  3. Supercap Solar Powered Mysensors nodes as cheap as possible
98 Posts 6 Posters 34.3k Views 8 Watching
    wrote on last edited by gohan
    #47
    nope, that was the 5.5v supercap version. I mean plugged in in the socket next to the green screw terminal. Of course the buck boost module now it is not used. I have to put the new photo I know.
      Since you're not posting schematics, maybe it's time for a new photo....
        I need to learn how to make schematics :sweat_smile:
          0_1509643234861_upload-e0f0eada-447b-47c3-9d6d-500457d53ed2
          Does it make sense? The output terminals go to the Easy Pcb green screw terminals .
            @gohan said in Supercap Solar Powered Mysensors nodes as cheap as possible:
            Does it make sense?
            I suppose. Why the two diodes again instead of just the one?
              #52
              Because only one was not dropping enough voltage to have a safe margin, the schottky is giving that extra 0.2v
                You'll have a very long charge tail with the diode(s) in that position.
                  Do you mean it will take long time to fully charge?
                    @gohan Yes.
                      It took about 5 hours to charge and it wasn't in direct sunlight, I'm still happy with the results given I'm using general purpose parts I already had around and no sophisticated charge controllers (and no particular knowledge about electronics :sweat_smile:)
                        @gohan :+1:
                          0_1509815907001_upload-9b8d0c02-2431-40e8-a5e2-a8116c85246a
                          Today was overcast all day so it took about 3 hours longer (until 3pm) to fully charge but overall it looks like a nice graph for the last 3 days.
                            0_1510134605001_upload-fe574220-a002-4e36-bb4f-a895f54f1db9
                            2 days of rain and it can't charge, luckily it has more than 3 days of running time without charge. Being not in direct sunlight (vertically positioned on a wall just below roof) it has some drawbacks, but today it is catching up
                              The overcast days are where the two diodes are burning you.
                                if it is overcast it is not that dramatic as it still charges, it is the rainy day that is bad. I know that a more efficient and specific charging circuit would work better even at lower light/voltages, but still this is working fine as it recovered to 2.4V within 3 hours and 3 more to reach 2.5V. Unless I get 4 days or rain I should be fine but in the event of 4 rainy days I think I would be more worried about other things :D
                                  0_1511358675325_upload-4799b991-916e-4052-9fd2-b421052a9d44
                                  That is looking great so far (the spike was a reboot after I installed the SMA antenna)
                                    Since your goal was "as cheap as possible," what was your final tally on how much it cost? It would be good to know just how cheap is possible.
                                      1.5€ for solar panel, 1.7€ for 100F supercap, 1€ for booster and some cents for MCP1700, diodes and a small PCB. A fully charged supercap gives 3 days of working time, with send every 10 minutes of temp. hum, TX rssi, RX RSSI, battery voltage and battery percentage
                                      #64
                                      I already wrote it 3 weeks ago. :D
                                        #65
                                        So, something like $4 then I guess at today's exchange rate.
                                          yes 5$ range, of course you need to add the other costs like box, the node itself and everything you need to have the node working outdoor
