  3. nRF5 action!
nRF5 action!
  • T Toyman
    I am trying to reprogram a commercial nrf51 module. Under "commerical" I mean "not from aliexpress", but installed in "smart" bluetooth socket.
    I can connect to it with Black Magic Probe just fine, but after mass_erase, BMP reports 0xfffffffe instead of usual 0xffffffff, meaning something is lef behind. That prohibits reflashing of softdevice BUT I can load "plain" skethes that do not require softdevice
    I ASSUME the module has some kind of write protection and/or UICR registers set that are not erased with BMP mass+erase command.
    I've tried to load d0016 uuicr clearing sketch, It loads fine, but I've still got 0xfffffffe after masserase.
    So what's the proper way to really completely erase the module?
    I have nrf52 dk that I tried to use as a programmer but it didn't worked.
    JokgiJ
    JokgiJ
    Jokgi
    @Toyman What is the make and model of the module. You can use the nRF52-DK to erase the device. P20 is a ease access to the programming pins on that board. You need to power up the module, run the VDD from the module back to the dev kit , P20, Pin2. Hook up the SWDIO lines to Pin3 and the SWDCLK to Pin4. and Ground, Pin8. As reset is not hardwired you don't have to hook that up unless you want to (Pin7. . ![alt text](image url) You can use nRFJPROG to exersise the J-Link (Segger). This is found in the downloadable tools on the Nordic site. BTW - I have no problem using J-Link Commander version 6.20c with the nRF52-DK with the nRF52832 mounted. I hope this helped. 0_1506616486979_Programming using P20 on the dev kit.JPG
    • JokgiJ Jokgi
      @NeverDie This may be old news but I will throw it out anyway. The Reset pin on the nRF52 series is both a GPIO and RESET line (one or the other) . This is not a dedicated Reset however and the application must define that pin as RESET. This is the only pin that can be defined as reset. The Datasheet describes this as well.
      Yes, and thanks to @d00616's work, RESET can also be enabled/disabled from the Tools menu of the arduino IDE if using myNRF5Board as the board definition.
      d00616D 1 Reply Last reply
        #973
        I just now compared the transmission range and packet loss of the cheap nRF51822 to the Ebyte nRF52832. I expected that the Ebyte, with its bigger and fancier antenna, to mop the floor with the nRF51822, but I was surprised to find that they actually seem fairly comparable (at least in my informal, off-the-cuff testing). So, if you have a sensor that's mostly transmission oriented, like, say, a TH sensor, the smaller and cheaper nRF51822 is maybe worth considering.
        TerrenceT 1 Reply Last reply
          TerrenceT
          TerrenceT
          Terrence
          That is interesting. What sort of range where you getting?
          Do you have the 840 dev kit? If so, can you measure range on that guy? Should be 10x I would think.
          • TerrenceT Terrence
            #975
            @Terrence
            Around 30 feet, through some walls, but at 2mbps. I realize that's not very far, but even so the measured packet loss (informal testing) is pretty high at that speed. I can see why most people default to 250kbps instead.
            I don't have the 840 dev kit yet, mostly because I don't see anyother 840 modules on the market right now.
              What's a good initial value to use for DATAWHITEIV, if doing data whitening?
              • JokgiJ Jokgi
                Toyman
                @Jokgi Thanks. That's exactly what I did. Flashed successfully but ideally I'd like to find a way to power the module from the DK (I had to use the external power)
                Unfortunately, this was the first time when BMP let me down. It just failed to load either softdevice or the sketch hex while Jlink@DK handled it without any problem.
                  #978
                  @d00616
                  Which settings are key for ensuring that packets sent by the nRF24 are correctly received by the nRF5? It would be nice to leverage the versions of the nRF24 that have amplified Tx. For sending wake-up packets, I shoudln't need shockburst, and so maybe this will work fairly easily.
                    @d00616
                    d00616D
                    d00616D
                    d00616
                    wrote on last edited by d00616
                    #979
                    These are more than settings. You have to set the Radio configuration like in Radio_ESB.cpp, reverse the addresses and handle sending ACK packages by software.
                    This is a good resource to understand the OTA protocol: https://hackaday.io/project/11942-antenna-diversity-receive-and-transmit/log/39510-shockburst-vs-enhanced-shockburst-nrf24-vs-nrf5x
                    I can provide a simple example how to use the MySensors transport code without Radio Head. This works for nRF5 and nRF24 modules, but its outside of that what the MY_CORE_ONLY mode is designed for.
