  3. rboard - Cheap relay/radio/arduino board ~$10
57 Posts 15 Posters 34.9k Views 7 Watching
  • HomerH Homer
    Ok, looks like I am slowly getting there :-)
    fyi I tried playing around with the above sketch, but it's a no go as Codebender tells me <Bounce2.h> is missing.
    @Homer
    The link above has been updated to point the MySensors codebender location (where Bounce2 is available).
    HomerH 1 Reply Last reply
      @Homer
      HomerH
      HomerH
      Homer
      Thanks mate. I'll give it ago again soon.
      • greglG
        greglG
        gregl
        I used one of these boards for a multi sensor recently.... Temp/Motion and Relay actuator.
        Turns out to be a very tidy solution !
        I'm using the A0 pins connected to a ds18b20 . This is really cute in that the sensor is connected in parasite mode meaning i only need two wires. To do this all you need to do is join pin 1 and 3 to GND and the middle signal wire goes to the A0 ( which is used as D14 ). The rboard also has a 10k resistor from the A0 connection to 3.3v. It works just fine!!
        Then for the PIR, im using the readily available RF433 connections to provide D3, 3.3v and GND. The cute trick here is that even though these PIR's are designed for 5v, they run great on 3,3 v too...you just need to connect it differently! See in the photo where the yellow wire which is the 3.3 v vcc supply connects on the PIR sensor.. Genius!!!
        See here for background on this:
        http://techgurka.blogspot.com.au/2013/05/cheap-pyroelectric-infrared-pir-motion.html
        Do this, feed it 5v ( as relay needs 5v) and you have a tidy little multisensor.
        Here's some pics:
        full sketch here https://codebender.cc/sketch:61919
        • epierreE
          epierreE
          epierre
          @gregl I've now my rboard, but I have no Foca, so I used my programmer I matched against the pins on the board.
          I choose mini pro 3V3 in the arduino ide but impossible to sync .... is there something I am missing ?
          Also, do you change something on initialization as for the 4 switch version ?
          thanks,
          z-wave - Vera -> Domoticz
          • greglG
            greglG
            gregl
            Hi @epierre - I do have a foca and i program as Nano with Atmega328.
            What do you mean "change something on initialization as for the 4 switch version" ?? iirc i also just programmed that as a Nano. is this what you mean??
            Cheers,
            Greg
            • epierreE
              epierreE
              epierre
              @gregl so there is no way to program it without a foca ? ;-(
              I meant about the gw initialization, for the 4 switch rboard you used other parameters, so my wuestion was wether I could use it with default values or extra values.
              • greglG
                greglG
                gregl
                wrote on last edited by gregl
                #29
                @epierre - you dont need the foca programmer... any programmer should work as long as you wire correctly - you could even use another arduino.
                http://www.instructables.com/id/Arduino-Examples-2-Use-an-Arduino-as-a-FTDI-Progr/
                • make sure you only feed it 3.3v via the programming socket...!
                For the 4 relay board the CE/CS pins are wired differently to the defaults used by MySensors sketches (9,10) , so you need to tell mysensors library to use (8,9) as this is how they are wired on the Rboard - see the doco ftp://imall.iteadstudio.com/IM120618001_RBoard/DS_IM120618001_RBoard.pdf
                epierreE 1 Reply Last reply
                • greglG gregl
                  epierreE
                  epierreE
                  epierre
                  @gregl nope, I tried and it failed... this is why I asked. One pin is missing, another has another use... I've ordered the foca and I will see.
                  Regarding your PIR Wiring on the picture, you added a 1DS80 right ? I mistakenly thought it was the yellow one ...
                  • greglG
                    greglG
                    gregl
                    @epierre - ill see if i can get it to program with another arduino...i dont think there is anything special about the foca....
                    so the PIR is wired as such that the VCC provided by the rboard mini ( 3.3) connects to a jumper pin and supplies the PIR module there.... then the PIR quite happliy operates on 3.3!
                    The ds18b20 is connected to the "A0" pin headers hidden under the radio - i just bent them over. On the ds18b20 connect pin 1 and 3 to GND and pin 2 to the A0 ... easy!!
                    • epierreE epierre
                      epierreE
                      epierreE
                      epierre
                      @epierre Hello,
                      I received the foca and ... RX and TX have to be inverted (RX to TX, and TX to RX), the answer is so simple...
