=2560000, Radio STATE=0, COUNTER=0x1570, packetCounter=27
    time=3072000, Radio STATE=0, COUNTER=0x3104, packetCounter=27
    time=3584000, Radio STATE=0, COUNTER=0x1337, packetCounter=27
    time=4096000, Radio STATE=0, COUNTER=0x2871, packetCounter=27
    time=4608000, Radio STATE=0, COUNTER=0x1104, packetCounter=27
    time=5120000, Radio STATE=0, COUNTER=0x2638, packetCounter=27
    All the lines labelled packetCounter=27 (after the first one that is) are a result of this. Looking at the time, they appear to happen on the rollover of some other timer (?)--apparently the one that is responsible for keeping track of millis(). I can filter them out after-the-fact, but I'd rather they not be waking up the CPU for no reason, as that is just a waste of energy.
      @d00616
      Can you see any reason as to why the radio isn't waking the MCU after it receives a packet? Here's the entire sketch:
      #include <nrf.h>
      //#include <MySensors.h>
      #include <RH_NRF51.h>
      // Singleton instance of the radio driver
      RH_NRF51 nrf51;
      bool toggle=true;
      uint32_t packetCounter=0;
      uint8_t myBuffer[20];  //required buffer for transmitting packet
      uint8_t my_default_network_address[] = {0xE7, 0xE7, 0xE7, 0xE7, 0xE7};
      bool mySetNetworkAddress(uint8_t* address, uint8_t len)
          if (len < 3 || len > 5)
        return false;
          // First byte is the prefix, remainder are base
          NRF_RADIO->PREFIX0    = ((address[0] << RADIO_PREFIX0_AP0_Pos) & RADIO_PREFIX0_AP0_Msk);
          uint32_t base;
          memcpy(&base, address+1, len-1);
          NRF_RADIO->BASE0 = base;
          NRF_RADIO->PCNF1 =  (
        (((sizeof(myBuffer)) << RADIO_PCNF1_MAXLEN_Pos)  & RADIO_PCNF1_MAXLEN_Msk)  // maximum length of payload
        | (((0UL)        << RADIO_PCNF1_STATLEN_Pos) & RADIO_PCNF1_STATLEN_Msk) // expand the payload with 0 bytes
        | (((len-1)      << RADIO_PCNF1_BALEN_Pos)   & RADIO_PCNF1_BALEN_Msk)); // base address length in number of bytes.
          return true;
        // Idle serial device
        NRF_UART0->TASKS_STOPRX = 1;
        NRF_UART0->TASKS_STOPTX = 1;
        NRF_UART0->TASKS_SUSPEND = 1;
        NRF_POWER->TASKS_LOWPWR = 1;
      // Sleep in System ON mode
      inline void doTheSleep()
        __WFE();
        __SEV();
        __WFE();
        // Start HFCLK
        //if (nrf5_pwr_hfclk) {
        if (false) {
          NRF_POWER->TASKS_CONSTLAT = 1;
         // Start serial device
      //#ifndef MY_DISABLED_SERIAL
        NRF_UART0->TASKS_STARTRX = 1;
        NRF_UART0->TASKS_STARTTX = 1;
      //#endif
        myHwSleepPrepare(ms);
        doTheSleep();
        //now sleeping
        myHwSleepEnd(ms);
        Serial.begin(250000);
        Serial.println();
        Serial.flush();
        // Configure RTC
        NRF_RTC0->TASKS_STOP = 1;  //stop the RTC counter so that it can be configured without incident
        // Enable interrupt
        //NVIC_SetPriority(GPIOTE_IRQn, 15);
        //NVIC_ClearPendingIRQ(GPIOTE_IRQn);
        //NVIC_EnableIRQ(GPIOTE_IRQn);
        NVIC_SetPriority(RADIO_IRQn, 15);
        NVIC_ClearPendingIRQ(RADIO_IRQn);
        NVIC_EnableIRQ(RADIO_IRQn);
        NRF_RADIO->INTENSET = B1000;  //interrupt MCU if a packet is received.
        while (NRF_RADIO->INTENSET != B1000) {}  //wait until confirmed
        //NRF_GPIOTE->INTENSET = 1;  //interrupt MCU if change detected on pin P0.16.
