No Auto node id
All of my devices don't get AUTO node id in Vera or openHab.Everytime i write it manually
in the skech. Is this normal? I couldn't find a solution in the forum.
@C.r.a.z.y.
I am not use Vera, but OpenHab with MQTT gateway works Ok. Which gateway you using? As i understand, serial and ethernet gateway's does not have such functionality.
UPD: I may be unclear, sorry, english not my native language. Only MQTT Gateway assign node id's on sensors by itself, Serial and Ethernet gateway does not, and id's should be assigned by controller. -
Thank you i am using serial so this is why i dont get auto node id.
Hi hek,
Orginal Relay sketch;
repeater started, id 0
send: 0-0-0-0 s=255,c=0,t=18,pt=0,l=5,st=fail:1.4.1
send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=5,st=fail:Relay
send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
send: 0-0-0-0 s=1,c=0,t=3,pt=0,l=5,st=fail:1.4.1I used orginal motion sensor sketch only change is define CHILD_ID 90
sensor started, id 0
send: 0-0-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=13,st=fail:Motion Sensor
send: 0-0-0-0 s=90,c=0,t=1,pt=0,l=5,st=fail:1.4.1
send: 0-0-0-0 s=90,c=1,t=16,pt=0,l=1,st=fail:0
send: 0-0-0-0 s=90,c=1,t=16,pt=0,l=1,st=fail:1 -
@C.r.a.z.y. is this confirm? coz i'm having the same problem.
and Yes, i'm using serial for my gateway and usb for my sensor.
Please share if there's possible answer for this problem.thanks
