  2. Announcements
  • skywatchS
    skywatchS
    skywatch
    I tried for months to get a stable working nrf24 attached to pi to act as a gw and controller.
    In the end I gave up and now have a 3.3V 8MHz pro mini gw attached to the pi. I took 0v and 5v from the pi (via a 3.3v buck converter) and serial tx and rx. Only 4 wires needed and has been as stable as can be for over a week now.
    Maybe help someone with the same unsolveable problems?
    • A aglock
      Hello all!
      I'm trying to build a gateway with a Raspberry pi2, ethernet and Domoticz.
      It looks like the gateway is beeing built ok and seems to run fine but nodes can not communicate with it.
      I have read most of the postings here but I can not find any solution.
      Hope you guys can help? Please!
      I run raspbian (Jessie)
      pi@raspberrypi:~/MySensors/bin $ uname -a
      Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
      Using master branch
      https://www.mysensors.org/build/raspberry
      Configuring like this
      pi@raspberrypi:~/MySensors $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24
      [OK] Finished.
      Obs! No Raspberry identification, why not? Maybe that is the culprit?
      After make I start the gateway and get this:
      pi@raspberrypi:~/MySensors $ cd bin
      pi@raspberrypi:~/MySensors/bin $ sudo ./mysgw -d
      mysgw: Starting gateway...
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:INIT:TSP OK
      mysgw: TSM:INIT:GW MODE
      mysgw: MCO:REG:NOT NEEDED
      mysgw: MCO:BGN:STP
      mysgw: MCO:BGN:INIT OK,TSP=1
      mysgw: Client 0 connected
      mysgw: Client 0: 0;0;3;0;2;
      Seems nice and dandy and Domoticz connecting fine.
      Trying with this example node:
      #define MY_NODE_ID 42
      #define MY_BAUD_RATE 9600
      #include<Arduino.h>
      #define OPEN 1
      #define CLOSE 0
      #define CHILD_ID 1
      uint8_t value = OPEN;
        Serial.print("setup()\n");
        sendSketchInfo("Door", "2.1.1");
        present(CHILD_ID, S_DOOR);
        Serial.print("presentation()\n");
        value = value == OPEN ? CLOSE : OPEN;
        send(msg.set(value));
        Serial.print("message sent");
        Serial.print(value + "\n");
        sleep(1000);
      And recieve this when running:
      --- Miniterm on /dev/ttyUSB0 9600,8,N,1 ---
      --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
      40 TSM:INIT
      55 TSF:WUR:MS=0
      77 TSM:INIT:TSP OK
      96 TSM:INIT:STATID=42
      120 TSF:SID:OK,ID=42
      141 TSM:FPAR
      190 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2267 !TSM:FPAR:NO REPLY
      2291 TSM:FPAR
      2340 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      4417 !TSM:FPAR:NO REPLY
      4442 TSM:FPAR
      4491 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      6569 !TSM:FPAR:NO REPLY
      6594 TSM:FPAR
      6643 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      8720 !TSM:FPAR:FAIL
      8740 TSM:FAIL:CNT=1
      8761 TSM:FAIL:PDT
      And no output in gateway either.
      Both radio modules using capacitors.
      What have I missed?
      Thanks, Andreas!
      @aglock I put a note on the raspberry gateway page to use latest development in case of problems with stable. Did you try?
      A 2 Replies Last reply
        aglock
        @gohan yes. Interesting though when I used git to switch between branches it said all files where the same?
        Do you think the fault is in the gateway somehow?
          aglock
          @gohan Tried it again
          configure now recognizes the rpi:
          pi@raspberrypi:~/mys_dev $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24
            [OK] machine detected: SoC=BCM2836, Type=rpi2, CPU=armv7l.
            [OK] SPI driver detected:BCM.
          [OK] Finished.
          But make fails with the following error:
          -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
          drivers/BCM/bcm2835.c: In function ‘bcm2835_delayMicroseconds’:
          drivers/BCM/bcm2835.c:441:40: error: expected ‘)’ before ‘PRIu64’
             printf("bcm2835_delayMicroseconds %" PRIu64 "\n", micros);
          drivers/BCM/bcm2835.c:441:40: warning: spurious trailing ‘%’ in format [-Wformat=]
          Makefile:102: recipe for target 'build/drivers/BCM/bcm2835.o' failed
          make: *** [build/drivers/BCM/bcm2835.o] Error 1
          What to do about it?
