  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 66.3k Views 21 Watching
  • pansenP
    pansenP
    pansen
    i'm sorry, i do not have experience with encryption. essentially it depends on the code you want to write, since on the pi you are kind of limited to scripting, whereas microcontroller code is closer to hardware. also, if you need things like an adc or spi you're better of with a microcontroller. if it's just about some LEDs lighting up..
    Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
    • 8 8667
      Thanks, I already have a broker and OpenHAB. Want this gateway to act as a client....maybe it will even support SSL MQTT. And encryption with
      #define MY_RF24_ENABLE_ENCRYPTION is wanted.
      In the article, there is no list of all available configurations...yea adding SD card does not make it cheaper
      @8667 said in 💬 Building a Orange Pi Gateway:
      From the article:
      For a complete list of configuration parameters, run:
      ./configure --help
      Did you miss this or is there something I'm not understanding?
      • B
        B
        BAsavaraj004
        mysgw: Could not open /sys/class/gpio/gpio10/direction
        Please help me to solve this error
        • B BAsavaraj004
          @BAsavaraj004 could you describe what you did when you got that error?
          • B
            B
            BAsavaraj004
            @mfalkvidd
            When I executed sudo ./bin/mysgw -d this command after that i'm facing error like :
            mysgw: Starting gateway...
            mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: Could not open /sys/class/gpio/gpio24/direction
            I followed all the steps provide in the site but still I am getting error.
            • B BAsavaraj004
              @mfalkvidd
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              @BAsavaraj004 thanks. Earlier posts indicate that the "Could not open" error could be caused by a problem with the pin mapping. I don't have an OrangePi myself so I don't know the details but maybe these posts can help:
              https://forum.mysensors.org/post/69656
              https://forum.mysensors.org/post/60943
              https://forum.mysensors.org/post/56374
              • S SdeWeb
                Well done finally i used the dedicated .fex file for Orange Pi Plus 2E here :
                https://linux-sunxi.org/Xunlong_Orange_Pi_Plus_2E#Expansion_Port
                at this point :
                https://github.com/igorpecovnik/lib/blob/master/config/fex/orangepiplus2e.fex
                Read the .fex file in a text editor, u'll see important things about "gpio_config" for H3 cpu :
                ; NOTE: This section is necessary only for "gpio_sunxi" driver
                ; which is obsolete for H3 boards
                [gpio_para]
                gpio_used = 0
                gpio_num = 0
                I connected my NRF24L01 on OPI P2E like this :
                NRF24L01 Port Name / (Pin N°) ----- OPI Port (Pin N°) / Name
                                      GND (1)  <-----------> (20) / GND
                                      VCC (2)  <-----------> (17) / 3.3V PWR
                                      CE (3)   <-----------> (22) / (PA2 / GPIO2)
                                      CSN (4)  <-----------> (24) / (PC3 / GPIO67)
                                      SCK (5)  <-----------> (23)
                                      MOSI (6) <-----------> (19) MOSI
                                      MISO (7) <-----------> (21) MISO
                                      IRQ (8)  <-----------> NC
                So "MySensors" setup is :
                ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67
                Then
                ./bin/mysgw -d
                Return :
                root@orangepiplus2e:~/MySensors# ./bin/mysgw -d
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:INIT:TSP OK
                mysgw: TSM:INIT:GW MODE
                mysgw: MCO:REG:NOT NEEDED
                mysgw: MCO:BGN:STP
                mysgw: MCO:BGN:INIT OK,TSP=1
                Best.
                Seb.
                E
                E
                ElDuderino
                wrote on last edited by ElDuderino
                #76
                @SdeWeb said in 💬 Building a Orange Pi Gateway:
                at this point :
                [gpio_para]
                gpio_used = 0
                gpio_num = 0
                Then
                ./bin/mysgw -d
                Return :
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                Best.
                Seb.
                This worked great on my Orange Pi Lite.
                I was trying to follow the tutorial at Building a Orange Pi Gateway and I tried all sorts of things that didn't work.
                IMO the main tutorial should have this as instruction to building a gateway with Orange Pi Lite/Plus.
                Thanks!!
                ( Sorry for quoting the entire original post, but this will help anyone searching for help with their Orange Pi Lite)
                  I got the OrangeZero and was building the configuration command... can someone provide me more detailed instructions about using higher security?
                  1. Is it possible to use SSL for the connecting to the broker?
                  2. How whitelisting works with Pi? I moved away of Arduino as I do not want to recompile it everytime I need to include new node. So far I have
                  -my-signing-request-signatures --my-signing-debug --my-signing=password --my-signing-password=SOMETHING --my-rf24-encryption-enabled
                  but this will not allow me to exclude stolen nodes right?