        //while (NRF_GPIOTE->INTENSET != 1) {}  //wait until confirmed
        Serial.print("LFCLKSTAT=0X");
        Serial.print(NRF_CLOCK->LFCLKSTAT,HEX);
        Serial.print("=B");
        Serial.println(NRF_CLOCK->LFCLKSTAT,BIN);
        Serial.flush();
        NRF_RADIO->FREQUENCY=123;
        NRF_RADIO->MODE=1;  //set 2Mbps datarate.
        NRF_RADIO->MODECNF0=1;  //enable fast ramp-up of radio from DISABLED state.
        if (!nrf51.init())
          Serial.println("init failed");
        mySetNetworkAddress(my_default_network_address, sizeof(my_default_network_address));
        if ((NRF_CLOCK->LFCLKSTAT)>>2) {//if LF clock is running
          NRF_CLOCK->TASKS_LFCLKSTOP=1;  //stop the clock
          while ((NRF_CLOCK->LFCLKSTAT)& 1)  {}  //busy-wait until LF clock has stopped running
          Serial.println("LF clock is stopped.");
        Serial.print("LFCLKSTAT=0x");
        Serial.print("=B");
        Serial.flush();
        while (!(NRF_CLOCK->LFCLKSRC=1)) {}  //
        Serial.println("Crystal oscillator is now the LF choice.");
        Serial.print("=B");
        Serial.flush();
        Serial.println("Low Frequency crystal oscillator started.");
        Serial.flush();
        Serial.print("=B");
        Serial.print("LFCLKSRC=0x");
        Serial.print(NRF_CLOCK->LFCLKSRC,HEX);
        Serial.print("=B");
        Serial.println(NRF_CLOCK->LFCLKSRC,BIN);
        Serial.print("Present PRESCALER=");
        Serial.println(NRF_RTC0->PRESCALER);
        Serial.print("=B");
        NRF_RTC0->PRESCALER=0;  //32768 frequency
        while (NRF_RTC0->PRESCALER!=0)  {}  //busy-wait until pre-scaler changes
        Serial.print("New PRESCALER=");
        Serial.println();
        Serial.println("Finished setup.");
        Serial.flush();
        //Radio enters RXIDLE soon after COUNTER overflows.
        NRF_RTC0->CC[0] = 24;  //the time to exit RX state.
        NRF_RTC0->CC[1] = 25;  //the time to put radio to sleep from RXIDLE
        NRF_RTC0->CC[2] = 3300;  //the time to restart the cycle
        NRF_RTC0->EVENTS_COMPARE[0] = 0;  //Clear the event flag.
        NRF_RTC0->EVENTS_COMPARE[1] = 0;  //Clear the event flag.
        NRF_RTC0->EVENTS_COMPARE[2] = 0;  //Clear the event flag.
        //Configure GPIOTE
        NRF_GPIOTE->CONFIG[0]=0x31001;  // Toggle Event; Pin P0.16; Event Mode
                                        //So, any pin change on P0.16 will trigger an event.
                                         //On the Nordic nRF52 DK, Pin 0.16 is a button.
        NRF_GPIOTE->CONFIG[1]=0x131203;  //Initial setting: HIGH; Toggle Task; Pin P0.18; Task Mode
                                         //On the Nordic nRF52 DK, Pin 0.18 is an LED.
                                         //Note: initial setting of HIGH means that the LED will be initially OFF.
        NRF_GPIOTE->CONFIG[2]=0x131103;  //Initial setting: HIGH; Toggle Task; Pin P0.17; Task Mode
                                         //On the Nordic nRF52 DK, Pin P0.17 is an LED.
