  3. FOTA flow in sleeping nodes - need two cycles?
14 Posts 3 Posters 3.6k Views 2 Watching
    @manutremo you're right. i need to take a look
    • M manutremo
      @scalz Many thanks, let me know if I can help further with the testing.
      Regarding your comment on blocking the sleep - how would that be done? I thought the conditional in my sketch (shown above) would already be blocking it.
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      @manutremo Can you post the entire sketch + full log when you receive a "OTA:FWP:UPDATE SKIPPED" message. In addition, it would be helpful to get infos on your setup, i.e. HW, IDE & board definition versions.
      • tekkaT tekka
        manutremo
        @tekka Sure, here it goes:
        #define MY_RADIO_RFM69
        #define MY_RFM69_NEW_DRIVER
        #define MY_IS_RFM69HW
        #define MY_RFM69_MAX_POWER_LEVEL_DBM 13
        #define MY_RFM69_FREQUENCY RFM69_868MHZ
        #define MY_PARENT_NODE_ID 0
        #define MY_TRANSPORT_MAX_TX_FAILURES (3u)
        #define MY_OTA_FIRMWARE_FEATURE
        #define MY_OTA_USE_I2C_EEPROM
        #include <Vcc.h>
        #include <Streaming.h>
        #include <math.h>
        #define SLEEP_TIME_15min  900000    // 15min x 60s = 900000 ms -13% = 783000                (my arduinos show a delay of 8s/min = 13%)
        #define SLEEP_TIME_1h     3600000   // 1 h = 1*60*60000 = 3600000 ms -13% = 3132000 ms
        #define SLEEP_TIME_2h     7200000   // 2 h = 2*60*60000 = 7200000 ms -13% = 6264000 ms
        #define SLEEP_TIME_3h     10800000  // 3 h = 3*60*60000 = 10800000 ms -13% = 9396000 ms
        #define VERSION "3.0"
        #define PIN_ALIM1 4                                   // Connect to input of resistor
        #define PIN_ALIM2 7                                   // Connect to input of measuring probe
        #define PIN_LECTURA A0
        #define AGUA_DIR            800.0
        #define AGUA_INV            160.0
        #define AIRE_DIR            0.0
        #define AIRE_INV            1023.0
        #define TIEMPO_LECTURA      10
        #define MAX_REP_LECTURA     20
        #define MAX_REPORTING_LOOPS 4
        // Battery calibration (Li-ion)
        const float VccMin   = 3.0;                         // Minimum expected Vcc level, in Volts.
        const float VccMax   = 4.2;                         // Maximum expected Vcc level, in Volts.
        const float VccCorrection = 3.82/3.74;              // Measured Vcc by multimeter divided by reported Vcc
        #define CHILD_MOIST_ID 1
        MyMessage msgmoist(CHILD_MOIST_ID, V_LEVEL);
        Vcc vcc(VccCorrection);
        int count=0;
        signed int oldv1=0, oldv2=0;
        float oldresultcb=0;
        #ifdef MY_DEBUG
          analogReference(DEFAULT);
          pinMode(PIN_LECTURA, INPUT);
          pinMode(PIN_ALIM1, OUTPUT);
          pinMode(PIN_ALIM2, OUTPUT);
        void presentation(){
            sendSketchInfo("Sensor de humedad", VERSION);
            present(CHILD_MOIST_ID, S_MOISTURE, "Humedad suelo");
          if (!isFirmwareUpdateOngoing()) {
            signed int value1=0, value2=0, i=0;
            float result1, result2, resultp, resultcb;
            //Loop until readings are stable or max number of readings is reached
            do {
              oldv1=value1; oldv2=value2;
              wait(TIEMPO_LECTURA);
              digitalWrite(PIN_ALIM1, HIGH);
              digitalWrite(PIN_ALIM2, LOW);
              value1 = analogRead(PIN_LECTURA);
              digitalWrite(PIN_ALIM1, LOW);
              digitalWrite(PIN_ALIM2, HIGH);
              value2 = analogRead(PIN_LECTURA);;
            } while (((oldv1 != value1) && (oldv2 != value2)) || (i == MAX_REP_LECTURA));
              0-10 Saturated Soil. Occurs for a day or two after irrigation
              10-20 Soil is adequately wet (except coarse sands which are drying out at this range)
              20-60 Usual range to irrigate or water (most soils except heavy clay soils).
