  3. Solar Powered Soil Moisture Sensor
79 Posts 19 Posters 48.8k Views 35 Watching
  • F
    F
    flopp
    wrote on last edited by flopp
    #70
    Just wanna update you all how the battery has been since start.
    No restart since 1st September.
    A few days ago we moved the plant indoor and I forgot to take out the sensor, I moved the sensor outdoor the day after
    • HuczasH
      HuczasH
      Huczas
      @flopp is your code should work with new version of gateway 2.1.1?
      Just maked using this tutorial my gateway https://www.mysensors.org/build/raspberry and I'm getting nothing in debug...
      mysgw: Starting gateway...
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: !TSM:INIT:TSP FAIL
      mysgw: TSM:FAIL:CNT=1
      mysgw: TSM:FAIL:PDT
      mysgw: TSM:FAIL:RE-INIT
      In node I used your newest code for gw2.0 - is this because version mismatch or something different in my setup?
      Could you update your code to work with new version?
      F 1 Reply Last reply
      • HuczasH Huczas
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:FAIL:PDT
        F
        F
        flopp
        @Huczas
        I don't use 2.1, yet. I only use 1.5.1.
        I don't have any knowledge of 2.x, so I cannot update the code, sorry
        HuczasH 1 Reply Last reply
        • F flopp
          @Huczas
          HuczasH
          HuczasH
          Huczas
          @flopp just release that @mrwomble was posting that updated code sorry. @mrwomble can you help?
          • H
            H
            hiddenuser
            Hello All,
            Wondering if any one of the successful implenters would be able to share their soil moisture graphs,both for a day and over months..
            • D
              dmonty
              To solve the battery discharge memory issue, could a second battery be added with logic to alternate between batteries and fully discharge one at a time?
                Charge memory is a thing of the past, lithium batteries don't have it (if I understood what you meant).
                  #77
                  @gohan said in Solar Powered Soil Moisture Sensor:
                  Except that, if I'm not mistaken, he's presently re-using the NiCd's that came with the original solar garden light.
                  [Edit: correction: I think maybe (?) he switched to Nimh. I didn't think those had a memory problem. Do they? ]
                  [Edit2: Maybe he'll "upgrade" to a supercap. :) A soil moisture meter would be a good application for one. ]
                    NiMh still have some charge memory but not as bad as the NiCd. I got the moisture sensors yesterday I have to test them the next days.
                    https://www.aliexpress.com/item/Soil-Moisture-Sensor/32532715392.html
                    • R
                      R
                      ricorico94
                      I started building this great idea of solar powered soil moisture sensor. Not integrated yet in a solar light as above, but still on my desk.
                      I tested the sensor in salted water and I get a report of 78% moisture : based on your experience, is it normal ? Then I pushed the sensor in a very humid plant pot and read 71%. I would have expected mroe differenc ecompared to salted water.
                      So, would you advise to caliber ? I guess I could modify the calculation formula in the script..
                      Precisely, is it possible with Mysensor technology and Domoticz to push to a sensor a new setting (for instance to caliber using Domoticz each different sensor) ?
                      And another question.. Is it possible to ask Domoticz to show the result of moisure reading in the Weather or Measures category rather than in the Temperature menu ?
                      br,
                      Ricorico94