        //Note: radio is assumed to be sleeping by this point, and with high frequency crystal oscillator turned off.
        NRF_PPI->CH[0].EEP = (uint32_t)&NRF_RTC0->EVENTS_OVRFLW;  //when COUNTER overflows.
        NRF_PPI->CH[0].TEP = (uint32_t)&NRF_CLOCK->TASKS_HFCLKSTART;  //turn on the HF crystal oscillator
        NRF_PPI->CH[1].EEP = (uint32_t)&NRF_CLOCK->EVENTS_HFCLKSTARTED;  //After HF Clock started.
        NRF_PPI->CH[1].TEP = (uint32_t)&NRF_RADIO->TASKS_RXEN;  //turn on the radio receiver
        //NRF_PPI->FORK[1].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[0]; //Make pin P0.18. be HIGH
        NRF_PPI->CH[2].EEP = (uint32_t)&NRF_RADIO->EVENTS_READY;  //After event READY, radio shall be in state RXIDLE.
        NRF_PPI->CH[2].TEP = (uint32_t)&NRF_RADIO->TASKS_START;  //Move from RXIDLE mode into RX mode.
        NRF_PPI->CH[3].EEP = (uint32_t)&NRF_RTC0->EVENTS_COMPARE[0];  // If time to turn off the radio receiver
        NRF_PPI->CH[3].TEP = (uint32_t)&NRF_RADIO->TASKS_STOP; //Move radio from RX mode back into RXIDLE mode
        NRF_PPI->CH[4].EEP = (uint32_t)&NRF_RTC0->EVENTS_COMPARE[1];  // If enough time has passed
        NRF_PPI->CH[4].TEP = (uint32_t)&NRF_RADIO->TASKS_DISABLE; //Sleep the radio
        NRF_PPI->FORK[4].TEP = (uint32_t)&NRF_CLOCK->TASKS_HFCLKSTOP; //Turn off the high frequency crystal oscillator
        NRF_PPI->CH[5].EEP = (uint32_t)&NRF_RTC0->EVENTS_COMPARE[2];  // If 100ms has passed
        NRF_PPI->CH[5].TEP = (uint32_t)&NRF_RTC0->TASKS_TRIGOVRFLW; //Set COUNTER so that it will overflow in 16 ticks.
        NRF_PPI->CH[6].EEP = (uint32_t)&NRF_RADIO->EVENTS_END;  //packet received.
        NRF_PPI->CH[6].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[1]; //Make pin P0.18. be LOW (turn on the LED).
        NRF_PPI->CH[7].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[0];  //P0.16 pin change occured.
        NRF_PPI->CH[7].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[2]; //Make pin P0.17. be LOW (turn on the LED).
        NRF_PPI->CHENSET=B11111111; //enable Channels 7,6,5,4,3,2,1,and 0.
        Serial.println("Crystal oscillator started.");
        Serial.flush();
        NRF_RTC0->EVTENSET=0x70003;  //enable routing of RTC TICK, OVRFLW, and comparison events to PPI for the comparisons
        while (NRF_RTC0->EVTEN!= (0x70003)) {};  //wait until EVTENSET setting is confirmed.
        NRF_RTC0->EVENTS_TICK=0;  //clear TICKS flag
        NRF_RTC0->EVENTS_OVRFLW=0;  //clear overflow flag
        NRF_RADIO->EVENTS_END=0;  //clear payload received flag.
        NRF_CLOCK->TASKS_HFCLKSTOP=1;  //Turn off the high frequency crystal oscillator.
        NRF_RTC0->TASKS_TRIGOVRFLW=1;  //prepare COUNTER so that an overflow will ensue in 16 ticks.
        while (NRF_RTC0->COUNTER!=0xFFFFF0) {} //wait until COUNTER is primed to overflow.