              60-100 Usual range to irrigate heavy clay soils
              100-200 Soil is becoming dangerously dry
            result1=constrain(value1/(AGUA_DIR-AIRE_DIR)*100.0, 1, 100);
            result2=constrain(100-(value2-AGUA_INV)/(AIRE_INV-AGUA_INV)*100.0,1,100);
            resultp = (result1+result2)/2.0;
            resultcb = resultcb + constrain(square((-2.96699 + 351.395/resultp)),0,200);                           //Equation fit using stat software
            count++;
            //Send the data - only if moisture changed to save battery (send anyways once every 4 readings). If moisture sent, send battery level.
            if ((oldresultcb!=resultcb) || (count==MAX_REPORTING_LOOPS)) {
              send(msgmoist.set((unsigned int)resultcb));
              oldresultcb=resultcb;
              //Measure battery voltage and send level
              float v = vcc.Read_Volts();
              int p = vcc.Read_Perc(VccMin, VccMax);
              p=constrain(p,0,100);
              sendBatteryLevel(p);
              #ifdef MY_DEBUG
                Serial << "Value1=" << value1 << " " << result1 << endl << "Value2=" << value2 << " " << result2 << endl << "Result = " << resultp << "% (" << resultcb << "cb)" << endl;
                Serial << "VCC = " << v << " Volts" << endl << "VCC% = " << p << " %" << endl;
            if (count==MAX_REPORTING_LOOPS) count=0;
            sleep(SLEEP_TIME_3h, true);
        The node uses a Mini Pro 3.3v @ 8 MHz. I'm powering it with a Li battery through a MCP1703 LDO with the 2 caps as shown in the datasheet. The radio is a RFM69HW with a 47uF cap in the power rail and a 0.1uF soldered to the power pins of the board shield. I'm using Arduino IDE v1.8.4, with boards definition v1.6.20.
        Thanks in advance.
        tekkaT 1 Reply Last reply
        • M manutremo
          #include <Vcc.h>
          #include <math.h>
          int count=0;
          #ifdef MY_DEBUG
              do {
              count++;
                #ifdef MY_DEBUG
          Thanks in advance.
          tekkaT
          tekkaT
          tekka
          @manutremo you're using a i2c eeprom? Please re-run a FOTA update with
          #define MY_DEBUG_VERBOSE_OTA_UPDATE
          enabled and post the full log. Could be an issue with the i2c eeprom...let's see
            manutremo
            wrote on last edited by manutremo
            Yes, an AT24C256. Will enable fota verbose debug but the update skipped issue doesn't happen always. Will try to reproduce it, though.
            in case it matters, I'm using kisse66's bootloader here
            • tekkaT tekka
              manutremo
              @tekka See below the log of a new occurence of the same issue with UPDATE SKIPPED. This time I enabled verbose debug for OTA . This time I was testing with another different node with a similar hw setup - I'm also adding the sketch below although I think that from an OTA standpoint it's the same. First the node says UPDATE (line 2600), then UPDATE SKIPPED (line 2654), then goes to sleep, and after wake-up the update starts. This time the firmware was a new one, so the update is correct - which makes me think that maybe it's just that the UPDATE SKIPPED appears incorrectly.