                      @hek a suggestion, would there be a knowledge management section about wiring a special platform to use mysensors ? I think about the Mega or the iboard ? that would be very useful, rather than going through many forum pages ?
                      • D
                        Dean
                        Woohoo! After stuffing around with a sketch for my Ethernet Gateway that was never complete to begin with, I have got that working and then made my first sensor using this board!!! L-)
                        • D
                          Dean
                          I've decided to try and do a little more with this board. I initially programmed it to only operate the relay on and off to activate the garage door opener, but it's time for me to push myself lol and do more :-)
                          The problem with how I have it now, is that my Vera 3 doesn't know if the door is open or closed. I was going to add a tilt sensor to the board and have that mounted to the actual door, which I think would mean that it could send a message reporting if it is closed or not. But then I started thinking about the example above which included a switch.
                          So using the relay and the switch to operate the garage door, would that then work to keep Vera 3 in the loop as to whether or not the door is open or closed?
                          If I don't get a response soon, I'll just build it and see what happens :-)
                          Thanks in advance for everyones help! I have already learnt a lot from this site :-)
                          • greglG
                            greglG
                            gregl
                            #35
                            Hi Dean,
                            Rather than use a tilt sensor and mount the mini rboard to the moving door, why not just use a reed switch? then you can mount the rboard next to your door controller and run cheap speaker wire to a reed switch and the magnet attached to the moving door..
                            Here is a sketch i use for my garage door using reed switch
                            https://codebender.cc/sketch:44296
                            • D
                              Dean
                              Thanks for the tips @gregl!
                              I am trying to see if I can build this with the sensors that I have, so I can keep my wife happy. So far I am not doing a very good job lol
                              One of my problems is not knowing which pin is what on this board. I see that you stated above that A0 is D14; how do you find this out?
                              The other thing I was wondering about is this: If I set up this sensor and garage door to only ever open/close using either my controller sending the message or me pressing a button, then do I even need a reed switch to determine what state the door is in? Can the sketch keep count of the state?
                              I like your suggested sketch above; in fact I like both examples, and would like to merge the two. The one above with the motion sensor- I don't need that bit, but I like having a temp sensor. What I would like to do is have the temp sensor and instead of the motion sensor I have a switch. Does that sound possible?
                              My wife has given me the rest of the night off, so I'll see what I can come up with :-)
                              • D
                                Dean
                                I just worked out where you get the info regarding what pin is what :-) you have a link in the sketch :-)
                                • D
                                  Dean
                                  lol scratch that last comment.... I have been looking at that PDF and I have no idea how the A0 pin is D14.
                                  • D
                                    Dean
                                    Ok what I have done is uploaded the sketch that is exampled above which has the temp sensor. Instead of the motion sensor, I will use a switch, and I'll connect the two wires to the 433 module spot; one wire to GND, and the other to DATA. I am hoping that this will mean that when the switch is activated it will operate.
                                    Gonna go test :-)
                                    • D
                                      Dean
                                      lol I ended up with a board that now malfunctions sometimes :-) For some reason the relay began to turn on and off repeatedly, then it stopped working altogether, and now it seems to be working as it should... when my son was running past me the other day which lead to the board falling on the ground, it must have fixed whatever the problem is! In any case, I won't be using that relay for anything too important. I have it in my garage now; it opens and closes the garage door, has a motion sensor and tells me if someone goes into the garage, and it is also sending me the temperature outside. I am happy :-)
                                      So now I want to use another one of these boards to turn a light on, but I want to also have a separate switch which will operate through the board. So basically I am going to use the Garagedoor sketch mentioned above, which is the same as the "Relay with button actuator". I understand what pins I need to assign, but I am a little confused as to how I need to wire up the switch. Am I just completing a circuit, or am I supplying power as the trigger?
                                      RJ_MakeR 1 Reply Last reply
                                      • greglG
                                        greglG
                                        gregl
                                        What voltage are you giving the board?
                                        I think i recall having an issue when i was giving it just 5v... i think at 6/7v the issue went away....
                                        • D Dean
                                          RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          @Dean So let me get this straight,, You are using that board to "opens and closes the garage door, has a motion sensor and tells me if someone goes into the garage, and it is also sending me the temperature outside . I am happy ...." and you don't consider that contrary to "I won't be using that relay for anything too important." ?
                                          Did I understand you correctly?
                                          RJ_Make
