  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 1.9m Views 44 Watching
    What's a good initial value to use for DATAWHITEIV, if doing data whitening?
    • JokgiJ Jokgi
      @Toyman What is the make and model of the module. You can use the nRF52-DK to erase the device. P20 is a ease access to the programming pins on that board. You need to power up the module, run the VDD from the module back to the dev kit , P20, Pin2. Hook up the SWDIO lines to Pin3 and the SWDCLK to Pin4. and Ground, Pin8. As reset is not hardwired you don't have to hook that up unless you want to (Pin7. . ![alt text](image url) You can use nRFJPROG to exersise the J-Link (Segger). This is found in the downloadable tools on the Nordic site. BTW - I have no problem using J-Link Commander version 6.20c with the nRF52-DK with the nRF52832 mounted. I hope this helped. 0_1506616486979_Programming using P20 on the dev kit.JPG
      Toyman
      @Jokgi Thanks. That's exactly what I did. Flashed successfully but ideally I'd like to find a way to power the module from the DK (I had to use the external power)
      Unfortunately, this was the first time when BMP let me down. It just failed to load either softdevice or the sketch hex while Jlink@DK handled it without any problem.
        #978
        @d00616
        Which settings are key for ensuring that packets sent by the nRF24 are correctly received by the nRF5? It would be nice to leverage the versions of the nRF24 that have amplified Tx. For sending wake-up packets, I shoudln't need shockburst, and so maybe this will work fairly easily.
        d00616D 1 Reply Last reply
          @d00616
          d00616D
          d00616D
          d00616
          wrote on last edited by d00616
          #979
          These are more than settings. You have to set the Radio configuration like in Radio_ESB.cpp, reverse the addresses and handle sending ACK packages by software.
          This is a good resource to understand the OTA protocol: https://hackaday.io/project/11942-antenna-diversity-receive-and-transmit/log/39510-shockburst-vs-enhanced-shockburst-nrf24-vs-nrf5x
          I can provide a simple example how to use the MySensors transport code without Radio Head. This works for nRF5 and nRF24 modules, but its outside of that what the MY_CORE_ONLY mode is designed for.
          #define MY_CORE_ONLY
          #ifndef ARDUINO_ARCH_NRF5
          #define MY_NODE_ID (1)
          #define SND_TO (2)
          #define MY_NODE_ID (2)
          #define SND_TO (1)
          // Enable debug
          //#define MY_DEBUG_VERBOSE_NRF5_ESB
          // RF24_250KBPS RF24_1MBPS RF24_2MBPS
          #define MY_RF24_DATARATE (RF24_1MBPS)
          // NRF5_250KBPS NRF5_1MBPS NRF5_2MBPS
          #define MY_NRF5_ESB_MODE (NRF5_1MBPS)
          #ifndef NRF5
          #define MY_RADIO_NRF5_ESB
            hwInit();
            transportInit();
            transportSetAddress(MY_NODE_ID);
            // Check for packages
            while (transportAvailable()) {
              uint8_t buffer[256];
              uint8_t num = transportReceive(&buffer);
              Serial.print("Data=");
              for (int i=0;i<num;i++) {
                if (buffer[i]<0x10) Serial.print("0");
                Serial.print(buffer[i], HEX);
                Serial.print(" ");
              Serial.println();
            wait(1000);
            // Send data
            transportSend(SND_TO, "abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz",32, false);
            @NeverDie This may be old news but I will throw it out anyway. The Reset pin on the nRF52 series is both a GPIO and RESET line (one or the other) . This is not a dedicated Reset however and the application must define that pin as RESET. This is the only pin that can be defined as reset. The Datasheet describes this as well.
            Yes, and thanks to @d00616's work, RESET can also be enabled/disabled from the Tools menu of the arduino IDE if using myNRF5Board as the board definition.
            d00616D
            d00616D
            d00616
            The reset support isn't complete at the moment. The menu is active, but it has no effect at the moment. I fix this with release 0.2.0.
            • U
              U
              Uhrheber
              I just received 2 of those little boards.
              Ideal for small sensor nodes, I'd say, but not very breadboard friendly.
              So I dug out the verowire, and did a little soldering.
              • d00616D d00616
                #define SND_TO (2)
                #define SND_TO (1)
                // Enable debug
                #ifndef NRF5
                  hwInit();
                  transportInit();
                      Serial.print(" ");
                    Serial.println();
                  wait(1000);
                  // Send data
                #982
                #define SND_TO (2)
                #define SND_TO (1)
                // Enable debug
                #ifndef NRF5
                  hwInit();
                  transportInit();
                      Serial.print(" ");
                    Serial.println();
                  wait(1000);
                  // Send data
                I tried compiling it using the Arduino Windows IDE, but for some reason it complains about not finding a whole litany of .h files: socket.h, w5100.h, netdb.h.... Does mysensors.h really need to drag in all of those .h files, even if only indirectly? Or, if there's an easy way to make it find them, what is it?