              18 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.0-rc.1
              28 TSM:INIT
              28 TSF:WUR:MS=0
              32 TSM:INIT:TSP OK
              34 TSM:INIT:STATID=22
              36 TSF:SID:OK,ID=22
              38 TSM:FPAR
              38 TSM:FPAR:STATP=0
              40 TSM:ID
              43 TSM:ID:OK
              45 TSM:UPL
              53 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              71 TSF:MSG:READ,0-0-22,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              77 TSF:MSG:PONG RECV,HP=1
              79 TSM:UPL:OK
              81 TSM:READY:ID=22,PAR=0,DIS=1
              307 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010001000005990D0300
              370 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              382 TSF:MSG:READ,0-0-22,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              397 TSF:MSG:SEND,22-22-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-rc.1
              464 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              491 TSF:MSG:READ,0-0-22,s=255,c=3,t=6,pt=0,l=1,sg=0:M
              507 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=11,pt=0,l=23,sg=0,ft=0,st=OK:Sensor de fugas de agua
              575 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
              638 TSF:MSG:SEND,22-22-0-0,s=1,c=0,t=32,pt=0,l=13,sg=0,ft=0,st=OK:Fugas de agua
              647 MCO:REG:REQ
              700 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              952 TSF:MSG:READ,0-0-22,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              958 MCO:PIM:NODE REG=1
              960 MCO:BGN:STP
              962 MCO:BGN:INIT OK,TSP=1
              2459 !TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:0
              2498 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:36
              No detection
              2506 MCO:SLP:MS=30000,SMS=1,I1=1,M1=1,I2=255,M2=255
              2560 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
              2592 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3
              2600 OTA:FWP:UPDATE
              2603 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF
              2615 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04
              2648 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3
              2654 OTA:FWP:UPDATE SKIPPED
              3069 TSF:TDI:TSL
              3072 MCO:SLP:WUP=-1
              3074 TSF:TRI:TSB
              3082 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000
              3104 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF
              3143 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04
              3178 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FF04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
              3188 OTA:FWP:RECV B=04FF
              3198 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE
              3211 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FE04
              3254 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FE04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
              3264 OTA:FWP:RECV B=04FE
              3270 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FD
              3282 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FD04
              3315 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FD042E310000FFFFFFFFFFFFFFFFFFFFFFFF
              3328 OTA:FWP:RECV B=04FD
              3334 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FC
              3346 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FC04
              3379 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FC0441434B003F002100322E322E302D7263
              3389 OTA:FWP:RECV B=04FC
              3397 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FB
              3407 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FB04
              3446 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FB04696F6E003C4E4F4E43453E004F4B004E
              3457 OTA:FWP:RECV B=04FB
              3467 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FA
              3477 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FA04
              3514 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FA04746564000D0A004E6F20646574656374
              3524 OTA:FWP:RECV B=04FA
              3530 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F9
              3543 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F904
              3579 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F9046167756100466C6F6F64206465746563
              3592 OTA:FWP:RECV B=04F9
              3598 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F8
              3608 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F804
              3651 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F804756100312E3100467567617320646520
              3661 OTA:FWP:RECV B=04F8
              3667 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F7
              3680 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F704
              3715 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F70472206465206675676173206465206167
              3727 OTA:FWP:RECV B=04F7
              #define MY_RFM69_NEW_DRIVER   // ATC on RFM69 works only with the new driver (not compatible with old=default driver)
              #define MY_NODE_ID 22
              #include <Vcc.h>
              #define SLEEP_TIME_5min   300000
              #define SLEEP_TIME_10min  600000
              #define VERSION "1.1"
              #define PIN_INTERRUPT 3
              #define CHILD_FLOOD_ID 1
              MyMessage msgflood(CHILD_FLOOD_ID, V_TRIPPED);
              bool res;
              int interrupt=digitalPinToInterrupt(PIN_INTERRUPT), oldbat=101;     // Set so that it will be sent always on the first run
              void setup(){
                pinMode(PIN_INTERRUPT, INPUT);
                  sendSketchInfo("Sensor de fugas de agua", VERSION);
                  present(CHILD_FLOOD_ID, S_WATER_LEAK, "Fugas de agua");
                  // Contact status is always sent as a safety measure to allow checking if the sensor is working
                  // We start with a short delay for debouncing the contact (otherwise the reading from the pin might be incorrect after exiting from the sleep()
                  delay(150);
                  res = (digitalRead(PIN_INTERRUPT) == LOW);
                  send(msgflood.set(res));
                  //Measure battery voltage and send level if it has changed
                  if (p != oldbat) { oldbat = p; sendBatteryLevel(p); }
                  #ifdef MY_DEBUG
                  if (res) Serial.println("Flood detected"); else Serial.println("No detection");
                  sleep(interrupt, CHANGE, 20000, true);//SLEEP_TIME_3h, true);
                manutremo
                By the way - following the above, I made a small modification to the sketch, compiled, etc. Myscontroller detected the new fw corectly and the update run fine at the next wake-up, with no SKIPPED messages.
                20987 MCO:SLP:MS=20000,SMS=1,I1=1,M1=1,I2=255,M2=255
                21041 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                21073 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:010001000005990D
                21082 OTA:FWP:UPDATE
                21084 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF
                21096 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04
                21135 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FF04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                21145 OTA:FWP:RECV B=04FF
                21155 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE
                However I then modified the sketch again, uploaded it to Myscontroller, etc, but this time I reset the node. The log showed the UPDATE SKIPPED message again before starting the update.