                  AnticimexA 1 Reply Last reply
                  • 8 8667
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @8667 no, it won't. As it is for the moment, whitelisting works no different compared to Arduino based devices. You will have to recompile your GW if you add new nodes as you will need to add their serials to the whitelist in the GW.
                    8 1 Reply Last reply
                    • AnticimexA Anticimex
                      @Anticimex said in 💬 Building a Orange Pi Gateway:
                      So how personalization works on the orange and how to pass the list of serials?
                      • 8 8667
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @8667 not sure. I have not been involved in the rPi port. I suggest you pass --help to the configure command. It should give a list of options.
                          This should be in the wiki
                          root@pi0:~/MySensors# ./configure --help
                          configure script for MySensors gateway.
                          Options:
                          Help:
                              -h, --help                  print this message
                          SPI driver options:
                              --spi-driver=[BCM|SPIDEV]
                              --spi-spidev-device=<DEVICE>
                                                          Device path. [/dev/spidev0.0]
                          Building options:
                              --soc=[BCM2835|BCM2836|BCM2837|AM33XX|A10|A13|A20|H3]
                                                          SoC type to be used. [configure autodetected]
                              --cpu-flags=<CPUFLAGS>      CPU defining/optimizing flags to be used. [configure autodetected]
                              --extra-cflags=<CFLAGS>     Extra C flags passed to C compilation. []
                              --extra-cxxflags=<CXXFLAGS> Extra C++ flags passed to C++ compilation. []
                              --extra-ldflags=<LDFLAGS>   Extra C flags passed to linking. []
                              --c_compiler=<CC>           C compiler. [arm-linux-gnueabihf-gcc][gcc]
                              --cxx_compiler=<CXX>        C++ compiler. [arm-linux-gnueabihf-g++][g++]
                              --build-dir=<DIR>           Compiler directory to store object files. [build]
                              --bin-dir=<DIR>             Compiler directory to store binary files. [bin]
                              --arduino-lib-dir=<DIR>     Arduino library directory.
                              --no-clean                  Don't clean previous build artifacts.
                          Installation options:
                              --prefix=<PREFIX>           Installation prefix path. [/usr/local]
                              --gateway-dir=<DIR>         Gateway files installation directory. [PREFIX/bin]
                          MySensors options:
                              --my-debug=[enable|disable] Enables or disables MySensors core debugging. [enable]
                              --my-config-file=<FILE>     Config file path. [/etc/mysensors.dat]
                              --my-gateway=[none|ethernet|serial|mqtt]
                                                          Set the protocol used to communicate with the controller.
                                                          [ethernet]
                              --my-node-id=<ID>           Disable gateway feature and run as a node with the specified id.
                                                          Controller or MQTT broker ip.
                              --my-serial-port=<PORT>     Serial port. [/dev/ttyACM0]
                              --my-serial-baudrate=<BAUD> Serial baud rate. [115200]
                              --my-serial-is-pty          Set the serial port to be a pseudo terminal. Use this if you want
                                                          to connect to a controller running on the same device.
                              --my-serial-pty=<NAME>      Symlink name for the PTY device. [/dev/ttyMySensorsGateway]
                              --my-serial-groupname=<GROUP>
                                                          Grant access to the specified system group for the serial device.
                              --my-mqtt-user=<UID>        MQTT user id.
                              --my-mqtt-password=<PASS>   MQTT password.
                              --my-mqtt-publish-topic-prefix=<PREFIX>
                                                          MQTT publish topic prefix.
                              --my-mqtt-subscribe-topic-prefix=<PREFIX>
                                                          MQTT subscribe topic prefix.
                              --my-transport=[none|nrf24|rs485|rfm95|rfm69]
                                                          Set the transport to be used to communicate with other nodes.
                                                          [nrf24]
                              --my-rf24-channel=<0-125>   RF channel for the sensor net. [76]
                              --my-rf24-pa-level=[RF24_PA_MAX|RF24_PA_LOW]
                                                          RF24 PA level. [RF24_PA_MAX]
                              --my-rf24-ce-pin=<PIN>      Pin number to use for rf24 Chip-Enable.
                              --my-rf24-cs-pin=<PIN>      Pin number to use for rf24 Chip-Select.
                              --my-rf24-irq-pin=<PIN>     Pin number connected to nRF24L01 IRQ pin.
                                                          Enables RF24 encryption.