                  #define SND_TO (2)
                  #define SND_TO (1)
                  // Enable debug
                  #ifndef NRF5
                    hwInit();
                    transportInit();
                        Serial.print(" ");
                      Serial.println();
                    wait(1000);
                    // Send data
                  d00616D
                  d00616D
                  d00616
                  I can compile it with Linux. What are missing is part of the Ethernet library. I don't know why it's included in you build.
                  • d00616D d00616
                    #984
                    I just now upgraded to the current release of the mysensors development library, and the compile problem went away. :) So, if anyone else encounters the same problem, I recommend doing that.
                      d00616D
                      d00616D
                      d00616
                      I just now upgraded to the current release of the mysensors development library, and the compile problem went away. So, if anyone else encounters the same problem, I recommend doing that.
                      Sorry. I have forgotten my uncommited changes. At the moment, you have to start the HFCLK in the CORE_ONLY mode. This is done in hwInit() later.
                      • d00616D d00616
                        ... At the moment, you have to start the HFCLK in the CORE_ONLY mode. ...
                        Do you have a revised sketch which does that? I tried running the sketch you gave above on an nRF52 DK, but it immediately goes into a boot-loop, wherein in keeps rebooting itself, over and over and over again.
                          I just now tried running it on a pro-mini using a nRF24, and it also gets into a boot-loop.
                            d00616D
                            d00616D
                            d00616
                            Please replace wait() with delay(). This is an issue in the transport code, which is triggered while sleep() or wait() is executed.
                            NeverDieN T 3 Replies Last reply
                            • d00616D d00616
                              OK, made that change, and it no longer boot-loops.
                              However, neither node appears to be receiving anything from the other.
                              Please advise.
                              • d00616D d00616
                                #990
                                @d00616
                                Since the original code didn't work, I upgraded it somewhat to give a larger Rx window. However, it still doesn't work:
                                #define SND_TO (2)
                                #define SND_TO (1)
                                // Enable debug
                                #ifndef NRF5
                                  Serial.println("Starting....");
                                  Serial.print("MY_NODE_ID=");
                                  Serial.println(MY_NODE_ID);
                                  Serial.print("SND_TO=");
                                  Serial.println(SND_TO);
                                  hwInit();
                                  transportInit();
                                uint32_t theTime=0;
                                uint32_t loopCounter=0;
                                  while ((millis()-theTime)<1000) {
                                        Serial.print(" ");
                                      Serial.println();
                                  theTime=millis();
                                  //delay(1000);
                                  Serial.print(loopCounter++);
                                  Serial.println(", SENDING:  abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz");
                                  // Send data
                                One node is an nRF24 on a pro mini, and the other is an nRF52832.
                                  @d00616
                                  #define SND_TO (2)
                                  #define SND_TO (1)
                                  // Enable debug
                                  #ifndef NRF5
                                    hwInit();
                                    transportInit();
                                  uint32_t theTime=0;
                                          Serial.print(" ");
                                        Serial.println();
                                    theTime=millis();
                                    //delay(1000);
                                    // Send data
                                  d00616D
                                  d00616D
                                  d00616
                                  #991
                                  Please add this to your setup() function (https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/985):
                                  	// Clock is manged by sleep modes. Radio depends on HFCLK.
                                  	// Force to start HFCLK
                                  	NRF_POWER->TASKS_CONSTLAT = 1;
                                  	// Enable cache on >= NRF52
                                  #ifndef NRF51
                                  	NRF_NVMC->ICACHECNF = NVMC_ICACHECNF_CACHEEN_Msk;
                                  At the moment I prepare a new Pull Request fixing this including some small fixes and improvements for nRF5 MCUs. When it's integrated the HFCLK is startet in hwInit().
                                  • d00616D d00616
                                    Toyman
                                    @d00616 is this universal recommendation?
                                    • T Toyman
                                      d00616D
                                      d00616D
                                      d00616
                                      I think you mean to start the HFCLK. This isn't a universal recommendation. At the moment the HFCLK is started in MyMainNRF5.cpp. This file is ignored in CORE_ONLY mode. I moved any initialization code into hwInit().
                                      • d00616D d00616
                                        #ifndef NRF51
                                        d00616D
                                        d00616D
                                        d00616
                                        The Pull Request is available: https://github.com/mysensors/MySensors/pull/938
                                        • d00616D d00616
                                          That link lists changes to the files, but it doesn't seem to provide the new files. Or else I'm overlooking where it does?
