  3. PIR sensor and false positives
13 Posts 6 Posters 10.9k Views 6 Watching
  • M Offline
    M Offline
    Mister_ik
    After building my first combined sensor (not battery powered) i got enthusiastic about the MySensors project. This project as you can see was based on Arduino Nano and is working like a charm
    So i wanted to add more off these combined sensor nodes to my smart house. This time i wanted to try a battery powered sensor based on Pro Mini (5v version) and built the following sensor:
    Both project use the same PIR & BH1750 sensor and are running the same sketch (the second without the temperature sensor), but the second project (even if project is not powered by the battery) gives a lot of (and i mean a lot of) false positives.
    I already checked the following things:
    • tested the PIR also on breadboard with a Nano and there it is working fine
    • the project with only the lux sensor is working fine (only removed the PIR in the sketch)
    Can anyone confirm if i can rule out the difference between the boards i used (Nano and Pro mini)? Or perhaps does anyone can point me in the right direction how i can solve this?
    mfalkviddM Y 2 Replies Last reply
      The pir sensor is known to give false positives due to power fluctuations and EM interference. Try to put sensors as far as possible from radio module and add a decent size capacitor as close as possible to vcc pin of the the pir sensor.
      • M Mister_ik
        @Mister_ik I had lots of false triggers on an esp8266 node. Almost every time the esp sent data, the pir was triggered. Since the nrf uses the same frequencies, you might be experiencing the same problem.
        I glued aluminium foil to a piece of regular printer paper to create a shield around the pir module. I connected the foil to gnd.
        That eliminated all false triggers.
        N 1 Reply Last reply
          N Offline
          N Offline
          @mfalkvidd said in PIR sensor and false positives:
          Do you have a photo of that?
          S M 2 Replies Last reply
          • N NeverDie
            Just a small sidenote... the 9v battery are a poor choise in some tests I have made (and google searches) to power the board because of their high cost / mah and also current draw capacity. Using a AA pack is a better solution. Even if you got it to work with 9v its very expensive in the long run.
            The main issue i guess is that the pir needs 5v unless you do some hacks, but with some time put into it - that works (i have two running on 3.3v)
            • M Mister_ik
              Y Offline
              Y Offline
              @Mister_ik try to design your sensor to be directly powered by batteries, without step up/down conversion. The converters in general introduce a lot of noise, which the pir is very sensitive to.
              I power my pir sensors from 3xAA battery (remove the regulator from the pir module) and a 3.3v pro mini from 2xAA (same battery pack, just branch power after 2 batteries instead of whole pack)
              Works flawlessly with many years of battery lifetime.
              • N NeverDie
                M Offline
                M Offline
                Mister_ik
                @NeverDie @mfalkvidd I am also curious how you have done that. I picture would be nice!
                • mfalkviddM Offline
                  Sorry, I didn't take any pictures.
                  All I did was cut a piece of aluminum foil (stolen from the kitchen) to the size of a A4 paper (I guess Americans would use the "letter" size) and glue it to the paper. The paper doesn't conduct, so I didn't need to worry about shorting things.
                  • N Offline
                    N Offline
                    It sounds as though Yveaux didn't need the paper-metal shroud for some reason.
                    Y 1 Reply Last reply
                    • N NeverDie
                      Y Offline
                      Y Offline
                      @NeverDie yup, no aluminum foil in my builds ;-)
                      I do keep the radio away as far as possible from the PIR though.
                      This thread contains a picture: https://forum.mysensors.org/topic/3756/multisensor-pir-based-on-ikea-molgan/61
                      • M Offline
                        M Offline
                        Mister_ik
                        wrote on last edited by Mister_ik
                        Finally i got some time this weekend to try out all of you tips. So thanks for those tips. Indeed the problem was solved when i moved the PIR away from the rest. But what i also noticed is that the PIR also have false positives (much less when it was near to radio, but still there where false positives) when it is close to the Arduino board and away from the radio. Therefore i decided to alter the setup and not to make the sensor a battery powered sensor, but use some ethernet cable to connect the sensors to the mainboard with the arduino and the radio. The cable is long enough to reach a wall outlet, so i can run the arduino and radio on normal power.
                        Because i had now all the space in the sensor module i added a DHT sensor. Now some new challenges arise. The sensor is working fine, but when the PIR is going off, it loops the sketch a lot of times (exactly 50 times) before it sleeps again. Perhaps someone can give me a hint which is causing this. My programming skills are not that good, so I have combined some different sample sketches. I am using currently the following sketch:
                         * Version 1.0 - Henrik Ekblad
                        // Enable debug prints
                        #define MY_NODE_ID 130
                        #include <BH1750.h>
                        #include <wire.h>
                        #define CHILD_ID_MOTION 131              // Id of the motion sensor child
                        #define CHILD_ID_LIGHT  133              // Id of the Light sensor child
                        #define CHILD_ID_HUM    134              // Id of Hum sensor child
                        #define CHILD_ID_TEMP   135              // Id of temp sensor child
                        #define DIGITAL_INPUT_SENSOR 2           // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                        #define DHT_DATA_PIN 4                   // The digital input you attached your DHT sensor.
