  3. Vera
  4. [Solved] Support for S_MULTIMETER and V_VOLTAGE in Vera
4 Posts 3 Posters 3.1k Views 3 Watching
  • W
    W
    Woodside
    wrote on last edited by Woodside
    Can anyone confirm if S_MULTIMETER and V_VOLTAGE are supported in Vera?
    L_Arduino.lua indicates it is supported
    Whereas Selecting a Controller, indicates it is not supported
    Using
    MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
    and
    present(CHILD_ID_VOLTAGE, S_MULTIMETER);
    The Multimeter device is created
    but the values are blank.
    The Vera log shows the 'Voltage' value is being sent with the correct value
    50      06/11/17 14:25:48.875   luup_log:78: Arduino: Set variable: 1;0;1;0;38;4.79 <0x2ebbe680>
    50      06/11/17 14:25:48.876   luup_log:78: Arduino: Setting variable 'Voltage' to value '4.79' <0x2ebbe680>
    50      06/11/17 14:25:48.876   luup_log:78: Arduino: urn:micasaverde-com:serviceId:EnergyMetering1,Voltage, 4.79, 87 <0x2ebbe680>
    Is it possible to get this to appear in the Multimeter device?
    • I
      I
      itbeyond
      wrote on last edited by itbeyond
      I have loaded a Github repo to the Vera branch to fix this. The problem is the service references in the D_Multimeter1.json file. Edit this file and change all 6 references of urn:arduino-cc:serviceId: to urn:micasaverde-com:serviceId:
      Then reload the LUUP file (D_Multimeter1.json) in VERA - APPS - DEVELOP APPS - LUUP FILES. Restart the LUUP Engine and the values will now correctly appear.
      You can also see the pull request here: https://github.com/mysensors/Vera/pull/57/commits/695dfefaca0b3c7c3529242132a0902de9ec212f
      • W
        W
        Woodside
        @itbeyond said in Support for S_MULTIMETER and V_VOLTAGE in Vera:
        Excellent, now working thanks
        I have commented accordingly on your pull request.
        • BartEB
          BartEB
          BartE
          wrote on last edited by BartE
          Does anyone know why the three value are not show in the "data_request?id=lu_sdata" output?
          It only outputs default values:
                "name": "MyMulti",
                "altid": "12;1",
                "id": 346,
                "category": 12,
                "subcategory": -1,
                "room": 0,
                "parent": 64
          While i would expect
                "name": "MyMulti",
                "altid": "12;1",
                "id": 346,
                "category": 12,
                "subcategory": -1,
                "room": 0,
                "parent": 64,
                "Impedance": 0,
                "Current": 0,
                "Voltage": 4.89
          I'm looking for a solution quite some time now, but I somehow miss a problem.