        NRF_RTC0->TASKS_START=1;  //  Resume the RTC, which had been paused.
        while ((NRF_RTC0->EVENTS_TICK==0)) {}  //wait until the radio is confirmed to be started.
      uint32_t loopCounter=0;
        Serial.print("time=");
        Serial.print(millis());
        Serial.print(", packetCounter=");
        Serial.println(packetCounter);
        Serial.flush();
        myHwSleep(500000000);  //sleep 100ms.  Already offset in setup by 1ms from wake-up of PPI.
      #if __CORTEX_M == 0x04
              event = 0;        \
              (void)event
      // This must be in one line
      extern "C" { void RADIO_IRQHandler(void) {packetCounter++; NRF5_RESET_EVENT(NRF_RADIO->EVENTS_END); NRF_RADIO->EVENTS_END=0; }}
      The PPI does toggle an LED each time it receives a packet, but unfortunately the CPU remains asleep. Nonetheless, it does seem to follow your prescription for the ISR.
      d00616D
      d00616D
      d00616
      @d00616
      I have no Idea why. The code is looking fine.
        #930
        FWIW, I noticed on the oscilliscope that turning on-and-off the HFCLK ten times a second produces a fair amount of ringing. If I simply leave HFCLK turned on, most of the ringing is eliminated.
        [Edit: So, if doing this as part of an aggressive energy saving approach (for instance, turning OFF HFCLK after RX mode and later turning it on again before initiating a new RX), what sort of extra circuitry beyond the two inductors for the DCDC might be needed? I don't know that the ringing is causing any actual problems, but it doesn't look proper on a scope. For now, I'm just flagging it so that folks are aware of it as a possible issue. ]
          #931
          To better quantify the issue, I measured sleep currents (now using sleep routines that are a fork from what's in mysensors.h), and with the High Frequency clock turned OFF, the sleep current is measured at 2.2ua using a uCurrent Gold. However, the same setup, but with the High Frequency clock left ON, the sleep current is measured at 596ua using the same a uCurrent Gold.
          So, clearly, for a battery/supercap application, leaving the High Frequency clock running all the time is not an especially good option.
          rmtuckerR 1 Reply Last reply
            rmtuckerR
            rmtuckerR
            rmtucker
            I am puzzled with your 596ua?
            I thought you were under 10ua with the mysensors sleep some time ago?
            Mine only measures 4-5ua when in sleep?
              • rmtuckerR rmtucker
                There's no contradiction. It's a different scenario. The MySensors hwSleep function turns off the High Frequency oscillator when sleeping and turns it back on when it wakes up. So, it's perfectly fine for sleeping your device, having it wake up to send something, and then go back to sleep.
                The present scenario that I'm working on though is where the MCU sleeps and the PPI manages a "listen mode" where the PPI wakes up the radio once every 100ms for a roughly 200us window of time to listen for an incoming packet. Then it goes back to sleep if nothing is received. On the other hand, if a packet is received, it wakes up the MCU so that the packet can be read and dealt with. Presently I have the PPI turn off the high-frequency oscillator each time after it has finished RX in the listen-mode cycle. Before entering RX again to listen for a new packet, it first ramps up the high frequency oscillator. According to the datasheet, the high frequency crystal oscillator must be operating in order for the radio to either transmit or receive. i.e. it can't simply run off the high frequency RC oscillator the way the MCU can.
                My measurements show that while the High Frequency oscillator is running, it consumes about 596ua.
                  Mike_Lemo
                  Did anyone managed to get two NRF52832 to connect to each other with the arduino IDE and communicate?
                  Also why does I2C initializes only after an SWD programmed gets connected?
                  Wierd phenomenon when I use an I2C oled display with that chip and program it with an st link V2 after it displays alright when it's booted if the SWD programmer is connected but as soon as you disconnect it everything else works but the I2C display...
                  NeverDieN U 2 Replies Last reply
                  • M Mike_Lemo
                    #936
                    Yes. @d00616's demo code will do this.