                        #define SENSOR_TEMP_OFFSET 0             // Set this offset if the sensor has a permanent small offset to the real temperatures
                        // Sleep time between sensor updates (in milliseconds).  Must be >1000ms for DHT22 and >2000ms for DHT11
                        static const uint64_t UPDATE_INTERVAL = 300000;
                        //unsigned long SLEEP_TIME = 300000;       // Sleep time between reports (in milliseconds)
                        float    lastTemp;
                        float    lastHum;
                        float    lasttripped;
                        uint16_t lastlux;
                        uint8_t  nNoUpdatesTemp;
                        uint8_t  nNoUpdatesHum;
                        uint16_t teller;
                        bool     metric = true;
                        BH1750 lightSensor;
                        DHT dht;
                        // Initialize motion message
                        MyMessage msgmotion(CHILD_ID_MOTION, V_TRIPPED);
                        MyMessage msglux(CHILD_ID_LIGHT, V_LEVEL);
                        //  setup
                          // setup of Lux sensor
                          lightSensor.begin();
                          // setup of DHT sensor
                          dht.setup(DHT_DATA_PIN);                   // set data pin of DHT sensor
                        //  presentation
                          sendSketchInfo("Motion + Lux + DHT", "1.0");
                          present(CHILD_ID_MOTION, S_MOTION);
                          present(CHILD_ID_HUM, S_HUM);
                          // Bepalen nodeID
                          uint8_t getNodeId();
                          Serial.println();
                          Serial.print("NodeID : ");
                          Serial.println(getNodeId());
                          Serial.println();
                          teller = 0;
                        //  loop
                          // **** BH1750 Lux sensor
                          Serial.println("------------------------------");
                          Serial.println("Requesting Light level...");
                          Serial.print("lux : ");
                          Serial.println(lux);
                          if (lux != lastlux) {
                             send(msglux.set(lux));
                             lastlux = lux;
                          else {
                             Serial.println("lux is nog hetzelfde : ");
                          // Read digital motion value
                          Serial.println("Requesting motion...");
                          bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                          Serial.print("Beweging sensor : ");
                          Serial.println(tripped);
                          if (tripped != lasttripped) {
                             send(msgmotion.set(tripped?"1":"0"));  // Send tripped value to gw
                             lasttripped = tripped;
                          else {
                             Serial.println("Motion is nog hetzelfde : ");
                          dht.readSensor(true);
                          //delay(dht.getMinimumSamplingPeriod());
                          Serial.print("Requesting Temperature...");
                          Serial.println("DONE");
                          if (isnan(temperature))
                          else if (temperature != lastTemp) {
                            #ifdef MY_DEBUG
                              Serial.print("OLD Temperature : ");
                              Serial.println(lastTemp);
                              Serial.print("NEW Temperature : ");
                            lastTemp = temperature;
                            if (!metric) {
                          Serial.println();
                          Serial.print("Requesting Humidity...");
                          if (isnan(humidity))
                          else if (humidity != lastHum ) {
                            #ifdef MY_DEBUG
                              Serial.print("OLD Humidity : ");
                              Serial.println(lastHum);
                              Serial.print("NEW Humidity : ");
                              Serial.println(humidity);
                            lastHum = humidity;
                            send(msgHum.set(humidity, 0));
                          // Sleep
                          teller++;
                          // Sleep for a while to save energys
                          Serial.print("teller...: ");
                          Serial.println(teller) ;
                          sleep(INTERRUPT, CHANGE, UPDATE_INTERVAL);
                          Serial.println();
                        // END : einde script
                          Did you try to put a short delay or sleep before the real sleep? Or you could also try some caps on the pir vcc
                          • M Mister_ik
                            #include <BH1750.h>
                            #include <wire.h>
                            float    lastTemp;
                            float    lastHum;
                            float    lasttripped;
                            uint16_t lastlux;
                            uint16_t teller;
                            bool     metric = true;
                            BH1750 lightSensor;
                            DHT dht;
                            //  setup
                            //  presentation
                              // Bepalen nodeID
                              Serial.println();
                              Serial.println();
                              teller = 0;
                            //  loop
                                 lastlux = lux;
                              else {
                              else {
                                #ifdef MY_DEBUG
                                if (!metric) {
                              Serial.println();
                                #ifdef MY_DEBUG
                                lastHum = humidity;
                              // Sleep
                              teller++;
                              Serial.println();
                            Y Offline
                            Y Offline
                            @Mister_ik make sure you're using mySensors 2.2.x development branch, as it contains some fixes for sleeping with interrupts.
                            12.0k
