  3. WiFi Gateway (ESP8266) - reconnect to wifi router
19 Posts 4 Posters 10.2k Views 6 Watching
    manutremo
    What do you see on your gw log when the connection to the router is lost?
    • pihomeP
      pihomeP
      pihome
      This is getting very odd, now if I connect my gateway to computer I don’t see anything on serial port, but i can talk to controler and get all nodes data which confirm it’s working.
      PiHome - Smart Heating Control
        manutremo
        That's odd - I assume you've checked port, bitrate, etc...
        If your gw is communicating via IP (I guess that's the case since you mention a wifi gw), you can also "spy" the communication between the gw and the controller by telnetting to the gw IP and port 5003 (assuming default hasn't been changed).
        • pihomeP
          pihomeP
          pihome
          wrote on last edited by pihome
          here is log when gateway is connected to wifi router, and then i powered off wifi router and then in few seconds powered on again, all other devicess connected to wifi router as expected apart from mysensors esp gateway. no special code in my gateway controller sketch.
          pm open,type:2 0
          0;255;3;0;9;TSF:MSG:READ,30-30-0,s=0,c=1,t=0,pt=7,l=5,sg=0:35.0
          0;255;3;0;9;Client 0 connected
          0;255;3;0;9;TSF:MSG:READ,30-30-0,s=0,c=1,t=0,pt=7,l=5,sg=0:35.8
          0;255;3;0;9;TSF:MSG:READ,21-21-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.6
          bcn_timout,ap_probe_send_start
          ap_probe_send over, rest wifi status to disassoc
          state: 5 -> 0 (1)
          rm 0
          pm close 7
          f r0, 0;255;3;0;9;Client 0 disconnected
          scandone
          no mynet-915C found, reconnect after 1s
          reconnect
          f 0, scandone
          reconnect
          f -180, scandone
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 1
          cnt
          chg_B1:-140
          connected with mynet-915C, channel 7
          dhcp client start...
          chg_B1:-100
          ip:192.168.99.3,mask:255.255.255.0,gw:192.168.99.1
          chg_B1:-60
          chg_B1:-20
          0;255;3;0;9;TSF:MSG:READ,21-21-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.9
          pm open,type:2 0
          0;255;3;0;9;TSF:MSG:READ,25-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0:20.8```
            manutremo
            I'm not sure i'm following you... from the low the gw seems to be reconnecting, it gets ip 192.168.99.3 after the router restarts and starts to receive messages from what seems to be a node.
            • pihomeP
              pihomeP
              pihome
              it looks from log as it is connected to wifi but i can not even ping mysensors gateway, until i press reset button on esp.
              yes you are right gateway receive all message from notes.
                Did you try latest mysensors 2.2 development?
                • ThomasDrT
                  ThomasDrT
                  ThomasDr
                  do you use only the Gateway Code or is there anybody else in your code?
                  If you do anybody else you need delays in the code.
                  I think the Arduino "delay()" not the "wait()".
                  Wait do Mysensors things.
                  Delay do WIFI things.
                  regards
                  ThomasDr
                    I think you could check every minute or so if wifi connection is established and if not call the connection routine (that should be basic esp8266 stuff)
                    • pihomeP
                      pihomeP
                      pihome
                      its basic gateway code nothing else, just copy and paste from mysensors. i added that nrf
                       * Version 1.0 - Henrik EKblad
                       * Contribution by Ivo Pullens (ESP8266 support)
                       * The EthernetGateway sends data received from sensors to the WiFi link.
                       * VERA CONFIGURATION:
                       * LED purposes:
                       * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
                       * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
                       * nRF24L01+  ESP8266
                       * VCC        VCC
                       * CE         GPIO4
                       * CSN/CS     GPIO15
                       * SCK        GPIO14
                       * MISO       GPIO12
                       * MOSI       GPIO13
                       * GND        GND
                        * Inclusion mode button:
                      #define MY_BAUD_RATE 9600
                      // i added this later to see this may be the cause as i have channel number etc in other sensors.
                      #define RF24_CHANNEL     125
                      #define MY_GATEWAY_ESP8266
                      #define MY_ESP8266_SSID "wifi"
                      #define MY_ESP8266_PASSWORD "wifi-pass"
                      // Enable UDP communication
                      //#define MY_USE_UDP
                      #define MY_ESP8266_HOSTNAME "PiHome_Gateway"
                      //#define MY_IP_ADDRESS 192,168,99,4
                      //#define MY_IP_GATEWAY_ADDRESS 192,168,99,1
                      #define MY_PORT 5003
                      // Enable inclusion mode
                      // #define MY_INCLUSION_BUTTON_FEATURE
                      // Set blinking period
                      // #define MY_DEFAULT_LED_BLINK_PERIOD 300
                      // Flash leds on rx/tx/err
                      #if defined(MY_USE_UDP)
                      #include <WiFiUdp.h>
                      #include <ESP8266WiFi.h>
                      ThomasDrT 1 Reply Last reply
                      • pihomeP pihome
                         * LED purposes:
                         * nRF24L01+  ESP8266
                         * VCC        VCC
                         * CE         GPIO4
                         * CSN/CS     GPIO15
                         * SCK        GPIO14
                         * MISO       GPIO12
                         * MOSI       GPIO13
                         * GND        GND
                        ThomasDrT
                        ThomasDrT
                        ThomasDr
                        @pihome Hello,
                        and what type of ESP8266 you have?
                        Can you try a other one?
                        I have some NodeMCU V0.9 with TCP and UDP in client mode with AVM Router and Repeater.
                        Without problems.
                        regards
                        ThomasD
                        • pihomeP
                          pihomeP
                          pihome
                          i dont have second esp8266 at this moment, i have order one
                          here is what i have and i m using it for gateway
                          https://www.aliexpress.com/item/V3-Wireless-module-NodeMcu-4M-bytes-Lua-WIFI-Internet-of-Things-development-board-based-ESP8266-for/32469441553.html?spm=a2g0s.9042311.0.0.FyzreG
                          @ThomasDr said in WiFi Gateway (ESP8266) - reconnect to wifi router:
                          ESP8266
                          • ThomasDrT
                            ThomasDrT
                            ThomasDr
                            wrote on last edited by ThomasDr
                            The NodeMCU looks like my.
                            and your ESP8266 Arduino version?
                            maybe there is a new version.
                            What Router or Access Point do you use?
                            regards
                            ThomasD
                            • pihomeP
                              pihomeP
                              pihome
                              Arduino 1.8.3 and ESP library is all updated. i m using vodafone router.
                              • ThomasDrT
                                ThomasDrT
                                ThomasDr
                                i try to build new Gateway for my Problem and Upload the same sketch, but the new Gateway do not connect to the router. I reminded the China NodeMCU have problems with Serial.begin and with WIFI.beginn. It need a delay after.
                                I found the WIFI.begin in the "MyGatewayTransportEthernet.cpp" file and see a wait(500). See my last post wait/delay, so I changed from wait to delay and the Gateway connect.
                                If you can try to change it too or change from 500 to 1000.
                                But i use the 2.2.0 dev.
                                regards
                                Thomas
                                pihomeP 1 Reply Last reply
                                • ThomasDrT ThomasDr
                                  regards
                                  Thomas
                                  pihomeP
                                  pihomeP
                                  pihome
                                  @thomasdr thank you for the info, and sorry for late reply, changing wait(500) to delay(500) worked.
                                  12.5k
