  2. Bug Reports
  3. NRF24L01+ problems in 2.1.1 and 2.2.0 Beta
49 Posts 9 Posters 17.1k Views 12 Watching
    I think he is asking if you tried other modules from different manufacturer
      #40
      Thanks @gohan
      In that case, the answer is that I don't know. I have ordered through Aliexpress 3-4 times. I don't know which modules came from which order, or if the orders were sourced from different manufacturers.
      • mfalkviddM
        I have now tracked down the commit that makes the default raspberry pi gateway work: https://github.com/mysensors/MySensors/commit/4c31e22d6ff45c3a4f8aa70f915c5f10fe345f64
        When using the commit before this (26c237adadda9f79b07d862708d8471285a96905 ) the radio init fails.
        So now we at least know why development works and 2.1.1 does not.
        git checkout 26c237adadda9f79b07d862708d8471285a96905
        ./configure --extra-cxxflags="-DMY_DEBUG -DMY_DEBUG_VERBOSE_RF24" && make && sudo bin/mysgw -d
        mysgw: Starting gateway...
        mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: RF24:INIT
        mysgw: RF24:INIT:PIN,CE=9,CS=24
        mysgw: RF24:WBR:REG=0,VAL=14
        mysgw: RF24:WBR:REG=3,VAL=3
        mysgw: RF24:WBR:REG=4,VAL=95
        mysgw: RF24:WBR:REG=5,VAL=76
        mysgw: RF24:WBR:REG=6,VAL=37
        mysgw: RF24:WBR:REG=16,VAL=115
        mysgw: RF24:WBR:REG=29,VAL=6
        mysgw: RF24:RBR:REG=6,VAL=0
        mysgw: RF24:RBR:REG=5,VAL=0
        mysgw: !RF24:INIT:SANCHK FAIL
        mysgw: !TSM:INIT:TSP FAIL
        git checkout 4c31e22d6ff45c3a4f8aa70f915c5f10fe345f64 #68
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: RF24:INIT
        mysgw: RF24:INIT:PIN,CE=22,CS=24
        mysgw: RF24:RBR:REG=6,VAL=37
        mysgw: RF24:RBR:REG=5,VAL=76
        mysgw: RF24:WBR:REG=2,VAL=2
        mysgw: RF24:WBR:REG=1,VAL=0
        mysgw: RF24:WBR:REG=28,VAL=3
        mysgw: RF24:FRX
        mysgw: RF24:FTX
        mysgw: RF24:WBR:REG=7,VAL=112
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: RF24:WBR:REG=2,VAL=3
        mysgw: RF24:WBR:REG=1,VAL=1
        mysgw: RF24:STL
        mysgw: RF24:WBR:REG=0,VAL=15
        mysgw: RF24:WBR:REG=10,VAL=0
        mysgw: MCO:REG:NOT NEEDED
        mysgw: RF24:RBR:REG=23,VAL=17
        miljumeM 1 Reply Last reply
        • G
          G
          GrantsPi
          I am glad I'm not the only one having this issue (but hope it will be resolved soon).
          I had a RPi3 with the MQTT gateway working well for the past year, until I decided to upgrade to the latest version of Raspbian (and MySensors). I've now tried with a fresh install on both the RPi3 and a RPi2; with the same NRF24 as before (working well in the previous build); I also tried with a different radio using a socket and capacitor.
          Looking forward to your progress!
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:FAIL:CNT=1
          mysgw: TSM:FAIL:PDT
          mysgw: TSM:FAIL:RE-INIT
          mysgw: TSM:INIT
          mysgw: TSM:FAIL:CNT=2
          mysgw: TSM:FAIL:PDT
          • JokgiJ Jokgi
            @miljume Are you using modules with the genuine Nordic Devices mounted on them? How do you have it connected? Are you successful with any other "compatible" modules?
            miljumeM
            miljumeM
            miljume
            wrote on last edited by miljume
            #43
            @Jokgi Mots probably they are not genuine (bought from Aliexpress) but these devices themselves have not caused me any issues before. It started when I upgraded to 2.1.1. Although, after a clean install with 2.2.0 Beta it started working again so I am 100% sure that it's not the modules
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: RF24:INIT
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: RF24:INIT
              mysgw: RF24:FRX
              mysgw: RF24:FTX
              mysgw: RF24:STL
              miljumeM
              miljumeM
              miljume
              @mfalkvidd Good! I have now succeded in getting 2.2.0 Beta up and running with Ethernet GW
              • W
                W
                wergeld
                @mfalkvidd said in NRF24L01+ problems in 2.1.1 and 2.2.0 Beta:
                Okay, this works for me now as well. However, Domoticz still doesn't report any updated data beyond the first seen measurement for the temp portion of the sensors....I am about to see how far these slim nodes can fly...
                • alowhumA
                  alowhumA
                  alowhum
                  #46
                  I had the same problem with 2.1.1 on a Raspberry Pi Zero W.
                  Changing to the development version fixed it.
                  • alowhumA
                    alowhumA
                    alowhum
                    I'm trying to connect Domoticz to a virtual serial.
                    ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-rf24-pa-level=RF24_PA_LOW --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/serial2
                    But while Domoticz sees the serial port, it does not seem to connect. I also see the "end of file" error in the Domoticz logs.
                    What baudrate should be set in Domoticz?
                      Compile as ethernet GW, much less problems :D
                      • alowhumA
                        alowhumA
                        alowhum
                        #49
                        Tried that, still having problems.
                        Syslog says a lot of: "mysgw: Client 0: 0:0:3:0:18:PING
                        with an occasional "rsyslogd-2007: action 'action 17' suspended, which is probanly about the log being spammed by MySensors.
                        • It uses a 3.3v stabiliser board.
                        • Tried different power levels in settings (usually use low power because it works better for the cheap Chinese knock-offs)
                        • Tried external 5v power supply.
                        My nodes are saying 'FPAR: NO REPLY'