                28 TSM:INIT
                28 TSF:WUR:MS=0
                32 TSM:INIT:TSP OK
                36 TSF:SID:OK,ID=22
                38 TSM:FPAR
                38 TSM:FPAR:STATP=0
                40 TSM:ID
                43 TSM:ID:OK
                45 TSM:UPL
                79 TSM:UPL:OK
                94 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010001000005990D0300
                161 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                172 TSF:MSG:READ,0-0-22,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                188 TSF:MSG:SEND,22-22-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-rc.1
                253 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                282 TSF:MSG:READ,0-0-22,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                299 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=11,pt=0,l=23,sg=0,ft=0,st=OK:Sensor de fugas de agua
                364 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                428 TSF:MSG:SEND,22-22-0-0,s=1,c=0,t=32,pt=0,l=13,sg=0,ft=0,st=OK:Fugas de agua
                436 MCO:REG:REQ
                489 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                505 TSF:MSG:READ,0-0-22,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                512 MCO:PIM:NODE REG=1
                514 MCO:BGN:STP
                516 MCO:BGN:INIT OK,TSP=1
                675 TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                739 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:32
                No detection
                745 MCO:SLP:MS=30000,SMS=1,I1=1,M1=1,I2=255,M2=255
                802 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                831 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3
                839 OTA:FWP:UPDATE
                841 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FF
                854 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FF04
                882 TSF:MSG:READ,0-0-22,s=0,c=4,t=1,pt=6,l=8,sg=0:0100010000057CC3
                888 OTA:FWP:UPDATE SKIPPED
                1220 TSF:MSG:READ,0-0-22,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                1288 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FF04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                1298 OTA:FWP:RECV B=04FF
                1308 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE
                1320 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FE04
                1329 TSF:TDI:TSL
                1331 MCO:SLP:WUP=-1
                1333 TSF:TRI:TSB
                1343 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000
                1810 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FE
                1820 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FE04
                1859 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FE04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                1869 OTA:FWP:RECV B=04FE
                1878 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FD
                1888 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FD04
                1925 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FD042E310000FFFFFFFFFFFFFFFFFFFFFFFF
                1935 OTA:FWP:RECV B=04FD
                1943 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FC
                1953 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FC04
                1992 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FC0441434B003F002100322E322E302D7263
                2002 OTA:FWP:RECV B=04FC
                2009 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FB
                2021 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FB04
                2056 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FB04696F6E003C4E4F4E43453E004F4B004E
                2066 OTA:FWP:RECV B=04FB
                2076 OTA:FRQ:FW REQ,T=0001,V=0001,B=04FA
                2086 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100FA04
                2123 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100FA04746564000D0A004E6F20646574656374
                2134 OTA:FWP:RECV B=04FA
                2140 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F9
                2152 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:01000100F904
                2187 TSF:MSG:READ,0-0-22,s=255,c=4,t=3,pt=6,l=22,sg=0:01000100F9046167756100466C6F6F64206465746563
                2197 OTA:FWP:RECV B=04F9
                2203 OTA:FRQ:FW REQ,T=0001,V=0001,B=04F8
                So it looks this happens only if right after a node reset. I hope this gives a hint.
                As a side note - I also find interesting that the number of update blocks sent before the node goes to sleep changes between test runs.
                tekkaT 2 Replies Last reply
                • M manutremo
                  28 TSM:INIT
                  28 TSF:WUR:MS=0
                  32 TSM:INIT:TSP OK
                  36 TSF:SID:OK,ID=22
                  38 TSM:FPAR
                  38 TSM:FPAR:STATP=0
                  40 TSM:ID
                  43 TSM:ID:OK
                  45 TSM:UPL
                  79 TSM:UPL:OK
                  436 MCO:REG:REQ
                  514 MCO:BGN:STP
                  No detection
                  839 OTA:FWP:UPDATE
                  1329 TSF:TDI:TSL
                  1331 MCO:SLP:WUP=-1
                  1333 TSF:TRI:TSB
                  tekkaT
                  tekkaT
                  tekka
                  @manutremo ok, I'm on something - it has to do with the smart sleep feature. I will prepare a fix for you to test.