                                                          All nodes and gateway must have this enabled, and all must be
                                                          personalized with the same AES key
                              --my-rx-message-buffer-size=<SIZE>
                                                          Buffer size for incoming messages when using rf24 interrupts. [20]
                              --my-rfm69-frequency=[315|433|868|915]
                                                          RFM69 Module Frequency. [868]
                              --my-is-rfm69hw             Enable high-powered rfm69hw.
                              --my-rfm69-cs-pin=<PIN>     Pin number to use for RFM69 Chip-Select.
                              --my-rs485-serial-port=<PORT>
                                                          RS485 serial port. You must provide a port.
                              --my-rs485-baudrate=<BAUD>  RS485 baudrate. [9600]
                              --my-rs485-de-pin=<PIN>     Pin number connected to RS485 driver enable pin.
                              --my-rs485-max-msg-length=<LENGTH>
                                                          The maximum message length used for RS485. [40]
                              --my-leds-err-pin=<PIN>     Error LED pin.
                              --my-leds-rx-pin=<PIN>      Receive LED pin.
                              --my-leds-tx-pin=<PIN>      Transmit LED pin.
                              --my-leds-blinking-inverse  Inverse the blinking feature.
                              --my-signing=[none|software|password]
                                                          Message signing. [none]
                              --my-signing-debug          Enable signing related debug.
                              --my-signing-request-signatures
                                                          Enable signature request from nodes that in turn requested
                                                          gateway signature.
                              --my-signing-weak_security  Enable this to permit downgrade of security preferences and
                                                          relaxed gateway signing requirements.
                              --my-signing-password=<PASSWORD>
                                                          If you are using password as the signature type, set your password here.
                          root@pi0:~/MySensors# sudo ./bin/mysgw -h
                          mysgw: Config file /etc/mysensors.dat does not exist, creating new config file.
                          Usage: mysgw [options]
                          Options:
                          AnticimexA mfalkviddM 2 Replies Last reply
                          • 8 8667
                            Options:
                            Help:
                            SPI driver options:
                            Building options:
                            MySensors options:
                                                            [ethernet]
                                                            [nrf24]
                                                            gateway signature.
                            Options:
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @8667 if there is no option for the whitelist, you should still be able to set it using the same #define as mentioned in the signing documentation. The implementation is shared.
                            It makes sense to keep it like that since the list could be quite long.
                            • 8 8667
                              Options:
                              Help:
                              SPI driver options:
                              Building options:
                              MySensors options:
                                                              [ethernet]
                                                              [nrf24]
                                                              gateway signature.
                              Options:
                              #83
                              @8667 a first try of making the help text available online is now available at https://ci.mysensors.org/job/MySensors/job/MySensors/job/PR-952/12/Doxygen_HTML/group__RaspberryPiGateway.html
                              If/when the pull request is accepted, a link can be added on the build page.
                              • Ricardo RibeiroR
                                Ricardo RibeiroR
                                Ricardo Ribeiro
                                Hello! I followed instructions by SdeWeb on my Orange Pi Lite with Armbian, and gateway is working fine, I can see debug messages from other node. But when I try to add a serial port in node-red I can't find the gateway one. Can you help me?
                                • Ricardo RibeiroR
                                  Ricardo RibeiroR
                                  Ricardo Ribeiro
                                  FYI i configure like this:
                                  ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB10 --my-serial-baudrate=115200
                                    NOTE for Armbian and Orange Pi Zero.
                                    Set static IP address or the device will lose connection on next DHCP request. I use only the LAN and was having problems for few days.
                                    • 8 8667
                                      @8667 I didn't know it was possibe to set ip address for the Pi gateway. How did you do that?
                                        SdeWeb
                                        wrote on last edited by SdeWeb
                                        #88
                                        You should set your gateway as a ethernet / network gateway. By default, it run on port 5003 (ex : [gwipadresse]:5003.
                                        If you controler is hosted on the same machine that the gateway, then you can call the ip adresse : 127.0.0.1:5003. (the localhost adress) whatever the real IP adresse of your PI.
                                        if you got a good router on u'r network, that it running DHCP server and give IP adresses of your devices on the network, then you can define static IP adresse for the MAC adresse of your PI.
                                        Regards.
                                        • Ricardo RibeiroR
                                          Ricardo RibeiroR
                                          Ricardo Ribeiro
                                          I had to use spidev0.0 and not spidev1.0:
                                          opilite@orangepilite:~/MySensors$ sudo ./bin/mysgw -d
                                          mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-beta
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: MCO:BGN:STP
                                          opilite@orangepilite:~/MySensors$ ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
