  3. Supercap Solar Powered Mysensors nodes as cheap as possible
98 Posts 6 Posters 33.9k Views 8 Watching
    exactly, it was me and it was about these sab mosfets
      I maybe up to something: I used a MCP1700 ldo and on Vout a diode + a schottky in series to drop the voltage ( could have used just the diode, but the Vout was 2.7x volts so for supercap longevity I added the schottky to have a safe margin) and it is charging even with panel pointed away from the sun. I'll see how it goes tomorrow, but I am pretty happy with the results so far. If it works I think i can't go cheaper then a LDO + 2 diodes :v:
        It started charging at around 7:30am: it is placed on an eastern wall in vertical position with practically no direct sunlight. It takes a while to stabilize around 2.55V but overall it looks reasonable for the cost of all the power circuit.
        0_1509635630373_upload-5a2288c5-2308-4125-ba3e-6d83cb94fa71
          What is the cost? Also, it's not clear to me how much usable charge you're getting.
            1.5€ for solar panel, 1.7€ for 100F supercap, 1€ for booster and some cents for MCP1700, diodes and a small PCB. A fully charged supercap gives 3 days of working time, with send every 10 minutes of temp. hum, TX rssi, RX RSSI, battery voltage and battery percentage
            gohanG NeverDieN 2 Replies Last reply
              #44
              Sounds sorta roughly like the kind of circuit used in solar garden lamps, except you've replaced the typical rechargeable battery with a supercap and are boosting to a higher voltage than they typically do. I wonder whether any of them do boost to the same voltage that you're targeting? Perhaps the brighter ones, for example? Those solar garden lights typically have a single, inexpensive integrated circuit that does it all.
                the booster is plugged in the Easy PCB and it is used to power arduino and sensor
                  #46
                  @gohan said in Supercap Solar Powered Mysensors nodes as cheap as possible:
                  By "plugged in," do you mean like in your earlier photo?
                    wrote on last edited by gohan
                    #47
                    nope, that was the 5.5v supercap version. I mean plugged in in the socket next to the green screw terminal. Of course the buck boost module now it is not used. I have to put the new photo I know.
                      Since you're not posting schematics, maybe it's time for a new photo....
                        I need to learn how to make schematics :sweat_smile:
                          0_1509643234861_upload-e0f0eada-447b-47c3-9d6d-500457d53ed2
                          Does it make sense? The output terminals go to the Easy Pcb green screw terminals .
                            Does it make sense?
                            I suppose. Why the two diodes again instead of just the one?
                              #52
                              Because only one was not dropping enough voltage to have a safe margin, the schottky is giving that extra 0.2v
                                You'll have a very long charge tail with the diode(s) in that position.
                                  Do you mean it will take long time to fully charge?
                                    @gohan Yes.
                                      It took about 5 hours to charge and it wasn't in direct sunlight, I'm still happy with the results given I'm using general purpose parts I already had around and no sophisticated charge controllers (and no particular knowledge about electronics :sweat_smile:)
                                        @gohan :+1:
                                          0_1509815907001_upload-9b8d0c02-2431-40e8-a5e2-a8116c85246a
                                          Today was overcast all day so it took about 3 hours longer (until 3pm) to fully charge but overall it looks like a nice graph for the last 3 days.
