  3. Solar Powered Soil Moisture Sensor
79 Posts 19 Posters 48.8k Views 35 Watching
  • F
    F
    flopp
    wrote on last edited by flopp
    #68
    I have put glue on top of the soldering
    • F
      F
      flopp
      #69
      WARNING!!!
      I opened one of my items which didn't worked since many weeks ago.
      I putted it on a table and should just open the stuff when I saw some brown water coming out from the pole.
      My first guess was that it was water mixed with mud but the smell was strange. It can be that the battery has leaked.
      If you will build this item please seal the battery to 100%. I just put the battery in the pole but unfortunately water came in and what I think destroyed the battery!
      Be careful
      • F
        F
        flopp
        #70
        Just wanna update you all how the battery has been since start.
        No restart since 1st September.
        A few days ago we moved the plant indoor and I forgot to take out the sensor, I moved the sensor outdoor the day after
        • HuczasH
          HuczasH
          Huczas
          @flopp is your code should work with new version of gateway 2.1.1?
          Just maked using this tutorial my gateway https://www.mysensors.org/build/raspberry and I'm getting nothing in debug...
          mysgw: Starting gateway...
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: !TSM:INIT:TSP FAIL
          mysgw: TSM:FAIL:CNT=1
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:FAIL:RE-INIT
          In node I used your newest code for gw2.0 - is this because version mismatch or something different in my setup?
          Could you update your code to work with new version?
          F 1 Reply Last reply
          • HuczasH Huczas
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: TSM:FAIL:PDT
            F
            F
            flopp
            @Huczas
            I don't use 2.1, yet. I only use 1.5.1.
            I don't have any knowledge of 2.x, so I cannot update the code, sorry
            HuczasH 1 Reply Last reply
            • F flopp
              @Huczas
              HuczasH
              HuczasH
              Huczas
              @flopp just release that @mrwomble was posting that updated code sorry. @mrwomble can you help?
              • H
                H
                hiddenuser
                Hello All,
                Wondering if any one of the successful implenters would be able to share their soil moisture graphs,both for a day and over months..
                • D
                  dmonty
                  To solve the battery discharge memory issue, could a second battery be added with logic to alternate between batteries and fully discharge one at a time?
                    Charge memory is a thing of the past, lithium batteries don't have it (if I understood what you meant).
                      #77
                      @gohan said in Solar Powered Soil Moisture Sensor:
                      Except that, if I'm not mistaken, he's presently re-using the NiCd's that came with the original solar garden light.
                      [Edit: correction: I think maybe (?) he switched to Nimh. I didn't think those had a memory problem. Do they? ]
                      [Edit2: Maybe he'll "upgrade" to a supercap. :) A soil moisture meter would be a good application for one. ]
                        NiMh still have some charge memory but not as bad as the NiCd. I got the moisture sensors yesterday I have to test them the next days.
                        https://www.aliexpress.com/item/Soil-Moisture-Sensor/32532715392.html
                        • R
                          R
                          ricorico94
                          I started building this great idea of solar powered soil moisture sensor. Not integrated yet in a solar light as above, but still on my desk.
                          I tested the sensor in salted water and I get a report of 78% moisture : based on your experience, is it normal ? Then I pushed the sensor in a very humid plant pot and read 71%. I would have expected mroe differenc ecompared to salted water.
                          So, would you advise to caliber ? I guess I could modify the calculation formula in the script..
                          Precisely, is it possible with Mysensor technology and Domoticz to push to a sensor a new setting (for instance to caliber using Domoticz each different sensor) ?
                          And another question.. Is it possible to ask Domoticz to show the result of moisure reading in the Weather or Measures category rather than in the Temperature menu ?
                          br,
                          Ricorico94
