  3. 💬 Multi-Sensor: Temp/Humidity/PIR/ Leak/Magnet/Light/Accel
117 Posts 18 Posters 44.9k Views 17 Watching
    I have the Version 1 design now working with the si7021 breakout board that I got from Aliexpress. Note that if you use these breakout boards, remember to remove the voltage regulator and solder bridge across the two pins as shown in the photo below:
    This is because the coin-cell voltage is already in the desired range, and so there's no need for further voltage reduction.
    • T
      Toyman
      Is v7 already for CR2477? BOM still mentions CR2032
      • T Toyman
        #41
        @Toyman said in 💬 Small Wireless Temp/Humidity Leak/Magnet/Light/Accel Sensor:
        If I had kept the same button cell holder as some of the earlier version it would be. However, I switched to a narrower profile battery holder in the BOM (which benefits the leakage sensor part of the design). Not sure if an equivalent CR2477 holder is still available with the new design. Haven't checked. When I brought up the possibility of a CR2477 earlier, it didn't seem to generate much enthusiasm at the time. So, I took that to mean most people weren't really interested.
        • K
          K
          krisha
          wrote on last edited by krisha
          #42
          Nice project!
          What about adding two resistors to measure and send the battery level as well?
          • K krisha
            Nice project!
            #43
            @krisha said in 💬 Small Wireless Temp/Humidity Leak/Magnet/Light/Accel Sensor:
            not needed. You can measure the battery voltage without a divider.
              I just now uploaded the Version 8 files, which contains pads for an optional 100uF ceramic capacitor. Thank you to @nca78 and @scalz for the suggestion.
                Now reads temperature and humidity from the si7021 and sends the values to Domoticz for graphing:
                • G
                  G
                  ghiglie
                  ...another n00b question: what are the PCB dimensions?
                  atmega328p serial killer
                  HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
                  • G ghiglie
                    @ghiglie said in 💬 Multi-Sensor: Temp/Humidity Leak/Magnet/Light/Accel:
                    The diameter is 27.15mm.
                    G 1 Reply Last reply
                      G
                      G
                      ghiglie
                      @NeverDie Thanks! I'll ask the fab if they can do it without charging extra costs. Or I'll "square" it - maybe with a hole in the angles to screw it. Really like this design.
                      • G ghiglie
                        @ghiglie What is it that you'd want to screw it to? It might be easier to just tape it or glue it in place. It's light enough that it wouldn't need much holding strength. Screwing may be overkill.
                          G
                          G
                          ghiglie
                          @NeverDie said in 💬 Multi-Sensor: Temp/Humidity Leak/Magnet/Light/Accel:
                          I was thinking about the top of a door... You'r right, I overestimated its weight.
                          • G ghiglie
                            #51
                            If you've never tried them, these things are great:
                            https://www.amazon.com/Command-Poster-Hanging-60-Pairs-17024-60ES/dp/B01FIK56Q4/ref=sr_1_3?ie=UTF8&qid=1510769859&sr=8-3&keywords=3m%2Bcommand%2Bmounting&th=1
                            They have a lot of holding power (more than ample for one of these sensors), and yet they can be cleanly removed without damaging the surface you hang it on.
                            3M also has a velcro-like version so that you can attach, then detach and re-attach as much as you want.
                              #52
                              First, the good news: it works! :) I've uploaded photos of the version 7 board that I just today received and put together. It powered up without a hitch and started sending temperature and humidity values to Domoticz like a champ. The one caveat is that I will need to increase the board diameter by a couple of millimeters, as there presently just isn't enough proper physical separation between the supportive male leak detection pins and the CR2032 battery holder. So, I will do that, and I will post a version 9 after I have received and tested the improved boards.
                                G
                                G
                                ghiglie
                                @NeverDie Thanks! Here in Italy they's sold with another name, but it's still a 3M branded one. I'll look for a pack! :)
                                  #54
                                  I have uploaded version 9. This should fix the physical clearance issue. Also, I upgraded the cap to be a 1206 220uF ceramic capacitor, as the cost is nearly the same as for an 0805 100uF capacitor. I should think that 220uF will offer plenty of reserve for the future when the battery ultimately develops a high internal resistance.
                                    #55
                                    More good news: I today received the PCB for a revision of my PIR module that's meant to be compatible with this Multi-Sensor. I just now did a dry-fitting, and, indeed, it should all fit together just fine:
                                    That means the entire PIR sensor can be quite small and compact! :)
                                      For PIR capability, the multi-sensor can simply plug into this PIR module: https://www.openhardware.io/view/420/AM612-Passive-Infrared-Sensor-Breakout-Board
                                        #57
                                        I have an experimental version in the works which uses a micro USB connector instead of the 10-pin connector. The advantage is that it can be connected from the side rather than above, which means the PIR sensor can be snuggled up close to the rest of the Multi-Sensor PCB and then permanently soldered into place:
                                        The result would be an even more compact PIR sensor.
                                        Once there's an OTA bootloader, though, this issue will become moot, and so I think for most people the 10-pin solution will be easier, especially for noobs.
                                          #58
                                          @nca78 Which do you think would be the best accelerometer to use? If affixed to a garbage can, for instance, it should be able to detect the trash can being emptied by the garbage truck.
                                          Nca78N 1 Reply Last reply
