  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 177.2k Views 38 Watching
    wrote on last edited by gohan
    #145
    I used the ceramic becuse I had a bunch of those :D
    • sinczeS
      sinczeS
      sincze
      MySensors Evangelist
      wrote on last edited by sincze
      #146
      @sundberg84: Received the V9 boards and started to work with them. Converting my nodes into smaller ones ;-)
      I want to use it with my 5v arduino. So need voltage regulator for the radio. I guess you are using LE33 if I read the thread correctly. I have LM1117 which seems to be a hassle to fix on the board with the 'rough bulky' legs. Suggestions or just buy LE33 ;-)
      dbemowskD 1 Reply Last reply
        if you have MCP1700 you can still fit those
        • sinczeS sincze
          dbemowskD
          dbemowskD
          @sincze When I first got my rev8 boards a long time ago I had the same issue. I did manage to bend the leads and solder some extensions on one to get it to work, but in the end it was just too much of a pain in the arse. I ended up buying L78L33ACZ regulators which work just fine, but the board was designed using the LE33. The LE33 is an LDO regulator where the L78L33 is not. The quiscent current of the L78L33 regulator, which is something I forgot to look at when I bought them, is 6mA where the LE33 maxes out at 3mA, which is much better when building battery operated nodes.
          sinczeS 1 Reply Last reply
          • sundberg84S
            sundberg84S
            As mentioned above, it works but you need to watch for the right pins... you might have to be careful bending those pins but I think its managable... My suggestion though is to look for volt. regulators with the same pinout.
            • dbemowskD dbemowsk
              sinczeS
              sinczeS
              sincze
              @dbemowsk said in Easy/Newbie PCB for MySensors:
              LDO regulator
              A well that is a clear answer. So I just ordered a few LE33. The project has to wait.
              It still will be a tough one getting everyting attached to the pins. ->. 2x Door Sensor / 3x Dallas DS18B20 / 3x Relais / 2x Control LEDS TX/RX. A well part of the game. Already figured out I have to use the A0x pins as digital ones. As i don't plan to use IRQ I'm really hopeful this nicely designed PCB will offer me A0,A1A4,A5 D2,D3,D5,D6. So should fit ;-)
              • sinczeS sincze
                LDO regulator
                dbemowskD
                dbemowskD
                @sincze With that much going on, you may want to connect a set of header pins to the outputs next to the nRF24 radio and run that to an external proto-board for connecting all of your devices. You won't make it on the small proto section of the newbie board for everything you want to add.
                  sundberg84S
                  sundberg84S
                  @dbemowsk @sincze - its a good idea with a proto board or you can build something and add as an shield on the MysX connector... I would also suggest you run a seperate power regulator for the sensors... atleast do some calculactions before adding them in because LE33 can handle maximum of 0.2A i think.
                  sinczeS dbemowskD 2 Replies Last reply
                  • sundberg84S sundberg84
                    sinczeS
                    sinczeS
                    sincze
                    @sundberg84 Ok tnx for the heads up. Currently I have everything in DEMO up and running on a NANO on my desk (using the exact same pins as I would on your PCB.
                    I was thinking of the following. Power the PCB with 5v and use a 5v arduino mini, use the LE33 to power the Antenna with 3,3v. Hopefully this will enable the pins Mys pins A0 ...Dx with 5v.(Have to look at the schematic to be sure). Keeping your advise in mind to add some extra juice I have to power the RELAIS & Temp sensor separately with 5v and keep the grounds of everything together with the PCB. I think it should work. But maybe I am missing something.
                    • sinczeS sincze
                      sundberg84S
                      sundberg84S
                      @sincze all you can do is test and learn !!
                        dbemowskD
                        dbemowskD
                        @sundberg84 Couldn't think of the name of the MysX connector when I did that post, but that's what I was talking about putting the header on to connect to the proto-board. Mainly to act as a proto-shield. I would agree to run the sensors from a separate regulator. If he plugs it into the MysX connector he should have access to RAW power if he jumpers the pads next to the MysX connector, and then he may be able to make use of at least one of his LM1117 regulators on his shield, provided that he runs the sensors from 3.3V. I am assuming that his LM1117's are 3.3V regulators and not the 5V versions.
                          sinczeS
                          sinczeS
                          sincze
                          @dbemowsk Got in stock 2 types of LM1117 the 3,3v and 5v. In any case the relais need 5v, the temp sensor as well. So If I read RAW in your answer that triggers me to watch out. ;-) I'll start soldering some pins and measure the voltage. as @sundberg84 said.. "all you can do is test and learn !! hehehe. Part of the Mysensors fun. And ofcourse this forum provides me with experienced feedback.
                          • sinczeS sincze
                            sinczeS
                            sinczeS
                            sincze
                            #157
                            So this is where the project is at. Using regulated 5V.
                            Still missing the 0,1u capacitor, but it is on its way,
                            The voltage divider is working fine 5v -> 3,3v.
                            Maybe I am missing some(connection)thing as I don't have 3,3v at the Antenna 3,3/GND connector. Did I miss something as I am not a PCB expert, sorry.
                            • sinczeS sincze
                              sundberg84S
                              sundberg84S
                              #158
                              @sincze
                              If you measure these points, what do you have?
                              • plus (left pin) on blue screw terminal (should be 5v)
                              • reg jumper (should be 5v)
                              • Vin voltage reg (should be 5v)
                              • Vout Voltage reg (should be 3.3v)
                              You should be able to follow the trace from Vout to VCC(radio) with your eye.
                              You can do a continuity test from Vout to VCC (radio) and GND(radio) to GND(screw terminal) to comfirm connectiom.
                              What kind of voltage regulator do you have? Did you check the pinout matched vin/vout/gnd ?
                              No rush, this supports the voltage reg but unless you do some heavy things you will do without.
                                @sincze
                                sinczeS
                                sinczeS
                                sincze
                                @sundberg84 I did measure the following:
                                plus (left pin) on blue screw terminal (should be 5v), is 4,96 V
                                Vin voltage reg (should be 5v), is 4,96
                                Vout Voltage reg (should be 3.3v), is 3,3
                                • sinczeS sincze
                                  sundberg84S
                                  sundberg84S
                                  @sincze but still 0v at radio VCC?
                                    sinczeS
                                    sinczeS
                                    sincze
                                    @sundberg84 unfortunately yes. However.
                                    You can do a continuity test from Vout to VCC (radio) , (We have no beep for continuity)
                                    and
                                    GND(radio) to GND(screw terminal) to comfirm connectiom. (We have a beep for contiuity)
                                    sundberg84S 2 Replies Last reply
                                    • sinczeS sincze
                                      and
                                      sundberg84S
                                      sundberg84S
                                      @sincze if this is so you have a broken pcb trace (first time I ever heard of) do you need to replace the trace with a wire.
                                      • sinczeS sincze
                                        and
                                        sundberg84S
                                        sundberg84S
                                        #163
                                        @sincze or a bad solder joint...
                                          sinczeS
                                          sinczeS
                                          sincze
                                          #164
                                          @sundberg84 as I am not a soldering king... we will check the work and report back...... applied a bit more solder to the vout and we have beep ;-) now let's continue the work.
                                          Wow, 3,3 and 3,29v on the antenna. tnx.