          • A aglock
            [OK] Finished.
            @aglock see https://forum.mysensors.org/post/79403
            A 1 Reply Last reply
              aglock
              @mfalkvidd Wow, thanks that works! :D
              • WoekaW
                WoekaW
                Woeka
                Got mysensors gateway working on gpio of my Pi again using ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-gateway=ethernet --my-port=5003
                However on tx or tx always the two leds connected to pin 16 and 18 are lit. More people with the same problem?
                S 1 Reply Last reply
                • WoekaW Woeka
                  sineverba
                  @Woeka There is (on Arduino Gateway) a function named "DEFINE INVERSE BLINK". Try to search for same for PI....
                  • R
                    R
                    romeo01
                    wrote on last edited by romeo01
                    #690
                    Can we use the "debug ota log" features with the raspberryPi gateway ??
                    My node is not accessible and runs MYSBootloader.
                    My gateway is raspberryPI.
                    Now, I need to update the firmware on my node. Via MYSController, no problems, upload runs like a charm.
                    But how to do for debugging my sketch ? Some bugs appear...... , I need to take a look on some vars values.
                    Usually, I use the serial port with serial.print(some vars).
                    Which alternative I have to use without serial port, only OTA features ?
                    Thanks for the great work !!
                      Unless you are using an esp8266, I don't think you can remote debug a pro mini. @sundberg84 is working on a serial logger to microsd card, maybe it could help you in some way
                      • R
                        R
                        romeo01
                        In fact, I do not need to log, but need to look what's happen in my sketch.
                        The new "OTALog" function, MY_OTA_LOG_SENDER_FEATURE or MY_DEBUG_OTA seems to be the good way.
                        From the docs, it allows to send a debug message to another node or gateway via OTA.
                        But how to got the debug message from OTA node, on the gateway side (RaspberryPi) ?
                          @romeo01 said in 💬 Building a Raspberry Pi Gateway:
                          MY_DEBUG_OTA
                          I'd start reading from here https://www.mysensors.org/apidocs-beta/group__SerialDebugGrpPub.html#ga6bd5956352d3a184a0cb02783b8d35ff
                          R 1 Reply Last reply
                            MY_DEBUG_OTA
                            R
                            R
                            romeo01
                            @gohan said in 💬 Building a Raspberry Pi Gateway:
                            MY_DEBUG_OTA
                            Well, you found the starting point !
                            MY_OTA_LOG_SENDER_FEATURE & MY_DEBUG_OTA are enabled on my OTA node.
                            Again the same question: What I have to do on the gateway side ?
                            Is it possible with the raspberry Gateway ?
                            I'm still looking for debugging my sketch in remote. I need to have a look on the debug messages. I reminder, the node is not accessible and runs MYSbootloader.
                              If I understood well, you need to set a target node ID that will receive the debug and then make a node with that ID in order to get the debug messages
                              • R
                                R
                                romeo01
                                Exactly, but I would like to use the gateway (raspberry) as target.
                                Is that possible ?
                                If yes, how to display the debug message on the gateway.
                                I have an access to my gateway only via SSH.
                                  I have no idea if can do it, but you could just have a node connected to USB port of the rpi and do a "cat" on the USB port and you can read the debug from the node
                                  • signal15S
                                    signal15S
                                    signal15
                                    Is it possible to build a gateway that is MQTT, but also listens on port 5003? I want to send my data up to AWS IoT, but I also need port 5003 for Vera integration.
                                      You can use node-red to bridge the ethernet gateway and the aws service. Are you sure vera plug in doesn't support mqtt?
                                      • signal15S
                                        signal15S
                                        signal15
                                        @gohan, there are two MQTT plugins for the Vera with varying capabilities. But, the mysensors plugin for Vera doesn't appear to support MQTT at all. I could probably get one of those MQTT plugins working, but I'm not sure how stable they are. I hate installing unstable plugins and having them crash LUUP. I need to maintain a positive WAF (Wife Acceptance Factor), and broken HA doesn't help with that. :)
                                          I guess node-red is the best option for you
