  3. Battery Level Measurement
arduinobattery
11 Posts 3 Posters 14.0k Views 1 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    Do you want to power it directly with battery connected to VCC of the atmega? Then it's possible to measure the battery voltage without any external components.
    http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    funky81F 1 Reply Last reply
    • funky81F funky81
      Hi Guys,
      Need your advice for arduino battery level measurement.
      The goal is that I want to monitor my battery consumption so I can get notice for battery replacement if it's already low.
      This is my setup. is it correct already? I'm using this link as reference.
      m26872M
      m26872M
      m26872
      wrote on last edited by m26872
      @funky81 The wiring priciple is correct but you have to think of the components. Try six 1,5V cells in series, use R1=5Mohm (=two 10Mohm in parallell) and R2=680kohm and preferably a 0.1uF capacitor in parallell with R2. And some of the code below.
      One (major) drawback with the "secret external-component-less" method from @tbowmo is the Vcc becomes unregulated and it will be more difficult to use and interact with other things like sensors.
      /* BATTERY METER
        Internal_ref=1.1V, res=10bit=2^10-1=1023,
        Some different 1.5V cell (I use AAs) configurations and some suggested corresponding resistor value relations:
        2AA: Vin/Vbat=470e3/(1e6+470e3), 3AA: Vin/Vbat=680e3/(2.5e6+680e3), 4AA: Vin/Vbat=1e6/(1e6+5e6), 5-6AA: Vin/Vbat=680e3/(5e6+680e3), 6-8AA: Vin/Vbat=1e6/(1e6+10e6)
        Example with 6AAs and R1=5Mohm (=two 10Mohm in parallell) and R2=680kohm:
        Vlim = 1.1*Vbat/Vin = 9.188235 V (Set eventually to Vmax)
                                (9.2V = 1.53V/cell which is a little low for a fresh cell but let's say it's ok to stay at 100% for the first period of time)
        Volts per bit = Vlim/1023 = 0.008982
        Vmin = 6V (Min input voltage to regulator according to datasheet. Or guess Vout+1V )   DEFINE
        Vmax = 9.188235V (Known or desired voltage of full batteries. If not, set to Vlim.)  DEFINE
        Vpercent = 100*(Vbat-Vmin)/(Vmax-Vmin)
        // some code
      #define VMIN 6.0 // (Min input voltage to regulator according to datasheet or guessing. (?) )
      #define VMAX 9.188235 // (Known or desired voltage of full batteries. If not, set to Vlim.)
        // some code
      int oldBatteryPcnt = 0;
        // some code
        analogReference(INTERNAL);    // use the 1.1 V internal reference for battery level measuring
        // some code
          // some code
        int sensorValue = analogRead(BATTERY_SENSE_PIN);    // Battery monitoring reading
      //  Serial.println(sensorValue);
        float Vbat  = sensorValue * 0.008982;
      //  Serial.print("Battery Voltage: "); Serial.print(Vbat); Serial.println(" V");
       //int batteryPcnt = sensorValue / 10;
      //  Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
          oldBatteryPcnt = batteryPcnt;
        // some code
      • tbowmoT
        tbowmoT
        tbowmo
        @m26872
        It highly depends on what sensors you want to use.
        If you want to go battery powered, you really should invest some time in finding the right sensors that can be used at low voltages.
        • m26872M
          m26872M
          m26872
          @tbowmo I agree.
          ... and something else than an Uno. Given that it actually is an Uno, I expect we're not really in to specialized sensors yet.
          And, sometimes opinions are not as helpful when we don't know the specification or application.
          • tbowmoT tbowmo
            funky81F
            funky81F
            funky81
            @tbowmo right now, the battery will be connected only to vin, coz it raw.
            my step up power converter (in this link) havent arrived yet. So i will use vin only.
            if it stable enough I will connect battery => step up power converter => vcc
            then i will use the link that you provide before
            is my theory correct?
            m26872M 1 Reply Last reply
            • m26872M m26872
              /* BATTERY METER
                // some code
                // some code
                // some code
                // some code
                  // some code
                // some code
              funky81F
              funky81F
              funky81
              @m26872 right now, i dont have any plans to use more than 2 batteries in series.
              but if i do, i will use step up power converter to stable it.
              but ofcourse this is my theory. am I correct ?
              • tbowmoT
                tbowmoT
                tbowmo
                @funky81
                If you use a step-up converter, then you need to use the design you made in first post.
                My method can only be used if you don't have any voltage regulators etc. between the battery and the atmel chip (f.ex. something like http://forum.mysensors.org/topic/510/minimal-design-thoughts, which do not use any regulators, and the battery is connected directly to the atmel.
                • funky81F funky81
                  m26872M
                  m26872M
                  m26872
                  @funky81 I'm confused. Are you trying to use a 3.3v step-up to an 5V Uno?
                  One or two 1.5V cells works great with a 3V-step-up setup like to power a 3V Arduino Pro Mini to Vcc as I do myself here BUT you can NOT supply a 5V-configuration.
                  • m26872M m26872
                    funky81F
                    funky81F
                    funky81
                    I'm sorry to make you confused. Currently I'm using 3.3v arduino pro mini.
                    What I mean is not step up converter, but step up power converter (http://goo.gl/PFt99R) => to stablize 3.3v to maintain a steady 3.3 VDC even as the battery capacity diminishes. (like in this page http://www.mysensors.org/build/battery)
                    Hmm..after I read your post (http://forum.mysensors.org/topic/486/my-2aa-battery-sensor/4), it seems I have the same goal like you. I'll asked few thing in your thread, if that's okay with you :)
                    • tbowmoT tbowmo
                      @funky81
                      funky81F
                      funky81F
                      funky81
                      wrote on last edited by funky81
                      Hi @tbowmo, do you mind to explain a bit about the design? I'm interested with your design.
                      I will use these steps for removing voltage regulator, http://goo.gl/CsZaNg
                      So the design will be battery > external step up regulator (http://goo.gl/PFt99R - to stabilize 3.3v) > vcc pin ?
                      with these then I can use my first post design?
