  2. Announcements
  3. 💬 Debugging Sensors and the Gateway
21 Posts 10 Posters 11.6k Views 10 Watching
    Not sure I understand...
    If you enable debug on gateway, I_LOG entries (with the debug information) is sent over ethernet (or serial) depending on the variant you use.
    NiklasON 1 Reply Last reply
      NiklasON
      NiklasON
      NiklasO
      wrote on last edited by NiklasO
      @hek Really? That's nice. I use Sensebender GW with #define MY_DEBUG and #define MY_GATEWAY_W5100. Maybe using MY_SPECIAL_DEBUG?
      gohanG 1 Reply Last reply
        Oh, the sensebender gateway might be different as it has a some additional functionality (multi hardware serial ports). Need to ping @tbowmo for a correct answer here.
        • NiklasON NiklasO
          @NiklasO if you want to debug the gateway you could use the MYSController and connect it to the ethernet gateway over LAN.
          • NiklasON
            NiklasON
            NiklasO
            Ah, I see. The "MySensors Debug" does only show data when you use the serial connection?
            • tbowmoT
              tbowmoT
              tbowmo
              If you have configured it as a ethernet GW, it still dumps debug data to the serial port.
              Once I had plans to make a tcp connection to a debug channel, but never got any further with it.
                Debugging over Lan connection is so much simpler because you can leave the gateway in its place and move around with your laptop 😁
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @gohan
                  I totally agree, but there is only 24 hours a day.. With family, work etc there is just not enough time to realize all my ideas. :)
                    Sure, that's why I suggested to use myscontroller since it can be used to debug pretty much everything you need to know out of the gateway.
                    • EduardoE
                      EduardoE
                      Eduardo
                      Anyone knows what happened to The Transport messages (TSM & TSF) and MySensors Core messages (MCO) links? I get a message from Jenkins saying "<user> is missing the Overall/Read permission".
                      Isn't it publicly available anymore? Or do I need to do something else?
                      • yogui79Y
                        yogui79Y
                        yogui79
                        hello
                        the links to "The Transport messages " and "The MySensors Core messages" are brocken
                        • yogui79Y yogui79
                          hello
                          @yogui79 thanks for reporting. I've fixed them now. Adding them below for reference:
                          The Transport messages (TSM & TSF) are described here.
                          The MySensors Core messages (MCO) are described here
                          • jopebeJ
                            jopebeJ
                            jopebe
                            The MySensors Core messages (MCO) are described here = broken!?!
                            • jopebeJ jopebe
                              @jopebe thanks for noticing. The link ended in .htmls instead of .html. Fixed now.
                              • user1306U
                                user1306U
                                user1306
                                my home has many sensors all built on my sensors library, (around 40 devices and 80+ sensors) as you can imagine it’s big network.
                                from time to time messages don’t get through, and when a sensor first start it take a long time to connect.
                                i was doing some testing the other day and i left the debug on the gateway turned on, and noticed things are working 10 times better, sensors connect immediately i can send multi command at the same time and they all reach their target (Home assistant turning multiple lights).
                                is this normal? did anyone notice this as well?
                                not sure why, maybe the delay it creates when it writes to Serial is making it work better?
                                mfalkviddM alexeliteA 2 Replies Last reply
                                • user1306U user1306
                                  @user1306 yes, this has been reported by multiple users.
                                  user1306U 1 Reply Last reply
                                    user1306U
                                    user1306U
                                    user1306
                                    @mfalkvidd
                                    Thanks, and please let me know if i can help in some way
                                      alexeliteA
                                      alexeliteA
                                      alexelite
                                      What type of gateway and radio do you use?
                                      • alexeliteA alexelite
                                        user1306U
                                        user1306U
                                        user1306
                                        @alexelite
                                        I’m using Arduino Nano connected through Serial
                                        radio is nrf24l01+ PA LNA connected to the 3.3 converter module and powered separately