                    I don't know the answers to the rest of your questions, because I don't use the ST.
                      #937
                      Here's a scopeshot of how the revised current draw looks:
                      As you can see, there is now about a 370us warm-up time at the beginning for the High Frequency oscillator to come up to speed before the RX cycle can be started. Then it takes about 100us for the receiver to warm-up to RXIDLE. From there it finally achieves about 200us of actual productive RX time. Then everything powers down until the end of the 100ms cycle, after which it all repeats again. To conserve energy, all this is managed by the PPI while the MCU sleeps.
                      Scale: 1mv=1ma
                      I think this is about as energy efficient as it's ever going to get, short of chipping away at the number of bits in the frame/packet size, as I indicated earlier.
                        Mike_Lemo
                        wrote on last edited by Mike_Lemo
                        #938
                        Any idea how I reach to this code?
                        Also you say you don't experience any issues with I2C like that?
                        • M Mike_Lemo
                          #939
                          Yes, it's all explained in detail by @d00616 here: https://www.openhardware.io/view/376/MySensors-NRF5-Platform
                          Haven't tried I2C on this platform yet. I'd be very surprised if it didn't work though, as that's ARM Cortex M4 stuff, which is well vetted. i.e. no real dependency on anything Nordic per se.
                            Mike_Lemo
                            The link you attached links me to a getting started page not wireing two nrf's together
                            NeverDieN M 2 Replies Last reply
                            • M Mike_Lemo
                              #941
                              Your question was ambiguous. When you said "connect" I just assumed you meant wirelessly connect.
                              Sorry, I can't help you. Seems like @scalz has gotten I2C to work with it though, but more likely for reading a TH sensor than for the purpose of wiring two nRF52832's. Still, that would prove that it works. If you know the I2C protocol, it shouldn't be hard to go from that to wiring two nRF52832's together.
                                Scale: 1mv=1ma
                                #942
                                I also measured the current between the peaks shown in the scopeshot. By increasing the period between listens, I was able to do the measurement using a uCurrent Gold. Doing so, I found that the current drawn was 10.7ua using the Low Frequency crystal oscillator, and 11.2ua using the Low Frequency RC oscillator. I'm now sure how to square that with some of the earlier measurements I had taken with the nRF52832 sleeping using the MySensors sleep routine, as those measurements came out to about 6ua. Perhaps the difference is the extra current required to run the PPI in this configuration? With neither oscillator configured, and no PPI, it measures, as I said earlier, at 2.2ua, which is close to what the datasheet predicts.
                                • M Mike_Lemo
                                  Mike_Lemo
                                  Yes I did mean wirelessly like central and peripherial connection... Is that supported?
                                  scalzS 1 Reply Last reply
                                    #944
                                    I'm sorry, but I can't help you any more than I already have.
                                      Scale: 1mv=1ma
                                      #945
                                      Epilog: I ran it overnight on a 10F capacitor, and it dropped only 0.011v per hour. I'm very happy with that, considering it's listening every 100ms as to whether or not it has received a packet. :)
                                        #946
                                        @d00616 Your posting says,
                                        At the moment on Arduino, there is no definition of various OUTPUT modes. If you want to access all nRF5 output modes, you have to use hwPinMode and the OUTPUT_... macro.
                                        Exactly which macro would that be? It looks to me as though what most users will want is the function nrf5_pinmode(..,..), which appears to do all the actual work. Is that right? It is defined in the file nrf5_wiring_digital.c.
                                        Meanwhile, hwPinMode appears to be merely a straight pass-through for pinMode:
                                        void hwPinMode(uint8_t pin, uint8_t mode)
                                          pinMode(pin, mode);
                                          Mike_Lemo
                                          Where is it possible to find a reference schematic for using the NTF52832 E73-2G4M04S module with NFC?
                                          not much is being given in the datasheet not even where the NFC pins go.
                                          d00616D T 2 Replies Last reply
