  3. nRF5 action!
nRF5 action!
  • M Mike_Lemo
    @scalz
    Yeah but my question was about what is connected in the module and what components I have to use....
    Also about the NFC I'm planning to use it with the arduino IDE so just wanted to ask if there is a library for it because the SDK is quite useless in this case as well as the Central peripheral connection.
    d00616D
    d00616D
    d00616
    Now there is a second port of arduino to nRF52. This includes some libraries, like NFC, but they using the SDK. MySensors is currently not ready for this arduino-port.
      I was able to reduce the active listen period to about 100us:
      Now listening every 100ms yields a 10F supercap voltage measured decline of just 9mv per hour. i.e. a decline of 0.108v by the end of 12 hours.
      d00616D
      d00616D
      d00616
      Great job. If I'm not wrong the method allows nearly 1 year of listening time with a CR2032.
      • M Mike_Lemo
        Where is it possible to find a reference schematic for using the NTF52832 E73-2G4M04S module with NFC?
        not much is being given in the datasheet not even where the NFC pins go.
        Toyman
        @Mike_Lemo your best bet is to "convert" the module to Arduino Primo and use the NFC libraries developed for it.
        d00616 gave you the link to the arduino org github. Pls. note that Primo core generates a merged softdevice+sketch hex so you should locate it in the Temp folder and upload.
          #957
          Here's a very simple OPEN/CLOSE remote control I was able to quickly throw together using my small prototyping board:
          It required only two buttons, a diode, a resistor, and (obviously) some wire. When not in use, everything is powered 100% OFF to save the most energy possible. So, pushing either button powers it ON, at which point it rapidly determines which button was pushed and then sends the corresponding packet to the receiver. From the standpoint of human perception, it all appears to happen instantly.
          Nca78N 1 Reply Last reply
            This is how the next version of the protoboard will look:
              #959
              Interestingly, it looks as though Arduino is suggesting/recommending users to use the regular Arduino Primo to program the Arduino Primo Core (i.e. the wearable).
                Toyman
                @NeverDie is this SWD?
                • T Toyman
                  #961
                  I don't have either the Primo or the Primo Core, so I can't say for sure. However, I presume so.
                  • M Mike_Lemo
                    Did anyone managed to get two NRF52832 to connect to each other with the arduino IDE and communicate?
                    Also why does I2C initializes only after an SWD programmed gets connected?
                    Wierd phenomenon when I use an I2C oled display with that chip and program it with an st link V2 after it displays alright when it's booted if the SWD programmer is connected but as soon as you disconnect it everything else works but the I2C display...
                    U
                    U
                    Uhrheber
                    @Mike_Lemo
                    This sounds more like an EMC issue.
                    The connected ST Link filters some disturbance at the i2c lines, and when it's not connected, the disturbance corrupts the signals.
                    Try connecting capacitors from the i2c lines to ground. I'd start with 100pF each.
                    May also be a power supply issue. Did you connect the st-link's 3.3V line to the board?
                      Here's the small budget nRF51 soldered to the breakout board that I had linked earlier above:
                        #964
                        I have the RTC running off the low frequency internal RC, because I don't see a crystal oscillator on the module. I have it blinking an LED now and sending text to the serial port, which I'm able to read on the serial console.
                        At least so far, all is good. :)
                          Hello @NeverDie, could you please share the code for this ?
                          I'd like to adapt and test it on a reprogrammed nrf51822 beacon that I just received.
                          • Nca78N Nca78
                            #966
                            @Nca78
                            I can, but it wouldn't be proper "mysensors" code, because mysensors code has a 5-10 second power-up delay. So, for that reason, it's using radiohead instead. Do you still want it anyway?
                              @Nca78
                              @Nca78
                              Ah I see, probably still interesting to see, please share anyway :)
                              • T
                                Toyman
                                wrote on last edited by Toyman
                                #968
                                I am trying to reprogram a commercial nrf51 module. Under "commerical" I mean "not from aliexpress", but installed in "smart" bluetooth socket.
                                I can connect to it with Black Magic Probe just fine, but after mass_erase, BMP reports 0xfffffffe instead of usual 0xffffffff, meaning something is lef behind. That prohibits reflashing of softdevice BUT I can load "plain" skethes that do not require softdevice
                                I ASSUME the module has some kind of write protection and/or UICR registers set that are not erased with BMP mass+erase command.
                                I've tried to load d0016 uuicr clearing sketch, It loads fine, but I've still got 0xfffffffe after masserase.
                                So what's the proper way to really completely erase the module?
                                I have nrf52 dk that I tried to use as a programmer but it didn't worked.
                                JokgiJ 1 Reply Last reply
                                • Nca78N Nca78
                                  @Nca78
                                  #969
                                  @Nca78
                                  Here it is, warts and all:
                                  0_1506603795796_remote_control_v031.zip
                                  It works, but it's just hastily improvised throw-away code, so I made no attempt to polish it. i.e. For anyone reading this: It is very definitely not demo code.
                                    I was thinking that maybe the Ebyte module is stuck in some kind of reset mode, but I just now checked pin P0.21 (the reset pin), and it measures high at 3.3v. This is the same as for the Sparkfun board, which I have no trouble programming. Reset is active low.
                                    JokgiJ
                                    JokgiJ
                                    Jokgi
                                    @NeverDie This may be old news but I will throw it out anyway. The Reset pin on the nRF52 series is both a GPIO and RESET line (one or the other) . This is not a dedicated Reset however and the application must define that pin as RESET. This is the only pin that can be defined as reset. The Datasheet describes this as well.
                                    • T Toyman
                                      JokgiJ
                                      JokgiJ
                                      Jokgi
                                      @Toyman What is the make and model of the module. You can use the nRF52-DK to erase the device. P20 is a ease access to the programming pins on that board. You need to power up the module, run the VDD from the module back to the dev kit , P20, Pin2. Hook up the SWDIO lines to Pin3 and the SWDCLK to Pin4. and Ground, Pin8. As reset is not hardwired you don't have to hook that up unless you want to (Pin7. . ![alt text](image url) You can use nRFJPROG to exersise the J-Link (Segger). This is found in the downloadable tools on the Nordic site. BTW - I have no problem using J-Link Commander version 6.20c with the nRF52-DK with the nRF52832 mounted. I hope this helped. 0_1506616486979_Programming using P20 on the dev kit.JPG
                                      • JokgiJ Jokgi
                                        Yes, and thanks to @d00616's work, RESET can also be enabled/disabled from the Tools menu of the arduino IDE if using myNRF5Board as the board definition.
                                        d00616D 1 Reply Last reply
                                          #973
                                          I just now compared the transmission range and packet loss of the cheap nRF51822 to the Ebyte nRF52832. I expected that the Ebyte, with its bigger and fancier antenna, to mop the floor with the nRF51822, but I was surprised to find that they actually seem fairly comparable (at least in my informal, off-the-cuff testing). So, if you have a sensor that's mostly transmission oriented, like, say, a TH sensor, the smaller and cheaper nRF51822 is maybe worth considering.
                                          TerrenceT 1 Reply Last reply
