  2. Announcements
    @aglock I put a note on the raspberry gateway page to use latest development in case of problems with stable. Did you try?
    aglock
    @gohan yes. Interesting though when I used git to switch between branches it said all files where the same?
    Do you think the fault is in the gateway somehow?
      aglock
      @gohan Tried it again
      configure now recognizes the rpi:
      pi@raspberrypi:~/mys_dev $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24
        [OK] machine detected: SoC=BCM2836, Type=rpi2, CPU=armv7l.
        [OK] SPI driver detected:BCM.
      [OK] Finished.
      But make fails with the following error:
      -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
      drivers/BCM/bcm2835.c: In function ‘bcm2835_delayMicroseconds’:
      drivers/BCM/bcm2835.c:441:40: error: expected ‘)’ before ‘PRIu64’
         printf("bcm2835_delayMicroseconds %" PRIu64 "\n", micros);
      drivers/BCM/bcm2835.c:441:40: warning: spurious trailing ‘%’ in format [-Wformat=]
      Makefile:102: recipe for target 'build/drivers/BCM/bcm2835.o' failed
      make: *** [build/drivers/BCM/bcm2835.o] Error 1
      What to do about it?
      • A aglock
        [OK] Finished.
        @aglock see https://forum.mysensors.org/post/79403
        A 1 Reply Last reply
          aglock
          @mfalkvidd Wow, thanks that works! :D
          • WoekaW
            WoekaW
            Woeka
            Got mysensors gateway working on gpio of my Pi again using ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-gateway=ethernet --my-port=5003
            However on tx or tx always the two leds connected to pin 16 and 18 are lit. More people with the same problem?
            S 1 Reply Last reply
            • WoekaW Woeka
              sineverba
              @Woeka There is (on Arduino Gateway) a function named "DEFINE INVERSE BLINK". Try to search for same for PI....
              • R
                R
                romeo01
                wrote on last edited by romeo01
                #690
                Can we use the "debug ota log" features with the raspberryPi gateway ??
                My node is not accessible and runs MYSBootloader.
                My gateway is raspberryPI.
                Now, I need to update the firmware on my node. Via MYSController, no problems, upload runs like a charm.
                But how to do for debugging my sketch ? Some bugs appear...... , I need to take a look on some vars values.
                Usually, I use the serial port with serial.print(some vars).
                Which alternative I have to use without serial port, only OTA features ?
                Thanks for the great work !!
                  Unless you are using an esp8266, I don't think you can remote debug a pro mini. @sundberg84 is working on a serial logger to microsd card, maybe it could help you in some way
                  • R
                    R
                    romeo01
                    In fact, I do not need to log, but need to look what's happen in my sketch.
                    The new "OTALog" function, MY_OTA_LOG_SENDER_FEATURE or MY_DEBUG_OTA seems to be the good way.
                    From the docs, it allows to send a debug message to another node or gateway via OTA.
                    But how to got the debug message from OTA node, on the gateway side (RaspberryPi) ?
                      @romeo01 said in 💬 Building a Raspberry Pi Gateway:
                      MY_DEBUG_OTA
                      I'd start reading from here https://www.mysensors.org/apidocs-beta/group__SerialDebugGrpPub.html#ga6bd5956352d3a184a0cb02783b8d35ff
                      R 1 Reply Last reply
                        MY_DEBUG_OTA
                        R
                        R
                        romeo01
                        @gohan said in 💬 Building a Raspberry Pi Gateway:
                        MY_DEBUG_OTA
                        Well, you found the starting point !
                        MY_OTA_LOG_SENDER_FEATURE & MY_DEBUG_OTA are enabled on my OTA node.
                        Again the same question: What I have to do on the gateway side ?
                        Is it possible with the raspberry Gateway ?
                        I'm still looking for debugging my sketch in remote. I need to have a look on the debug messages. I reminder, the node is not accessible and runs MYSbootloader.
                          If I understood well, you need to set a target node ID that will receive the debug and then make a node with that ID in order to get the debug messages
                          • R
                            R
                            romeo01
                            Exactly, but I would like to use the gateway (raspberry) as target.
                            Is that possible ?
                            If yes, how to display the debug message on the gateway.
                            I have an access to my gateway only via SSH.
                              I have no idea if can do it, but you could just have a node connected to USB port of the rpi and do a "cat" on the USB port and you can read the debug from the node
                              • signal15S
                                signal15S
                                signal15
                                Is it possible to build a gateway that is MQTT, but also listens on port 5003? I want to send my data up to AWS IoT, but I also need port 5003 for Vera integration.
                                  You can use node-red to bridge the ethernet gateway and the aws service. Are you sure vera plug in doesn't support mqtt?
                                  • signal15S
                                    signal15S
                                    signal15
                                    @gohan, there are two MQTT plugins for the Vera with varying capabilities. But, the mysensors plugin for Vera doesn't appear to support MQTT at all. I could probably get one of those MQTT plugins working, but I'm not sure how stable they are. I hate installing unstable plugins and having them crash LUUP. I need to maintain a positive WAF (Wife Acceptance Factor), and broken HA doesn't help with that. :)
                                      I guess node-red is the best option for you
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        Hi
                                        I start build MySensors Gateway on my Rpi3. I use radio RFM69HW and connected it as show on page to GPIO.
                                        https://www.mysensors.org/build/raspberry
                                        I build it by command:
                                        ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB1
                                        Then make. But in Domoticz when i run and add to hardware i have error:
                                        2017-12-27 17:05:09.419 MySensors: Using serial port: /dev/ttyUSB1
                                        2017-12-27 17:05:09.419 MySensors: Gateway Version: 2.2.0-rc.2
                                        2017-12-27 17:05:09.420 Error: Serial Port closed!... Error: End of file
                                        2017-12-27 17:05:10.419 MySensors: retrying in 30 seconds...
                                        2017-12-27 17:05:39.422 MySensors: Using serial port: /dev/ttyUSB1
                                        2017-12-27 17:05:39.422 Error: Serial Port closed!... Error: End of file
                                        2017-12-27 17:05:40.422 MySensors: retrying in 30 seconds...
                                        2017-12-27 17:06:09.425 MySensors: Using serial port: /dev/ttyUSB1
                                        2017-12-27 17:06:09.425 Error: Serial Port closed!... Error: End of file
                                        2017-12-27 17:06:10.425 MySensors: retrying in 30 seconds...
                                        2017-12-27 17:06:39.427 MySensors: Using serial port: /dev/ttyUSB1
                                        2017-12-27 17:06:39.428 Error: Serial Port closed!... Error: End of file
                                        2017-12-27 17:06:40.428 MySensors: retrying in 30 seconds...
                                        2017-12-27 17:07:09.430 MySensors: Using serial port: /dev/ttyUSB1
                                        2017-12-27 17:07:09.430 Error: Serial Port closed!... Error: End of file
                                        port ttyUSB1 is empty as i check.
                                        Please help me where is the problem...
                                        • pepsonP pepson
                                          Hi
                                          @pepson what output did you get when you tested the gateway?
