  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.3k Views 58 Watching
  • tekkaT tekka
    @ahmedadelhosni Why would you want to flash MYSBootloader on your GW? OTA FW update capabilities only make sense on sensor nodes...
    ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    @tekka I just thought that if I flashed a bootloader on a new hardware IC then I can decide whether to flash GW or sensor node when connected to the serial computer.
    • K
      K
      ksya
      I see that after compiling I get to choose between sketch.ino.hex and sketch.ino.with_bootloader.hex
      Is it possible to update the bootloader OTA by using this hex file instead? Which is the best bootloader available now, because my nodes are now on 1.3pre (from topic start).
      • I
        I
        itbeyond
        How does GW mode actually work - I have been trying to relay a connection to Vera but not matter what combination I am trying I cannot understand how the GW mode operates?
        • petewillP
          petewillP
          petewill
          @itbeyond Have you opened up your firewall so the Vera can communicate with the computer running MYSController?
          Here is how I have MYSContoller configured...
          First, connect MYSController to your existing gateway (if you are using Ethernet
          you only want one device to connect so don't have your Vera connected at the same time)
          0_1510582509499_upload-28bab7f1-4863-41bc-a749-179cb82ecf6c
          Once you do that you need to choose a port in the settings:
          0_1510582093482_upload-14ac4c29-1501-49ea-b0c5-d7503a02b769
          Then you press Connect (to connect to the actual Ethernet or Serial gateway).
          Once connected turn on GW Mode (mine is grayed out because I'm not at home connected to my gateway):
          0_1510582137860_upload-dd16413a-ef4c-4c1f-9dd9-7377f5090ed5
          In your Vera you would obviously want to connect to the IP address of the computer running MYSController
          0_1510582624549_upload-5296052c-b9b0-446b-b089-259b375d11e9
          I 1 Reply Last reply
          • karlheinz2000K
            karlheinz2000K
            karlheinz2000
            I have problems connecting a serial NRF24 gateway to MYSController b3314. After some minutes working properly, no more messages seem to get received by MYSController. If I disconnect and connect again (button, not USB), it works for about the same time until it stops again.
            I put a second USB2serial in parallel and connected a terminal program (hterm). The terminal programm continuously receives messages, even when MYSController stops receiving. So it's no gateway issue.
            I tried several different USB2serial adapter with MYSController - no difference.
            Any idea how to get MYSController to work continuously ?
            tekkaT 1 Reply Last reply
            • petewillP petewill
              I
              I
              itbeyond
              @petewill - Thanks of course Windows Firewall - how many times does one have to forget about that little gem. One other quick question I created a new post in controllers for a MYSBootloader issue - should I add it to this post or leave it where I posted it? I cannot get one node to accept firmware (wonder if signing is a problem however it should not be).
              petewillP 1 Reply Last reply
              • I itbeyond
                petewillP
                petewillP
                petewill
                @itbeyond I responded in the other thread.
                • karlheinz2000K karlheinz2000
                  tekkaT
                  tekkaT
                  tekka
                  @karlheinz2000 Sounds like an issue with your GW - what happens if you connect to your GW via the Arduino serial terminal - does it behave the same?
                  • karlheinz2000K
                    karlheinz2000K
                    karlheinz2000
                    @tekka I did this already. GW connected to MYSController and to terminal program in parallel via 2 USB2serial adapters. MYSController stops logging, but terminal keeps logging MSGs. So I expect no GW issue. I tried 3 different USB serial adapters with no difference.
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      #163
                      @karlheinz2000 Try with the latest build (MYSController 1.0.0beta build 3316) - MYSController will inform you about an available update.
                      • tekkaT tekka
                        manutremo
                        @tekka Where can that be downloaded? All the links I find lead to a 404...
                        • M manutremo
                          tekkaT
                          tekkaT
                          tekka
                          @manutremo see above, you will get notified when running MYSController
                            manutremo
                            Done, nice job, I see the new message types have been added, probably other enhancements under the hood? thanks!
                            • Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              @tekka it's been some time since I flashed the bootloader, I notice I currently have a lot of different hex files (which I believe I compiled myself), do I no longer need different files for different speeds, i.e 16 / 8 /1Mhz?
                              • Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                I'd also love to use the signal report features, I thought it was enabled by default in MS, seems not to work here when I request an item from MYS?
                                • karlheinz2000K
                                  karlheinz2000K
                                  karlheinz2000
                                  The new build runs since several hours with no problems :+1:
                                  The old one stoped within 10min.
                                    manutremo
                                    I'm sorry to say that in my case FOTA updates seem to be worse than with the previous version, they stop before the 5th line of sent code... but it may be my fault, I'll continue investigating.
                                    • M manutremo
                                      manutremo
                                      @manutremo As expected, it was my fault. FOTA updates work correctly with this version.
                                      • C
                                        C
                                        Chris83
                                        I 'm new to MySensors and MySController. I have everything working and I thanks all the good developers here :-)
                                        I have 1 question to better understand how everything works: when I start MYSController I can see in the message tab those 2 messages (heartbeat) repeating every 10 seconds. Can someone tell me what they are? Where does the GW send the heartbeat to? Is it going through RF24?
                                        Thanks in advance for the reply.
                                        raptorjrR 1 Reply Last reply
                                        • C Chris83
                                          raptorjrR
                                          raptorjrR
                                          raptorjr
                                          @chris83 Which version do you use? I only have the RX line?
                                          I thought it was for the MYSController, since it is connected to the gateway. Guess the gateway sends it to all connected clients.