                    #define MY_CORE_ONLY
                    #ifndef ARDUINO_ARCH_NRF5
                    #define MY_NODE_ID (1)
                    #define SND_TO (2)
                    #define MY_NODE_ID (2)
                    #define SND_TO (1)
                    // Enable debug
                    //#define MY_DEBUG_VERBOSE_NRF5_ESB
                    // RF24_250KBPS RF24_1MBPS RF24_2MBPS
                    #define MY_RF24_DATARATE (RF24_1MBPS)
                    // NRF5_250KBPS NRF5_1MBPS NRF5_2MBPS
                    #define MY_NRF5_ESB_MODE (NRF5_1MBPS)
                    #ifndef NRF5
                    #define MY_RADIO_NRF5_ESB
                      hwInit();
                      transportInit();
                      transportSetAddress(MY_NODE_ID);
                      // Check for packages
                      while (transportAvailable()) {
                        uint8_t buffer[256];
                        uint8_t num = transportReceive(&buffer);
                        Serial.print("Data=");
                        for (int i=0;i<num;i++) {
                          if (buffer[i]<0x10) Serial.print("0");
                          Serial.print(buffer[i], HEX);
                          Serial.print(" ");
                        Serial.println();
                      wait(1000);
                      // Send data
                      transportSend(SND_TO, "abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz",32, false);
                      d00616D
                      d00616D
                      d00616
                      The reset support isn't complete at the moment. The menu is active, but it has no effect at the moment. I fix this with release 0.2.0.
                      • U
                        U
                        Uhrheber
                        I just received 2 of those little boards.
                        Ideal for small sensor nodes, I'd say, but not very breadboard friendly.
                        So I dug out the verowire, and did a little soldering.
                        • d00616D d00616
                          #define SND_TO (2)
                          #define SND_TO (1)
                          // Enable debug
                          #ifndef NRF5
                            hwInit();
                            transportInit();
                                Serial.print(" ");
                              Serial.println();
                            wait(1000);
                            // Send data
                          #982
                          #define SND_TO (2)
                          #define SND_TO (1)
                          // Enable debug
                          #ifndef NRF5
                            hwInit();
                            transportInit();
                                Serial.print(" ");
                              Serial.println();
                            wait(1000);
                            // Send data
                          I tried compiling it using the Arduino Windows IDE, but for some reason it complains about not finding a whole litany of .h files: socket.h, w5100.h, netdb.h.... Does mysensors.h really need to drag in all of those .h files, even if only indirectly? Or, if there's an easy way to make it find them, what is it?
                            #define SND_TO (2)
                            #define SND_TO (1)
                            // Enable debug
                            #ifndef NRF5
                              hwInit();
                              transportInit();
                                  Serial.print(" ");
                                Serial.println();
                              wait(1000);
                              // Send data
                            d00616D
                            d00616D
                            d00616
                            I can compile it with Linux. What are missing is part of the Ethernet library. I don't know why it's included in you build.
                            • d00616D d00616
                              #984
                              I just now upgraded to the current release of the mysensors development library, and the compile problem went away. :) So, if anyone else encounters the same problem, I recommend doing that.
                                d00616D
                                d00616D
                                d00616
                                I just now upgraded to the current release of the mysensors development library, and the compile problem went away. So, if anyone else encounters the same problem, I recommend doing that.
                                Sorry. I have forgotten my uncommited changes. At the moment, you have to start the HFCLK in the CORE_ONLY mode. This is done in hwInit() later.
                                • d00616D d00616
                                  ... At the moment, you have to start the HFCLK in the CORE_ONLY mode. ...
                                  Do you have a revised sketch which does that? I tried running the sketch you gave above on an nRF52 DK, but it immediately goes into a boot-loop, wherein in keeps rebooting itself, over and over and over again.
                                    I just now tried running it on a pro-mini using a nRF24, and it also gets into a boot-loop.
                                      d00616D
                                      d00616D
                                      d00616
                                      Please replace wait() with delay(). This is an issue in the transport code, which is triggered while sleep() or wait() is executed.
                                      NeverDieN T 3 Replies Last reply
                                      • d00616D d00616
                                        OK, made that change, and it no longer boot-loops.
                                        However, neither node appears to be receiving anything from the other.
                                        Please advise.
                                        • d00616D d00616
                                          #990
                                          @d00616
                                          Since the original code didn't work, I upgraded it somewhat to give a larger Rx window. However, it still doesn't work:
                                          #define SND_TO (2)
                                          #define SND_TO (1)
                                          // Enable debug
                                          #ifndef NRF5
                                            Serial.println("Starting....");
                                            Serial.print("MY_NODE_ID=");
                                            Serial.println(MY_NODE_ID);
                                            Serial.print("SND_TO=");
                                            Serial.println(SND_TO);
                                            hwInit();
                                            transportInit();
                                          uint32_t theTime=0;
                                          uint32_t loopCounter=0;
                                            while ((millis()-theTime)<1000) {
                                                  Serial.print(" ");
                                                Serial.println();
                                            theTime=millis();
                                            //delay(1000);
                                            Serial.print(loopCounter++);
                                            Serial.println(", SENDING:  abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz");
                                            // Send data
                                          One node is an nRF24 on a pro mini, and the other is an nRF52832.