                  • M manutremo
                    28 TSM:INIT
                    28 TSF:WUR:MS=0
                    32 TSM:INIT:TSP OK
                    36 TSF:SID:OK,ID=22
                    38 TSM:FPAR
                    38 TSM:FPAR:STATP=0
                    40 TSM:ID
                    43 TSM:ID:OK
                    45 TSM:UPL
                    79 TSM:UPL:OK
                    436 MCO:REG:REQ
                    514 MCO:BGN:STP
                    No detection
                    839 OTA:FWP:UPDATE
                    1329 TSF:TDI:TSL
                    1331 MCO:SLP:WUP=-1
                    1333 TSF:TRI:TSB
                    tekkaT
                    tekkaT
                    tekka
                    @manutremo here you go: https://github.com/tekka007/MySensors/tree/FOTAUpdates
                    M 2 Replies Last reply
                    • tekkaT tekka
                      manutremo
                      Many thanks @tekka, that was really fast! I'll give it a try as soon as I can spare some minutes.
                      • tekkaT tekka
                        manutremo
                        @tekka Tested the new library and both issues seem to be gone now, great job ! :clap:
                        I have one more question though :)
                        During testing I treid to put things difficult for my radios and move them until reception started to be bad. At some point the FOTA process gave up with a FW UPD FAIL message (line 41146 in attached log). So the node gave up and went to sleep. I was expecting it to try again after wake-up, but it didn't (see lines after 43589).
                        36734 !RFM69:SWR:NACK
                        36737 RFM69:PTX:NO ADJ
                        36771 RFM69:SWR:SEND,TO=0,RETRY=5
                        36966 RFM69:SWR:ACK,FROM=0,SEQ=119,RSSI=-55
                        36972 RFM69:ATC:ADJ TXL,cR=-55,tR=-80,TXL=12
                        36976 RFM69:PTX:LEVEL=12 dBm
                        36978 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005
                        36988 OTA:FRQ:FW REQ,T=0001,V=0001,B=0520
                        36993 RFM69:SWR:SEND,TO=0,RETRY=0
                        37203 !RFM69:SWR:NACK
                        37206 RFM69:PTX:LEVEL=13 dBm
                        37216 RFM69:SWR:SEND,TO=0,RETRY=1
                        37423 !RFM69:SWR:NACK
                        37425 RFM69:PTX:NO ADJ
                        37459 RFM69:SWR:SEND,TO=0,RETRY=2
                        37666 !RFM69:SWR:NACK
                        37668 RFM69:PTX:NO ADJ
                        37679 RFM69:SWR:SEND,TO=0,RETRY=3
                        37885 !RFM69:SWR:NACK
                        37888 RFM69:PTX:NO ADJ
                        37922 RFM69:SWR:SEND,TO=0,RETRY=4
                        38129 !RFM69:SWR:NACK
                        38131 RFM69:PTX:NO ADJ
                        38174 RFM69:SWR:SEND,TO=0,RETRY=5
                        38313 RFM69:SWR:ACK,FROM=0,SEQ=120,RSSI=-56
                        38318 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=12
                        38322 RFM69:PTX:LEVEL=12 dBm
                        38326 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005
                        38334 OTA:FRQ:FW REQ,T=0001,V=0001,B=0520
                        38338 RFM69:SWR:SEND,TO=0,RETRY=0
                        38547 !RFM69:SWR:NACK
                        38549 RFM69:PTX:LEVEL=13 dBm
                        38559 RFM69:SWR:SEND,TO=0,RETRY=1
                        38768 !RFM69:SWR:NACK
                        38770 RFM69:PTX:NO ADJ
                        38805 RFM69:SWR:SEND,TO=0,RETRY=2
                        39012 !RFM69:SWR:NACK
                        39014 RFM69:PTX:NO ADJ
                        39024 RFM69:SWR:SEND,TO=0,RETRY=3
                        39231 !RFM69:SWR:NACK
                        39233 RFM69:PTX:NO ADJ
                        39268 RFM69:SWR:SEND,TO=0,RETRY=4
                        39475 !RFM69:SWR:NACK
                        39477 RFM69:PTX:NO ADJ
                        39520 RFM69:SWR:SEND,TO=0,RETRY=5
                        39702 RFM69:SWR:ACK,FROM=0,SEQ=121,RSSI=-54
                        39706 RFM69:ATC:ADJ TXL,cR=-54,tR=-80,TXL=12
                        39712 RFM69:PTX:LEVEL=12 dBm
                        39714 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005
                        39723 OTA:FRQ:FW REQ,T=0001,V=0001,B=0520
                        39729 RFM69:SWR:SEND,TO=0,RETRY=0
                        39938 !RFM69:SWR:NACK
                        39940 RFM69:PTX:LEVEL=13 dBm
                        39983 RFM69:SWR:SEND,TO=0,RETRY=1
                        40192 !RFM69:SWR:NACK
                        40194 RFM69:PTX:NO ADJ
                        40228 RFM69:SWR:SEND,TO=0,RETRY=2
                        40435 !RFM69:SWR:NACK
                        40437 RFM69:PTX:NO ADJ
                        40480 RFM69:SWR:SEND,TO=0,RETRY=3
                        40687 !RFM69:SWR:NACK
                        40689 RFM69:PTX:NO ADJ
                        40724 RFM69:SWR:SEND,TO=0,RETRY=4
                        40931 !RFM69:SWR:NACK
                        40933 RFM69:PTX:NO ADJ
                        40943 RFM69:SWR:SEND,TO=0,RETRY=5
                        41125 RFM69:SWR:ACK,FROM=0,SEQ=122,RSSI=-54
                        41129 RFM69:ATC:ADJ TXL,cR=-54,tR=-80,TXL=12
                        41134 RFM69:PTX:LEVEL=12 dBm
                        41138 TSF:MSG:SEND,22-22-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:010001002005
                        41146 !OTA:FRQ:FW UPD FAIL
                        41299 RFM69:SWR:SEND,TO=0,RETRY=0
                        41506 !RFM69:SWR:NACK
                        41508 RFM69:PTX:LEVEL=13 dBm
                        41519 RFM69:SWR:SEND,TO=0,RETRY=1
                        41725 !RFM69:SWR:NACK
                        41728 RFM69:PTX:NO ADJ
                        41762 RFM69:SWR:SEND,TO=0,RETRY=2
                        41969 !RFM69:SWR:NACK
                        41971 RFM69:PTX:NO ADJ
                        42014 RFM69:SWR:SEND,TO=0,RETRY=3
                        42221 !RFM69:SWR:NACK
                        42223 RFM69:PTX:NO ADJ
                        42258 RFM69:SWR:SEND,TO=0,RETRY=4
                        42465 !RFM69:SWR:NACK
                        42467 RFM69:PTX:NO ADJ
                        42477 RFM69:SWR:SEND,TO=0,RETRY=5
                        42684 !RFM69:SWR:NACK
                        42686 RFM69:PTX:NO ADJ
                        42721 !TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=NACK:0
                        42729 RFM69:SWR:SEND,TO=0,RETRY=0
                        42950 !RFM69:SWR:NACK
                        42952 RFM69:PTX:NO ADJ
                        42995 RFM69:SWR:SEND,TO=0,RETRY=1
                        43005 RFM69:SWR:ACK,FROM=0,SEQ=124,RSSI=-55
                        43010 RFM69:ATC:ADJ TXL,cR=-55,tR=-80,TXL=12
                        43014 RFM69:PTX:LEVEL=12 dBm
                        43018 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:20
                        No detection
                        43026 MCO:SLP:MS=30000,SMS=1,I1=1,M1=1,I2=255,M2=255
                        43030 RFM69:SWR:SEND,TO=0,RETRY=0
                        43065 RFM69:SWR:ACK,FROM=0,SEQ=125,RSSI=-56
                        43069 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=11
                        43075 RFM69:PTX:LEVEL=11 dBm
                        43077 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                        43585 TSF:TDI:TSL
                        43587 RFM69:RSL
                        43589 MCO:SLP:WUP=-1
                        43591 TSF:TRI:TSB
                        43593 RFM69:RSB
                        43595 RFM69:SWR:SEND,TO=0,RETRY=0
                        43606 RFM69:SWR:ACK,FROM=0,SEQ=126,RSSI=-56
                        43610 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=10
                        43616 RFM69:PTX:LEVEL=10 dBm
                        43618 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:30000
                        43778 RFM69:SWR:SEND,TO=0,RETRY=0
                        43788 RFM69:SWR:ACK,FROM=0,SEQ=127,RSSI=-59
                        43792 RFM69:ATC:ADJ TXL,cR=-59,tR=-80,TXL=9
                        43796 RFM69:PTX:LEVEL=9 dBm
                        So when this occurs the only way I can think of to force another update would be update the sketch, refresh the repo in MysController and assign it to the node again. Therefore I wonder if this is intended behaviour and if so, if there is some other way to force an update after a failed one.
